410-270
410-270
    DIGILENT(迪芝伦)
    PMODAMP3STEREOPOWERAMPLIFIER
410-270 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodAMP3™ Reference Manual Revised April 15, 2016 This manual applies to the PmodAMP3 rev. A Overview The Digilent PmodAMP3 features an Analog Devices® SSM2518 2 watt Class-D Audio Power Amplifier. The module enables the use of I²S audio protocol or TDM to produce stereo audio at various sampling frequencies. Users may configure the digital volume and dynamic range control via an I²C interface. Additionally, the PmodAMP3 may be used in a stand-alone mode that does not require the use of the I²C interface. Features include:        The PmodAMP3. 1  Audio amplifier with left and right channel separation Stereo output via two standard 1/8“ (0.32 cm) mono speaker jacks Supports common I²S audio formats Digitally configurable volume control for each channel Dynamic range control Stand-alone mode for systems without I²C interface Small PCB size for flexible designs 1.5” × 0.8“ (3.8 cm × 2.0 cm) 12-pin Pmod port with I²C interface Functional Description The PmodAMP3 utilizes Analog Devices SSM2518 to reproduce digitally fed audio signals in separate left and right headphone jacks. The separation of the jacks enables better audio signal isolation. 2 Interfacing with the Pmod The PmodAMP3 communicates with the host board via the I²C protocol. Users may operate the PmodAMP3 in either an I²C programmable mode or a simple stand-alone mode. The stand-alone mode is the default setting and can be activated by removing the shorting block on jumper JP5. When the stand-alone mode is active, jumpers JP3, JP4, and JP6 allow a simple hardware configuration of the amplifier. Within the stand-alone mode jumper JP3 configuration determines whether to use Standard or Left Justified I²S protocol. Jumper JP4 determines if the MCLK input is 256 or 384 times the audio sampling frequency Fs. The jumper JP6 configures the amplifier to output at either 0dB or +12dB gain. DOC#: 502-270 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 3 PmodAMP3™ Reference Manual If JP5 is loaded, I²C is enabled so that the on-board chip can be configured. Consequently, the shorting blocks on both JP3 and JP4 must be removed so that the SCL and SDA lines are pulled to a logic high voltage state. JP6 sets the I²C address of the Pmod; both addresses are valid, but a user may want to use one particular address if another I²C device on the bus is using the other address. JP5 Unloaded (default Stand-alone mode) JP5 Loaded (I2C Programmable Mode) Loaded MCLK-provide own external MCLK Unloaded BCLK-route BCLK to MCLK input Loaded Unloaded Don't Care Don't Care JP3 JP4 I2S (Standard) 256x Fs Left Justified 384x Fs Prohibited Prohibited Required Required JP6 12dB Gain 0dB Gain ADDR: 0110100[r/w] ADDR: 0110110[r/w] JP2 Table 1. Connector descriptions. Note: Both the 0dB and +12dB gain modes are very loud. You should take care to protect both yourself and your equipment when operating in stand-alone mode. Digilent recommends that you use the programmable mode and set the gain to -12dB or lower. The I²C programmable mode is used to set alternate Master Clock (MCLK) and Bit Clock (BCLK) ratios as well as configure the Dynamic Range Control (DRC). More information about these options is available in our user guide. To transfer audio data in the I²S audio format, the MCLK, BCLK, the Left/Right Word Clock (LRCLK), and the data (SDATA) will need to be provided either internally or externally as appropriate. This module is able to receive audio data anywhere between 8 and 32-bits of resolution. An example timing diagram from Texas Instruments on how I²S data is to be sent to the module is provided below: Figure 1. Example I2S timing diagram. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 3 PmodAMP3™ Reference Manual Pin 1 2 3 4 5 6 7 8 9 10 11 12 Table 2. Header J1 pinout table. Figure 2. PmodAMP3 block diagram. Header J2 Pin Description 1 Left Audio Jack Signal LRCLK SDATA NC BCLK GND VCC NC NC MCLK-E ~SHUT GND VCC Header J1 Description Left/Right Word Clock Serial Data Not Connected Bit Clock Power Supply Ground Positive Power Supply Not Connected Not Connected Master Clock-external Shutdown Power Supply Ground Positive Power Supply Header J3 Pin Description 1 Serial Clock 2 Serial Data Header J4 Pin Description 1 Right Audio Jack Table 3. Header J2, J3, and J4 pinout table. Any external power applied to the PmodAMP3 must be within 2.5V and 5.5V; however, it is recommended that the Pmod is operated at 3.3V. 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1.5 inches long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 3
410-270 价格&库存
很抱歉,暂时无法提供与“410-270”相匹配的价格&库存,您可以联系我们找货
  • 1+176.455201+22.84029
库存:24
