PowerBoost 1000 Charger - Rechargeable
5V Lipo USB Boost @ 1A - 1000C
PRODUCT ID: 2465
DESCRIPTION
PowerBoost 1000C is the perfect power supply for your portable project! With a
built-in load-sharing battery charger circuit, you'll be able to keep your powerhungry project running even while recharging the battery! This little DC/DC boost
converter module can be powered by any 3.7V LiIon/LiPoly battery, and convert the
battery output to 5.2V DC for running your 5V projects.
If you dont need the 1A battery charger, smart load-sharing, or 1A iOS resistors,
check out the Powerboost 500C
Like our popular 5V 1A USB wall adapter, we tweaked the output to be 5.2V instead
of a straight-up 5.0V so that there's a little bit of 'headroom' for long cables, high
draw, the addition of a diode on the output if you wish, etc. The 5.2V is safe for all
5V-powered electronics like Arduino, Raspberry Pi, or Beagle Bone while preventing
icky brown-outs during high current draw because of USB cable resistance.
The PowerBoost 1000C has at the heart a TPS61090 boost converter from TI. This
boost converter chip has some really nice extras such as low battery detection, 2A
internal switch, synchronous conversion, excellent efficiency, and 700KHz highfrequency operation. Check out these specs!
• Synchronous operation means you can disconnect the output completely by
connecting the ENable pin to ground. This will completely turn off the output
• 2A internal switch (~2.5A peak limiting) means you can get 1000mA+ from a
3.7V LiPoly/LiIon battery. Just make sure your battery can handle it!
• Low battery indicator LED lights up red when the voltage dips below 3.2V,
optimized for LiPo/LiIon battery usage
• Onboard 1000mA charge-rate 'iOS' data resistors. Solder in the USB connector
and you can plug in any iPad, iPhone or iPod for 1000mA charge rate.
• Full breakout for battery in, control pins and power out
• 90%+ operating efficiency in most cases (see datasheet for efficiency graphs),
and low quiescent current: 5mA when enabled and power LED is on, 20uA when
disabled (power and low batt LED are off)
To make this even more useful, we stuck a smart load-sharing Lipoly charger on
the other side. The charger circuitry is powered from a microUSB jack, and will
recharge any 3.7V/4.2V LiIon or LiPoly battery at 1000mA max rate. There's two
LEDs for monitoring the charge rate, a yellow one tells you its working, a green one
lights up when its done.
Since the built-in battery charger has load-sharing, it will automatically switch over
to the USB power when available, instead of continuously charging/draining the
battery. This is more efficient, and lets you charge-and-boost at the same time
without any interruption on the output so its fine for use as a "UPS" (uninterruptable power supply).
Just be aware that the charge rate is 1000mA max, and there's some inefficiency
during the boosting stage, so make super sure that the USB adapter you're using to
charge with is high quality, can supply 2A and has thick power wires. This one from
Adafruit is ideal and has been tested, lower quality ones will not act well due to the
voltage drop on the wires or droop on the power supply. This is especially true if
you're actually drawing 1000mA out of the PowerBoost 1000C, the MCP73871
maxes out at 1.8A.
This charger-booster is great for powering your robot, Arduino project, singleboard-computer such as Raspberry Pi or BeagleBone! Each order comes with one
fully assembled and tested PCB and a loose USB A jack. If you are powering your
project from USB, solder the USB A jack in (a 3-minute soldering task). If you would
like to use a terminal block, pick up a 3.5mm 2pin block here and solder to the
output spot where the USB jack would go. Or dont solder anything in for a more
compact power pack.
If you're trying to figure out how much current your project is using, check out
the CHARGER DOCTOR!
You may get an off-white or black JST connector.
http://www.adafruit.com/products/2465
7/27/2015
Technical Details
23mm x 45mm x 10mm / 0.9" x 1.8" x 0.4"
Weight: 6g
很抱歉,暂时无法提供与“2465”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+190.178921+24.68176
