1385
1385
    ADAFRUIT
    LAMP INCAND R-12 REFL BAYO 28V
1385 数据手册
UBEC DC/DC Step-Down (Buck) Converter - 5V @ 3A output PRODCT ID: 1385  Description Your power supply problems just got SOLVED! This little circuit board may look tiny but inside is a high efficiency DC/DC step-down converter which can output up to 3 Amp at 5V without the need of any heatsink or forced cooling. (It does get a bit toasty at 3A though) UBEC stands for "universal battery eliminator circuit" and this UBEC is designed to replace a 5V supply in RC planes and 'copters but its also great for any kind of microcontroller or electronics project that runs off of 5V. We tried a half dozen different 'BECs and found this one to be the best in terms of range and stability. You can check the technical tab for the analysis of input/output range and current draw. To use, connect 6V up to 16V (recommended) to the IN-side wires and 5V will be generated on the OUTside wires. You'll get 5V (+-5%) regulated output from higher voltage input. 3A output current, 5A peak if you're trying to draw 3A you'll need to give it a little more than 6V though, 7V works well. The UBEC has built in filter capacitors on the input and output, but its a switching supply so its a little noisy compared to a linear regulator. We pulled the heatshrink off of one and found an MP2307 you can check the datasheet for conversion efficiency and other specifications.  Technical Details We pulled the heatshrink off of one and found an MP2307 you can check the datasheet for conversion efficiency and other specifications. The input capacitor might be rated for 16V max. Here are some numbers we found when attaching various loads to the UBEC: Iout Vin Iin Vout 0.5A 6V 0.47A 4.9V 0.5A 7V 0.39A 5.2V 0.5A 9V 0.35A 5.2V 0.5A 12V 0.28A 5.25V Iout Vin Iin Vout 1A 6V 0.9A 4.8V 1A 7V 0.79A 5.2V 1A 9V 0.67A 5.1V 1A 12V 0.52A 5.2V Iout Vin Iin Vout 2A 6V 1.85A 4.9V 2A 7V 1.67A 5.1V 2A 9V 1.28A 5.0V 2A 12V 0.97A 4.9V Iout Vin Iin Vout 3A 7V 2.6A 5.0V 3A 9V 1.88A 4.7V 3A 12V 1.43A 4.8V        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1385”相匹配的价格&库存,您可以联系我们找货
