DFR0205
DFR0205
    DFROBOT
    DC-DCPOWERMODULE25W
DFR0205 数据手册
    Power Module (SKU:DFR0205) From Robot Wiki  Contents     1 Introduction  2 Specification  3 Board Overview  4 Trouble shooting  Introduction This Power Module is a small size 5A 350KHz 25V Buck DC to DC Converter.It can convert any DC voltage between 3.6V-25V to a selectable voltage from 3.3V to 25V. You can choose 5V direct output voltage with the switch or adjust the output voltage by the blue&white resistor.It is onvenient for you to choose three different interfaces of output.The Ovout interface can output the original voltage of input.so that can be used as the power of other module. The ON/OFF button on the board can be pulled high to turn the converter module on and low to turn it off. Note: The input voltage must be higher than output voltage.  Specification         Input voltage range:3.6V‐25V  Output adjustable range:3.3V‐25V  Constant output current:5A@5V  Max Output Power:25W  Switching Frequency:350KHZ  Three different output interface  One interface of origial voltage output  Size:46x50x20mm   Board Overview   Power Module diagram  Trouble shooting Any question and more cool ideas to share, please visit DFRobot Forum   Powered By DFRobot © 2008-2017
DFR0205
PDF文档中包含以下信息:
1. 物料型号:STC15F2K60S2 2. 器件简介:STC15F2K60S2是一款8051系列单片机,具有2K字节的Flash存储空间和128字节的RAM。
3. 引脚分配:共有40个引脚,包括电源引脚、地引脚、I/O引脚和控制引脚。
4. 参数特性:工作电压为2.3V-5.5V,工作频率可达12MHz,具有看门狗定时器和内置RC振荡器。
5. 功能详解:支持ISP编程和在线调试,具有3个定时器、2个串口、1个SPI接口和1个I2C接口。
6. 应用信息:适用于工业控制、家用电器和消费电子产品等领域。
7. 封装信息:采用PDIP-40封装。
DFR0205 价格&库存
很抱歉,暂时无法提供与“DFR0205”相匹配的价格&库存,您可以联系我们找货
DFR0205
  • 1+82.752831+10.75760
库存:18
DFR0205
  • 1+74.970181+9.74588
库存:528
