high
performance
needs great
design.
Datasheet: AS8650B High-efficient Power Management Device
with High-speed CAN Interface
Please be patient while we update our brand image as
austriamicrosystems and TAOS are now ams.
www.ams.com
AS8650B
High-efficient Power Management Device with High-speed CAN
Interface
1 General Description
2 Key Features
DCDC converter for 5V output with very high efficiency
The AS8650B is a companion IC which combines power
management functions and a fully conforming high-speed CAN
Transceiver in one high performance analog device for automotive
applications. The AS8650B is powered by the battery, provides 4
output voltage levels of which 3 outputs in the range of 1.8V to 3.3V
with a maximum current consumption up to 120mA at the LDO
voltage regulator outputs. An integrated DCDC converter with a very
high efficiency for the 5V output supplies the 3 voltage regulators
and ensures a voltage stability of ±2.5%. The combination of DCDC
converter with low-drop-out voltage regulators makes the AS8650B
suitable for all Automotive Control Units where power efficiency is a
must.
Three voltage regulators providing 3.3V, 2.8V and 1.8V with
accuracy better than 2.5% (Two are adjustable through factory
settings).
High-speed CAN interface (ISO 11898-5) with remote wake-up
Comprehensive voltage monitoring
Configurable watchdog functions for start-up, operation, and
standby
Automatic thermal shutdown protection
Excellent EMC performance with outstanding switching
The AS8650B provides a high-speed CAN interface up to 1Mbps
communication rate conforming to ISO 11898-5. The AS8650B
provides wake-up via remote wake-up at CAN bus lines and a local
wake pin. The watchdog unit provides three different timing
functions: start-up, window- and timeout watchdog; configurable via
the SPI and I²C interface.
technology for the DCDC converter
Ambient temperature range from -40°C to +105°C in maximum
load conditions
Lead-free 36-pin QFN (6x6x0.9)
package
3 Applications
Voltage monitoring is implemented for the battery supply, DCDC
output and the 3 LDO regulator outputs. Undervoltage will be
signalled on the INTN pin to the microcontroller. All diagnostics and
status flags can be accessed with the SPI interface.
The AS8650B provides high efficient and flexible power supply
together with state-of-the-art high-speed CAN Interface for
automotive control units.The device is pin compatible with AS8550
(LIN interface) in order to change from CAN to LIN easy.
The product is available in a 36-pin QFN (6x6x0.9) package.
Figure 1. AS8650B Block Diagram
VSUP
AS8650B
I2C_EN
FB
CSSPI
SCLKI2C / SCLKSPI
SDAI2C / SDISPI
I2C
SPI
DC / DC Converter 5V
LX
SDOSPI
INTN
Configurable
Voltage
Regulator
CANH
SPLIT
CANL
RxD
High-speed
CAN
Transceiver
Digital
Logic
TxD
RESET
Configurable
Voltage
Regulator
Configurable
Voltage
Regulator
Watchdog
WAKE
www.ams.com/AS8650
Revision 1.1
V5V_LDO1
V5V_LDO2
V5V_LDO3
VREG
VREG
VREG
GND
1 - 46
AS8650B
Datasheet - C o n t e n t s
Contents
1 General Description ..................................................................................................................................................................
1
2 Key Features.............................................................................................................................................................................
1
3 Applications...............................................................................................................................................................................
1
4 Pin Assignments .......................................................................................................................................................................
4
4.1 Pin Descriptions....................................................................................................................................................................................
4
5 Absolute Maximum Ratings ......................................................................................................................................................
6
6 Electrical Characteristics...........................................................................................................................................................
7
6.1 Electrical System Specification.............................................................................................................................................................
8
6.2 DCDC Converter ..................................................................................................................................................................................
8
6.3 Low Drop Out Regulators .....................................................................................................................................................................
9
6.4 CAN Transceiver ................................................................................................................................................................................
10
6.4.1 Timing Diagrams........................................................................................................................................................................ 12
6.5 Undervoltage Detection ......................................................................................................................................................................
13
6.6 Digital Timing Specification ................................................................................................................................................................
13
6.6.1 System Specification and Timings............................................................................................................................................. 16
7 Detailed Description................................................................................................................................................................
17
7.1 Operating Modes and States..............................................................................................................................................................
7.1.1
7.1.2
7.1.3
7.1.4
Normal Mode .............................................................................................................................................................................
Receive-Only Mode ...................................................................................................................................................................
Standby Mode............................................................................................................................................................................
Sleep Mode................................................................................................................................................................................
17
17
17
17
17
7.2 Power Management Strategy .............................................................................................................................................................
17
7.3 State Diagram.....................................................................................................................................................................................
7.4 Initialization Sequence........................................................................................................................................................................
7.5 DCDC Converter ................................................................................................................................................................................
22
7.6 Voltage Regulator LDO1.....................................................................................................................................................................
22
7.7 Voltage Regulator LDO2.....................................................................................................................................................................
22
7.8 Voltage Regulator LDO3.....................................................................................................................................................................
22
7.9 Over-Temperature Monitor .................................................................................................................................................................
22
7.10 Undervoltage Reset..........................................................................................................................................................................
22
7.11 Reset Block......................................................................................................................................................................................
23
7.12 CAN Transceiver ..............................................................................................................................................................................
24
7.12.1
7.12.2
7.12.3
7.12.4
7.12.5
7.12.6
BUS Driver...............................................................................................................................................................................
Normal Receiver ......................................................................................................................................................................
Low Power Receiver................................................................................................................................................................
Operating Modes .....................................................................................................................................................................
Local Wake-up Event...............................................................................................................................................................
Remote Wake-up.....................................................................................................................................................................
7.13 Internal Flags....................................................................................................................................................................................
7.13.1
7.13.2
7.13.3
7.13.4
7.13.5
7.13.6
VSUP_UV_flag ........................................................................................................................................................................
VSUP_POK_flag......................................................................................................................................................................
V5V_UV_flag ...........................................................................................................................................................................
V5V_POK_flag.........................................................................................................................................................................
VLDO2_UV_flag ......................................................................................................................................................................
VLDO2_POK_flag....................................................................................................................................................................
www.ams.com/AS8650
Revision 1.1
24
24
24
24
24
25
26
26
26
26
26
26
26
2 - 46
AS8650B
7.13.7 VLDO3_UV_flag ......................................................................................................................................................................
7.13.8 VLDO3_POK_flag....................................................................................................................................................................
7.13.9 BUS Wake_up Flag .................................................................................................................................................................
7.13.10 Local Wake_up Flag ..............................................................................................................................................................
7.13.11 OVT_Warning Flag ................................................................................................................................................................
7.13.12 OVT_Recover Flag ................................................................................................................................................................
7.13.13 Bus Failure Flags...................................................................................................................................................................
7.13.14 Local Failure Flags ................................................................................................................................................................
7.14 Watchdog (WD) ................................................................................................................................................................................
26
26
27
27
27
27
27
27
28
7.14.1 Start-up Watchdog Behavior.................................................................................................................................................... 28
7.14.2 Window Watchdog Behavior.................................................................................................................................................... 28
7.14.3 Timeout Watchdog Behavior ................................................................................................................................................... 29
7.15 Interrupt Generation .........................................................................................................................................................................
7.16 Status Registers ...............................................................................................................................................................................
8 Application Information ...........................................................................................................................................................
29
30
31
8.1 Serial Peripheral Interface ..................................................................................................................................................................
31
8.1.1 SPI Write Operation................................................................................................................................................................... 32
8.1.2 SPI Read Operation................................................................................................................................................................... 33
8.1.3 SPI Timing Diagram................................................................................................................................................................... 34
8.2 Inter-Integrated Circuit (I²C) Interface.................................................................................................................................................
35
8.2.1 I²C Slave Address...................................................................................................................................................................... 35
8.2.2 I²C Write Operation.................................................................................................................................................................... 35
8.2.3 I²C Read Operation.................................................................................................................................................................... 36
8.3 Register Space ...................................................................................................................................................................................
38
9 Package Drawings and Markings ...........................................................................................................................................
43
10 Ordering Information.............................................................................................................................................................
45
www.ams.com/AS8650
Revision 1.1
3 - 46
AS8650B
Datasheet - P i n A s s i g n m e n t s
4 Pin Assignments
LX
LX
FB
V5V_LDO2
V5V_LDO3
V5V_LDO1
VLDO3
36
LX
Figure 2. Pin Assignments (Top View)
35
34
33
32
31
30
29
28
VSUP
1
27
VLDO3FB
VSUP
2
26
VLDO2
VSUP
3
25
VLDO2FB
GND_DCDC
4
24
VLDO1FB
GND
5
23
VLDO1
WAKE
6
22
RESERVED
CANH
7
21
RESERVED
CANL
8
RESERVED
GND_CAN
9
19
RESET
AS8650B
QFN 6x6x0.9
13
14
15
16
17
18
SCLKI2C (SCLKSPI)
CSSPI
RxD
INTN
TxD
I2C_EN
12
SDOSPI
11
SDAI2C / SDISPI
10
SPLIT
GND
(Exposed pad)
Table 1. Pin Descriptions
Pin
Pin Name
1, 2, 3
VSUP
4
GND_DCDC
5
GND
6
WAKE
7
CANH
Analog Input / Output high-voltage High level CAN bus line
8
CANL
Low level CAN bus line
9
GND_CAN
10
SPLIT
www.ams.com/AS8650
Pin Type
Description
Power Supply Input
Power Supply
Local wake request (high-voltage input)
Power Supply Input
Power supply
Analog Input / Output high-voltage Common-mode stabilization output
Revision 1.1
4 - 46
AS8650B
Pin
Pin Name
Pin Type
Description
11
I2C_EN
Digital Input
12
SDAI2C / SDISPI
Digital Input/Output
/ Digital Input
13
SDOSPI
Digital Output
14
SCLKI2C / SCLKSPI
Digital Input
15
CSSPI
Digital input with pull-up
SPI chip select
16
RxD
Digital output with pull-up
CAN Transceiver receive signal
17
INTN
Digital Output
18
TxD
19
RESET
Digital Output
I²C/SPI select signal (High = I²C, Low = SPI)
Unidirectional for SPI, Bidirectional for I²C
SPI data out
Serial clock (Multiplexed for I²C and SPI) unidirectional
Active low interrupt to µC. Generated if status / diagnostic is
updated.
CAN Transceiver transmit signal
Digital Output referenced to VLDO1, active low
Pin with Digital / Analog Input /
Open-Drain-Output
Reserved
Reserved
21
22
Regulated voltage output
23
VLDO1
Power Supply Input
24
VLDO1FB
Open-Drain-Output
Regulated voltage feedback
25
VLDO2FB
Open-Drain-Output
26
VLDO2
Power Supply Input
27
VLDO3FB
Open-Drain-Output
28
VLDO3
29
V5V_LDO1
30
V5V_LDO3
31
V5V_LDO2
32
FB (DCDC)
33, 34, 35
LX (DCDC)
GND
www.ams.com/AS8650
Power Supply Input
Step-down converter 5V output, supply for LDO1
Step-down converter 5V output, supply for LDO3
Step-down converter 5V output, supply for LDO2
DCDC output voltage feedback
Analog Input
Power Supply Input
DCDC output
Exposed pad (GND)
Revision 1.1
5 - 46
AS8650B
Datasheet - A b s o l u t e M a x i m u m R a t i n g s
Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only. Functional operation of the
device at these or any other conditions beyond those indicated in Electrical Characteristics on page 7 is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect device reliability.
Table 2. Absolute Maximum Ratings
1
Parameter
Min
Max
Units
Voltage at positive supply pin (VVSUP)
-0.3
40
V
Voltage at pin V5V_LDO1, V5V_LDO2,
V5V_LDO3, VLDO1, VLDO2, VLDO3, FB,
VLDO1FB, VLDO2FB, VLDO3FB
-0.3
7
V
Voltage at pin CANH, CANL, SPLIT
-40
+40
V
Voltage at pin LX, WAKE
-0.3
VVSUP + 0.3
V
Voltage at pin RESET, INTN, RxD, TxD, CS,
SCLK, SDO, SDA/SDI, I2C_EN
-0.3
4.5
V
1
V/µs
Notes
Electrical Parameters
Input Supply slew-rate (Vsup_slew)
Input power supply ramp rate
Electrostatic Discharge
Electrostatic discharge voltage
AEC-Q100-002 human body model standard
(ESD)
All pins except VSUP, GND, CANH, CANL,
WAKE, SPLIT
±2
kV
±4
±8
Latch-Up Immunity
VSUP, GND, WAKE, SPLIT
CANH, CANL
-100
+100
mA
AEC-Q100-004
1.2
W
170
ºC
+150
ºC
30
ºC/W
SEMI G42-88
ºC
The reflow peak soldering temperature (body
temperature) specified is in accordance with IPC/
JEDEC J-STD-020 “Moisture/Reflow Sensitivity
Classification for Non-Hermetic Solid State
Surface Mount Devices”.
The lead finish for Pb-free leaded packages is
matte tin (100% Sn).
Continuous Power Dissipation
Maximum power dissipation (Ptot)
Temperature Ranges and Storage Conditions
Junction temperature (TJ)
Storage temperature (Tstg)
-55
Thermal resistance MLF package (Rthj_36)
Package body temperature (TBODY)
Moisture Sensitivity Level
260
3
Represents a maximum floor life time of 168h
1. All voltages mentioned above are referred with respect to ground reference voltage VGND.
www.ams.com/AS8650
Revision 1.1
6 - 46
AS8650B
Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s
Table 3. Electrical Characteristics
Symbol
Parameter
Conditions
Min
VSUP
Positive supply voltage
Normal operating condition
6
GND
Ground
In reference to all the voltages
TAMB
Ambient temperature
Junction temperature (TJ) ≤ 150ºC
(at full-load)
-40
Typ
Max
Units
18
V
Operating Conditions
Isupp
Supply current, Normal mode
V
105
VSUP = 6V, LDOs at full load,
DCDC load = 390mA,
CAN dominant
425
VSUP = 18V, LDOs at full load,
DCDC load = 390mA,
CAN dominant, not production tested.
150
VSUP = 16V, LDOs at full load,
CAN dominant
170
ºC
mA
CS
Vt-
Negative-Going Threshold
Vt+
Positive-Going Threshold
Ilil_cs
Pull up current
VOH
High level output voltage
VOL
Low level output voltage
IO
Output drive current
VLDO1 = 3.3V
In CS pad, Pulled up to VLDO1
1.12
1.52
V
1.77
2.23
V
-60
-15
µA
SDO
2.5
VSUP ≥ 6V
V
0.4
V
4
mA
SDA / SDI
0.7*
VLDO1
VIH
High level input voltage
VIL
Low level input voltage
0.3*
VLDO1
V
VOL
0.4
V
V
SCLK
VIH
VIL
Open-drain, external 500Ω pull-up
0.7*
VLDO1
V
0.3*
VLDO1
V
RESET, INTN
VOH
VOL
IO
VIH
VIL
IO
VSUP ≥ 6V
Ilil
Pull-up current
TxD pulled up to VLDO1 with control
RxD pulled up to VLDO1
2.5
VSUP ≥ 6V
V
0.4
V
4
mA
TxD
www.ams.com/AS8650
2.0
Revision 1.1
-60
V
0.8
V
1
mA
-15
µA
7 - 46
AS8650B
Symbol
Parameter
Conditions
Min
Typ
Max
Units
RxD
VOH
VOL
IO
VSUP ≥ 6V
Ilil
Pull-up current
2.5
V
0.4
V
1
mA
-15
µA
Typ
Max
Units
-60
-40°C < TJ < 150°C
Table 4. Electrical System Specification
Symbol
Parameter
Conditions
Min
IDDnom
Current consumption Normal mode
No load, VSUP = 12V, CAN recessive
3.5
6
mA
IDDrecv
Current consumption Receive-only mode
1
2
mA
IDDstby
Current consumption Standby mode
No load, VSUP = 12V
135
270
µA
IDDsleep
Current consumption Sleep mode
No load, VSUP = 12V
75
150
µA
Min
Typ
Max
Units
6.2 DCDC Converter
-40°C < TJ < 150°C; all voltages are with respect to ground, normal operating mode, unless otherwise mentioned.
Table 5. DCDC Converter
Symbol
Parameter
Conditions
VSUP
Battery Voltage Range
6
12
18
V
V5V
Output Voltage
4.75
5
5.25
V
ILXS
LX current limit
0.8
1
1.25
A
IV5V
DCDC output current
500
mA
RON
LX switch on-resistance
0.8
1
Ω
VFB
Reference Voltage for FB
5
5.25
V
For inductor 22µH and capacitor 100µF
(bondwire resistance included)
4.75
Lireg_dc
Line regulation
Step from VIN = 6V to VIN2 = 18V,
ILOAD = 100mA
Lireg = 100*(VOUT1-VOUT2) /
[VOUT2*(VIN1-VIN2)]
Loreg_dc
Load regulation
ILOAD step from 90mA to 10mA
VSUP = 12V
Loreg = 100*(V_90mA-V_10mA) / V_90mA
LX_ind
Output inductor
10
22
µH
V5V_cer1
Output ceramic capacitor 1
10
100
µF
V5V_esr1
ESR of ceramic capacitor 1
Ω
V5V_cer2
Output ceramic capacitor 2
100
220
nF
V5V_esr2
ESR of ceramic capacitor 2
0.01
Ω
100
µF
1
Ω
Csup
Csup_esr
www.ams.com/AS8650
Input capacitor (ceramic)
X7R type
For EMC suppression
Revision 1.1
-0.1
+0.1
%/V
-0.9
+0.9
22
8 - 46
AS8650B
-40°C < Tj < 150°C; all voltages are with respect to ground, normal operating mode, unless otherwise mentioned. The LDO block is a linear
voltage regulator, which provides a regulated (band-gap stabilized) output voltage from the DCDC converter output voltage (V5V).
Table 6. VLDO1 Block Specifications
Symbol
Parameter
V5V
Input Voltage Range
IOUTLDO1
Output current
VLDO1
Output Voltage Range
ICC_SH
Output Short Circuit Current
Normal mode
dVLDO1
Line Regulation
ΔVLDO1 / ΔV5V (static) for the input range,
ILOAD = 100mA
LOREG_NM
Load Regulation
CL2
ESR2
Output Capacitor (Ceramic)
CL1
Conditions
Min
Typ
Max
Units
4.75
5
5.25
V
100
mA
3.383
V
300
mA
-8
8
mV/V
ΔVLDO1 (for 100mA > ILOAD > 1mA),
V5V = 5V
-0.15
+0.15
mV/mA
X7R type
2
5
µF
0.02
0.1
Ω
100
220
nF
0.01
Ω
Guaranteed by design.
Not production tested.
X7R type
3.3
ESR1
1
Table 7. VLDO2 Block Specifications
Symbol
Parameter
V5V
Input Voltage Range
IOUTLDO2
Output current
VLDO2
VOUT (typ) depends on the trim code as in
OTP register mapping.
Default code gives 2.8V
0.975*
VOUT
ICC_SH
Normal mode
dVLDO2
Line Regulation
ΔVLDO2 / ΔV5V (static) for the input
range, ILOAD = 100mA
LOREG_NM
Load Regulation
CL2
ESR2
CL1
Conditions
Min
Typ
Max
Units
4.75
5
5.25
V
120
mA
1.025*
VOUT
V
300
mA
-8
8
mV/V
ΔVLDO2 (for 120mA > ILOAD > 1mA)
-0.15
+0.15
mV/mA
X7R type
2
5
µF
0.02
0.1
Ω
100
220
nF
0.01
Ω
X7R type
ESR1
VOUT
1. Factory setting: VOUT = 2.8V.
www.ams.com/AS8650
Revision 1.1
9 - 46
AS8650B
1
Table 8. VLDO3 Block Specifications
Symbol
Parameter
V5V
Input Voltage Range
IOUTLDO3
Output current
VLDO3
Default code gives 1.8V
0.975*
VOUT
ICC_SH
Normal mode
dVLDO3
Line Regulation
ΔVLDO3 / ΔV5V (static) for the input
LOREG_NM
Load Regulation
CL2
ESR2
CL1
Conditions
Min
Typ
Max
Units
4.75
5
5.25
V
100
mA
1.025*
VOUT
V
300
mA
-8
8
mV/V
ΔVLDO3 (for 100mA > ILOAD > 1mA)
-0.15
+0.15
mV/mA
X7R type
2
5
µF
0.02
0.1
Ω
100
220
nF
0.01
Ω
X7R type
VOUT
ESR1
1. Factory setting: VOUT = 1.8V.
6.4 CAN Transceiver
6V < VSUP < 18V; -40°C < Tj < 150ºC; all voltages are with respect to ground; 4.75V < V5V_LDO1 < 5.25V; RL=60Ω.
Table 9. DC Electrical Characteristics
Symbol
Parameter
Conditions
Dominant output voltage
V_TxD = 0V
Min
Typ
Max
Units
3
4.25
V
0.5
1.75
V
-0.1
0.15
V
45Ω < RL < 60Ω,
V_TxD = 0V (dominant)
1.5
3
V
No load; V_TxD = VLDO1 (recessive)
-50
50
mV
V_TxD = VLDO1; No bus load,
Normal mode
2
3
V
No bus load, Standby mode
-0.1
0.1
V
V_TxD = 0V, V_CANH = 0V
-160
-50
mA
V_TxD = 0V, V_CANL = 40V
+50
+160
mA
-27V < V_CAN < 40V
-2.5
+2.5
mA
-12V < V_CANH < 12V
-12V < V_CANL < 12V
Receive-only mode (CAN receiver)
0.5
0.9
V
-12V < V_CANH < 12V
-12V < V_CANL < 12V
Standby mode (low-power receiver)
0.4
1.15
V
Driver
CANH_dom
CANL_dom
VO_dom_m
Matching dominant output voltage
V5V_LDO1-V_CANH-V_CANL
VO_diff
Differential output voltage
V_CANH-V_CANL
Recessive output voltage
V_CANH, V_CANL
VO_rec
IO_short
Short circuit output current
IO_rec
Recessive output current
Receiver
V_RxD_th
Differential receiver threshold
voltage
www.ams.com/AS8650
Revision 1.1
10 - 46
AS8650B
Symbol
Parameter
Conditions
Min
V_RxD_hys
Differential receiver hysteresis
voltage
-12V < V_CANH < 12V
-12V < V_CANL < 12V
I_RxD_LEAK
Input leakage current
R_IN_cm
Max
Units
mV
V5V_LDO1 = 0V;
V_CANH = V_CANL = 5V
100
250
µA
Common mode input resistance
Tested in Receive-only mode
15
35
kΩ
R_IN_cm_m
matching
V_CANH = V_CANL
(Tested in Receive-only mode)
-3
+3
R_IN_diff
Differential input resistance
25
75
kΩ
VO_SPLIT
Output voltage on SPLIT pin
Normal mode
-500µA < I_SPLIT < 500µA
0.3*
V5V_LDO1
0.7*
V5V_LDO1
V
Standby mode
0V < V_SPLIT < 35V
(Not production tested)
-5
+5
µA
Standby mode
-22V < V_SPLIT < 0
-1
+1
mA
Max
Units
Leakage current on SPLIT pin
IL_SPLIT
Typ
Table 10. AC Electrical Characteristics
Symbol
Parameter
Conditions
Min
Typ
t_TxD_BUS_on
Delay TxD to bus dominant
10
110
ns
t_TxD_BUS_off
Delay TxD to bus recessive
10
140
ns
t_BUS_on_RxD
Delay bus dominant to RxD
15
115
ns
t_BUS_off_RxD
Delay bus recessive to RxD
ns
t_TxD_RxD
Propagation Delay TxD to RxD
40
255
ns
Dominant time for wake-up detection
via bus
0.75
5
µs
WAKE UP via BUS
t_BUS_WR
BUS Diagnostic
t_OC_CANH
Time to detect over current CANH
60
µs
t_LC_CANH
Time to detect low current CANH
V_TxD = 0V, V_CANH = 40V
60
µs
t_OC_CANL
Time to detect over current CANL
60
µs
t_LC_CANL
Time to detect low current CANL
V_TxD = 0V, V_CANL = 0V
60
µs
Table 11. Temperature Limiter
Symbol
Parameter
Conditions
Min
Typ
Max
Units
Tjshut
Shut down temperature
Junction temperature when IC shuts down
150
170
185
ºC
Tjrecv
Recovery temperature
Junction temperature below which state
machine returns from shutdown / warning
125
140
155
ºC
Tjwarn
Over-temperature warning flag set
Junction temperature beyond which the
warning flag is set
140
157
175
ºC
www.ams.com/AS8650
Revision 1.1
11 - 46
AS8650B
6.4.1
Timing Diagrams
Figure 3. Timing Diagram and Hysteresis of CAN Receiver
TxD
CANH_dom
Vo_rec
CANL_dom
0.9V
Vin_diff
0.5V
2.5V
RxD
0.4V
t_TxD_BUS_on
t_TxD_BUS_off
t_BUS_off_RxD
t_BUS_on_RxD
t_TxD_RxD
V_RxD
t_TxD_RxD
V_RxD_hys
V_RxD_th (low)
www.ams.com/AS8650
V_RxD_th (high)
Revision 1.1
Vin_diff
12 - 46
AS8650B
Table 12. Undervoltage Detection
Symbol
Parameter
Conditions
Min
Typ
Max
Units
VSUP_POR
VSUP Power on Reset threshold on
Rising edge of VSUP
5.09
5.5
5.91
V
VSUP_RESET
VSUP Power on Reset threshold off
(Master Reset for Device)
4.49
4.85
5.21
V
VSUP_POKTH
VSUP undervoltage threshold off
VSUP rising edge
(Brown out reset threshold)
4.95
5.35
5.75
V
VSUP_UVTH
VSUP undervoltage threshold on
(CAN bus in recessive state)
VSUP falling edge
4.625
5.0
5.375
V
V5V_POKTH
V5V undervoltage threshold off
Rising edge of V5V
4.16
4.5
4.84
V
V5V_UVTH
V5V undervoltage threshold on
Falling edge of V5V
3.8
4.1
4.4
V
VLDO_POKTH
LDO undervoltage threshold off
(VLDO1, VLDO2 and VLDO3)
Percent value is with respect to LDO
output. Rising edge of LDO
87
89
91
VLDO_UVTH
LDO undervoltage threshold on
output. Falling edge of LDO
78
80
82
trr
Spike filter on VLDO1
To remove disturbance
2
4
8
µs
tRes
Reset delay time
4
8
12
ms
Min
Typ
Max
Units
1
Mbps
SPI Protocol.
Table 13. SPI Timing Parameters
Symbol
Parameter
Conditions
General
BRSPI
Bit rate
TSCLKH
Clock high time
500
ns
TSCLKL
Clock low time
500
ns
Write Operation Parameters
tDIS
Data in setup time
ns
tDIH
Data in hold time
10
ns
TCSH
CS hold time
40
ns
Read Operation Parameters
tDOD
Data out delay
tDOHZ
Data out to high impedance delay
Time for the SPI to release the SDO bus
80
ns
80
ns
Timing Parameters for SCLK Polarity Identification
tCPS
Clock setup time
(CLK polarity)
Setup time of SCLK with respect to CS
falling edge
ns
tCPHD
Clock hold time
(CLK polarity)
Hold time of SCLK with respect to CS
falling edge
ns
www.ams.com/AS8650
Revision 1.1
13 - 46
AS8650B
I²C Protocol. Electrical characteristics of SDA & SCLK bus lines for F/S mode
Table 14. I²C Electrical Parameters
Standard
Fast
Symbol
Parameter
VIL
VLDO1related input levels
VIH
High level input voltage:
VLDO1-related input levels
0.7V*LDO1
Vhys
Hysteresis of Schmitt trigger input
n/a
VOL1
Low level output voltage (open drain or
open collector) at 3mA sink current
tof
Output fall time from VIHmin to VILmax
with a bus capacitance from
10pF to 400pF
tSP
Pulse width of spikes which must be
suppressed by the input filter
n/a
n/a
Ii
Input current of each I/O pin with an
input voltage between 0.1VLDO1 and
0.9VLDO1 maximum
-10
10
Ci
Capacitance for each I/O pin
Min
Max
Low level input voltage:
Min
0.3V*LDO1
n/a
Max
0.3V*LDO1
Units
V
0.7V*LDO1
V
0.05V*LDO1
V
0.4
0.4
250
20 + 0.1Cb
250
(see Footnote 2) (see Footnote 1) (see Footnote 2)
50
-10
10
(see Footnote 3) (see Footnote 3)
10
10
V
ns
(lab tested
only)
ns
µA
pF
(guaranteed
by design)
1. Cb = capacitance of one bus line in pF.
2. The maximum tf for the SDA and SCLK bus lines quoted in Table 15 (300ns) is longer than the specified maximum tof for the output
stages (250ns). This allows for any series protection resistors to be connected between the SDA/SCLK pins and the SDA/SCLK bus
lines without exceeding the maximum specified tf.
3. I/O pins of Fast-mode devices must not obstruct the SDA and SCLK lines if VLDO1 is switched off.
www.ams.com/AS8650
Revision 1.1
14 - 46
AS8650B
Characteristics of the SDA and SCLK Bus Lines for F/S Mode I²C Bus.
Table 15. I²C Timing Parameters
Standard
Symbol
Parameter
fSCLK
Fast
Min
Max
Min
Max
(see Footnote 1)
Units
SCLK clock frequency
kHz
tHD_STA
Hold time (repeated) START condition.
After this period, the first clock pulse is
generated
4
0.6
µs
tLOW
Low period of the SCLK clock
4.7
1.3
µs
tHIGH
High period of the SCLK clock
4.0
0.6
µs
tSU_STA
Set-up time for a repeated START
condition
4.7
0.6
µs
tSU_DAT
Data set-up time
250
100
(see Footnote 2)
ns
tHD_DAT
Data hold-time
tr
Rise time of SDA and SCLK signals
1000
20+
0.1Cb
(see Footnote 4)
300
ns
tf
Fall time of SDA and SCLK signals
300
20+
0.1Cb
(see Footnote 4)
300
ns
tSU_STO
Set-up time for STOP condition
4.0
0.6
µs
tBUF
Bus free time between a STOP and
START condition
4.7
1.3
µs
Cb
Capacitive load for each bus line
400
400
pF
VnL
Noise margin at the Low level for each
connected device (including hysteresis)
0.1V*LDO1
0.1V*LDO1
VnH
Noise margin at the High level for each
0.2V*LDO1
0.2V*LDO1
(see Footnote 5) (see Footnote 3) (see Footnote 5) (see Footnote 3)
ns
1. All values referred to VIHmin and VIlmax levels (see Table 14).
2. A fast mode I²C bus device can be used in Standard mode I²C bus system, but the requirement tSU_DAT ≥ 250ns must then be met. This
will automatically be the case if the device do not stretch the low period of the SCLK signal. If such a device does stretch the low period
of the SCLK signal, it must output the next data bit to the SDA line trmax. TSU_DAT = 1000 + 250 = 1250ns (according to standard mode
I²C bus specification) before the SCLK line released.
3. The maximum tHD;DAT has only to be met if the device does not stretch the low period (tLOW) of the SCLK signal.
4. Cb = total capacitance of one bus line in pF. If mixed with Hs-mode devices, faster fall-times according to Table 14 allowed.
5. This device internally provides a hold time of at least 300ns for the SDA signal to bridge the undefined region of the falling edge of the
SCLK.
www.ams.com/AS8650
Revision 1.1
15 - 46
AS8650B
6.6.1
Table 16. System Timing Parameters
Symbol
Parameter
Conditions
Min
Typ
Max
Units
70
ms
10
ms
50
ms
Mode Transition Related Timing
TPOST
Power-up to Standby mode
TSTNO
Standby to Normal mode
TSLST
Sleep to Standby mode
Reset time included,
Start-up watchdog not included
Reset time included
Wake-up Timing
Tdom(wake)
Minimum dominant pulse for CAN
wake-up detection (remote wake)
5
µs
Trec(wake)
Minimum recessive pulse for CAN
5
µs
TL_wake
Time between edge on WAKE pin to
local wake detection
TLW_filter
WAKE_LOCAL signal
(Filter on WAKE pin)
TR_wake
Remote wake detection time from the
valid pattern detection
TINTN
INTN pin high time
7
V_LWUTH
Local WAKE threshold input
2
32
0.75
µs
5
24
µs
µs
µs
4
V
Local Failure Related Timing
TTxDC(dom)
TxD dominant timeout period
600
1000
1400
µs
TBUSC(dom)
BUS dominant clamping timeout period
600
1000
1400
µs
Watchdog Timing & Timeouts
TWD(init)
Start-up Watchdog timeout
(initialization time)
Twd_trig
Window watchdog Trigger window
www.ams.com/AS8650
300
Twwd_period is defined in
WWD register
Revision 1.1
0.375
0.5
ms
0.625
Twwd_period
16 - 46
AS8650B
Datasheet - D e t a i l e d D e s c r i p t i o n
The AS8650B consists of the following components on chip:
DCDC converter with 5V outputs that supplies the three LDO voltage regulators and the CAN Transceiver
Three voltage regulators with output voltages 3.3V, 2.8V and 1.8V and output accuracy up to 2.5%
High-speed CAN bus Transceiver according to ISO 11898-5
Integrated RESET unit with a power-on-reset delay and a programmable watchdog time
The AS8650B provides four main operating modes Normal, Receive-only, Standby, and Sleep. In Normal mode, the CAN Transceiver can be
disabled in case of over-temperature condition. The detailed transition table for each mode is shown in the subsequent pages.
7.1.1
Normal Mode
In Normal mode DCDC converter, the three voltage regulators, BUS Transceiver, and Window Watchdog are turned on with full functionality. All
the LDO regulators are capable of delivering maximum load current possible as per their respective ratings. The BUS Transceiver is capable of
sending the TxD data from the microcontroller to the CANH at the maximum rate.
7.1.2
Receive-Only Mode
In this mode, the CAN transmitter is disabled. The CAN receiver, the three voltage regulators, and over-temperature monitor circuit are enabled.
7.1.3
Standby Mode
This is the mode after power up. The Standby mode is a functional low-power mode where the CAN Transceiver is disabled. The bus wake-up
(low power receiver) circuit, LDO1, and over-temperature monitor circuit are enabled. Both LDO2 and LDO3 can be enabled or disabled (default
state) using the host command. The AS8650B can enter Normal mode, Sleep mode or Receive-only mode through host command.
7.1.4
Sleep Mode
Sleep mode is the current saving mode that is entered by host command or by over-temperature condition. The DCDC converter, the three
voltage regulators, CAN Transceiver, the reset, and window watchdog unit are all switched off. The bus wake-up (low power receiver) circuit,
oscillator, and over-temperature monitor circuit are active. The bus is in recessive state (high). The only wake-up possible is through remote
wake-up (through the bus lines) or local wake up (through the WAKE pin) as described in the WAKE specification. In the case of entering Sleep
mode due to over-temperature condition (T > Tjshut), the device can come out of Sleep only after the temperature falls back below the return
temperature Tjrecv and any one of the wake up events mentioned above.
The detailed block diagram and the power management strategy are shown in Figure 4.
Internal Regulator. This module is powered externally by the VSUP. All the critical modules that needs to be kept always on, work on this
supply. Some of the important modules among them are Over-temperature monitor, Local Wake block, Internal Power-on Reset module, Internal
Oscillator, complete mode-control unit, Undervoltage comparators of three external LDOs.
DCDC Converter. This is the main supply regulator for all the internal blocks. A step-down hysteretic buck converter is used to generate 5V
output from VSUP. This 5V output is then used to generate all the three LDOs. This high-efficiency step-down DCDC converter contains the
following features:
Current limited operation
Thermal shutdown
LDO1. This is the main I/O supply. This is generated internally from the 5V DCDC converter output and gives a regulated 3.3V output to powerup the external micro-controller. All the I/Os that interface with the microcontroller work on this supply.
LDO2. This regulator is generated internally from the 5V DCDC converter output and gives a regulated 2.8V output. The voltage level can be
changed through factory settings.
LDO3. This regulator is generated internally from the 5V DCDC converter output and gives a regulated 1.8V output. The voltage level can be
www.ams.com/AS8650
Revision 1.1
17 - 46
18 - 46
Figure 4. Power Management Strategy
VSUP GND
WAKE
CANH
SPLIT
CANL
Local WAKE
CAN
Transceiver
LX
ldo1_uvb
otm_160
otm_170
otm_en
ldo2_en
loc_wake
tx_en
tx
rx_en
rx
flags
ldo1_en
ldo2_uvb
ldo3_en
Mode Control / Reset
Generation
ldo3_uvb
AS8650B
Level Shifter
Definer
Window
WatchDog
Digital
Interface
V5V
LDO1
(100mA)
VLDO1
UV Comp
LDO2
(120mA)
Revision 1.1
OTM
FB
DCDC Converter 5V
VLDO2
UV Comp
LDO3
(100mA)
VLDO3
UV Comp
OTP
Level Shifter
Level Shifter
Definer
Level Shifter
RESET
INTN
TxD
RxD
Definer
Definer
Definer
Level Shifter
Definer
CSSPI
SCLKI2C / SCLKSPI
SDAI2C / SDISPI
SDOSPI
I2C_EN
LDO1
Pre-reg
DCDC 5V
www.ams.com/AS8650
Osc
start
done
Pre-Reg
3.3V &
5.0V
por
clk
osc_en
POR
AS8650B
Table 17. Power Management Strategy for AS8650B
Control States
Analog Blocks
Power-up
Normal
Rx Only
Standby
Sleep
DCDC Converter
ON
ON
ON
ON
OFF
Oscillator
ON
ON
ON
ON
ON
Internal Regulator
ON
ON
ON
ON
ON
OTM
ON
ON
ON
ON
ON
LDO1
ON
ON
ON
ON
2
LDO2
OFF
ON
LDO3
OFF
ON
CAN Tx
OFF
ON
CAN Rx
OFF
Low Power Rx
OFF
LOCAL WAKE
2
ON
2
ON
2
1
OFF
OFF
1
OFF
OFF
1
OFF
OFF
OFF
OFF
ON
ON
OFF
OFF
OFF
OFF
ON
ON
OFF
OFF
OFF
ON
ON
OFF
ON
ON
ON
ON
WWD
OFF
ON
ON
ON
OFF
Digital Interface
OFF
ON
ON
ON
OFF
SPLIT Generation
Digital Blocks
1. Can be turned ON using Device Configuration Register
2. Can be turned OFF using Device Configuration Register
www.ams.com/AS8650
Revision 1.1
19 - 46
AS8650B
7.3 State Diagram
Figure 5. State Machine Model
VSUP_UV_flag = 1 OR V5V_UV_flag =1
→ BUS transceiver disabled
VSUP_UV_flag =1 OR
V5V_UV_flag= 1
BUS
Host command (go to ReceiveOnly)
Normal
Receive Only
(go
to
No
rm
al)
Ho
st
st c
Ho
om
nd
ma
(g
co
mm
an
d
ep)
Sle
o to
(g
ot
oS
tan
db
y)
Sleep
Standby
→ BUS wake
VLD
BUS Wake
OR
Local Wake
=0
O1
PO
R t
ime
O
out
atc R
hdo
g tim
eou
t
Power-up
Power Off
Normal OR
Receive_only OR
Standby state
T=
star
tup
w
ESE
T ==
1
R es &
et tim
e ou
t
From any state
Host command (go to Sleep)
VLD
O1_
R
TEMP > Tjshut
disabled
Host command (go to Standby)
co
mm
an
d
T
SE
RE
R_
O
_P
UP
VS
VL
DO
1_
RE
SE
Ho
st
TEMP>Tjwarn
BUS transmitter
disabled BUS transmitter will be
enabled on TEMP < Tjrecv
Host command (go to Normal)
The DCDC converter is switched ‘ON’. Subsequently, on receiving power-good (PG) signal from the DCDC converter, the LDO1 regulator is
switched ‘ON’. During the initialization sequence, the VLDO1 is set to 2.5V if VLDO1 > VLDO1_POKTH threshold. VLDO1_RESET is released to
‘high’. Then, active-low PORN_2_OTP is generated.
Initially the rising edge of PORN_2_OTP loads contents into the OTP latch. Next the LOAD_OTP_IN_PREREG signal loads the content of OTP
latch into the pre-regulator domain register. Once the VLDO1_POKTH threshold is reached, the reset timeout timer also starts.
The RESET signal expires after Reset timeout period TRes. After the RESET signal is ‘high’, the startup watchdog is launched. If the
microcontroller generates a trigger within the startup window, then the device enters into Standby mode.
If the microcontroller fails to generate the trigger, then the RESET signal is generated and the Reset timeout will start.
If the microcontroller fails to generate the startup watchdog trigger for 3 consecutive times, then the device enters into Sleep mode. On receiving
Normal mode command from the microcontroller, the LDO2 and LDO3 regulators are activated. By the time VLDO2 and VLDO3 reach their
respective power-ok (POK) threshold values, an interrupt signal is generated. The AS8650B supports very slow VSUP ramp up of 0.5V/min.
www.ams.com/AS8650
Revision 1.1
20 - 46
AS8650B
The power initialization sequence diagram is shown in Figure 6.
After activating the power supply on VSUP pin,
the VSUP_POR_RESET flag becomes inactive (high) while the voltage exceeds the
VSUP_POR threshold.
The DCDC output voltage V5V exceeds the V5V_POKTH thresholds after the DCDC settling time and the first voltage regulator (LDO1) will
be activated with the V5V_POK set.
If the voltage output at LDO1 (set to 2.5V on power-up) reaches the VLDO1_POKTH threshold, the PORN_2_OTP flag is set and OTP
register setting for the LDO1 is read. Consequently the output voltage will be regulated to the actual OTP settings.
The initialization phase of the device is terminated after the preset output voltage level threshold is exceeded and the reset
timeout is
expired.
After entering Standby mode the host controller can switch the device in any operation mode through the I²C or SPI interface.
Figure 6. Initialization Sequence
VSUP_POR
Tpost = Power-up to Standby mode time
VSUP
VSUP_POR_RESET
V5V_POKTH
V5V
V5V_POK
VLDO1_POKTH
VLDO1
VLDO1_POKTH
VLDO1_RESET
PORN_2_OTP
6 Cycles of
RC- Oscillator
LOAD_OTP_IN_
PREREG
RESET
Tres = Reset Timeout
DEVICE
STATE
INITIALIZATION
Start-up watchdog
disabled by default
STARTUP
WATCHDOG
STANDBY
MODE
NORMAL MODE
VLDO2_POKTH
VLDO2
VLDO3_POKTH
VLDO3
INTN
Host Command
Tstno = Standby to Normal mode time
www.ams.com/AS8650
Revision 1.1
21 - 46
AS8650B
7.5 DCDC Converter
The high-efficiency, high-voltage, hysteretic step-down DCDC converter, operates in asynchronous mode and delivers 500mA of output load to
drive the three internal LDOs and the CAN Transceiver. The low-power architecture extends hold-up time in battery-backed and critical
applications where maximum up-time over a wide input supply voltage range is needed, while still providing for high efficiencies of up to 90%
during peak current demands.
The stability of the voltage output is below ±2.5% over the full input range and temperature for load current up to 100mA at 3.3V. Power Input to
this LDO is the V5V_LDO1 pin. This LDO is activated in Normal, Receive-only or Standby mode. It is switched OFF in Sleep mode.
The stability of the voltage output is below ±2.5% over input range and temperature for load current up to 120mA at 2.8V. Power Input to this
LDO is the V5V_LDO2 pin. LDO2 is activated in Normal and Receive-only mode. The output voltage level can be changed through factory
settings. For further information, please contact ams regional sales person.
The stability of the voltage output is below ±2.5% over input range and temperature for load current up to 100mA at 1.8V. Power Input to this
LDO is the V5V_LDO3 pin. LDO3 is activated in Normal and Receive-only mode. The output voltage level can be changed through factory
In Normal mode, if the junction temperature reaches the over-temperature threshold Tjwarn, a warning flag is set in the diagnostic register which
can be accessed via the I²C and the SPI interface and an interrupt is signalled on INTN pin. The CAN transmitter is disabled and the device
remains in Normal mode. If the junction temperature falls below Tjrecv, the CAN transmitter is enabled. The warning flag is cleared in the
diagnostic register and an interrupt is signalled at the INTN pin. If the junction temperature exceeds the over-temperature threshold Tjshut, the
device enters Sleep mode irrespective of the current mode and bus wake receiver (Low power receiver) is disabled. As soon as the temperature
falls below Tjrecv (thermal recovery), the device goes through the power-up sequencing while entering Power-up mode and enters Standby mode
if the boundary conditions of the statemachine are fulfilled.
Undervoltage on VSUP (Brown out Indication). If VSUP voltage falls below VSUP_UVTH threshold, the VSUP_UV_flag is set and an
interrupt at INTN is generated. In this case the device enters into the Standby mode. The LDO1 voltage regulator remains activated. Two
scenarios are possible at this stage:
VSUP is recovering: If VSUP exceeds the VSUP_POKTH threshold, the VSUP_POK_flag is set and the device remains in Standby mode.
VSUP is still falling: In this case the device continues to stay in Standby mode. If voltage falls below VSUP_RESET threshold,
then the
device enters Power-Off and the logic is reset.
Undervoltage on V5V. If the V5V falls below V5V_UVTH threshold, the V5V_UV_flag is set. Once V5V returns to V5V_POKTH threshold
value, V5V_POK_flag is set. In case a flag is set, an interrupt is generated at the INTN pin. If undervoltage on V5V occurs in Normal or Receiveonly modes then CAN Transceiver is disabled and the device remains in its operation mode.
Undervoltage on LDO1. If the voltage level of LDO1 falls below the VLDO1_UVTH threshold value and device is not in Sleep mode, the
device enters into power-up state while RESET signal is asserted and the voltage regulator is still active. Once the VLDO1_POKTH threshold is
reached, RESET signal is de-asserted after reset timeout period and device enters into Standby mode.
Undervoltage on LDO2. If the voltage level of the LDO2 falls below the VLDO2_UVTH threshold value a VLDO2_UV_flag is set. An
indication is given to microcontroller by setting a bit in interrupt register and giving interrupt on INTN pin. Once VLDO2 returns to
VLDO2_POKTH threshold value, VLDO2_POK_flag is set. An indication is given to microcontroller by setting a bit in interrupt register and giving
Undervoltage on LDO3. If the voltage level of the LDO3 falls below the VLDO3_UVTH threshold value a VLDO3_UV_flag is set. An
indication is given to microcontroller by setting a bit in interrupt register and giving interrupt on INTN pin. Once VLDO3 returns to
VLDO3_POKTH threshold value, VLDO3_POK_flag is set. An indication is given to microcontroller by setting a bit in interrupt register and giving
www.ams.com/AS8650
Revision 1.1
22 - 46
AS8650B
Figure 7. Power-up and Undervoltage Sequence
VLDO2_POKTH
VSUP_POR
VLDO2_UVTH
VSUP_POKTH
VSUP_RESET
VSUP_UVTH
VSUP
VLDO2
VSUP_POR_RESET
VSUP recovering
VSUP_UV_flag
VLDO2_POK_flag
VSUP still falling
VSUP recovering
VSUP still falling
VSUP_POK_flag
VSUP Supply
V5V_POKTH
VLDO2_UV_flag
LDO2 Supply
VLDO3_POKTH
V5V_UVTH
V5V
VLDO3_UVTH
VLDO3
V5V_POK_flag
VLDO3_POK_flag
V5V_UV_flag
VLDO3_UV_flag
DCDC Supply
LDO3 Supply
VLDO1_POKTH
VLDO1_UVTH
VLDO1
VLDO1_RESET
LDO1 Supply
7.11 Reset Block
The reset block generates an external RESET signal to reset the microcontroller and all other external circuits. The reset functionality is
explained in Figure 8. The reset block consists of a digital buffer at the output. The RESET signal is affected by VLDO1_RESET (during
overload, reset on VLDO1) and watch dog output. All conditions which cause a drop of the VLDO1 voltage will be detected from the low voltage
reset unit which in-turn generates a reset signal.
Figure 8. Reset Block Functional Waveform
VVSUP_UV
VSUP
T>Tjshut
TTrec(wake)
>Tdom(wake)
WAKE_remote_flag
>Trec(wake)
Remote wake
detected
7.13 Internal Flags
The AS8650B supports internal flags to indicate the failures in the system. If any of these flag is set an interrupt is generated on INTN pin.
7.13.1 VSUP_UV_flag
This is a VSUP undervoltage flag. This flag is set when VSUP falls below the VSUP_UVTH threshold. When this flag is set the device enters into
Standby mode and BUS Transceiver is switched off to save power. When VSUP recovers and raises above VSUP_POKTH threshold the
VSUP_UV_flag is reset.
7.13.2 VSUP_POK_flag
This is a VSUP power ok flag. This indicates the VSUP recovery from undervoltage condition. When the VSUP rises above VSUP_POKTH
threshold, this flag is set. This indicates the microcontroller that undervoltage condition on battery is cleared.
7.13.3 V5V_UV_flag
This is a V5V undervoltage flag. This flag is set when V5V falls below the V5V_UVTH threshold. When this flag is set the device enters into
Standby mode and BUS Transceiver is switched off to save power. When V5V recovers and raises above V5V_POKTH threshold the
V5V_UV_flag is reset.
7.13.4 V5V_POK_flag
This is a V5V power ok flag. This indicates the V5V recovery from undervoltage condition. When the V5V rises above V5V_POKTH threshold,
this flag is set. This indicates the microcontroller that undervoltage condition on DCDC converter is cleared.
7.13.5 VLDO2_UV_flag
This is a VLDO2 undervoltage flag. This flag is set when VLDO2 falls below the VLDO2_UVTH threshold. When VLDO2 recovers and raises
above VLDO2_POKTH threshold the VLDO2_UV_flag is reset.
7.13.6 VLDO2_POK_flag
This is a VLDO2 power ok flag. This indicates the VLDO2 recovery from undervoltage condition. When the VLDO2 rises above VLDO2_POKTH
threshold this flag is set. This indicates the microcontroller that undervoltage condition on LDO2 is cleared.
This is a VLDO3 undervoltage flag. This flag is set when VLDO3 falls below the VLDO3_UVTH threshold. When VLDO3 recovers and raises
above VLDO3_POKTH threshold the VLDO3_UV_flag is reset.
This is a VLDO3 power ok flag. This indicates the VLDO3 recovery from undervoltage condition. When the VLDO3 rises above VLDO3_POKTH
threshold this flag is set. This indicates the microcontroller that undervoltage condition on LDO3 is cleared.
www.ams.com/AS8650
Revision 1.1
26 - 46
AS8650B
The BUS Wake_up flag is set when the device detects a remote wake-up (BUS message) request. The remote wake-up request is detected
when pattern shown in Figure 11 is found on wake_remote port of low power receiver. This indicates the microcontroller about the Bus wake
event.
The Local Wake_up flag is set when the device detects a local wake-up request on WAKE pin. A local wake-up request is detected when a logic
state change on pin WAKE as shown in Figure 9. This indicates the microcontroller about the local wake event.
The OVT_Warning flag is set when temperature exceeds Tjwarn. This indicates the microcontroller about temperature exceeding warning levels.
The OVT_Recover flag is set when temperature falls back below Tjrecv. This indicates the microcontroller about temperature falling back below
recovery levels.
The bus failure flag is set if the CAN Transceiver detects a bus line short-circuit condition to VSUP, V5V_LDO1 or GND. Such possible conditions
are indicated to microcontroller through these flags. All these flags are cleared on microcontroller read. If the fault condition still exist after
microcontroller read, the particular flag is set again. The device still be working in the current state. The microcontroller takes appropriate action
on reading of these flags.
CANH_short_GND. This flag indicates Over Current condition on pin CANH. For example short to ground on pin CANH. When the output
current on pin CANH exceeds the threshold OC_CANH_th then the output OC_CANH switches on high level after a filter time t_OC_CANH.
CANH_short_VSUP. This flag indicates Low Current on pin CANH. For example open load or short to VSUP on pin CANH. When the output
current on pin CANH falls below the threshold LC_CANH_th then the output LC_CANH switches on high level after a filter time t_LC_CANH.
CANL_short_VSUP. This flag indicates Over Current on pin CANL. For example short to VSUP on pin CANL. When the output current on pin
CANL exceeds the threshold OC_CANL_th, then the output OC_CANL switches on high level after a filter time t_OC_CANL.
CANL_short_GND. This flag indicates Low Current on pin CANL. For example open load or short to ground on pin CANL. When the output
current on pin CANL falls the threshold LC_CANL_th then the output LC_CANL switches on high level after a filter time t_LC_CANL.
The AS8650B prevents the system from four kinds of local failures without disturbing the BUS network. The four failures are TxD dominant
clamping, RxD recessive clamping, TxD & RxD short, and bus dominant clamping. All these failures are indicated to microcontroller through
flags.
TxD_Dom_Clamp flag. A permanent Low-level on pin TxD (due to a hardware or software application failure) would drive the BUS into a
permanent dominant state, blocking BUS network communication. If pin TxD remains at a Low level for longer than the TxD dominant timeout
period TTxDC(dom), the device disables the transmitter of BUS Transceiver and TxD_Dom_Clamp flag is set. The device prevents such BUS
network lock-up by disabling the transmitter of the transceiver. The device will not change the functional state. The transmitter remains disabled
until the local failure persists. The flag is cleared with microcontroller read request.
TxD_RxD_Short flag. The TxD_RxD short circuit would result in a dead-lock situation clamping the bus dominant. For example the
Transceiver receives a dominant signal, RxD outputs a dominant level. Because of the short circuit, TxD reflects a dominant signal, retaining the
dominant bus state. As a result TxD and the bus are clamped continuously dominant. The resulting effect is the same as for the continuously
clamped dominant TxD signal. The TxD dominant timeout interrupts the deadlock situation by disabling the transmitter and the TxD_RxD short
condition is differentiated. The bus becomes recessive again and TxD will be recessive if it is not driven by microcontroller. However, the failure
scenario may still exist and with the next dominant signal on the bus the described procedure will start again.
The device keeps the transmitter off after detection of TxD_RxD short fault and keeps updating this flag status. The microcontroller has to send
2 consecutive low pulses of duration 500ns with high period of 500ns in-between, in regular intervals to check short circuit recovery. This way a
local TxD/RxD short circuit will not disturb the communication of the remaining bus system.
BUS_Dom_Clamp flag. In the case of a short circuit from BUS to GND, the circuit for the BUS receiver senses dominant signal continuously
even if there is no dominant transmitting node. The result may be a permanently dominant clamped bus. The device detects and reports a Bus
Dominant Clamping situation to microcontroller through BUS_Dom_Clamp flag. If the receiver detects a bus dominant phase of longer than the
bus dominant time out TBUSC(dom) BUS_Dom_Clamp flag is set. The flag is cleared on microcontroller read.
www.ams.com/AS8650
Revision 1.1
27 - 46
AS8650B
7.14 Watchdog (WD)
The WD has the following three monitory timing functions:
Start-up
watchdog: Gives opportunity to microcontroller to initialize the system.
Window
watchdog: Detects too early or too late microcontroller software response (loops and hangs).
Timeout watchdog: Detects too very long response from microcontroller.
Following any reset event the watchdog is used to monitor the ECU start-up procedure. Once the reset is released the watchdog counter will
start. In case the watchdog is not properly served (a trigger from microcontroller) within TWD(init), another reset is forced on RESET pin and the
monitoring procedure is restarted. The watchdog will give three opportunities to microcontroller to initialize the system. In case the watchdog is
not properly served for three times, then the system enters into Sleep mode.
Whenever the device enters Normal mode, the Window mode of the watchdog is activated. This ensures that the microcontroller operates within
the required speed; a too fast as well as a too slow operation will be detected. Watchdog triggering using the Window watchdog is illustrated in
Figure 12.
Figure 12. Window Watchdog Triggering
Twwd_period
Twd_no_trig
Twd_trig
NON-TRIGGER WINDOW
TRIGGER WINDOW
Trigger
restarts
period
SPI
TRIGGER
Last
Trigger
Point
50%
100%
Latest
Trigger
Point
Earliest
Trigger
Point
Trigger restarts period
( with new period if desired)
New Period
NON-TRIGGER WINDOW
TRIGGER WINDOW
50%
SPI
TRIGGER
Unwanted Trigger
(RESET generated,
watchdog enter Start-up
mode)
Earliest
Trigger
Point
100%
Latest
Trigger
Point
The AS8650B provides 8 different period timings. This timing can be changed through digital interface when desired. The period can be changed
within any valid trigger window. Whenever the watchdog is triggered within the window time Twd_trig, the timer will be reset to start a new period.
The watchdog window is defined to be between 50% and 100% of the nominal programmed watchdog period. Any too early (trigger in nontrigger window) or too late watchdog trigger will result an immediate system reset on RESET pin and watchdog entering Start-up watchdog
mode. During undervoltage condition on VLDO1 the watchdog timer is disabled.
www.ams.com/AS8650
Revision 1.1
28 - 46
AS8650B
Whenever the AS8650B operates in Standby mode, active watchdog operates in Timeout watchdog mode. The watchdog has to be triggered
within the actual programmed period time Twd_tout_period. The device provides 8 different possible periods for programming through digital
interface. If the microcontroller fails to trigger the watchdog within trigger range then the system reset is generated on RESET pin and watchdog
enters into Start-up watchdog mode. The timeout watchdog function is illustrated in Figure 13.
Figure 13. Timeout Watchdog Triggering
Twwd_period
Twd_no_trig
Twd_trig
NON-TRIGGER WINDOW
TRIGGER WINDOW
Trigger
restarts
period
SPI
TRIGGER
Last
Trigger
Point
50%
100%
Latest
Trigger
Point
Earliest
Trigger
Point
New Period
NON-TRIGGER WINDOW
TRIGGER WINDOW
50%
SPI
TRIGGER
Unwanted Trigger
(RESET generated,
watchdog enter
Start-up mode)
Earliest
Trigger
Point
100%
Latest
Trigger
Point
The pin INTN is an interrupt output. The INTN is forced ‘low’ if one bit in the Interrupt register is set. The Interrupt register bits are cleared when
the microcontroller clears the corresponding interrupt source register. The Interrupt register will also be cleared during a system reset (RESET
LOW). As there are microcontrollers with level sensitive or edge sensitive interrupt port, pin INTN will be ‘high’ for at least TINTN after any of the
interrupt source register is cleared. The Interrupt source register is cleared through write operation by overwriting ‘1’ in to respective set bits
position. Without further interrupts within TINTN pin INTN stays ‘high’, otherwise it will revert to ‘low’ again.
The Interrupt register indicates the cause of an interrupt event. There are two levels of interrupt registers. First level register indicates the source
region of interrupt and the second level register indicates the exact source of interrupt. With this structured interrupt, the microcontroller can trace
source of interrupt by two read operations instead of polling for source of interrupt and also interrupts can be prioritized by microcontroller. The
interrupt register structure is given in Figure 14. The register is cleared through digital interface write operation and upon any reset event. The
hardware ensures no interrupt event is lost in case there is a new interrupt forced while reading the register.
www.ams.com/AS8650
Revision 1.1
29 - 46
AS8650B
Figure 14. Interrupt Register Structure
D6
D5
R
R
R
I3
I2
I1
D4
D3
CANH_Short_VCC
Reserved
D7
CANL_Short_VCC
TxD_RxD_Short
D0
CANH_Short_GND
BUS_Dom_Clamp
D1
TxD_Dom_Clamp
Wake_up
D3 D2
CANL_Short_GND
Local Wake_up
R
BUS and Local failure Interrupt
R
R
wake-up, temperature and LDO timeout Interrupt
R
R
Supply Related interrupt
Interrupt Register
OVT_Recovery
R
OVT_Warning
D0
Reserved
D1
Reserved
Reserved
D2
Reserved
D3
VSUP_UV_flag
D4
VSUP_POK_flag
V2P8_UV_flag
D5
V5V_UV_flag
V2P8_POK_flag
D7 D6
V5V_POK_flag
V1P8_UV_flag
V1P8_POK_flag
Interrupt Source Registers
D2
D1
D0
The AS8650B has three Flag status registers and one RESET Reason Register. The Flag status registers indicate the current status of flags
which are related to respective interrupt source registers. The Flag status registers are BUS Status Register, Temperature Status Register, and
Supply Status Register. The microprocessor can read these registers any time to check the status of device. The function of each flag is listed in
register space description in subsequent sections.
A RESET Reason register indicates the reasons for RESET generation. Once the RESET pin goes ‘low’, the reason of this reset event is stored
in RESET Reason register. When RESET is released microprocessor can read this register to know the cause for last RESET signal. The
RESET Reason register is cleared once microprocessor reads this register through read operation. The bits functionality of this register is
explained in register space description table.
www.ams.com/AS8650
Revision 1.1
30 - 46
AS8650B
Datasheet - A p p l i c a t i o n I n f o r m a t i o n
Device Interfaces. There are two ways to communicate with AS8650B, one is 4 wires SPI and other is I²C. The selection between these two
interfaces is through I2C_EN pin, as shown in Table 19. The pins CS, SCLK, SDI, and SDO are used for SPI interface. For I²C interface, SCLK is
used as I²C Clock and SDA is used as I²C data line. Pins SCLKI2C / SCLKSPI and SDAI2C / SDISPI are multiplexed for both SPI and I²C interface.
Since I2C_EN is a digital input pin, it has to be connected either to VLDO1 or GND.
Note: I2C_EN should not be changed during a I²C/SPI Read/Write operation. Maximum switching delay between I²C and SPI is 8µs.
Table 19. Device Interface Selection
I2C_EN
Description
LOW
Interface is 4-wire SPI
HIGH
Interface is I²C
The Serial Peripheral Interface (SPI) provides the communication link with the microcontroller. The SPI is configured for half-duplex data transfer.
The SPI provides access to configuration registers, control registers, and diagnostic registers. The modes of the AS8650B are changed by
writing required code in to Mode Control Register through SPI. The SPI is also used to enter into test and OTP modes. This interface is only
slave interface and only master can initiate SPI operation.
The SPI can work on both the clock polarities. The polarity of the clock depends on the value of SCLK at the falling edge of CS. At the falling
edge of CS if SCLK is “1” then the SPI is positive edge triggered and if the SCLK is “0” then SPI is negative edge triggered logic (see Table 20).
Table 20. SPI Clock Polarity
CS
SCLK
Description
LOW
HIGH
Serial data is transferred at falling edge and sampled at rising edge of SCLK
LOW
LOW
Serial data is transferred at rising edge and sampled at falling edge of SCLK
The SPI protocol frame is divided in to two fields, the header field and the data field. The header field is 1 byte long containing a read/write
command bit, 5 address bits and 2 reserved bits. The data field is of one data byte. The SPI frame format is shown in Figure 15. In the data
phase MSB is sent first and LSB is sent last.
Figure 15. SPI Frame Format
Header Field
Data Field
1 byte
R/W
Reserved
Bits
0–
1–
www.ams.com/AS8650
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
5 bits
Address
WRITE
READ
Revision 1.1
31 - 46
AS8650B
8.1.1
SPI Write Operation
The SPI write operation begins with clock polarity selection at negative edge of CS, given in Table 20. Once the clock polarity is selected the SPI
write command is given by providing ‘0’ in R/W bit of the header field in first sampling edge at SDI pin. The 5 bits address of register to be written
is provided at SDI pin in next five consecutive sampling edges of SCLK. The first 2 bits in header fields are reserved and set to ‘0’. The data to be
written is followed by last bit of header field. With each sampling edge a bit is sampled starting from MSB to LSB. During complete SPI write
operation the CS has to be ‘low’. The SPI write operation ends with positive edge of CS. The wave form for SPI write operation with single data
byte is shown in Figure 16 and Figure 17.
Figure 16. SPI Write Operation with Negative Clock Polarity and 1 Byte of Data Field
CS
SCLK
SDI
R1
R0
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
SDO
Sampling Edge
High Impedance Sate
Figure 17. SPI Write Operation with Positive Clock Polarity and 1 Byte of Data Field
CS
SCLK
R1
R0
A4
A3
A2
A1
A0
D7
D6
D5
D4
D3
D2
D1
D0
SDI
SDO
Sampling Edge
High Impedance Sate
www.ams.com/AS8650
Revision 1.1
32 - 46
AS8650B
8.1.2
SPI Read Operation
The SPI read operation also begins with clock polarity selection at negative edge of CS, given in Table 20. Once the clock polarity is selected the
SPI read command is given by providing ‘1’ in R/W bit of the header field in first sampling edge at SDI pin. The 5 bits address of register to be
read is provided at SDI pin in next five consecutive sampling edges of SCLK. The first 2 bits in header fields are reserved and set to ‘0’. The read
data is followed by last bit of header field on SDO pin. With each sampling edge a bit can be read on SDO pin starting from MSB to LSB. During
complete SPI read operation the CS has to be ‘low’. The SPI read operation ends with positive edge of CS. The wave form for SPI read operation
with single data byte is shown in Figure 18 and Figure 19.
Figure 18. SPI Read Operation with Negative Clock Polarity and 1 Byte of Data Field
CS
SCLK
SDI
R1
R0
A4
A3
A2
A1
A0
D7
SDO
D6
D5
Sampling Edge
D4
D3
D2
D1
D0
D1
D0
High Impedance Sate
Figure 19. SPI Read Operation with Positive Clock Polarity and 1 Byte of Data Field
CS
SCLK
SDI
R1
R0
A4
A3
A2
A1
A0
D7
SDO
Sampling Edge
www.ams.com/AS8650
D6
D5
D4
D3
D2
High Impedance Sate
Revision 1.1
33 - 46
AS8650B
8.1.3
SPI Timing Diagram
Figure 20. Timing Diagram for SPI Write Operation
CS
tCPS
tCPHD
tSCLKH
tSCLKL
tCSH
CLK
polarity
SCLK
tDIH
tDIS
SDI
DATAI
DATAI
DATAI
SDO
Figure 21. Timing Diagram for SPI Read Operation
CS
tSCLKL
tSCLKH
SCLK
SDI
DATAI
DATAI
tDOHZ
tDOD
SDO
www.ams.com/AS8650
DATAO (D7 N )
Revision 1.1
DATAO (D0 0 )
34 - 46
AS8650B
I²C is a bidirectional 2 line bus interface with a serial data line (SDA) and a serial clock line (SCLK) for inter IC control. This interface is only slave
interface and only microcontroller can start and stop the I²C operation. The overview of I²C protocol is shown in Figure 22. A ‘high’ to ‘low’
transition on SDA line while SCLK is ‘high’ is the START (S) condition and a ‘low’ to ‘high’ transition on SDA line while SCLK is ‘high’ is the STOP
(P) condition, as shown in Figure 22. The START and STOP conditions should always be generated by the microcontroller. After the START
condition, microcontroller has to make sure that data on SDA line must be stable during the ‘high’ period of SCLK. The data should only change
when SCLK line is ‘low’. The Bus is busy after the START condition and it is free after the STOP condition. Any number of data bytes can be
transmitted between START and STOP. Each byte is followed by an acknowledgement (which is the ninth bit). The data transmitter always
receives an acknowledgement from the data receiver at end of each byte. The data transmitter releases the SDA bus at start of ‘low’ period of
8th clock pulse and data receiver acknowledges by pulling the SDA to ‘low’ during the ‘low’ period of the SCLK. The Data receiver releases the
bus at start of ‘low’ period of 9th clock pulse of the SCLK and data transmitter gets the data bus.The AS8650B does not support general call
address, START byte and high-speed mode.
Figure 22. I²C Bus Protocol
SDA
MSB
S
SCLK
1
LSB
2
3
4
5
6
8
7
1
9
3
2
7 bit Slave address
5
6
8
7
9
1
2
3
4
5
6
8
7
S
or
P
9
8 bit Data
8 bit Data
R/W
8.2.1
4
ACK
ACK
ACK
I²C Slave Address
The 7-bit slave address of the device is by default set to 0000000.
On request the slave address can be changed in the range from 0000000 to 1111110 through factory settings.
8.2.2
I²C Write Operation
After the START condition, microcontroller has to send, in the first byte, the 7-bit slave address and 0 into the R/W bit as shown in Figure 23. The
microcontroller has to send the address of the register to be written in the second byte. The first 3 MSB bits are reserved and remaining 5 bits are
used as address bits. The data is sent starting from MSB to LSB. The AS8650B sends acknowledgement on 9th clock pulse. In the next byte
(3rd byte) microcontroller has to send the data to be written into addressed register. If it is a single write operation, after receiving the
acknowledgment from AS8650B, microcontroller has to send START or STOP condition, as shown in Figure 23. In case of auto increment write
operation, microcontroller should not generate START or STOP condition after the third byte. If microcontroller continuously writes then address
pointer rolls back to the starting register address after reaching the last register address. Data bytes coming from the microcontroller are written
at the consecutive address locations, starting from the address sent in first data byte. After each data byte, direction of the bus line changes and
AS8650B acknowledges by pulling the SDA line ‘low’. To terminate the write operation microcontroller has to generate STOP or repeated START
condition. For details, see Figure 24.
Figure 23. I²C Write Operation
acknowledge
from slave
Slave address
A
SDA
MSB
SCLK
S
1
acknowledge
from slave
register address
A4
A3 A2
A1 A0
A
8
9
data to register
acknowledge
from slave
A
LSB
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
1
2
3
4
5
6
7
8
9
S
or
P
R/W
www.ams.com/AS8650
Revision 1.1
35 - 46
AS8650B
Figure 24. I²C Auto-increment Write Operation
acknowledge
From slave
Slave address
SDA
Master
transmitter
SCLK
A
MSB
S
1
acknowledge
From slave
register address
A3 A2
A4
A1 A0
A
8
9
data to register
acknowledge
From slave
data to register + n
A
LSB
2
3
4
5
6
7
8
9
1
2
3
4
5
6
7
1
2
3
4
5
6
8
7
S
or
P
9
R/W
8.2.3
I²C Read Operation
After the START condition, microcontroller has to send, in the first byte, the 7-bit slave address and 0 into the R/W bit as shown in Figure 25. The
used as address bits. The data is sent starting from MSB to LSB. After receiving the acknowledgement on the 9th clock pulse, microcontroller
has to send on the SDA line repeated START or STOP, as shown in Figure 25. If microcontroller sends STOP then microcontroller has to send
START again. If microcontroller sends repeated START then there is no need to generate START again. The microcontroller again has to send
the 7-bit slave address and writes ‘1’ into the R/W bit (8th bit). Now AS8650B sends data of the corresponding addressed register in the next
eight clock cycles. In case of single read, microcontroller does not acknowledge on the 9th clock pulse and generates START or STOP condition
after the ninth clock pulse. If it is an auto increment read operation, microcontroller acknowledges on the 9th clock pulse and AS8650B sends
data from the consecutive address locations, (see Figure 25). If microcontroller continuously reads then address pointer rolls back to the starting
register address after reaching the last register address. In the data phase MSB is sent first and LSB is sent last. After each data byte,
microcontroller has to send the acknowledgement. The microcontroller can terminate the auto read operation by not generating
acknowledgement for the last byte that was sent by the AS8650B and generates STOP or repeated START condition after the 9th clock pulse.
Figure 25. I²C Read Operation
acknowledge
from slave
Slave address
SDA
MSB
SCLK S
1
A
8
9
acknowledge
from slave
register address
A4
A3 A2 A1 A0
A
LSB
2
3
4
5
6
7
1
2
3
4
5
6
7
8
9
S
or
P
W
acknowledge
from slave
SDA
MSB
SCLK S
1
1
A
8
9
acknowledge
from master
Data byte
Slave address
A
LSB
2
3
4
5
6
7
1
2
3
4
5
6
7
8
9
S
or
P
R
www.ams.com/AS8650
Revision 1.1
36 - 46
AS8650B
Figure 26. I²C Auto-increment Read Operation
A
7 8
9
SDA
MSB
SCLK S
1
acknowledge
register address from slave
acknowledge
from slave
Slave address
A
4
LSB
2
3
4
5
6
1
2
3
4
A
3
5
A
2
6
A
1
A
A
7
8
9
S
or
P
W
acknowledge
from slave
Slave address
1
A
7 8
9
SDA
MSB
SCLK S
1
Data byte 1
acknowledge
from master
Last data byte
Data byte n
No
acknowledge
from master
A
A
LSB
2
3
4
5
6
1
2
3
4
5
6
7
8
1
9
2
3
4
5
6
7
8
9
S
or
P
R
Figure 27. Definition of I²C Timing Parameters
SDA
tr
tf
SCLK
tLOW
tr
tf
tSU_DAT
tHD_DAT
tBUF
tSP
S
tHD_STA
www.ams.com/AS8650
tHIGH
tSU_STA
Revision 1.1
Sr
tSU_STO
P
S
37 - 46
AS8650B
8.3 Register Space
The AS8650B register space consists of configuration registers, control registers and diagnostic registers. All of these registers are accessible
through SPI or I²C commands.
Table 21. Configuration Registers
Addr
Register Name
0x00
Reserved
0x01
Reserved
0x02
WD Access Control
Register
POR Value
Bit
Type
Description
Reserved
Reserved
0000_0000
POR_VLDO1
D[7:0]
R/W
0101_1010
01
D[7:6]
WD Configuration Register access Enabled
Else WD Configuration Register access disabled
WD disabled
Else WD enabled
Timeout Watchdog mode Window period Twd_tout_period.
(Accuracy of the timings is ±25%)
D[5:3]
0x03
WD Configuration
Register
0000_1001
POR_VSUP
R/W
000
80 ms
001
160 ms
010
320 ms
011
480 ms
100
800 ms
101
1000 ms
110
2000 ms
111
4000 ms
Window Watchdog mode Window period Twwd_period
(50% of above value is trigger window)
D[2:0]
D[7:1]
0x04
WD Trigger Register
www.ams.com/AS8650
0000_0000
POR_VLDO1
D[0]
000
10 ms
001
40 ms
010
80 ms
011
120 ms
100
160 ms
101
240 ms
110
320 ms
111
400 ms
Reserved
W
Watchdog trigger bit. The microcontroller set this bit within the
required window of watchdog timer. After this internal counter is
reset and this bit is cleared internally.
Revision 1.1
38 - 46
AS8650B
Addr
Register Name
POR Value
Bit
Type
Description
D[7]
D[6]
D[5]
0x05
Device
Configuration
Register
0110_1101
POR_VSUP
D[4]
R/W
D[3]
D[2]
D[1]
LDO3 disable in Standby mode
1
LDO3 enable in Standby mode
LDO3 disable in Receive-only mode
1
LDO3 enable in Receive-only mode
LDO3 disable in Normal mode
1
LDO3 enable in Normal mode
LDO2 disable in Standby mode
1
LDO2 enable in Standby mode
LDO2 disable in Receive-only mode
1
LDO2 enable in Receive-only mode
LDO2 disable in Normal mode
1
LDO2 enable in Normal mode
DCDC disable in Sleep mode
1
DCDC enable in Sleep mode
D[7:6]
Reserved
Device state (Read-only values)
D[5:4]
0x06
Mode Control
Register
0000_0000
POR_VSUP
D[3:2]
R/W
D[1:0]
Device in Standby mode
1
Device in Normal mode
10
Device in Receive-only mode
00
Standby mode
01
Normal mode
10
Receive-only mode
11
Sleep mode
Reserved
D[7:3]
Reserved
D[2]
0x07
Interrupt Register
0000_0000
POR_VSUP
D[1]
No Interrupt
1
Supply Related Interrupt. The source of interrupt is
known by reading Interrupt Source Register 3
No Interrupt
1
Wake-up & temperature Related Interrupt. The
source of interrupt is known by reading Interrupt
Source Register 2
No Interrupt
1
BUS & Local Failure Related Interrupt. The source
of interrupt is known by reading Interrupt Source
Register 1
R
D[0]
www.ams.com/AS8650
Revision 1.1
39 - 46
AS8650B
Addr
Register Name
POR Value
Bit
Type
D[7]
D[6]
Description
No Interrupt
1
Interrupt due to BUS clamped to dominant
No Interrupt
1
Interrupt due to short TxD & RxD pins
D[5]
Reserved
D[4]
0x08
Interrupt Source
Register 1
0000_0000
POR_VSUP
D[3]
R/W
D[2]
D[1]
D[0]
No Interrupt
1
Interrupt due to TxD pin clamped to Dominant
No Interrupt
1
Interrupt due to CANL pin shorted to VCC
No Interrupt
1
Interrupt due to CANL pin shorted to GND
No Interrupt
1
Interrupt due to CANH pin shorted to GND
No Interrupt
1
Interrupt due to CANH pin shorted to VCC
D[7:4]
Reserved
D[3]
0x09
Interrupt Source
Register 2
0000_0000
POR_VSUP
D[2]
D[1]
D[0]
www.ams.com/AS8650
Revision 1.1
No Interrupt
1
Interrupt due to junction temperature falling back
below Tjrecv
No Interrupt
1
Interrupt due to junction temperature exceeding
Tjwarn
No Interrupt
1
Interrupt due to Local Wake up event on WAKE pin
No Interrupt
1
Interrupt due to Wake up by BUS message
(remote wake)
40 - 46
AS8650B
Addr
Register Name
POR Value
Bit
Type
D[7]
D[6]
D[5]
D[4]
0x0A
Interrupt Source
Register 3
0000_0000
POR_VSUP
R/W
D[3]
D[2]
D[1]
D[0]
0x0B
0x0C
0x0D
0x0E
Reserved
BUS Status
Register
Temperature Status
Register
Supply Status
Register
www.ams.com/AS8650
0000_0000
POR_VSUP
0000_0000
POR_VSUP
0000_0000
POR_VSUP
1010_1010
POR_VSUP
Description
No Interrupt
1
Interrupt due to VLDO3_POK_flag set
No Interrupt
1
Interrupt due to VLDO3_UV_flag set
No Interrupt
1
Interrupt due to VLDO2_POK_flag set
No Interrupt
1
Interrupt due to VLDO2_UV_flag set
No Interrupt
1
Interrupt due to V5V_POK_flag set
No Interrupt
1
Interrupt due to V5V_UV_flag set
No Interrupt
1
Interrupt due to VSUP_POK_flag set
No Interrupt
1
Interrupt due to VSUP_UV_flag set
D[7:0]
Reserved
D[7]
D[6]
TxD & RxD pins short
D[4]
D[3]
R
D[2]
D[1]
D[0]
D[7:2]
Reserved
D[1]
R
OTM 140 Recovery flag
D[0]
OTM 160 Warning flag
D[7]
VLDO3_POK_flag
D[6]
VLDO3_UV_flag
D[5]
VLDO2_POK_flag
D[4]
D[3]
R
VLDO2_UV_flag
V5V_POK_flag
D[2]
V5V_UV_flag
D[1]
VSUP_POK_flag
D[0]
VSUP_UV_flag
Revision 1.1
41 - 46
AS8650B
Addr
Register Name
POR Value
Bit
Type
Description
These bits are cleared on microcontroller read
0x0F
RESET Reason
Register
0000_0000
POR_VSUP
D[7]
Reserved
D[6]
Sleep mode exit by Local Wake up on WAKE pin
D[5]
Sleep mode exit by Remote wake
D[4]
R
Window Watchdog failure
D[3]
Timeout Watchdog failure
D[2]
Start-up Watchdog failure
D[1]
Undervoltage on VLDO1
D[0]
OTM Shutdown flag
0x10
D[7:0]
OTP_BITS[32:25] / MCU Backup Data
0x11
D[7:0]
OTP_BITS[40:33] / MCU Backup Data
0x12
D[7:0]
OTP_BITS[48:41] / MCU Backup Data
0x13
0x14
Backup Register
0000_0000
POR_VSUP
D[7:0]
D[7:0]
R/W
OTP_BITS[56:49] / MCU Backup Data
{1’b0, OTP_BITS[63:57]} / MCU Backup Data
0x15
D[7:0]
{2'd0, Slave address[6:1]}/MCU Backup Data
0x16
D[7:0]
10bit_slave_address[3:0]/MCU Backup Data
0x17
D[7:0]
MCU Backup Data
www.ams.com/AS8650
Revision 1.1
42 - 46
AS8650B
Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s
9 Package Drawings and Markings
The device is available in a 36-pin QFN (6x6x0.9) package.
Figure 28. Drawings and Dimensions
18249-03
AS8650B
YYWWXZZ
Symbol
A
A1
A3
L
L1
b
D
E
e
D2
E2
aaa
bbb
ccc
ddd
eee
fff
N
Notes:
Min
0.80
4.60
4.60
Nom
0.90
0.02
0.20 REF
0.40
0.25
6.00 BSC
6.00 BSC
0.50 BSC
4.70
4.70
0.15
0.10
0.10
0.05
0.08
0.10
36
Max
1.00
0.05
0.45
0.15
0.30
1. Dimensions and tolerancing conform to ASME Y14.5M-1994.
2. All dimensions are in millimeters, angle is in degrees.
3. Dimension b applies to metallized terminal and is measured between 0.25mm
and 0.30mm from terminal tip. Dimension L1 represents terminal full back from package edge up to 0.15mm is acceptable.
4. Coplanarity applies to the exposed heat slug as well as the terminal.
5. Radius on terminal is optional.
6. N is the total number of terminals.
4.80
4.80
Marking Description:
YY
WW
X
ZZ
Last two digits of the current year
Manufacturing Week
Assembly plant identifier
Assembly traceability code
Sublot identifier
www.ams.com/AS8650
Revision 1.1
43 - 46
AS8650B
Datasheet - R e v i s i o n H i s t o r y
Revision History
Revision
Date
1.0
28 Mar, 2012
1.1
Jan 11, 2013
Owner
hgl
Description
Initial release for AS8650B
Updated Ordering Information
Note: Typos may not be explicitly mentioned under revision history.
www.ams.com/AS8650
Revision 1.1
44 - 46
AS8650B
Datasheet - O r d e r i n g I n f o r m a t i o n
10 Ordering Information
The devices are available as the standard products shown in Table 22.
1
Table 22. Ordering Information
Ordering Code
Marking
Description
AS8650B-ZQFP-01
AS8650B
AS8650B-ZQFM-01
AS8650B
AS8650B Power Management device with
high-speed CAN Interface
(standard configuration)
Delivery Form
Package
Tape & Reel in Dry Pack
(1 reel = 4000 units)
36-pin QFN
(6x6x0.9)
(1 reel = 1000 units)
36-pin QFN
(6x6x0.9)
1. The AS8650B provides various configuration options during production. For more information, please contact our sales office.
Note: All products are RoHS compliant and ams green.
Buy our products or get free samples online at www.ams.com/ICdirect
Technical Support is available at www.ams.com/Technical-Support
For further information and requests, email us at sales@ams.com
(or) find your local distributor at www.ams.com/distributor
www.ams.com/AS8650
Revision 1.1
45 - 46
AS8650B
Datasheet - C o p y r i g h t s
Copyrights
Copyright © 1997-2013, ams AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights
reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the
copyright owner.
All products and companies mentioned are trademarks or registered trademarks of their respective companies.
Disclaimer
Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. ams AG makes no
warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described
devices from patent infringement. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior
to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in normal
commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability
applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing
by ams AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard
production flow, such as test flow or test location.
The information furnished here by ams AG is believed to be correct and accurate. However, ams AG shall not be liable to recipient or any third
party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or
indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the
technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other
services.
Contact Information
Headquarters
ams AG
A-8141 Unterpremstaetten, Austria
Tel
Fax
: +43 (0) 3136 500 0
: +43 (0) 3136 525 01
For Sales Offices, Distributors and Representatives, please visit:
http://www.ams.com/contact
www.ams.com/AS8650
Revision 1.1
46 - 46
