austriamicrosystems AG
is now
ams AG
The technical content of this austriamicrosystems document is still valid.
Contact information:
Headquarters:
ams AG
Tobelbaderstrasse 30
8141 Unterpremstaetten, Austria
Tel: +43 (0) 3136 500 0
e-Mail: ams_sales@ams.com
Please visit our website at www.ams.com
AS1336 - Demo Board Manual
Step-Up Converter
Demo Board Manual
al
id
AS1336
Te
ch
ni
ca
am
lc s
on A
te G
nt
st
il
www.austriamicrosystems.com/DC-DC_Step-Up/AS1336
lv
Dual, Low Voltage, Micropower DC-DC Step-Up
Converters
Revision 1.00
1-5
Step-Up Converter
General Description
Board Description
H1
D
L
B
C2
E1
E2 J
e1
e2
f1 f2
VIN
GND
VOUT1
VOUT2
am
lc s
on A
te G
nt
st
il
Name
A
B
C1
C2
K1
L
K2
Figure 2: Board Description – Measurement Points
Connector Description
Label
I
lv
Figure 1: Board Description - Connectors
F1 F2
H2
al
id
C1
A
G2
G1
Description
Info
Supply Voltage
Ground
Output Voltage 1
Output Voltage 2
Supply voltage ranging from 0.8V to 3.6V
Output voltage ranging from 1.8V to 3.6V
Measurement Point Description
Name
D
e1
e2
f1
f2
G1
G2
H1
H2
I
J
K1
K2
L
VIN
EN1
EN2
MODE1
MODE2
LX1
LX2
FB1
FB2
LBO
LBI
VOUT1
VOUT2
GND
E2
Info
Measurement Points
ni
ch
EN1
Te
E1
Description
Supply Voltage
Enable 1
Enable 2
Mode 1
Mode 2
External Inductor 1
External Inductor 2
Feedback 1
Feedback 2
Low Battery Comparator Output
Low Battery Comparator Input
Output Voltage 1
Output Voltage 2
Ground
ca
Label
EN2
on: The VOUT1 of AS1336 is enabled
off: The VOUT1 of AS1336 is disabled
Enable 1
No Jumper: Connect a valid enable signal
to “e1”.
on: The VOUT2 of AS1336 is enabled
Enable 2
to “e2”.
on: fixed frequency operation of regulator 1
F1
MODE1
Mode 1
off: autom. Powersafe operation of reg.1
Revision 1.00
2-5
Step-Up Converter
on: fixed frequency operation of regulator 2
MODE2
F2
Mode 2
off: autom. Powersafe operation of reg.2
Getting Started
al
id
The AS1336 Demoboard is designed to work with the AS1336A adjustable output voltage version.
With the resistor divider R1/R2 it is possible to adjust the “Low Battery Comparator Input” threshold.
With the resistor divider R3/R4 it is possible to adjust VOUT1 and with the resistor divider R5/R6 it is possible to
adjust VOUT2.
On this Demoboard the following resistor values are mounted:
R1 = 330k and R2 = 1M VDETECT = 800mV
R3 = 560k and R4 = 180k VOUT1 = 3.3V
R5 = 150k and R6 = 120k VOUT2 = 1.8V
Function
Value
Description
Manufacturer
Cin
Input Capacitor
10µF
0805 / X5R / 6.3V
Murata
Cout1
Output 1 Capacitor
10µF
0805 / X5R / 6.3V
Murata
Mfg. Order Nr.
GRM219R60J106KE19
GRM219R60J106KE19
am
lc s
on A
te G
nt
st
il
Ref.
lv
Bill of Materials
Output 2 Capacitor
10µF
0805 / X5R / 6.3V
Murata
GRM219R60J106KE19
L1
Coil
10µH
456mΩ / 0.7A / 3.2x2.5x1.55mm
Murata
LQH32PN100MN0
L2
Coil
10µH
Murata
LQH32PN100MN0
R1
Resistor (LBI)
330k
0805/ ±1%
Multicomp
MC 0.1W 0805 1% 330K
R2
Resistor (LBI)
1M
0805/ ±1%
Multicomp
MC 0.1W 0805 1% 1M
R3
Resistor (VOUT1)
560k
0805/ ±1%
Multicomp
MC 0.1W 0805 1% 560K
R4
Resistor (VOUT1)
180k
0805/ ±1%
Multicomp
MC 0.1W 0805 1% 180K
R5
Resistor (VOUT2)
150k
0805/ ±1%
Multicomp
MC 0.1W 0805 1% 150K
R6
Resistor (VOUT2)
120k
0805/ ±1%
Multicomp
MC 0.1W 0805 1% 120K
U1
DC/DC Converter
ASSM
TQFN 3x3mm 16-pin
Austriamicrosystems AG
AS1336A-BQFT
Te
ch
ni
ca
Cout2
Revision 1.00
3-5
Step-Up Converter
Layout of Demo Board
Figure 3: Schematics
am
lc s
on A
te G
nt
st
il
lv
al
id
Board schematics and layout
Te
ch
ni
ca
Figure 4: Top + Bottom Layer
Revision 1.00
4-5
Step-Up Converter
Copyright
Copyright © 1997-2010, austriamicrosystems AG, Tobelbaderstraße 30, 8141 Unterpremstätten - Graz, Austria Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted,
merged, translated, stored, or used without the prior written consent of the copyright owner.
All products and companies mentioned are trademarks or registered trademarks of their respective companies.
Disclaimer
ca
am
lc s
on A
te G
nt
st
il
lv
al
id
Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions
appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by
description regarding the information set forth herein or regarding the freedom of the described devices from
patent infringement. Austriamicrosystems AG reserves the right to change specifications and prices at any time
and without notice. Therefore, prior to designing this product into a system, it is necessary to check with
austriamicrosystems AG for current information.
This product is intended for use in normal commercial applications. Applications requiring extended temperature
range, unusual environmental requirements, or high reliability applications, such as military, medical life-support
or life-sustaining equipment are specifically not recommended without additional processing by
austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might
show deviations from the standard production flow, such as test flow or test location.
The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However,
austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not
limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect,
special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing,
performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise
or flow out of austriamicrosystems AG rendering of technical or other services.
ni
Contact Information
Te
ch
Headquarters
Tobelbaderstraße 30
A-8141 Unterpremstätten - Graz, Austria
T. +43 (0) 3136 500 0
F. +43 (0) 3136 5692
For Sales Offices, Distributors and Representatives, please visit:
http://www.austriamicrosystems.com/contact
Revision 1.00
5-5
很抱歉,暂时无法提供与“AS1336A/BEB”相匹配的价格&库存,您可以联系我们找货
