TDPS1000E0E10-KIT
TDPS1000E0E10-KIT
    TRANSPHORM
    1KWHB,BUCKORBOOSTEVALKIT
TDPS1000E0E10-KIT 数据手册
TDPS1000E0E10 Application Note 1. TDPS1000E0E10 Half-Bridge Evaluation Board 1.1 Introduction This half-bridge evaluation board provides the elements of a simple buck or boost converter for basic study of switching characteristics and efficiency achievable with Transphorm’s 600V GaN power switches. In either buck or boost mode the circuit can be configured for synchronous rectification. Jumpers allow use of a single logic input or separate hi/lo inputs. The high-voltage input and output can operate at up to 400Vdc, with a power output of up to 1kW. The inductor provided is intended for efficient operation at 100kHz, although other inductors and other frequencies may be easily used. Fig. 1. Half-Bridge Evaluation Board 1 1/06/2015 jc TDPS1000E0E10 1.2 TDPS1000E0E10 Input/output Specifications: • High-voltage input/output: 400 Vdc maximum • Auxiliary Supply (J1): 10V min, 18V max • Logic inputs: nominal 0-5V; for the pulse-generation circuit, for direct connection to gate driver, SMA coaxial connectors Vlo < 1.5V, Vhi> 3.0V Vlo < 0.8V, Vhi > 2.0V • Switching frequency: configuration dependent lower limit determined by peak inductor current upper limit determined by desired dead time and power dissipation • Power dissipation in HEMTs is limited by maximum junction temperature. Refer to the TPH3006PS data sheet. 1.3 Circuit Description The circuit comprises a simple half bridge featuring two TPH3006PS GaN power transistors, as indicated in the block diagram of Figure 2. Two high-voltage ports are provided which can serve as either input or output, depending on the configuration: boost or buck. In either case one transistor acts as the active power switch while the other carries the freewheeling current. The latter device may be enhanced, as a synchronous rectifier, or not. With GaN power transistors the reverse recovery charge is low and there is no need for additional freewheeling diodes. Two input connectors are provided which can be connected to sources of logic-level command signals for the hi/lo gate driver. Both inputs may be driven by off-board signal sources, or alternatively, a single signal source may be connected to an on-board pulse-generator circuit which generates the two non-overlapping pulses. Jumpers determine how the input signals are used. An inductor is provided as a starting point for investigation. This is a 320uH toroid intended to demonstrate a reasonable compromise between size and efficiency for power up to 1kW at a switching frequency of 100kHz. 2 1/06/2015 jc TDPS1000E0E10 Figure 2: Functional Block Diagram 1.4 Using the board The board can be used for evaluation of basic switching functionality in a variety of circuit configurations. It is not a complete circuit, but rather a building block. It can be used in steadystate DC/DC converter mode with output power up to 1kW. Depending on circuit configuration and desired operating temperature, forced air flow might be required at higher power levels. 1.5 Configurations Figure 3 shows the basic power connections for buck and boost modes. For buck mode, the HVdc input (terminals J2,J3) is connected to the high-voltage supply and the output is taken from terminals J5 and J7. For boost mode the connections are reversed. Note that in boost mode a load must be connected. The load current affects the output voltage up to the transition from DCM to CCM. In buck mode the load may be an open circuit. 3 1/06/2015 jc TDPS1000E0E10 (a) Buck Mode (b) Boost mode Figure 3. Supply and Load connections for Buck (a) and Boost (b) configurations. 4 1/06/2015 jc TDPS1000E0E10 Figure 4 shows possible configurations for the gate-drive signals. In figure 4(a) a single input from an external signal source is used together with the on-board pulse generation circuit. J4 is used, J6 is left open circuit. Jumpers JP1 and JP2 are in the top position, as shown. If the highside transistor is to be the active switch (e.g. buck mode), then the duty cycle of the input source should simply be set to the desired duty cycle (D). If the low-side transistor is to be the active switch (e.g. boost mode) the duty cycle of the input source should be set to (1-D), where D is the desired duty cycle of the low-side switch. This configuration results in synchronous rectification. If it is desired to let the device carrying the freewheeling current act as a diode, then the appropriate jumper should be placed so that the pull-down resistor is connected to the driver. Figure 4(b) shows a buck-mode configuration where the low-side device is not enhanced. Finally, figure 4(c) shows use of two external signal sources as inputs to the gate driver. For any configuration an auxiliary supply voltage of 10V-18V must be supplied at connector J1. Pull-down resistors R5 and R6 have a value of 4.99k. If a 50 ohm signal source is used and 50 ohm termination is desired, then R5 and R6 may be replaced (or paralleled) with 1206 size 50 ohm resistors. (a) 5 1/06/2015 jc TDPS1000E0E10 (b) (c) Figure 4: input configurations. (a) using a single source for either buck or boost mode (b) buck mode without synchronous rectification (c) using two signal sources 1.6 Deadtime control The required form of the gate-drive signals is shown in Figure 5. The times marked A are the deadtimes when neither transistor is driven on. The deadtime must be greater than zero to avoid shoot-through currents. The Si8230BB gate drive chip ensures a minimum deadtime based on the value of resistor R7, connected to the DT input. The deadtime in ns is equal to the resistance 6 1/06/2015 jc TDPS1000E0E10 in kohm x 10: so the default value of 5.7k corresponds to 57ns. This will add to any deadtime already present in the input signals. The on-board pulse generator circuit, for example, creates deadtimes of about the 60ns. The resulting deadtime at the gate pins of Q1 and Q2 is about 120ns. Either shorting or removing R7 will reduce the deadtime to 60ns. Figure 5: Non-overlapping gate pulses 1.7 Design details The detailed circuit schematic is included with this file as a pdf. The parts list follows in table 1. Qty Value 1 1 1 2 2.2uF 450V 2 120ohm Package 529802B02 500G 74LVC1G17 DBV DIODE-DO214AC ECWFD2W225J FB0603 4 1 HS1 U3 D1 C18 Manf Aavid Thermalloy Texas Instruments Fairchild Manf P/N 529802B02500G SN74LVC1G17DBVR ES1J ECW-FD2W225J FB1, FB2 Panasonic TDK J1 Molex 22-23-2021 JP2E KEYSTONE_ 7691 JP1, JP2 FCI 68001-403HLF 7691 LT3082 U1 Keystone Linear Technology 1 2 ID J2, J3, J5, J7 MMZ1608Q121B LT3082EST#PBF 1 320uH TVH49164A L1 CWS 1 .1u C-EUC1812 Kemet 7 .1u C-USC0603 3 .1u C-USC2225K C7 C10, C11, C12, C14, C20, C21, C22 C8, C16, C17 Mag-Inc 77083 core; 63 turns AWG18 C1812V104KDRACTU AVX Vishay 06033C104JAT2A VJ2225Y104KXGAT 7 1/06/2015 jc TDPS1000E0E10 1 1 1 2 1 2 2 1 1 5.76k 0 10 100pF 10MEG 10u 1k 1u 2.2u 1 1 3 3 1 0.68uF 630V 22u 4.7n 4.99k 499k 2 74AHC1G86DBV 2 BAT54W 2 1 BU-SMA-G SI8230 2 TPH3006PS 2 TPSPAD1-13 Q1 insulator (high side) Q2 insulator (low side) 1 1 R-US_R0603 R-US_R1206 R-US_R0805 C-USC0603 R-US_R1206 C-EUC0805 R-US_R0603 C-EUC0805 C-EUC0805 B32922C36 84M C-USC1206 C-EUC1206 R-US_R1206 R-US_R1206 74AHC1G86 DBV BAT54W R7 R9 R4 C19, C23 R3 C13, C15 R8, R10 C2 C3 Yageo Panasonic Panasonic AVX Stackpole Kemet Yageo Yageo TDK RC0603FR-075K76L ERJ-8GEY0R00V ERJ-6GEYJ100V 06035A101FAT2A HVCB1206FKC10M0 C0805C106M4PACTU RC0603FR-071KL CC0805ZRY5V8BB105 C2012X5R1E225K125AC C9 C1 C4, C5, C6 R1, R5, R6 R2 B32922C3684M C3225X7R1C226K250AC C1206C472KDRACTU RMCF1206FT4K99 RMCF1206FT499K D2, D3 EPCOS TDK Kemet Stackpole Stackpole Texas Instruments NXP BU-SMA-G SI8230 TPH_TO220 VERT_TRI TPSPAD1-13 J4, J6 U2 Molex Silicon Labs 731000114 SI8230BB-B-IS1 Q1, Q2 Transphorm TPH3006PS U4, U5 TP1, TP3 SN74AHC1G86DBVR BAT54W (TP2, TP4, TP5 DNI) Bergquist SP2000-0.015-00-54 Aavid Thermalloy 53-77-9G Table 1. Bill of Materials for the half-bridge Evaluation Board 8 1/06/2015 jc TDPS1000E0E10 (a) PCB: Top and Bottom Layers (b) PCB: Inner Layer 2, Ground Plane 9 1/06/2015 jc TDPS1000E0E10 (c) PCB: Inner Layer 3: Power Plane Figure 7: PCB layers 1.7 Probing Plated-through holes labeled test points 4 and 5 (TP4, TP5) are provided for probing the switching waveform. In order to minimize inductance during measurement, the tip and the ground of the probe should be directly attached to the sensing points to minimize the sensing loop. For safe, reliable and accurate measurement, a scope probe tip may be directly soldered to TP4 and a short ground wire soldered to TP5. Figure 8 indicates an alternative which does not require soldering the probe tip. WARNINGS: There is no specific protection against over-current or over-voltage on this board. If the on-board pulse generation circuit is used in boost mode, a zero input corresponds to 100% duty cycle for the active low-side switch. 10 1/06/2015 jc TDPS1000E0E10 Fig. 8. Low-inductance probing of fast, high-voltage signals Efficiency has been measured for this circuit in boost mode with 200Vdc in and 400Vdc out, switching at 100kHz. 99 Efficiency (%) 98.5 98 97.5 97 96.5 96 0 200 400 600 800 1000 1200 Output Power (W) Figure 9: efficiency for a boost 200V:400V converter 11 1/06/2015 jc
TDPS1000E0E10-KIT 价格&库存
很抱歉,暂时无法提供与“TDPS1000E0E10-KIT”相匹配的价格&库存,您可以联系我们找货
