BOB-10616
BOB-10616
    SPARKFUNELECTRONICS
    TLC5940 LED Driver Evaluation Board
BOB-10616 数据手册
TLC5940 PWP www.ti.com RHB NT SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 16 CHANNEL LED DRIVER WITH DOT CORRECTION AND GRAYSCALE PWM CONTROL FEATURES APPLICATIONS • 16 Channels • 12 bit (4096 Steps) Grayscale PWM Control • Dot Correction – 6 bit (64 Steps) – Storable in Integrated EEPROM • Drive Capability (Constant-Current Sink) – 0 mA to 60 mA (VCC < 3.6 V) – 0 mA to 120 mA (VCC > 3.6 V) • LED Power Supply Voltage up to 17 V • VCC = 3 V to 5.5 V • Serial Data Interface • Controlled In-Rush Current • 30MHz Data Transfer Rate • CMOS Level I/O • Error Information – LOD: LED Open Detection – TEF: Thermal Error Flag • • • • 1 2 VCC GND SCLK DESCRIPTION The TLC5940 is a 16-channel, constant-current sink LED driver. Each channel has an individually adjustable 4096-step grayscale PWM brightness control and a 64-step, constant-current sink (dot correction). The dot correction adjusts the brightness variations between LED channels and other LED drivers. The dot correction data is stored in an integrated EEPROM. Both grayscale control and dot correction are accessible via a serial interface. A single external resistor sets the maximum current value of all 16 channels. The TLC5940 features two error information circuits. The LED open detection (LOD) indicates a broken or disconnected LED at an output terminal. The thermal error flag (TEF) indicates an overtemperature condition. SIN XLAT VPRG IREF Max. OUTn Current VREF =1.24 V VPRG 1 DCPRG CNT 1 0 GS Register 0 DCPRG 1 DC Register 0 GS Counter CNT 5 LED Open Detection CNT 192 12−Bit Grayscale PWM Control GS Register 12 23 DCPRG 1 96 95 1 0 VPRG 96 6 DC EEPROM11 Temperature Error Flag (TEF) 0 Constant Current Driver OUT1 Delay x1 LED Open Detection VPRG CNT Blank 1 6−Bit Dot Correction DC Register 11 0 6 96 LED Open Detection (LOD) OUT0 Delay x0 VPRG 96 192 Constant Current Driver 6−Bit Dot Correction 0 0 DC EEPROM 5 Input Shift Register Status 0 Information: LOD, TED, DC DATA 191 12−Bit Grayscale PWM Control 11 0 0 GSCLK BLANK Monocolor, Multicolor, Full-Color LED Displays LED Signboards Display Backlighting General, High-Current LED Drive Input Shift Register 12−Bit Grayscale PWM Control GS Register 180 191 DCPRG 1 XERR 90 191 90 SOUT DC Register 95 0 DC EEPROM 95 Constant Current Driver OUT15 Delay x15 6−Bit Dot Correction LED Open Detection VPRG 1 2 Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. PowerPAD is a trademark of Texas Instruments. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. Copyright © 2004–2007, Texas Instruments Incorporated TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. ORDERING INFORMATION PACKAGE (1) PART NUMBER 28-pin HTSSOP PowerPAD™ TLC5940PWP 32-pin 5mm x 5mm QFN TLC5940RHB 28-pin PDIP TLC5940NT TA –40°C to 85°C (1) For the most current package and ordering information, see the Package Option Addendum at the end of this document, or see the TI website at www.ti.com. ABSOLUTE MAXIMUM RATINGS. over operating free-air temperature range (unless otherwise noted) (1) UNIT VI Input voltage range (2) IO Output current (dc) VI Input voltage range VO VCC –0.3V to 6V 130mA Output voltage range EEPROM program range V(BLANK), V(DCPRG), V(SCLK), V(XLAT), V(SIN), V(GSCLK), V(IREF) –0.3V to VCC +0.3V V(SOUT), V(XERR) –0.3V to VCC +0.3V V(OUT0) to V(OUT15) –0.3V to 18V V(VPRG) –0.3V to 24V EEPROM write cycles 50 ESD rating HBM (JEDEC JESD22-A114, Human Body Model) 2kV CBM (JEDEC JESD22-C101, Charged Device Model) 500V Tstg Storage temperature range TA Operating ambient temperature range Package thermal impedance (1) (2) (3) (4) 2 –55°C to 150°C (3) –40°C to 85°C HTSSOP (PWP) (4) 31.58°C/W QFN (RHB) 35.9°C/W PDIP (NP) 48°C/W Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute maximum rated conditions for extended periods may affect device reliability. All voltage values are with respect to network ground terminal. The package thermal impedance is calculated in accordance with JESD 51-7. With PowerPAD soldered on PCB with 2 oz. (56,7 grams) trace of copper. See SLMA002 for further information. Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 RECOMMENDED OPERATING CONDITIONS MIN NOM MAX UNIT DC CHARACTERISTICS VCC Supply Voltage VO Voltage applied to output (OUT0–OUT15) 3 VIH High-level input voltage VIL Low-level input voltage IOH High-level output current VCC = 5V at SOUT IOL Low-level output current VCC = 5V at SOUT, XERR 5.5 V 17 V 0.8 VCC VCC V GND 0.2 VCC V –1 mA 1 mA OUT0 to OUT15, VCC < 3.6V 60 mA OUT0 to OUT15, VCC > 3.6V 120 mA 23 V 85 °C IOLC Constant output current V(VPRG) EEPROM program voltage TA Operating free-air temperature range 20 22 -40 AC CHARACTERISTICS VCC = 3 V to 5.5 V, TA = –40°C to 85°C (unless otherwise noted) f(SCLK) Data shift clock frequency SCLK 30 MHz f(GSCLK) Grayscale clock frequency GSCLK 30 MHz twh0/twl0 SCLK pulse duration SCLK = H/L (see Figure 11) 16 ns twh1/twl1 GSCLK pulse duration GSCLK = H/L (see Figure 11) 16 ns twh2 XLAT pulse duration XLAT = H (see Figure 11) 20 ns twh3 BLANK pulse duration BLANK = H (see Figure 11) 20 ns 5 ns tsu0 SIN to SCLK ↑ (1) (see Figure 11) tsu1 SCLK ↓ to XLAT ↑ (see Figure 11) 10 ns tsu2 VPRG ↑ ↓ to SCLK ↑ (see Figure 11) 10 ns VPRG ↑ ↓XLAT ↑ (see Figure 11) 10 ns tsu4 BLANK ↓ to GSCLK ↑ (see Figure 11) 10 ns tsu5 XLAT ↑ to GSCLK ↑ (see Figure 11) 30 ns tsu6 VPRG ↑ to DCPRG ↑ (see Figure 16) 1 ms th0 SCLK ↑ to SIN (see Figure 11) 3 ns th1 XLAT ↓ to SCLK ↑ (see Figure 11) 10 ns th2 SCLK ↑ to VPRG ↑ ↓ (see Figure 11) 10 ns XLAT ↓ to VPRG ↑ ↓ (see Figure 11) 10 ns th4 GSCLK ↑ to BLANK ↑ (see Figure 11) 10 ns th5 DCPRG ↓ to VPRG ↓ (see Figure 11) 1 ms tprog Programming time for EEPROM (see Figure 16) 20 ms tsu3 Hold Time th3 (1) Setup time ↑ and ↓ indicates a rising edge, and a falling edge respectively. DISSIPATION RATINGS (1) PACKAGE POWER RATING TA < 25°C DERATING FACTOR ABOVE TA = 25°C POWER RATING TA = 70°C POWER RATING TA = 85°C 28-pin HTSSOP with PowerPAD™ (1)soldered 3958mW 31.67mW/C 2533mW 2058mW 28-pin HTSSOP with PowerPAD™ unsoldered 2026mW 16.21mW/°C 1296mW 1053mW 32-pin QFN (1) 3482mW 27.86mW/°C 2228mW 1811mW 28-pin PDIP 2456mW 19.65mW/°C 1572mW 1277mW The PowerPAD is soldered to the PCB with a 2 oz. (56,7 grams) copper trace. See SLMA002 for further information. Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 3 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 ELECTRICAL CHARACTERISTICS VCC = 3 V to 5.5 V, TA = –40°C to 85°C (unless otherwise noted) PARAMETER TEST CONDITIONS VOH High-level output voltage IOH = -1mA, SOUT VOL Low-level output voltage IOL = 1mA, SOUT II Input current MIN TYP Supply current VI = VCC or GND; BLANK, DCPRG, GSCLK, SCLK, SIN, XLAT –1 1 VI = GND; VPRG –1 1 µA 50 4 10 No data transfer, all output OFF, VO = 1V, R(IREF) = 10kΩ 0.9 6 No data transfer, all output OFF, VO = 1V, R(IREF) = 1.3kΩ 5.2 12 Data transfer 30MHz, all output ON, VO = 1V, R(IREF) = 1.3kΩ 16 25 Data transfer 30MHz, all output ON, VO = 1V, R(IREF) = 640Ω 30 60 61 69 mA 0.1 µA Constant sink current (see Figure 2) All output ON, VO = 1V, R(IREF) = 640Ω Ilkg Leakage output current All output OFF, VO = 15V, R(IREF) = 640Ω, OUT0 to OUT15 ΔIO(LC0) V VI = 22V; VPRG; DCPRG = VCC IO(LC) Constant sink current error (see Figure 2) UNIT V 0.5 VI = VCC; VPRG ICC MAX VCC –0.5 mA mA 54 All output ON, VO = 1V, R(IREF) = 640Ω, OUT0 to OUT15, –20°C to 85°C 1 ±4 All output ON, VO = 1V, R(IREF) = 640Ω, OUT0 to OUT15 (1) 1 8 All output ON, VO = 1V, R(IREF) = 320Ω, OUT0 to OUT15, –20°C to 85°C 1 6 All output ON, VO = 1V, R(IREF) = 320Ω, VCC = 4.5V to 5.5V, OUT0 to OUT15 (1) ±1 ±8 % ΔIO(LC1) Constant sink current error (see Figure 2) Device to device, Averaged current from OUT0 to OUT15, R(IREF) = 1920Ω (20mA) (2) –2 +0.4 4 % ΔIO(LC2) Constant sink current error (see Figure 2) Device to device, Averaged current from OUT0 to OUT15, R(IREF) = 480Ω (80mA) (2) –2.7 +2 ±4 % All output ON, VO = 1V, R(IREF) = 640Ω OUT0 to OUT15, VCC = 3V to 5.5V (3) 1 ±4 %/V All output ON, VO = 1V, R(IREF) = 320Ω , OUT0 to OUT15, VCC = 3V to 5.5V (3) ±1 ±6 %/V All output ON, VO = 1V to 3V, R(IREF) = 640Ω, OUT0 to OUT15 (4) ±2 ±6 %/V All output ON, VO = 1V to 3V, R(IREF) = 320Ω, OUT0 to OUT15 (4) 2 8 %/V ΔIO(LC3) ΔIO(LC4) Line regulation (see Figure 2) Load regulation (see Figure 2) T(TEF) Thermal error flag threshold V(LED) LED open detection threshold V(IREF) Reference voltage output (1) (2) (3) (4) (5) 4 Junction temperature (5) R(IREF) = 640Ω 150 1.20 170 C 0.3 0.4 V 1.24 1.28 V The deviation of each output from the average of OUT0-15 constant current. It is calculated by Equation 1 in Table 1. The deviation of average of OUT1-15 constant current from the ideal constant-current value. It is calculated by Equation 2 in Table 1. The ideal current is calculated by Equation 3 in Table 1. The line regulation is calculated by Equation 4 in Table 1. The load regulation is calculated by Equation 5 in Table 1. Not tested. Specified by design Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 Table 1. Test Parameter Equations D(%) = D(%) = I OUTn - I OUTavg _ 0 -15 IOUTavg _ 0 -15 IOUTavg - I OUT (IDEAL ) I OUT (IDEAL ) ´ 100 (1) ´ 100 (2) æ 1.24 V ö ÷÷ IOUT (IDEAL ) = 31.5 ´ çç è R IREF ø D(% / V ) = D(% / V ) = (3) (IOUTn at VCC = 5.5 V ) - (I OUTn at VCC = 3.0 V ) 100 ´ (I OUTn at VCC = 3.0 V ) 2.5 (4) (IOUTn at VOUTn = 3.0 V ) - (IOUTn at VOUTn = 1.0 V ) 100 ´ (IOUTn at VOUTn = 1.0 V ) 2 .0 (5) SWITCHING CHARACTERISTICS VCC = 3V to 5.5V, TA = -40°C to 85°C (unless otherwise noted) PARAMETER tr0 tr1 tf0 tf1 Rise time Fall time TEST CONDITIONS MIN TYP SOUT MAX 16 OUTn, VCC = 5V, TA = 60°C, DCn = 3Fh 10 SOUT 30 16 OUTn, VCC = 5V, TA = 60°C, DCn = 3Fh 10 30 UNIT ns ns tpd0 SCLK to SOUT (see Figure 11) 30 ns tpd1 BLANK to OUT0 60 ns tpd2 OUTn to XERR (see Figure 11 ) 1000 ns tpd3 Propagation delay time GSCLK to OUT0 (see Figure 11 ) 60 ns tpd4 XLAT to IOUT (dot correction) (see Figure 11 ) 60 ns tpd5 DCPRG to OUT0 (see Figure 11) 30 ns 20 30 ns –50 –90 ns td Output delay time OUTn to OUT(n+1) (see Figure 11 ) ton-err Output on-time error touton– Tgsclk (see Figure 11), GSn = 01h, GSCLK = 11 MHz 10 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 5 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 DEVICE INFORMATION PWP PACKAGE (TOP VIEW) GND BLANK XLAT SCLK SIN VPRG OUT0 OUT1 OUT2 OUT3 OUT4 OUT5 OUT6 OUT7 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Thermal PAD NT PACKAGE (TOP VIEW) 28 27 26 25 24 23 22 21 20 19 18 17 16 15 VCC IREF DCPRG GSCLK SOUT XERR OUT15 OUT14 OUT13 OUT12 OUT11 OUT10 OUT9 OUT8 OUT1 1 28 OUT0 OUT2 2 27 VPRG OUT3 3 26 SIN OUT4 4 25 SCLK OUT5 5 24 XLAT OUT6 6 23 BLANK OUT7 7 22 GND OUT8 8 21 VCC OUT9 9 20 IREF OUT10 10 19 DCPRG OUT11 11 18 GSCLK OUT12 12 17 SOUT OUT13 13 16 XERR OUT14 14 15 OUT15 OUT14 OUT13 OUT12 OUT11 20 18 17 OUT15 21 19 SOUT XERR 23 22 GSCLK 24 RHB PACKAGE (TOP VIEW) DCPRG 25 16 OUT10 IREF 26 15 OUT9 VCC 27 14 OUT8 13 NC NC 28 THERMAL PAD OUT6 9 OUT5 OUT4 8 10 32 OUT3 7 31 XLAT OUT2 6 BLANK OUT1 5 OUT7 OUT0 4 NC 11 SIN 2 12 30 VPRG 3 29 SCLK 1 NC GND NC − No internal connection 6 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 TERMINAL FUNCTION TERMINAL NAME NO. I/O DESCRIPTION DIP PWP RHB BLANK 23 2 31 I Blank all outputs. When BLANK = H, all OUTn outputs are forced OFF. GS counter is also reset. When BLANK = L, OUTn are controlled by grayscale PWM control. DCPRG 19 26 25 I Switch DC data input. When DCPRG = L, DC is connected to EEPROM. When DCPRG = H, DC is connected to the DC register. DCPRG also controls EEPROM writing, when VPRG = V(PRG). EEPROM data = 3Fh (default) GND 22 1 30 G Ground GSCLK 18 25 24 I Reference clock for grayscale PWM control IREF 20 27 26 I Reference current terminal NC – – 12, 13, 28, 29 OUT0 28 7 4 O Constant current output OUT1 1 8 5 O Constant current output OUT2 2 9 6 O Constant current output OUT3 3 10 7 O Constant current output OUT4 4 11 8 O Constant current output OUT5 5 12 9 O Constant current output OUT6 6 13 10 O Constant current output OUT7 7 14 11 O Constant current output OUT8 8 15 14 O Constant current output OUT9 9 16 15 O Constant current output OUT10 10 17 16 O Constant current output OUT11 11 18 17 O Constant current output OUT12 12 19 18 O Constant current output OUT13 13 20 19 O Constant current output OUT14 14 21 20 O Constant current output OUT15 15 22 21 O Constant current output SCLK 25 4 1 I Serial data shift clock SIN 26 5 2 I Serial data input SOUT 17 24 23 O Serial data output VCC 21 28 27 I Power supply voltage VPRG 27 6 3 I Multifunction input pin. When VPRG = GND, the device is in GS mode. When VPRG = VCC, the device is in DC mode. When VPRG = V(VPRG), DC register data can programmed into DC EEPROM with DCPRG=HIGH. EEPROM data = 3Fh (default) XERR 16 23 22 O Error output. XERR is an open-drain terminal. XERR goes L when LOD or TEF is detected. XLAT 24 3 32 I Level triggered latch signal. When XLAT = high, the TLC5940 writes data from the input shift register to either GS register (VPRG = low) or DC register (VPRG = high). When XLAT = low, the data in GS or DC register is held constant. No connection Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 7 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 PARAMETER MEASUREMENT INFORMATION PIN EQUIVALENT INPUT AND OUTPUT SCHEMATIC DIAGRAMS Resistor values are equivalent resistances, and they are not tested. INPUT EQUIVALENT CIRCUIT (BLANK, XLAT, SCLK, SIN, GSCLK, DCPRG) OUTPUT EQUIVALENT CIRCUIT (SOUT) VCC VCC 23 W 400 W INPUT SOUT 23 W GND GND INPUT EQUIVALENT CIRCUIT (IREF) V(IREF) OUTPUT EQUIVALENT CIRCUIT (XERR) VCC _ 400 W INPUT 23 W Amp XERR + 100 W GND GND INPUT EQUIVALENT CIRCUIT (VCC) OUTPUT EQUIVALENT CIRCUIT (OUT) INPUT OUT GND INPUT EQUIVALENT CIRCUIT (VPRG) INPUT GND GND Figure 1. Input and Output Equivalent Circuits 8 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 PARAMETER MEASUREMENT INFORMATION (continued) tr0, tf0, tpd0 tr1, tf1, tpd1, tpd2, tpd3, tpd4, tpd5, td VO = 4V Testpoint SOUT RL = 51W CL = 15pF Testpoint OUTn CL = 15pF IO(LC), DIO(LC0), DIO(LC1), DIO(LC2), DIO(LC3) OUTn DIO(LC4) OUTn VO = 1V VO = 1V to 3V V(IREF) tpd3 VCC Testpoint IREF R (IREG) = 640W 470kΩ XERR Figure 2. Parameter Measurement Circuits Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 9 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 TYPICAL CHARACTERISTICS REFERENCE RESISTOR vs OUTPUT CURRENT POWER DISSIPATION RATE vs FREE-AIR TEMPERATURE 4k 10 k TLC5940PWP PowerPAD Soldered Power Dissipation Rate - mW Reference Resistor, R(IREF) - W 7.68 kΩ 1.92 kΩ 1k 0.96 kΩ 0.64 kΩ 0.48 kΩ 0.38 kΩ 0.32 kΩ 100 0 20 40 60 80 100 TLC5940RHB 3k TLC5940NT 2k TLC5940PWP PowerPAD Unsoldered 1k 0 -40 120 -20 IO − Output Current − mA 80 60 100 TA − Free-Air Temperature − C Figure 4. OUTPUT CURRENT vs OUTPUT VOLTAGE OUTPUT CURRENT vs OUTPUT VOLTAGE 65 TA = 25°C, VCC = 5 V IO = 120 mA IO = 60 mA, VCC = 5 V 64 TA = 85°C 63 IO = 100 mA IO - Output Current - mA IO - Output Current - mA 40 Figure 3. 100 IO = 80 mA 80 IO = 60 mA 60 IO = 40 mA 40 62 61 60 TA = 25°C TA = -40°C 59 58 IO = 20 mA 57 IO = 5 mA 56 20 55 0 0 0.5 1 1.5 2 VO - Output Voltage - V 2.5 3 0 0.5 1 1.5 2 2.5 3 VO - Output Voltage - V Figure 5. 10 20 o 140 120 0 Figure 6. Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 TYPICAL CHARACTERISTICS (continued) CONSTANT OUTPUT CURRENT, ΔIOLC vs AMBIENT TEMPERATURE CONSTANT OUTPUT CURRENT, ΔIOLC vs OUTPUT CURRENT 8 8 TA = 25°C, VCC = 5 V 6 6 Δ IOLC - Constant Output Current - % Δ IOLC - Constant Output Current - % IO = 60 mA 4 VCC = 3.3 V 2 0 -2 VCC = 5 V -4 -6 -8 -40 0 20 40 60 80 TA - Ambient Temperature - °C 0 -2 -4 -6 0 100 20 40 60 IO - Output Current - mA 80 Figure 7. Figure 8. OUTPUT CURRENT vs DOT CORRECTION LINEARITY (ABS VALUE) OUTPUT CURRENT vs DOT CORRECTION LINEARITY (ABS VALUE) 70 TA = 25°C, VCC = 5 V IO = 60 mA, VCC = 5 V IO = 120 mA 60 100 IO = 80 mA 80 IO = 60 mA 60 40 IO = 30 mA 20 IO - Output Current - mA IO - Output Current - mA 2 -8 -20 140 120 4 TA = 25°C TA = 85°C 50 TA = -40°C 40 30 20 10 IO = 5 mA 0 0 0 10 20 30 40 50 Dot Correction Data - dec 60 70 0 Figure 9. 10 20 30 40 50 Dot Correction Data - dec Figure 10. 60 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 70 11 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 PRINCIPLES OF OPERATION SERIAL INTERFACE The TLC5940 has a flexible serial interface, which can be connected to microcontrollers or digital signal processors in various ways. Only 3 pins are needed to input data into the device. The rising edge of SCLK signal shifts the data from the SIN pin to the internal register. After all data is clocked in, a high-level pulse of XLAT signal latches the serial data to the internal registers. The internal registers are level-triggered latches of XLAT signal. All data are clocked in with the MSB first. The length of serial data is 96 bit or 192 bit, depending on the programming mode. Grayscale data and dot correction data can be entered during a grayscale cycle. Although new grayscale data can be clocked in during a grayscale cycle, the XLAT signal should only latch the grayscale data at the end of the grayscale cycle. Latching in new grayscale data immediately overwrites the existing grayscale data. Figure 11 shows the timing chart. More than two TLC5940s can be connected in series by connecting an SOUT pin from one device to the SIN pin of the next device. An example of cascading two TLC5940s is shown in Figure 12 and the timing chart is shown in Figure 13. The SOUT pin can also be connected to the controller to receive status information from TLC5940 as shown in Figure 22. VPRG DC Data Input Mode GS Data Input Mode th3 tsu3 twh2 XLAT 1st GS Data Input Cycle DC MSB SIN th2 SCLK GS1 LSB tsu2 GS2 MSB GS2 LSB th1 tsu1 1 96 1 2nd GS Data Input Cycle GS1 MSB DC LSB GS3 MSB tsu0 twh0 192 193 th0 193 192 1 tpd0 twl0 - SOUT DC MSB - GS1 MSB - 1 SID1 SID1 MSB MSB-1 SID2 SID2 MSB MSB-1 SID1 GS2 LSB MSB twh3 BLANK 1st GS Data Output Cycle tsu5 GSCLK 2nd GS Data Output Cycle 1 tpd4 4096 1 tpd3 tpd1 Tgsclk tpd3 OUT0 (current) td tpd1 + td twh1 tsu4 th4 tpd3 + td twl1 touton OUT1 (current) 15 x td tpd1 + 15 x td OUT15 (current) tpd2 XERR Figure 11. Serial Data Input Timing Chart SIN(a) SIN SOUT TLC5940 (a) SIN SOUT SOUT(b ) TLC5940 (b) SCLK, XLAT, BLANK, GSCLK, DCPRG, VPRG Figure 12. Cascading Two TLC5940 Devices 12 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 VPRG XLAT SIN(a ) SCLK DCb MSB DCa LSB GSb1 MSB 1 192 1 384 96X2 - SOUT(b ) GSb2 MSB GSa1 LSB 385 GSa2 LSB GSb3 MSB 385 384 1 1 192X2 DCb MSB - SIDb1 SIDb1 MSB MSB-1 GSb1 MSB - SIDa1 LSB SIDb2 SIDb2 MSB MSB-1 GSb2 MSB BLANK 1 GSCLK 1 4096 OUT0 (current) OUT1 (current) OUT15 (current) XERR Figure 13. Timing Chart for Two Cascaded TLC5940 Devices ERROR INFORMATION OUTPUT The open-drain output XERR is used to report both of the TLC5940 error flags, TEF and LOD. During normal operating conditions, the internal transistor connected to the XERR pin is turned off. The voltage on XERR is pulled up to VCC through an external pullup resistor. If TEF or LOD is detected, the internal transistor is turned on, and XERR is pulled to GND. Since XERR is an open-drain output, multiple ICs can be OR'ed together and pulled up to VCC with a single pullup resistor. This reduces the number of signals needed to report a system error (see Figure 22). To differentiate LOD and TEF signal from XERR pin, LOD can be masked out with BLANK = HIGH. Table 2. XERR Truth Table ERROR CONDITION ERROR INFORMATION TEMPERATURE OUTn VOLTAGE TEF LOD TJ < T(TEF) Don't Care L X TJ > T(TEF) Don't Care H X OUTn > V(LED) L L OUTn < V(LED) L H OUTn > V(LED) H L OUTn < V(LED) H H TJ < T(TEF) TJ > T(TEF) SIGNALS BLANK XERR H H L H L L L L TEF: THERMAL ERROR FLAG The TLC5940 provides a temperature error flag (TEF) circuit to indicate an overtemperature condition of the IC. If the junction temperature exceeds the threshold temperature (160C typical), TEF becomes H and XERR pin goes to low level. When the junction temperature becomes lower than the threshold temperature, TEF becomes L and XERR pin becomes high impedance. TEF status can also be read out from the TLC5940 status register. Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 13 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 LOD: LED OPEN DETECTION The TLC5940 has an LED-open detector that detects broken or disconnected LEDs. The LED open detector pulls the XERR pin to GND when an open LED is detected. XERR and the corresponding error bit in the Status Information Data is only active under the following open-LED conditions. 1. OUTn is on and the time tpd2 (1 µs typical) has passed. 2. The voltage of OUTn is < 0.3V (typical) The LOD status of each output can be also read out from the SOUT pin. See STATUS INFORMATION OUTPUT section for details. The LOD error bits are latched into the Status Information Data when XLAT returns to a low after a high. Therefore, the XLAT pin must be pulsed high then low while XERR is active in order to latch the LOD error into the Status Information Data for subsequent reading via the serial shift register. DELAY BETWEEN OUTPUTS The TLC5940 has graduated delay circuits between outputs. These circuits can be found in the constant current driver block of the device (see the functional block diagram). The fixed-delay time is 20ns (typical), OUT0 has no delay, OUT1 has 20ns delay, and OUT2 has 40ns delay, etc. The maximum delay is 300ns from OUT0 to OUT15. The delay works during switch on and switch off of each output channel. These delays prevent large inrush currents which reduces the bypass capacitors when the outputs turn on. OUTPUT ENABLE All OUTn channels of the TLC5940 can be switched off with one signal. When BLANK is set high, all OUTn channels are disabled, regardless of logic operations of the device. The grayscale counter is also reset. When BLANK is set low, all OUTn channels work under normal conditions. If BLANK goes low and then back high again in less than 300ns, all outputs programmed to turn on still turn on for either the programmed number of grayscale clocks, or the length of time that the BLANK signal was low, which ever is lower. For example, if all outputs are programmed to turn on for 1ms, but the BLANK signal is only low for 200ns, all outputs still turn on for 200ns, even though some outputs are turning on after the BLANK signal has already gone high. Table 3. BLANK Signal Truth Table BLANK OUT0 - OUT15 LOW Normal condition HIGH Disabled SETTING MAXIMUM CHANNEL CURRENT The maximum output current per channel is programmed by a single resistor, R(IREF), which is placed between IREF pin and GND pin. The voltage on IREF is set by an internal band gap V(IREF) with a typical value of 1.24V. The maximum channel current is equivalent to the current flowing through R(IREF) multiplied by a factor of 31.5. The maximum output current per channel can be calculated by Equation 6: V (IREF) I max + 31.5 R (IREF) (6) where: V(IREF) = 1.24 V R(IREF) = User-selected external resistor. Imax must be set between 5 mA and 120 mA. The output current may be unstable if Imax is set lower than 5 mA. Output currents lower than 5 mA can be achieved by setting Imax to 5 mA or higher and then using dot correction. Figure 3 shows the maximum output current IO versus R(IREF). R(IREF) is the value of the resistor between IREF terminal to GND, and IO is the constant output current of OUT0 to OUT15. A variable power supply may be connected to the IREF pin through a resistor to change the maximum output current per channel. The maximum output current per channel is 31.5 times the current flowing out of the IREF pin. 14 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 POWER DISSIPATION CALCULATION The device power dissipation must be below the power dissipation rating of the device package to ensure correct operation. Equation 7 calculates the power dissipation of device: DC n x dPWM x N PD = VCC x ICC + VOUT x IMAX x 63 (7) ( ) ( ) where: VCC: device supply voltage ICC: device supply current VOUT: TLC5940 OUTn voltage when driving LED current IMAX: LED current adjusted by R(IREF) Resistor DCn: maximum dot correction value for OUTn N: number of OUTn driving LED at the same time dPWM: duty cycle defined by BLANK pin or GS PWM value OPERATING MODES The TLC5940 has operating modes depending on the signals DCPRG and VPRG. Table 4 shows the available operating modes. The TPS5940 GS operating mode (see Figure 11) and shift register values are not defined after power up. One solution to solve this is to set dot correction data after TLS5940 power-up and switch back to GS PWM mode. The other solution is to overflow the input shift register with 193 bits of dummy data and latch it while TLS540 is in GS PWM mode. The values in the input shift register, DC register and GS register are unknown just after power on. The DC and GS register values should be properly stored through the serial interface before starting the operation. Table 4. TLC5940 Operating Modes Truth Table SIGNAL DCPRG L H L H INPUT SHIFT REGISTER MODE GND 192 bit Grayscale PWM Mode VCC 96 bit Dot Correction Data Input Mode V(VPRG) X EEPROM Programming Mode VPRG DC VALUE EEPROM DC Register EEPROM DC Register L H EEPROM Write dc register value to EEPROM. (Default data: 3Fh) SETTING DOT CORRECTION The TLC5940 has the capability to fine adjust the output current of each channel OUT0 to OUT15 independently. This is also called dot correction. This feature is used to adjust the brightness deviations of LEDs connected to the output channels OUT0 to OUT15. Each of the 16 channels can be programmed with a 6-bit word. The channel output can be adjusted in 64 steps from 0% to 100% of the maximum output current Imax. Dot correction for all channels must be entered at the same time. Equation 8 determines the output current for each output n: I + I max DCn OUTn 63 (8) where: Imax = the maximum programmable output current for each output. DCn = the programmed dot correction value for output n (DCn = 0 to 63). n = 0 to 15 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 15 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 Figure 14 shows the dot correction data packet format which consists of 6 bits x 16 channel, total 96 bits. The format is Big-Endian format. This means that the MSB is transmitted first, followed by the MSB-1, etc. The DC 15.5 in Figure 14 stands for the 5th most significant bit for output 15. MSB LSB 95 90 DC 15.5 89 6 DC 15.0 DC 14.5 DC 1.0 DC OUT15 5 0 DC 0.5 DC 0.0 DC OUT0 DC OUT14 − DC OUT2 Figure 14. Dot Correction Data Packet Format When VPRG is set to VCC, the TLC5940 enters the dot correction data input mode. The length of input shift register becomes 96 bits. After all serial data are shifted in, the TLC5940 writes the data in the input shift register to DC register when XLAT is high, and holds the data in the DC register when XLAT is low. The DC register is a level triggered latch of XLAT signal. Since XLAT is a level-triggered signal, SCLK and SIN must not be changed while XLAT is high. After XLAT goes low, data in the DC register is latched and does not change. BLANK signal does not need to be high to latch in new data. XLAT has setup time (tsu1) and hold time (th1) to SCLK as shown in Figure 15. DC Mode Data Input Cycle n DC Mode Data Input Cycle n+1 VCC VPRG SIN DC n−1 LSB DC n MSB DC n MSB−1 DC n MSB−2 DC n LSB+1 DC n LSB DC n+1 MSB DC n+1 MSB−1 twh0 SCLK 1 2 3 95 96 1 2 twl0 SOUT DC n−1 MSB DC n−1 MSB−1 DC n−1 MSB−2 DC n−1 LSB+1 DC n−1 LSB tsu1 DC n MSB DC n MSB−1 DC n MSB−2 twh2 th1 XLAT Figure 15. Dot Correction Data Input Timing Chart The TLC5940 also has an EEPROM to store dot correction data. To store data from the dot correction register to EEPROM, DCPRG is set to high after applying VPRG to the VPRG pin. Figure 16 shows the EEPROM programming timings. The EEPROM has a default value of all 1s. 16 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 V(PRG) VPRG VCC tsu6 tprog th5 DCPRG XLAT SIN DC MSB SCLK 1 DC LSB 96 - SOUT DC MSB Figure 16. EEPROM Programming Timing Chart DCPRG tpd5 tpd5 OUT0 (Current) OUT15 (Current) Figure 17. DCPRG and OUTn Timing Diagram SETTING GRAYSCALE The TLC5940 can adjust the brightness of each channel OUTn using a PWM control scheme. The use of 12 bits per channel results in 4096 different brightness steps, respective 0% to 100% brightness. Equation 9 determines the brightness level for each output n: Brightness in % + GSn 100 4095 (9) where: GSn = the programmed grayscale value for output n (GSn = 0 to 4095) n = 0 to 15 Grayscale data for all OUTn Figure 18 shows the grayscale data packet format which consists of 12 bits x 16 channels, totaling 192 bits. The format is Big-Endian format. This means that the MSB is transmitted first, followed by the MSB-1, etc. MSB 191 180 179 12 GS 15.0 GS 14.11 GS 15.11 GS OUT15 GS 1.0 GS OUT14 − GS OUT2 11 LSB 0 GS 0.11 GS 0.0 GS OUT0 Figure 18. Grayscale Data Packet Format When VPRG is set to GND, the TLC5940 enters the grayscale data input mode. The device switches the input shift register to 192-bit width. After all data is clocked in, a rising edge of the XLAT signal latches the data into Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 17 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 the grayscale register (see Figure 11). New grayscale data immediately becomes valid at the rising edge of the XLAT signal; therefore, new grayscale data should be latched at the end of a grayscale cycle when BLANK is high.The first GS data input cycle after dot correction requires an additional SCLK pulse after the XLAT signal to complete the grayscale update cycle. All GS data in the input shift register is replaced with status information data (SID) after updated the grayscale register. STATUS INFORMATION OUTPUT The TLC5940 does have a status information register, which can be accessed in grayscale mode (VPRG=GND). After the XLAT signal latches the data into the GS register the input shift register data will be replaced with status information data (SID) of the device (see Figure 18). LOD, TEF, and dot correction EEPROM data (DCPRG=LOW) or dot correction register data (DCPRG=HIGH) can be read out at SOUT pin. The status information data packet is 192 bits wide. Bits 0-15 contain the LOD status of each channel. Bit 16 contains the TEF status. If DCPRG is low, bits 24-119 contain the data of the dot-correction EEPROM. If DCPRG is high, bits 24-119 contain the data of the dot-correction register.The remaining bits are reserved. The complete status information data packet is shown in Figure 19. SOUT outputs the MSB of the SID at the same time the SID are stored in the SID register, as shown Figure 20. The next SCLK pulse, which will be the clock for receiving the SMB of the next grayscale data, transmits MSB-1 of SID. If output voltage is < 0.3 V (typical) when the output sink current turns on, LOD status flage becomes active. The LOD status flag is an internal signal that pulls XERR pin down to low when the LOD status flag becomes active. The delay time, tpd2 (1 µs maximum), is from the time of turning on the output sink current to the time LOD status flage becomes valid. The timing for each channel's LOD status to become valid is shifted by the 30-ns (maximum) channel-to-channel turn-on time. After the first GSCLK goes high, OUT0 LOD status is valid; tpd3 + tpd2 = 60 ns + 1 µs. OUT1 LOD status is valid; tpd3 + td + tpd2 = 60 ns + 30 ns + 1 µs = 1.09 µs. OUT2 LOD status is valid; tpd3 + 2*td + tpd2 = 1.12 µs, and so on. It takes 1.51 µs maximum (tpd3 + 15*td + tpd2) from the first GSCLK rising edge until all LOD become valid; tsuLOD must be > 1.51 µs (see Figure 20) to ensure that all LOD data are valid. LSB MSB 0 15 16 LOD 15 LOD 0 TEF LOD Data X 23 24 119 120 191 X DC 15.5 DC 0.0 X X TEF DC Values Reserved Figure 19. Status Information Data Packet Format 18 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 VPRG GS Data Input Mode XLAT 1st GS Data Input Cycle GS1 MSB SIN 2nd GS Data Input Cycle GS1 LSB GS2 MSB > tpd4 + 15 x td + tpd3 tsuLOD 1 SCLK SOUT - 192 - GS2 LSB 193 GS1 MSB SID1 MSB 192 1 SID1 MSB-1 SID1 LSB GS2 MSB (1st GS Data Output Cycle) BLANK GSCLK 4096 1 tpd3 OUT0 (current) td OUT1 (current) 15 x td OUT15 (current) tpd2 XERR tpd3 + 15 x td + tpd2 Figure 20. Readout Status Information Data (SID) Timing Chart GRAYSCALE PWM OPERATION The grayscale PWM cycle starts with the falling edge of BLANK. The first GSCLK pulse after BLANK goes low increases the grayscale counter by one and switches on all OUTn with grayscale value not zero. Each following rising edge of GSCLK increases the grayscale counter by one. The TLC5940 compares the grayscale value of each output OUTn with the grayscale counter value. All OUTn with grayscale values equal to the counter values are switched off. A BLANK=H signal after 4096 GSCLK pulses resets the grayscale counter to zero and completes the grayscale PWM cycle (see Figure 21). When the counter reaches a count of FFFh, the counter stops counting and all outputs turn off. Pulling BLANK high before the counter reaches FFFh immediately resets the counter to zero. Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 19 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 GS PWM Cycle n BLANK t wl1 t wh1 t h4 GSCLK 1 t wl1 t wh3 4096 3 t su4 1 t pd3 nxt d t pd1 + td OUT1 (Current) 2 t pd3 t pd1 OUT0 (Current) GS PWM Cycle n+1 t pd3+ n x t d t pd1 + 15 x td OUT15 (Current) t pd2 XERR Figure 21. Grayscale PWM Cycle Timing Chart SERIAL DATA TRANSFER RATE Figure 22 shows a cascading connection of n TLC5940 devices connected to a controller, building a basic module of an LED display system. The maximum number of cascading TLC5940 devices depends on the application system and is in the range of 40 devices. Equation 10 calculates the minimum frequency needed: f + 4096 f (GSCLK) (update) f (SCLK) + 193 f (update) n (10) where: f(GSCLK): minimum frequency needed for GSCLK f(SCLK): minimum frequency needed for SCLK and SIN f(update): update rate of whole cascading system n: number cascaded of TLC5940 device 20 Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 TLC5940 www.ti.com SLVS515C – DECEMBER 2004 – REVISED OCTOBER 2007 APPLICATION EXAMPLE VCC V(LED) V(LED) V(LED) V(LED) 100 k OUT0 SIN XERR SCLK SCLK VCC 100 nF TLC5940 GSCLK DCPRG DCPRG BLANK BLANK SOUT VPRG OUT15 SIN SOUT XERR VCC SCLK XLAT GSCLK OUT0 SOUT XERR XLAT Controller OUT15 SIN IREF 100 nF XLAT GSCLK TLC5940 DCPRG IREF BLANK IC 0 VPRG IC n W_EEPROM 7 VPRG_D VPRG_OE V(22V) 50 k V(22V) 50 k 50 k 50 k 50 k 50 k VPRG Figure 22. Cascading Devices Submit Documentation Feedback Copyright © 2004–2007, Texas Instruments Incorporated Product Folder Link(s): TLC5940 21 PACKAGE OPTION ADDENDUM www.ti.com 6-Nov-2009 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Drawing Pins Package Eco Plan (2) Qty TLC5940NT ACTIVE PDIP NT 28 13 Green (RoHS & no Sb/Br) CU NIPDAU N / A for Pkg Type TLC5940NTG4 ACTIVE PDIP NT 28 13 Green (RoHS & no Sb/Br) CU NIPDAU N / A for Pkg Type TLC5940PWP ACTIVE HTSSOP PWP 28 50 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR TLC5940PWPG4 ACTIVE HTSSOP PWP 28 50 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR TLC5940PWPR ACTIVE HTSSOP PWP 28 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR TLC5940PWPRG4 ACTIVE HTSSOP PWP 28 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR TLC5940RHBR ACTIVE QFN RHB 32 3000 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR TLC5940RHBRG4 ACTIVE QFN RHB 32 3000 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR Lead/Ball Finish MSL Peak Temp (3) (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 18-May-2009 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel Diameter Width (mm) W1 (mm) TLC5940PWPR HTSSOP PWP 28 2000 330.0 TLC5940RHBR QFN RHB 32 3000 330.0 A0 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant 16.4 7.1 10.4 1.6 12.0 16.0 Q1 12.4 5.3 5.3 1.5 8.0 12.0 Q2 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 18-May-2009 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) TLC5940PWPR HTSSOP PWP 28 2000 346.0 346.0 33.0 TLC5940RHBR QFN RHB 32 3000 346.0 346.0 29.0 Pack Materials-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All products are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its hardware products to the specifications applicable at the time of sale in accordance with TI’s standard warranty. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by government requirements, testing of all parameters of each product is not necessarily performed. TI assumes no liability for applications assistance or customer product design. Customers are responsible for their products and applications using TI components. To minimize the risks associated with customer products and applications, customers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any TI patent right, copyright, mask work right, or other TI intellectual property right relating to any combination, machine, or process in which TI products or services are used. Information published by TI regarding third-party products or services does not constitute a license from TI to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. Reproduction of this information with alteration is an unfair and deceptive business practice. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI products or services with statements different from or beyond the parameters stated by TI for that product or service voids all express and any implied warranties for the associated TI product or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. TI products are not authorized for use in safety-critical applications (such as life support) where a failure of the TI product would reasonably be expected to cause severe personal injury or death, unless officers of the parties have executed an agreement specifically governing such use. Buyers represent that they have all necessary expertise in the safety and regulatory ramifications of their applications, and acknowledge and agree that they are solely responsible for all legal, regulatory and safety-related requirements concerning their products and any use of TI products in such safety-critical applications, notwithstanding any applications-related information or support that may be provided by TI. Further, Buyers must fully indemnify TI and its representatives against any damages arising out of the use of TI products in such safety-critical applications. TI products are neither designed nor intended for use in military/aerospace applications or environments unless the TI products are specifically designated by TI as military-grade or "enhanced plastic." Only products designated by TI as military-grade meet military specifications. Buyers acknowledge and agree that any such use of TI products which TI has not designated as military-grade is solely at the Buyer's risk, and that they are solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI products are neither designed nor intended for use in automotive applications or environments unless the specific TI products are designated by TI as compliant with ISO/TS 16949 requirements. Buyers acknowledge and agree that, if they use any non-designated products in automotive applications, TI will not be responsible for any failure to meet such requirements. Following are URLs where you can obtain information on other Texas Instruments products and application solutions: Products Applications Amplifiers amplifier.ti.com Audio www.ti.com/audio Data Converters dataconverter.ti.com Automotive www.ti.com/automotive DLP® Products www.dlp.com Communications and Telecom www.ti.com/communications DSP dsp.ti.com Computers and Peripherals www.ti.com/computers Clocks and Timers www.ti.com/clocks Consumer Electronics www.ti.com/consumer-apps Interface interface.ti.com Energy www.ti.com/energy Logic logic.ti.com Industrial www.ti.com/industrial Power Mgmt power.ti.com Medical www.ti.com/medical Microcontrollers microcontroller.ti.com Security www.ti.com/security RFID www.ti-rfid.com Space, Avionics & Defense www.ti.com/space-avionics-defense RF/IF and ZigBee® Solutions www.ti.com/lprf Video and Imaging www.ti.com/video Wireless www.ti.com/wireless-apps Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2010, Texas Instruments Incorporated
BOB-10616 价格&库存
很抱歉,暂时无法提供与“BOB-10616”相匹配的价格&库存,您可以联系我们找货
BOB-10616
    库存:29
