250-0587-00
250-0587-00
    FLIR(菲力尔)
    LEPTON BREAKOUT BOARD PCB ASSY
250-0587-00 数据手册
FLIR LEPTON® Camera Breakout v1.4 The FLIR Lepton® Thermal Camera Breakout is an easy to interface to evaluation board to quickly evaluate the FLIR Lepton® Camera module. It is compatible with a number of low-cost ARM based evaluation boards such as the NUCLEO-F401RE. In addition it is easy to wire to any nonstandard pin outs as well such as the raspberry PI.. FEATURES • Input Voltage: 3 V to 5.5 V • Space-Saving, (25 mm × 24 mm) • Works with the FLIR Lepton® modules: 50 degree shuttered, 50 degree, and 25 degree • Access to SPI and I2C camera module interfaces • Provides 25-MHz reference clock • Power Efficient 1.2 V core voltage • Dual Low Noise LDO for 2.8 V voltage • 32-pin Molex camera socket for Lepton® Module • 100 mil header, pinout compatible with Arduino® headers • PCB size and mounting holes same as standard Raspberry camera • Additional low profile .5mm FPC connector for embedded applications APPLICATIONS • Thermal Imaging • Motion Sensor • Night Vision • Gesture Recognition Lepton Specifications and Pinouts Item Description Specifications Input Voltage (Vi) 5.5 V continuous Operating Temperature Range 0° C to 55° C (over Vi range) Breakout Board Pins Pin 8 - SCL Camera Control Interface Clock, I2C Pin 7 - SDA Camera Control Interface Data, I2C Pin 6 - VIN 3-5 V Supply input Pin 5 - GND Common Ground Pin 4 - SPI CLK Video Over SPI Slave Clock Pin 3 - SPI MISO Video Over SPI Slave Data Out Pin 2 - SPI MOSI Video Over SPI Slave Data In Pin 1 - SPI CS Video Over SPI Slave Chip Select (active LOW) Dimensions SANTA BARBARA FLIR Systems, Inc. 70 Castilian Drive Goleta, CA 93117 USA PH: +1 805.964.9797 EUROPE FLIR Systems Luxemburgstraat 2 2321 Meer Belgium PH: +32 (0) 3665 5100 PORTLAND Corporate Headquarters FLIR Systems, Inc. 27700 SW Parkway Ave. Wilsonville, OR 97070 USA PH: +1 866.477.3687 CHINA – SHANGHAI FLIR Systems, Co., Ltd. K301-302, No.26 Lane 168, Daduhe Road, Putuo District, Shanghai 200062,P.R.China PH: +86-21-5169 7628 www.flir.com NASDAQ: FLIR Equipment described herein may require US Government authorization for export purposes. Diversion contrary to US law is prohibited. Imagery for illustration purposes only. Specifications are subject to change without notice. ©2014 FLIR Systems, Inc. All rights reserved. (Created 11/21/14) Application Information The figure below shows a typical application. Getting Started A basic code example has been posted to the Pure Engineering github site at the following URL: https://github.com/PureEngineering/LeptonModule. Please Note that these are examples to get one started and not for use in final designs. Familiarity of programming and compiling are highly recommended. Support For support that extends beyond this datasheet please consult the following google groups site at the following URL: https:// groups.google.com/d/forum/flir-lepton Please search for your question before posting as your question may already be answered. Additional Information All additional information about the breakout board, SDK’s, Lepton® Datasheet, and Purchase Information will be maintained at the Following URL: http://www.pureengineering.com/projects/lepton Example Application See the schematic on the following page for an example application.
250-0587-00 价格&库存
很抱歉,暂时无法提供与“250-0587-00”相匹配的价格&库存,您可以联系我们找货
