SEN-08883
SEN-08883
    SPARKFUNELECTRONICS
    LOW CURRENT SENSOR BREAKOUT - AC
SEN-08883 数据手册
 SparkFun Low Current Sensor Breakout ACS712 S EN -08 883 RO HS        4  images are CC BY-NC-SA 3.0 Description: This current sensor gives precise current measurement for both AC and DC signals. These are good sensors for metering and measuring overall power consumption of systems. The ACS712 current sensor measures up to 5A of DC or AC current. We added an opamp gain stage for more sensitive current measurements. By adjusting the gain (from 4.27 to 47) you can measure very small currents. The ACS712 Low Current Sensor Breakout outputs an analog voltage that varies linearly with sensed current. To calibrate, first set the output offset to the desired level (with zero current on the sense lines, read output with a DVM). Then with a known current input (a 100mA limited supply works well for this), set the output deflection with the gain pot. Sensitivity is then calculated as (Vref - Vdeflect)/(current input). The bandwidth on the ACS712 Low Current Sensor Breakout has been set to 34Hz to reduce noise when using at high gains. The full 80KHz bandwidth that the sensor is capable of can be recovered by removing C1. See schematic for more details. https://www.sparkfun.com/products/8883 10/8/2015
SEN-08883 价格&库存
很抱歉,暂时无法提供与“SEN-08883”相匹配的价格&库存,您可以联系我们找货
SEN-08883
    • 1+225.41760
    • 200+89.94240
    • 500+86.94000
    • 1000+85.46040
