Adafruit MCP9808 Precision I2C
Temperature Sensor Guide
Created by lady ada
https://learn.adafruit.com/adafruit-mcp9808-precision-i2c-temperature-sensor-guide
Last updated on 2022-10-05 02:06:50 PM EDT
©Adafruit Industries
Page 1 of 28
Table of Contents
Overview
3
Pinouts
6
• Power Pins
• I2C Data Pins
• Optional Pins
Arduino Code
Prepare the header strip:
Add the breakout board:
And Solder!
Arduino Wiring
Download Adafruit_MCP9808
Load Demo
Python & CircuitPython
8
14
CircuitPython Microcontroller Wiring
Python Computer Wiring
CircuitPython Installation of MCP9808 Library
CircuitPython & Python Usage
Full Example Code
Python Docs
19
WipperSnapper
19
• What is WipperSnapper
• Wiring
• Usage
Downloads
26
• Datasheets & Files
• Schematic and Fab Print for STEMMA QT Version
• Schematic and Fab Print for Original Version
Page 2 of 28
Overview
This I2C digital temperature sensor is one of the more accurate/precise we've ever
seen, with a typical accuracy of ±0.25°C over the sensor's -40°C to +125°C range and
precision of +0.0625°C. They work great with any microcontroller using standard i2c.
There are 3 address pins so you can connect up to 8 to a single I2C bus without
address collisions. Best of all, a wide voltage range makes is usable with 2.7V to 5.5V
logic!
Unlike the DS18B20, this sensor does not come in through-hole package so we
placed this small sensor on a breakout board PCB for easy use. The PCB includes
Page 3 of 28
mounting holes, and pull down resistors for the 3 address pins. We even wrote a
lovely little library for Arduino that will work with any Arduino compatible. You'll be up
and running in 15 minutes or less.
To get you going fast, we spun up a custom made PCB with the MCP9808 and some
supporting circuitry such as pull-up resistors and capacitors, in the STEMMA QT form
factor (https://adafru.it/LBQ), making them easy to interface with. The STEMMA QT
connectors (https://adafru.it/JqB) on either side are compatible with the SparkFun
Qwiic (https://adafru.it/Fpw) I2C connectors. This allows you to make solderless
connections between your development board and the MCP9808 or to chain them
with a wide range of other sensors and accessories using a compatible cable (https://
adafru.it/JnB). QT Cable is not included, but we have a variety in the shop (https://
adafru.it/JnB).
Page 4 of 28
• Simple I2C control
• Up to 8 on a single I2C bus with adjustable address pins
• 0.25°C typical precision over -40°C to 125°C range (0.5°C guaranteed max from
-20°C to 100°C)
• 0.0625°C resolution
• 2.7V to 5.5V power and logic voltage range
• Operating Current: 200 μA (typical)
There are two versions of this board - the STEMMA QT version shown above, and
the original header-only version shown below. Code works the same on both!
Page 5 of 28
Pinouts
The MCP9808 is a very straight-forward sensor, lets go thru all the pins so you can
understand what you need to connect to get started
Power Pins
• VIN (VDD on header-only version) - This is the positive power and logic level
pin. It can be 2.7-5.5VDC, so fine for use with 3 or 5V logic. Power VIN (VDD)
with whatever logic level you plan to use on the i2c lines.
Page 6 of 28
• GND - this is the ground power and logic reference pin.
I2C Data Pins
• SCL - this is the I2C clock pin. There's a 10K pull-up already on the board, so
connect this directly to the i2c master clock pin on your microcontroller
• SDA - this is the I2C data pin. There's a 10K pull-up already on the board, so
connect this directly to the i2c master data pin on your microcontroller
• STEMMA QT (https://adafru.it/Ft4) - These connectors allow you to connect to
development boards with STEMMA QT connectors, or to other things, with vario
us associated accessories (https://adafru.it/Ft6).
Optional Pins
These are pins you don't need to connect to unless you want to!
• Alert - This is the interrupt/alert pin from the MCP9808. The chip has some
capability to 'alert' you if the chip temperature goes above or below a set
amount. This output can trigger to let you know. It is open collector so you need
to use a pull-up resistor if you want to read signal from this pin.
• A0 (as well as A1 and A2 on the original version) - These are the address select
pins. Since you can only have one device with a given address on an i2c bus,
there must be a way to adjust the address if you want to put more than one
MCP9808 on a shared i2c bus. The A0/A1/A2 pins set the bottom three bits of
the i2c address. There are pull-down resistors on the board so connect them to
VDD to set the bits to '1'. They are read on power up, so de-power and re-power
to reset the address
The default address is 0x18 and the address can be calculated by 'adding' the A0/A1/
A2 to the base of 0x18
A0 sets the lowest bit with a value of 1, A1 sets the middle bit with a value of 2 and A2
sets the high bit with a value of 4. The final address is 0x18 + A2 + A1 + A0.
So for example if A2 is tied to VDD and A0 is tied to VDD, the address is 0x18 + 4 + 1 =
0x1D.
If only A0 is tied to VDD, the address is 0x18 + 1 = 0x19
If only A1 is tied to VDD, the address is 0x18 + 2 = 0x1A
If only A2 is tied to VDD, the address is 0x18 + 4 = 0x1C
Page 7 of 28
This address information applies to both versions of the MCP9808 breakout. The
STEMMA QT version has jumpers on the back that you can use to tie the address
pins to VDD.
Arduino Code
Cut the strip to length if necessary. It will
be easier to solder if you insert it into a
breadboard - long pins down
Page 8 of 28
Place the breakout board over the pins so
that the short pins poke through the
breakout pads
Page 9 of 28
And Solder!
Be sure to solder all pins for reliable
electrical contact.
(For tips on soldering, be sure to check out
our Guide to Excellent Soldering (https://
adafru.it/aTk)).
Page 10 of 28
You're done! Check your solder joints
visually and continue onto the next steps
Arduino Wiring
You can easily wire this sensor to any microcontroller, we'll be using an Arduino
Page 11 of 28
Connect VIN (Vdd) (red wire on the
STEMMA QT version) to the power supply,
3V or 5V is fine. Use the same voltage that
the microcontroller logic is based off of.
For most Arduinos, that is 5V
Connect GND (black wire on the STEMMA
QT version) to common power/data
ground
Connect the SCL pin to the I2C clock SCL
pin on your Arduino (yellow wire on
STEMMA QT version). On an UNO & '328
based Arduino, this is also known as A5,
on a Mega it is also known as digital 21
and on a Leonardo/Micro, digital 3
Connect the SDA pin to the I2C data SDA
pin on your Arduino (blue wire on STEMMA
QT version). On an UNO & '328 based
Arduino, this is also known as A4, on a
Mega it is also known as digital 20 and on
a Leonardo/Micro, digital 2
The MCP9808 has a default I2C address
of 0x18 but you can set the address to any
of 8 values between 0x18 and 0x1F so you
can have up to 8 of these sensors all
sharing the same SCL/SDA pins.
To begin reading sensor data, you will need to download the Adafruit MCP9808
library from the Arduino library manager.
Open up the Arduino library manager:
Page 12 of 28
Search for the Adafruit MCP9808 library and install it
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https://
adafru.it/aYM)
Load Demo
Open up File->Examples->Adafruit_MCP9808->mcp9808test and upload to your
Arduino wired up to the sensor
Thats it! Now open up the serial terminal window at 9600 speed to see the
temperature in real time. You can try touching your finger to the sensor to see the
Page 13 of 28
temperature rise.
It's easy to use the MCP9808 sensor with Python or CircuitPython and the Adafruit
CircuitPython MCP9808 (https://adafru.it/zcr) module. This module allows you to
easily write Python code that reads the temperature from the sensor.
You can use this sensor with any CircuitPython microcontroller board or with a
computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN).
Page 14 of 28
First wire up a MCP9808 to your board exactly as shown on the previous pages for
Arduino. Here's an example of wiring a Feather M0 to the sensor:
Board 3V to sensor VIN (Vdd) (red wire on
STEMMA QT version)
Board GND to sensor GND (black wire on
STEMMA QT version)
Board SCL to sensor SCL (yellow wire on
STEMMA QT version)
Board SDA to sensor SDA (blue wire on
STEMMA QT version)
Page 15 of 28
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Here's the Raspberry Pi wired with I2C:
Pi 3V3 to sensor VIN (red wire on STEMMA
QT version)
Pi GND to sensor GND (black wire on
STEMMA QT version)
Pi SCL to sensor SCK (yellow wire on
STEMMA QT version)
Pi SDA to sensor SDA (blue wire on
STEMMA QT version)
Page 16 of 28
Library
Next you'll need to install the Adafruit CircuitPython MCP9808 (https://adafru.it/zcr) lib
rary on your CircuitPython board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/tBa) for your board.
Next you'll need to install the necessary libraries to use the hardware--carefully follow
the steps to find and install these libraries from Adafruit's CircuitPython library bundle
(https://adafru.it/zdx). For example the Circuit Playground Express guide has a great
page on how to install the library bundle (https://adafru.it/Bf2) for both express and
non-express boards.
Remember for non-express boards like the Trinket M0, Gemma M0, and Feather/
Metro M0 basic you'll need to manually install the necessary libraries from the bundle:
• adafruit_mcp9808.mpy
• adafruit_bus_device
Before continuing make sure your board's lib folder or root filesystem has the adafruit
_mcp9808.mpy, and adafruit_bus_device files and folders copied over.
Next connect to the board's serial REPL (https://adafru.it/pMf)so you are at the
CircuitPython >>> prompt.
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling I2C on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https:
//adafru.it/BSN)!
Once that's done, from your command line run the following command:
• sudo pip3 install adafruit-circuitpython-mcp9808
Page 17 of 28
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
To demonstrate the usage of the sensor we'll initialize it and read the temperature.
First initialize the I2C connection and library by running:
import board
import busio
import adafruit_mcp9808
i2c = busio.I2C(board.SCL, board.SDA)
mcp = adafruit_mcp9808.MCP9808(i2c)
Now you can read the temperature property to retrieve the temperature from the
sensor in degrees Celsius:
print('Temperature: {} degrees C'.format(mcp.temperature))
That's all there is to reading temperature with the MCP9808 and CircuitPython code!
Full Example Code
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
import time
import board
i2c = board.I2C()
# uses board.SCL and board.SDA
# To initialise using the default address:
# To initialise using a specified address:
# Necessary when, for example, connecting A0 to VDD to make address=0x19
# mcp = adafruit_mcp9808.MCP9808(i2c_bus, address=0x19)
while True:
tempC = mcp.temperature
tempF = tempC * 9 / 5 + 32
print("Temperature: {} C {} F ".format(tempC, tempF))
time.sleep(2)
Page 18 of 28
Python Docs
Python Docs (https://adafru.it/C3s)
WipperSnapper
WipperSnapper is a firmware designed to turn any WiFi-capable board into an
Internet-of-Things device without programming a single line of code. WipperSnapper
connects to Adafruit IO (https://adafru.it/fsU), a web platform designed (by Adafruit! (ht
tps://adafru.it/Bo5)) to display, respond, and interact with your project's data.
Simply load the WipperSnapper firmware onto your board, add credentials, and plug it
into power. Your board will automatically register itself with your Adafruit IO account.
From there, you can add components to your board such as buttons, switches,
potentiometers, sensors, and more! Components are dynamically added to hardware,
so you can immediately start interacting, logging, and streaming the data your
projects produce without writing code.
If you've never used WipperSnapper, click below to read through the quick start guide
before continuing.
Quickstart: Adafruit IO
WipperSnapper
https://adafru.it/Vfd
Wiring
First, wire up an MCP9808 to your board exactly as follows. Here is an example of the
MCP9808 wired to an Adafruit ESP32 Feather V2 (https://adafru.it/ZbS) using I2C with
a STEMMA QT cable (no soldering required) (https://adafru.it/FNS)
Page 19 of 28
Board 3V to sensor VIN (red wire on
STEMMA QT)
STEMMA QT)
STEMMA QT)
STEMMA QT)
Usage
Connect your board to Adafruit IO Wippersnapper and navigate to the
WipperSnapper board list (https://adafru.it/TAu).
On this page, select the WipperSnapper board you're using to be brought to the
board's interface page.
Page 20 of 28
If you do not see your board listed here - you need to connect your board to Adafruit
IO (https://adafru.it/Vfd) first.
On the device page, quickly check that
you're running the latest version of the
WipperSnapper firmware.
The device tile on the left indicates the
version number of the firmware running on
the connected board.
If the firmware version is green with a
checkmark - continue with this guide.
If the firmware version is red with an "X" update to the latest WipperSnapper
firmware (https://adafru.it/Vfd) on your
board before continuing.
Next, make sure the sensor is plugged into your board and click the Start I2C Scan bu
tton.
You should see the MCP9808's default I2C address of 0x18 pop-up in the I2C scan
list.
Page 21 of 28
I don't see the sensor's I2C address listed!
First, double-check the connection and/or wiring between the sensor and the
board.
Then, reset the board and let it re-connect to Adafruit IO WipperSnapper.
With the sensor detected in an I2C scan, we're ready to add the sensor to your board.
Click the New Component button or the + button to bring up the component picker.
Select the MCP9808 from the component picker.
Page 22 of 28
On the component configuration page, the MCP9808's sensor address should be
listed along with the sensor's settings.
The Send Every option is specific to each sensor's measurements. This option will tell
the Feather how often it should read from the MCP9808 sensor and send the data to
Adafruit IO. Measurements can range from every 30 seconds to every 24 hours.
For this example, set the Send Every interval to every 30 seconds.
Page 23 of 28
Your device interface should now show the sensor components you created. After the
interval you configured elapses, WipperSnapper will automatically read values from
the sensor(s) and send them to Adafruit IO.
To view the data that has been logged from the sensor, click on the graph next to the
sensor name.
Page 24 of 28
Here you can see the feed history and edit things about the feed such as the name,
privacy, webhooks associated with the feed and more. If you want to learn more
about how feeds work, check out this page (https://adafru.it/10aZ).
For IO Free accounts, feed data is stored for a maximum of 30 days. If you’d like to
store data for more than 30 days or increase your data rate to send more sensor
measurements to Adafruit IO upgrade your account to Adafruit IO Plus (https://
adafru.it/Eg3).
Page 25 of 28
Downloads
Datasheets & Files
• MCP9808 datasheet (https://adafru.it/dfL)
• EagleCAD PCB files on GitHub (https://adafru.it/qib)
• MCP9808 3D Models on GitHub (https://adafru.it/11hf)
• MCP9808 STEMMA 3D Models on GitHub (https://adafru.it/11hA)
• Fritzing object in Adafruit Fritzing library (https://adafru.it/c7M)
Version
Page 26 of 28
Version
Page 27 of 28
Page 28 of 28
