SEN-09569
SEN-09569
    SPARKFUNELECTRONICS
    HIH-4030 - Humidity Sensor Evaluation Board
SEN-09569 数据手册
  SparkFun Humidity Sensor Breakout - HIH4030 S EN -09 569 RO HS       1  images are CC BY-NC-SA 3.0 Description: This is a breakout board for Honeywell’s HIH-4030 humidity sensor. The HIH-4030 measures relative humidity (%RH) and delivers it as an analog output voltage. You can connect the output of the sensor directly to an ADC on a microcontroller; and, thanks to the sensor’s near linear voltage output, the data is very easy to process. Voltage applied to the supply pins should be within 4-5.8VDC, and optimally at 5V. The sensor will typically only consume about 200μA. This product comes as shown in the picture, with the HIH-4030 soldered onto the breakout board. The pins of the 3-pin header are spaced by 0.1". Features: • • • • • • • • Near linear, analog output 4-5.8VDC voltage supply All pins broken out to a 0.1" pitch header Laser trimmed interchangeability Low power design, typical current draw of only 200μA Enhanced accuracy Fast response time Stable, low drift performance Dimensions: 0.75 x 0.30 “ (19.05 x 7.62 mm) https://www.sparkfun.com/products/9569 6/24/2015
SEN-09569 价格&库存
很抱歉,暂时无法提供与“SEN-09569”相匹配的价格&库存,您可以联系我们找货
