Standalone Toggle Capacitive Touch
Sensor Breakout - AT42QT1012
PRODUCT ID: 1375
Description
This breakout board is the simplest way to create a project with a single "toggle" capacitive touch
sensor. No microcontroller is required here - just power with 1.8 to 5.5VDC and touch the pad to
activate the sensor.
This sensor is a toggle output type: touch-on then touch-off. That means that when a capacitive
load is detected (e.g. a person touches the sensor-pad area) the red LED will alternate turning off
and the output pin will go high or low, respectively. This sensor is good for a project where you
want to activate something on the first touch, then deactivate it when touching again, like a switch.
You can also solder a wire to the middle pad and create your own capacitive pad if the built-in one
isn't suited to your project.
If you want to save power, the LED can be disconnected from the output pin (cut the trace between
the jumper marked as such). We designed this breakout to have infinite time-out. The chip does
support having the sensor time-out, so for example, if something is turned on, it will eventually
turn off on its own. If you'd like to use this mode, cut the TIMER jumper and then connect a
resistor/capacitor to the TIME pin. Check the datasheet for how to calculate the TIME pin to match
your desired timeout.
Comes with a fully assembled board, and a small stick of 0.1" header so you can solder and plug it
into a breadboard. For additional contacts, we suggest using copper foil, then solder a wire that
connects from the foil pad to the breakout.
Technical Details
Dimensions: 20mm / 0.8" x 29.35mm / 1.15"
Weight: 2.03g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1375”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.819401+7.35577
