Adafruit Capacitive Touch Sensor
Breakouts
Created by Bill Earl
https://learn.adafruit.com/adafruit-capacitive-touch-sensor-breakouts
Last updated on 2022-07-18 08:22:22 PM EDT
©Adafruit Industries
Page 1 of 25
Table of Contents
Overview
3
• Momentary
• Toggle
• 5-Pad Momentary
Assembly and Wiring
Installing the Headers:
Position the header strips
Position the breakout
And Solder
Wiring for Toggle and Momentary
6
7
Toggle Operation
Momentary Operation
Other Options:
LED Control
Speed vs. Power (Momentary Only)
Timer (Toggle Only)
Connecting to your Circuit.
Simple Motor Control
Wiring for 5-pad Momentary
11
Adding Custom Touch Pads
12
• Wire, Thread, Foil, Fabric, Paint
• Connections:
• Sensor Pads
Build a Touch Control Panel
Design your panel
Cut the touch-pads
Attach the touch-pads
Attach the Wires
Adjust the Wires
Install the Panel
And Test
Connect to your Circuit
Downloads
16
22
Files
AT42QT1010 Breakout
AT42QT1012 Breakout
AT42QT1070
Page 2 of 25
Overview
These breakout boards are a simple way to add capacitive touch to your project. Just
power with 1.8 to 5.5VDC and touch the pad to activate the sensor. These touch
switches interface easily to any project - with or without a microcontroller.
When a capacitive load (such as a human hand) is in close proximity to the sense-pad,
the sensor detects the change in capacitance and activates the switch. Custom
sense-pads can be made from nearly any conductive material and these sensors can
detect touch through thin layers of non-conductive materials such as glass, plastic,
fabric or even wood.
The breakouts come in three styles:
Page 3 of 25
Momentary
This sensor has a built-in sense-pad and is
active for as long as the sensor area is
touched.
The sense-pad can be extended with wire
and almost any conductive material.
Page 4 of 25
Toggle
This sensor also has a built-in sense-pad. It
becomes active when touched and
remains active until it is touched again.
As with the momentary sensor, the sensepad can be extended with wire and almost
5-Pad Momentary
This version combines 5 momentary
switches into one breakout. There are 5
pins for attaching wires to up to 5 external
sensor pads.
Page 5 of 25
We also have a new 12-Key version with
it's own tutorial over here! (https://
adafru.it/dKH)
Assembly and Wiring
These breakouts come fully assembled. For use in a breadboard, you may want to
take a couple minutes to install the included header strips:
Install the headers by following these 3 easy steps. The photographs below show one
of each sensor type.
Plug them long-pins down into a
breadboard to stabilize them for soldering.
Place the breakout board over the header
pins.
Page 6 of 25
And Solder
Solder each pin for solid electrical contact.
These two breakouts are very similar and can be powered by anything from 1.8V to
5.5V DC. Simply connect Ground to GND and the positive voltage to VDD. The
standalone sensors are fully functional without further connections.
Page 7 of 25
Toggle Operation
The Toggle version of the sensor turns on
when you touch it once, then turns off
when you touch it again. The on-board
LED indicates the state of the switch.
Momentary Operation
The momentary touch sensor works just
like a momentary switch. It is on when you
touch it and off when you move away. The
on-board LED indicates the state of the
switch.
Page 8 of 25
Other Options:
These sensors have several jumper configurable operating modes as described
below:
LED Control
The led indicators can be disabled for
ultra-low power applications. To disable
the LED, simply cut the jumper between
the pads where indicated on the back of
the breakout board.
With the jumper cut, the LED can be
controlled externally via the LED pin on the
header.
Speed vs. Power
(Momentary Only)
The Momentary version can be configured
for "Fast" mode (default) or low-power
mode. Fast mode requires 0.5mA. Low
Power mode requires just 50uA. To switch
between the two, cut the jumper on one
side of the "mode" pads and bridge the
other side with a drop of solder.
Page 9 of 25
Timer (Toggle Only)
By default, the toggle sensor is configured
for infinte time-out. it will stay on until you
touch the sensor to turn it off. It also
supports a configurable time-out to turn off
the output automatically after a delay. To
select this mode, cut the 'TIMER' jumper
and connect a resistor & capacitor to the
TIME pin. For a circuit diagram and
resistor/capacitor calculations, see page 13
of the datasheet (https://adafru.it/cgW).
You can also just connect TIME to Vdd and
the chip will turn off approx 15 minutes
after being turned on. Connect TIME to
OUT and the chip will time-out approx one
hour after being turned on.
The outputs of these touch switches are 'active high'. Use them like a positive logic
signal, or a pushbutton that shorts to VCC.
Page 10 of 25
You can use it just like a pushbutton or
logic signal with a transistor or MOSFET to
drive high-current loads like a DC motor.
Page 11 of 25
The 5-pin momentary breakout can be powered with anything from 1.8V to 5.5VDC.
Just connect ground to GND and the positive voltage to VDD. This sensor does not
have built-in touch pads, but you can create your own pads in any size or shape from
wire, foil or any other conductive material. Simply connect your touch-pads to each of
the 5 sense pins. When you touch the pad, the corresponding LED on the other side
will light up. The chip only detects one touch-pad at a time to prevent false readings.
5 touch inputs in one device makes this the perfect component for building your own
custom capacitive touch panel!
Custom touch pads are easy to make. You can use almost any conductive material:
Page 12 of 25
Paint
If it will conduct electricity, it will work as a
touch sensor!
Page 13 of 25
Page 14 of 25
Connections:
The Toggle and Momentary boards have a
solder hole located just below the sensor
pad for attaching a wire to an external
sensor.
The 5-pad breakout has pins numbered
0-4 on the left side of the board.
Sensor Pads
Attach the connecting wire to any
conductive object or surface. That surface
will become touch sensitive. Larger
surfaces tend to be more sensitive. You
will be able to sense through fabric, plastic
glass and many other non-conductive
materials.
Note that the wire will be touch sensitive
too! Be sure to route any connecting wires
away from areas where they might create
an accidental touch input.
Page 15 of 25
Capacitive touch sensors are a great way to add external controls to a waterproof
enclosure. There is no need to drill holes or worry about gaskets and O-rings. These
sensors will detect your touch right through the plastic case!
Design your panel
You can draw it by hand, or with your
favorite drawing tool and print it on some
heavy card-stock.
Cut the touch-pads
Cut pads from copper tape. About 1/2"
square is a good size for buttons on a
touch-pad.
Page 16 of 25
Peel the release paper from the back of
the copper tape and stick the touch-pads
to be back of the panel so that they align
with the buttons on the front.
Page 17 of 25
Attach the Wires
Solder wires to the copper touch-pads. For
this example, I used a 6-conductor 0.1"
socket cable (http://adafru.it/206) with one
end cut off to simplify connections to the
breakout.
Adjust the Wires
Bend the wires away from the panel. The
wires will be touch-sensitive too. To
prevent accidental false touches, we want
to keep them away from the panel surface.
Page 18 of 25
Install the Panel
Tape the panel to the inside of the
polycarbonate cover using clear packing
tape.
Page 19 of 25
And Test
Connect the cable to the breakout. Power
it up and test your control panel. Touching
each button should cause a different LED
to light up.
Page 20 of 25
The output signals are 'active low', so they
can replace any pushbutton that shorts to
ground - such as the buttons on the RGB
LCD shield. You can leave off the buttons
and solder directly to the circled pads, or
(if your shield is already built), just 'tacksolder' the wires to the legs of the buttons.
When you put it all together, you will have a completely sealed, touch sensitive
control panel!
Page 21 of 25
Downloads
Files
• AT42QT1070 Datasheet (https://adafru.it/rha)
• AT42QT1010 Datasheet (https://adafru.it/rhb)
• AT42QT1012 Datasheet (https://adafru.it/rhc)
• Objects for all in the Adafruit Fritzing Library (https://adafru.it/aP3)
• EagleCAD PCB files for all three in GitHub (https://adafru.it/rDr)
AT42QT1010 Breakout
Page 22 of 25
AT42QT1012 Breakout
Page 23 of 25
AT42QT1070
Page 24 of 25
Page 25 of 25
很抱歉,暂时无法提供与“1374”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.645081+7.33115
- 国内价格
- 1+110.92680
- 200+44.25840
- 500+42.77880
- 1000+42.05520
