Adafruit HTU21D-F Temperature &
Humidity Sensor
Created by lady ada
https://learn.adafruit.com/adafruit-htu21d-f-temperature-humidity-sensor
Last updated on 2021-11-15 06:13:47 PM EST
©Adafruit Industries
Page 1 of 20
Table of Contents
Overview
3
Pinouts
5
• Power Pins:
• I2C Logic pins:
6
7
Assembly
7
• Prepare the header strip:
• Add the breakout board:
• And Solder!
7
8
8
Wiring & Test
9
• Download Adafruit_HTU21DF
• Load Demo
• Library Reference
10
11
12
Python & CircuitPython
13
13
14
15
16
16
17
CircuitPython MicroController Wiring
Python Computer Wiring
CircuitPython Installation of HTU21D Library
CircuitPython & Python Usage
Full Example Code
Python Docs
18
Downloads
18
• Files & Datasheets
• Schematic and Fab Print for STEMMA QT Version
• Schematic and Fab Print for Original Version
18
18
19
Page 2 of 20
Overview
It's summer and you're sweating and your hair's all frizzy and all you really want to
know is why the weatherman said this morning that today's relative humidity would
max out at a perfectly reasonable 52% when it feels more like 77%. Enter the HTU21DF Temperature + Humidity Sensor - the best way to prove the weatherman wrong!
This I2C digital humidity sensor is an accurate and intelligent alternative to the much
simpler Humidity and Temperature Sensor - SHT15 Breakout (http://adafru.it/1638) It
has a typical accuracy of ±2% with an operating range that's optimized from 5% to
95% RH. Operation outside this range is still possible - just the accuracy might drop a
Page 3 of 20
bit. The temperature output has an accuracy of ±1°C from -30~90°C. If you're looking
to measure temperature more accurately, we recommend the MCP9808 High
Accuracy I2C Temperature Sensor Breakout Board. (http://adafru.it/1782)
Such a lovely chip - so we spun up a breakout board that includes the Filtered version
(the white bit of plastic which is a PTFE filter to keep the sensor clean), a 3.3V
regulator and I2C level shifting circuitry. This lets you use it safely with any kind of
microcontroller with 3.3V-5V power or logic.
To get you going fast, we spun up a custom made PCB in the STEMMA QT form
factor (https://adafru.it/LBQ), making them easy to interface with. The STEMMA QT
Page 4 of 20
connectors (https://adafru.it/JqB) on either side are compatible with the SparkFun
Qwiic (https://adafru.it/Fpw) I2C connectors. This allows you to make solderless
connections between your development board and the HTU21Ds or to chain them
with a wide range of other sensors and accessories using a compatible cable (https://
adafru.it/JnB). QT Cable is not included, but we have a variety in the shop (https://
adafru.it/JnB).
Each order comes with one fully assembled and tested PCB breakout and a small
piece of header. You'll need to solder the header onto the PCB but it's fairly easy and
takes only a few minutes even for a beginner.
There are two versions of this board - the STEMMA QT version shown above, and
the original header-only version shown below. Code works the same on both!
Pinouts
The HTU21D-F is a I2C sensor. That means it uses the two I2C data/clock wires
available on most microcontrollers, and can share those pins with other sensors as
long as they don't have an address collision. For future reference, the I2C address is
0x40 and you can't change it!
Page 5 of 20
Power Pins:
• Vin - this is the power pin. Since the chip uses 3 VDC, we have included a
voltage regulator on board that will take 3-5VDC and safely convert it down. To
power the board, give it the same power as the logic level of your
microcontroller - e.g. for a 5V micro like Arduino, use 5V
Page 6 of 20
• 3Vo (3v3 on original version) - this is the 3.3V output from the voltage regulator,
you can grab up to 100mA from this if you like
• GND - common ground for power and logic
I2C Logic pins:
• SCL - I2C clock pin, connect to your microcontrollers I2C clock line.
• SDA - I2C data pin, connect to your microcontrollers I2C data line.
• STEMMA QT (https://adafru.it/Ft4) - These connectors allow you to connect to
development boards with STEMMA QT connectors, or to other things, with vario
us associated accessories (https://adafru.it/Ft6).
Assembly
Cut the strip to length if necessary. It will
be easier to solder if you insert it into a
breadboard - long pins down
Page 7 of 20
Place the breakout board over the pins
so that the short pins poke through the
breakout pads
And Solder!
Be sure to solder all pins for reliable
electrical contact.
(For tips on soldering, be sure to check
out our Guide to Excellent
Soldering (https://adafru.it/aTk)).
Page 8 of 20
You're done! Check your solder joints
visually and continue onto the next steps
Wiring & Test
You can easily wire this breakout to any microcontroller, we'll be using an Arduino. For
another kind of microcontroller, just make sure it has I2C, then port the code - its
pretty simple stuff!
Page 9 of 20
• Connect Vin to the power supply,
3-5V is fine. (red wire on STEMMA
QT version) Use the same voltage
that the microcontroller logic is
based off of. For most Arduinos,
that is 5V
• Connect GND to common power/
data ground (black wire on
STEMMA QT version)
• Connect the SCL pin to the I2C
clock SCL pin on your Arduino.
(yellow wire on STEMMA QT
version) On an UNO & '328 based
Arduino, this is also known as A5,
on a Mega it is also known as digital
21 and on a Leonardo/Micro, digital
3
• Connect the SDA pin to the I2C
data SDA pin on your Arduino. (blue
wire on STEMMA QT verison) On an
UNO & '328 based Arduino, this is
also known as A4, on a Mega it is
also known as digital 20 and on a
Leonardo/Micro, digital 2
The HTU21D-F has a default I2C address
of 0x40 and cannot be changed!
To begin reading sensor data, you will need to download the Adafruit HTU21DF library
from the Arduino library manager.
Open up the Arduino library manager:
Page 10 of 20
Search for the Adafruit HTU21DF library and install it
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https://
adafru.it/aYM)
Load Demo
Open up File->Examples->Adafruit_HTU21DF->HTU21DFtest and upload to your
Arduino wired up to the sensor
Thats it! Now open up the serial terminal window at 9600 speed to begin the test.
Page 11 of 20
You can try breathing on the sensor to increase the humidity. The sensor reacts very
fast!
Library Reference
The library we have is simple and easy to use
You can create the Adafruit_HTU21DF object with:
Adafruit_HTU21DF htu = Adafruit_HTU21DF()
There are no pins to set since you must use the I2C bus!
Then initialize the sensor with:
htu.begin()
this function returns True if the sensor was found and responded correctly and False i
f it was not found
Once initialized, you can query the temperature in °C with
htu.readTemperature()
Page 12 of 20
Which will return floating point (decimal + fractional) temperature. You can convert to
Fahrenheit by multiplying by 1.8 and adding 32 as you have learned in grade school!
Reading the humidity is equally simple. Call
htu.readHumidity()
to read the humidity also as a floating point value between 0 and 100 (this reads %
humidity)
It's easy to use the HTU21D-F sensor with Python or CircuitPython and the Adafruit
CircuitPython HTU21D (https://adafru.it/CDn) module. This module allows you to
easily write Python code that reads the humidity and temperature from the sensor.
You can use this sensor with any CircuitPython microcontroller board or with a
computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN).
First wire up a HTU21D-F to your board exactly as shown on the previous pages for
Arduino. Here's an example of wiring a Feather M0 Express to the sensor with I2C:
Page 13 of 20
• Board 3V3 to sensor VIN (red wire
on STEMMA QT version)
• Board GND to sensor GND (black
wire on STEMMA QT version)
• Board SCL to sensor SCL (yellow
• Board SDA to sensor SDA (blue
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Here's the Raspberry Pi wired with I2C:
Page 14 of 20
• Pi GND to sensor GND (black wire
• Pi 3V3 to sensor VIN (red wire on
STEMMA QT version)
• Pi SDA to sensor SDA (blue wire on
STEMMA QT version)
• Pi SCL to sensor SCL (yellow wire
You'll need to install the Adafruit CircuitPython HTU21D (https://adafru.it/CDn) library
on your CircuitPython board.
First make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/Amd) for your board.
Page 15 of 20
Next you'll need to install the necessary libraries to use the hardware--carefully follow
the steps to find and install these libraries from Adafruit's CircuitPython library bundle
(https://adafru.it/uap). Our CircuitPython starter guide has a great page on how to
install the library bundle (https://adafru.it/ABU).
For non-express boards like the Trinket M0 or Gemma M0, you'll need to manually
install the necessary libraries from the bundle:
• adafruit_htu21d.mpy
• adafruit_bus_device
Before continuing make sure your board's lib folder or root filesystem has the adafrui
t_htu21d.mpy, and adafruit_bus_device files and folders copied over.
Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the
CircuitPython >>> prompt.
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling I2C on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https
://adafru.it/BSN)!
Once that's done, from your command line run the following command:
• sudo pip3 install adafruit-circuitpython-htu21d
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
To demonstrate the usage of the sensor we'll initialize it and read the humidity and
temperature values from the board's Python REPL.
Page 16 of 20
Run the following code to import the necessary modules and initialize the I2C
connection with the sensor:
import time
import board
import busio
from adafruit_htu21d import HTU21D
# Create library object using our Bus I2C port
i2c = busio.I2C(board.SCL, board.SDA)
sensor = HTU21D(i2c)
Now you're ready to read values from the sensor using any of these properties:
• temperature - the temperature in degrees Celsius.
• relative_humidity - the relative humidity in percent.
For example to print temperature:
print("\nTemperature: %0.1f C" % sensor.temperature)
That's all there is to using the HTU21D-F sensor with CircuitPython!
Full Example Code
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
import time
import board
# Create sensor object, communicating over the board's default I2C bus
i2c = board.I2C() # uses board.SCL and board.SDA
Page 17 of 20
while True:
print("Humidity: %0.1f %%" % sensor.relative_humidity)
time.sleep(2)
Python Docs
Python Docs (https://adafru.it/CDF)
Downloads
Files & Datasheets
• Datasheet for the HTU21D-F (https://adafru.it/dKR) (the -F part is for the PTFE Fil
ter, which is the white insert on top of the sensor)
• Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3)
• EagleCAD PCB files in GitHub (https://adafru.it/r5F)
• K&R Smith calibration notes (https://adafru.it/BfU)
Version
Page 18 of 20
Version
Page 19 of 20
Page 20 of 20
很抱歉,暂时无法提供与“1899”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+104.533281+13.54951
