MK21P-KIT
MK21P-KIT
    STANDEX-MEDER(斯丹麦德)
    REED SENSOR/MAGNET EVAL KIT
MK21P-KIT 数据手册
Europe: +49 / 7731 8399 0 | Email: info@meder.com USA: +1 / 508 295 0771 | Email: salesusa@meder.com Asia: +852 / 2955 1682 | Email: salesasia@meder.com Item No.: 9210000000 Item: MK21P-KIT Modifications in the sense of technical progress are reserved Designed at: Last Change at: 02/16/11 Designed by: Last Change by: MAPODACA Approval at: Approval at: 03/21/11 Approval by: Approval by: TLANE Rev. No.: 01 Europe: +49 / 7731 8399 0 | Email: info@meder.com USA: +1 / 508 295 0771 | Email: salesusa@meder.com Asia: +852 / 2955 1682 | Email: salesasia@meder.com Magnetic properties Pull-In Test equipment Conditions Item No.: 9210000000 Item: MK21P-KIT Min Typ at 20°C Special Product Data Contact - form Contact rating Switching voltage Carry current Switching current Sensor-resistance Housing material Case color Sealing compound Max Unit Max Unit KMS-14 Conditions Min Typ A - NO not to exceed their individual max.'s DC or Peak AC DC or Peak AC DC or Peak AC measured with 40% overdrive Environmental data Shock Vibration Operating temperature Operating temperature Storage temperature Cable specification Crastin SK655FR1 black Polyurethane Conditions Min 1/2 sine, duration 11ms, in 3 axis from 10 - 2000 Hz cable not moved cable moved Typ Max Unit Typ Max Unit Max Unit ! ! Conditions Min Cable type Cable material Cross section flat cable PVC 0,14 sq-mm Conditions General data Min # $%& '! (# Disk ISO 7089 Tightening torque Mounting advice Typ " over 5m cable, a resistor is recommended. Modifications in the sense of technical progress are reserved Designed at: Last Change at: 02/16/11 Designed by: Last Change by: MAPODACA Approval at: Approval at: 03/21/11 Approval by: Approval by: TLANE Rev. No.: 01
MK21P-KIT 价格&库存
很抱歉,暂时无法提供与“MK21P-KIT”相匹配的价格&库存,您可以联系我们找货
