MOD-EKG
MOD-EKG
    OLIMEX
    OLIMEX MSP430FG439 MODULE
MOD-EKG 数据手册
MOD-EKG development board User's manual All boards produced by Olimex are ROHS compliant Document revision B, December 2016 Page 1 of 17 INTRODUCTION: MOD-EKG is an implementation of the hardware design proposed by Texas Instruments in their document “Heart-Rate and EKG Monitor Using the MSP430FG439” (document name “slaa280a”). MOD-EKG is an open-hardware, open-software project. The user places his index fingers and thumbs at the metallic pads of the board and the heartbeat rate per minute gets displayed on the LCD. In addition, the application outputs a digital data stream to a serial data interface which allows you to display EKG waveform on a PC. The serial interface is available at the UEXT connector. Using our serial ↔ USB adapter. A connection between the PC and MOD-EKG can be achieved by using our adapter – MOD-USB-RS232 that converts the serial interface to USB, and vice versa. An electrocardiogram (ECG), also called an EKG, is a graphic showing the voltage generated by the heart muscle during a heartbeat. In this application, the EKG waveform is used by the MCU to measure the heartbeat rate. Because heartbeat calculation is the major focus the electrodes are simplified to two points for collecting data, one for the right hand and the other for the left hand. BOARD FEATURES:  Microcontroller: MSP430FG439  EKG amplifiers with INA321EA  14-pin 0.1” step JTAG connector for direct microcontroller access via MSP430 debugger to debug the software or to power the board  UEXT connector that allows easier connection to other boards  Custom LCD display  3V CR2032 Lithium coin battery holder  Extension rows of pinholes for all microcontroller ports – with no plastic connectors placed  No additional electrodes required! Right and left hand contact boardmounted electrodes – HR1 and HR2  Two status LEDs  Two user buttons  A switch to alternate between “battery” and “UEXT” power supply  Based on Texas Instruments application note SLAA280a  FR-4, 1.5 mm, red soldermask, white component print  Dimensions: (3.0 x 2.8)" ~ (76 x 71)mm Page 2 of 17 ELECTROSTATIC WARNING: The MOD-EKG board is shipped in protective anti-static packaging. The board must not be subject to high electrostatic potentials. General practice for working with static sensitive devices should be applied when working with this board. BOARD USE REQUIREMENTS: In order to set up the PIC32-RETROBSD board optimally one or more additional items may be needed. They might be generally placed in two categories: Required – items that are needed in order to achieve minimum functionality; Recommended – items that is good to have in order to be able to interact with the most important of the features of the board. a) Required items: - A source of power; preferably a battery. MOD-EKG can take power from a number sources: 1) +3V CR2032 Lithium battery placed in the battery connector at the back – when switch BAT/UEXT is in position BAT. 2) JTAG deubgger placed in the JTAG connector – when jumper P_IN is closed and P_OUT is opened. 3) Pins #1 (3.3V) and #2 (GND) of the UEXT connector – when switch BAT/UEXT is in position UEXT; you can also supply 3V from a battery to these pins The power supply source gets selected by changing jumpers P_IN and P_OUT and using the BAT/UEXT switch. IMPORTANT: MOD-EKG is a sensitive board and glitches or noises in the power supply lines might affect the readings. Even if the USB ports and the power supply unit are of good quality, there is still parasitic capacitance between the human body and mains power line, which affects the readings. Be sure to test with a 3V battery – either insert a good CR2302 coin battery directly in the connector at the back of MOD-EKG or attach a 3V battery to the UEXT. If you wish to power the board from the JTAG or external power supply make sure there is galvanic isolation or good filtering between the power supply and the MOD-EKG board. For example, if you want to isolate your JTAG debugger from the mains power influence you can use our USB-ISO product (between the computer's USB port and the JTAG debugger). b) Recommended items: - serial to USB adapter board – to connect to a personal computer; you can use a number of our low cost solutions, for example, BB-340CH or MOD-USB-RS232; note that the examples for computer connection use MOD-USB-RS232 - MSP430-compatible debugger with 14-pin (2 x 7) 0.1” step connector; if you want a compatible low-cost Olimex product consider MSP430-JTAG-TINY-V2 or MSP430JTAG-ISO-MK2 Page 3 of 17 PROCESSOR FEATURES: MOD-EKG board uses ultralow power microcontroller MSP430FG439 from Texas Instruments with the following features:  Low Supply-Voltage Range, 1.8 V to 3.6 V  Ultralow-Power Consumption:  Active Mode: 300 μA at 1 MHz, 2.2 V  Standby Mode: 1.1 μA  Off Mode (RAM Retention): 0.1 μA  Five Power Saving Modes  Wake-Up From Standby Mode in Less Than 6 μs  16-Bit RISC Architecture, 125-ns Instruction Cycle Time  Single-Channel Internal DMA  12-Bit A/D Converter With Internal Reference, Sample-and-Hold and Autoscan Feature  Three Configurable Operational Amplifiers  Dual 12-Bit D/A Converters With Synchronization  16-Bit Timer_A With Three Capture/Compare Registers  16-Bit Timer_B With Three Capture/Compare-With-Shadow Registers  On-Chip Comparator  Serial Communication Interface (USART), Select Asynchronous UART or Synchronous SPI by Software  Brownout Detector  Supply Voltage Supervisor/Monitor With Programmable Level Detection  Bootstrap Loader  Serial Onboard Programming, No External Programming Voltage Needed Programmable Code Protection by Security Fuse  Integrated LCD Driver for Up to 128 Segments  60KB+256B Flash Memory  2KB RAM Page 4 of 17 BLOCK DIAGRAM: MEMORY ORGANIZATION: Page 6 of 17 1 2 10nF 2 4 6 8 10 12 14 BH14S JTAG 1 3 5 7 9 11 13 JTAG RST TDO TDI TMS TCK 4 5 6 4 1 1 5 2 2 6 3 3 3V-LI_BAT+ -BC-2001 + Page 7 of 17 NA GN D NA 10uF/6.3V C10 GND TDO TDI TMS TCK RST P6.0 P6.1 P6.2 GND GND VCC P1.6/CA0 P1.5/TACLK/ACLK P1.4/TBCLK/SMCLK P1.3/TBOUTH/SVSOUT P1.2/TA1 P1.1/TA0/MCLK P1.0/TA0 XT2OUT XT2IN TDO/TDI TDI TMS TCK RST/NMI P6.0/A0/OA0I0 P6.1/A1/OA0O P6.2/A2/OA0I1 AVSS DVSS1 AVCC C9 2 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 32768Hz/6pF P1.6 P1.5 P1.4 P1.3 P1.2 P1.1 P1.0 P3.3/UCLK0/S28 P3.4/S27 P3.5/S26 P3.6/S25/DMAE0 P3.7/S24 S23 S22 S21 S20 P2.6/CAOUT/S19 P2.7/ADC12CLK/S18 S17 S16 S15 S14 S13 S12 S11 S10 P4.0/S9 NA 1 2 3 4 VEREF+ VREF+ VEREF- NA 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 10uF/6.3V NA(0R) C12 0R R30 P2.3 VCC REF R31 680k 150k R11 R26 R10 680k 1 Q1 2 680k 3 R9 R33 R13 COM2 S0 P3.7 P3.5 UCLK0 SIMO0 4 100nF 5 45 C11 6 44 8 6 4 2 8 6 4 2 8 6 4 2 7 43 P1.7 P1.5 P1.3 P1.1 7 5 3 1 NA(HN2X4) PORT5 NA(HN2X4) R23 COM3 COM1 S1 8 6 4 2 8 6 4 2 7 5 3 1 7 5 3 1 NA(HN2X4) PORT6 NA(HN2X4) 7 5 3 1 UCLK0 P3.4 P3.5 P3.6 P3.7 S23 S22 S21 S20 S19 S18 S17 S16 S15 S14 S13 S12 S11 S10 S9 P6.6 P6.4 P6.2 P6.0 S3 S5 S7 S9 http://www.olimex.com/dev COPYRIGHT(C) 2011, OLIMEX Ltd. Rev. B d g a S19 UTXD0 P2.2 P2.0 MOD-EKG P6.7 P6.5 P6.3 P6.1 S2 S4 S6 S8 PORT2 PORT4 7 5 3 1 P3.6 P3.4 SOMI0 P3.0 8 6 4 2 NA(HN2X4) S18 URXD0 P2.3 P2.1 PORT3 P1.6 P1.4 P1.2 P1.0 Extensions 7 5 3 1 e OLIMEX NA(HN2X4) PORT1 9 100k 100k 10 S23 P3.7 P3.6 P3.5 P3.4 R7 R8 8 42 S21 S22 C8 100nF P1.7 P2.0 P2.1 P2.2 P2.3 UTXD0 URXD0 GND VCC R33 R23 R13 R03 COM3 COM2 COM1 COM0 P3.0 SIMO0 SOMI0 41 S19 S20 MSP430FG439 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 0R S16 S17 S18 U1 P1.7/CA1 P2.0/TA2 P2.1/TB0 P2.2/TB1 P2.3/TB2 P2.4/UTXD0 P2.5/URXD0 DVSS2 DVCC2 P5.7/R33 P5.6/R23 P5.5/R13 R03 P5.4/COM3 P5.3/COM2 P5.2/COM1 COM0 P3.0/STE0/S31 P3.1/SIMO0/S30 P3.2/SOMI0/S29 11 DVCC1 P6.3/A3/OA1I1/OA1O P6.4/A4/OA1I0 P6.5/A5/OA2I1/OA2O P6.6/A6/DAC0/OA2I0 P6.7/A7/DAC1/SVSIN VREF+ XIN XOUT VEREF+/DAC0 VREF-/VEREFP5.1/S0/A12/DAC1 P5.0/S1/A13 P4.7/S2/A14 P4.6/S3/A15 P4.5/S4 P4.4/S5 P4.3/S6 P4.2/S7 P4.1/S8 12 S14 S15 C7 100nF 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 37 NA(0R) 38 R28 39 NA(0R) 40 18 LCD 13 R29 4.7k 36 19 SW2 LCD 14 f 15 35 20 OLIMEX_LTD NA(0R) 0R R22 34 S11 S3 S2 21 T1107A(6x3.8x2.5mm) VCC NA P6.6 P6.1 16 22 T1107A(6x3.8x2.5mm) SW1 C16 R24 1M NA 24 C6 100nF VCC P6.3 P6.4 P6.5 P6.6 P6.7 VREF+ XIN XOUT VEREF+ VEREFS0 S1 S2 S3 S4 S5 S6 S7 S8 1k umHF 1.5nF R21 C15 17 33 NA VCC P6.5 P6.0 32 R25 R23 10k NA P1.3 R18 NA R20 31 S9 S10 23 C5 100nF R6 1k 100nF 1 8 4 6 S7 S8 IS-1390(Default: UEXT is closed) GYX-SD-TC0805SURK(RED) R5 P6.2 A3 VOUT RG SHUTDOWN V- A2 1 60 k 48 10nF NA C13 4 0k 47 LED2 C17 VCC A1 4 0k 46 GYX-SD-TC0805SURK(RED) LED1 P6.7 ECG amplifiers HR2 HR4 VINVIN+ V+ 1 60 k 1M 28 30 100nF 3 2 3 7 REF R19 INA321EA S4 S5 S6 29 C3 C4 J2 P1.4 P1.5 SOMI0 SIMO0 UCLK0 P3.0 1 1-2:Open; 2-3:Close 100k/1% 100k/1% 2.2M/1% 2.2M/1% 820R 1M 5 P6.4 26 27 C2 VCC 3 R12 R13 R14 R15 R16 R17 P6.3 U2 100nF R27 S0 S1 BAT/UEXT J1 HR3 HR1 C14 S13 S12 0R VCC 1 1-2:Open; 2-3:Close UTXD0 URXD0 UEXT 25 3.3V_UEXT BH10S R4 4.7k VCC VCC R3 4.7k 3.3V_UEXT UEXT-1 UEXT-2 UEXT-3 UEXT-4 UEXT-5 UEXT-6 UEXT-7 UEXT-8 UEXT-9 UEXT-10 10k R2 VCC 2 C1 R1 100k VCC COM0 COM1 COM2 COM3 POWER SUPPLY HN1x2(Close) 2 1 P_OUT HN1x2(Open) P_IN c b P6.6 P1.6 SCHEMATIC: BOARD LAYOUT: Page 8 of 17 POWER SUPPLY CIRCUIT: MOD-EKG can take power from: 1) +3V CR2032 Lithium battery placed in the battery connector at the back – when switch BAT/UEXT is in position BAT. 2) JTAG deubgger placed in the JTAG connector – when jumper P_IN is closed and P_OUT is opened. 3) Pins #1 (3.3V) and #2 (GND) of the UEXT connector – when switch BAT/UEXT is in position UEXT; you can also supply 3V from a battery to these pins The power supply source gets selected by changing jumpers P_IN and P_OUT and using the BAT/UEXT switch. RESET CIRCUIT: MOD-EKG reset circuit includes R1 (100k), C1(10nF), JTAG pin 11 and MSP430FG439 pin 74 (RST/NMI). CLOCK CIRCUIT: Quartz crystal (Q1) 32.768 kHz is connected to MSP430FG439 pin 8 (XIN) and pin 9 (XOUT). JUMPER DESCRIPTION: P_IN When this jumper is closed, the board is power supplied by the standard JTAG pin 2. This is only possible when the consumption of the board is not very high which is typically the case with MSP430 microcontrollers. If this jumper is open the board should be power supplied by another external source. This jumper and P_OUT should always be reversely open/closed, i.e. if P_IN is closed, P_OUT should be open and vice versa. Default state is opened. P_OUT When this jumper is closed, the board is power supplied not by the JTAG but from external source. Then the JTAG has to synchronize with the working voltages which is done through this line. This is especially important when debugging with JTAG. This jumper and P_IN should always be reversely Page 9 of 17 open/closed, i.e. if P_OUT is closed, P_IN should be open and vice versa. Default state is closed. J1 When jumper J1 is shorted in position 1-2, UEXT pin 3 is connected to MSP430FG439 pin 55 (P2.4/UTXD0) – signal “UTXD0”. When jumper J1 is shorted in position 2-3, UEXT pin 3 is connected to MSP430FG439 pin 54 (P2.5/URXD0) – signal “URXD0”. Default state is shorted in position 2-3. J2 When jumper J2 is shorted in position 1-2, UEXT pin 4 is connected to MSP430FG439 pin 54 (P2.5/URXD0) – signal “URXD0”. When jumper J2 is shorted in position 2-3, UEXT pin 4 is connected to MSP430FG439 pin 55 (P2.4/UTXD0) – signal “UTXD0”. Default state is shorted in position 2-3. Depending on jumpers J1 and J2 configuration, the board can work in host, or in device mode. The default state of J1 and J2 is for device mode (shorted in position 2-3). INPUT/OUTPUT: LED1 (red) connected to MSP430FG439 pin 67 (P1.0/TA0). LED2 (red) connected to MSP430FG439 pin 65 (P1.2/TA1). User button with name SW1 connected to MSP430FG439 pin 59 (P2.0/TA2). User button with name SW2 connected to MSP430FG439 pin 58 (P2.1/TB0). Power supply switch with name BAT/UEXT – when in position BAT – the board is power supplied via +3V lithium battery, when is in position UEXT – the board is connected to other board with UEXT and is power supplied by the other board via UEXT connector. LCD custom display. Page 10 of 17 EXTERNAL CONNECTORS DESCRIPTION: UEXT: Pin # Signal Name 1 VDD 2 GND 3 TX 4 RX 5 P1.4 6 P1.5 7 SOMI0 8 SIMO0 9 UCLK0 10 P3.0 Page 11 of 17 JTAG: Pin # Signal Name Pin # Signal Name 1 TDO 2 Via P_IN to VCC 3 TDI 4 Via P_OUT to VCC 5 TMS 6 Not Connected 7 TCK 8 Not Connected 9 GND 10 Not Connected 11 RST 12 Not Connected 13 Not Connected 14 Not Connected PORT1: Pin # Signal Name Pin # Signal Name 1 P1.0 2 P1.1 3 P1.2 4 P1.3 5 P1.4 6 P1.5 7 P1.6 8 P1.7 Page 12 of 17 PORT2: Pin # Signal Name Pin # Signal Name 1 P2.0 2 P2.1 3 P2.2 4 P2.3 5 UTXD0 6 URXD0 7 S19 8 S18 PORT3: Pin # Signal Name Pin # Signal Name 1 P3.0 2 SIMO0 3 SOMI0 4 UCLK0 5 P3.4 6 P3.5 7 P3.6 8 P3.7 PORT4: Pin # Signal Name Pin # Signal Name 1 S9 2 S8 3 S7 4 S6 5 S5 6 S4 7 S3 8 S2 Page 13 of 17 PORT5: Pin # Signal Name Pin # Signal Name 1 S1 2 S0 3 COM1 4 COM2 5 COM3 6 R13 7 R23 8 R33 PORT6: Pin # Signal Name Pin # Signal Name 1 P6.0 2 P6.1 3 P6.2 4 P6.3 5 P6.4 6 P6.5 7 P6.6 8 P6.7 REF: Pin # Signal Name Pin # Signal Name 1 VEREF+ 2 VREF+ 3 VEREF- 4 GND Page 14 of 17 MECHANICAL DIMENSIONS: Page 15 of 17 AVAILABLE DEMO SOFTWARE: 1. Example that demonstrates heart rate measuring, using MSP430FG439 microcontroller, requires IAR EW and JTAG tool. Available for download here: LINK 2. Instructions on connecting MOD-EKG to PC computer with the help of MOD-USBRS232, available here: LINK For more information visit the web-page of the product: https://www.olimex.com/Products/Modules/Biofeedback/MOD-EKG/ ORDER CODE: MOD-EKG – assembled and tested board HOW TO ORDER? You can order directly from our web-shop! Please visit our web www.olimex.com for more information. REVISION HISTORY: Hardware revision: Rev. B, April 2011 Document revision: Rev. Initial, June 2011 Rev. B, December 2016 – added important note about the main power supply influence over the readings; improved warranty and support information Page 16 of 17 For product support, hardware information and error reports mail to: support@olimex.com. All document or hardware feedback is welcome. Note that we are primarily a hardware company and our software support is limited. Please consider reading the paragraph below about the warranty of Olimex products. All goods are checked before they are sent out. In the unlikely event that goods are faulty, they must be returned, to OLIMEX at the address listed on your order invoice. OLIMEX will not accept goods that have clearly been used more than the amount needed to evaluate their functionality. If the goods are found to be in working condition, and the lack of functionality is a result of lack of knowledge on the customers part, no refund will be made, but the goods will be returned to the user at their expense. All returns must be authorized by an RMA Number. Email support@olimex.com for authorization number before shipping back any merchandise. Please include your name, phone number and order number in your email request. Returns for any unaffected development board, programmer, tools, and cables permitted within 7 days from the date of receipt of merchandise. After such time, all sales are considered final. Returns of incorrect ordered items are allowed subject to a 10% restocking fee. What is unaffected? If you hooked it to power, you affected it. To be clear, this includes items that have been soldered to, or have had their firmware changed. Because of the nature of the products we deal with (prototyping electronic tools) we cannot allow returns of items that have been programmed, powered up, or otherwise changed post shipment from our warehouse. All returned merchandise must be in its original mint and clean condition. Returns on damaged, scratched, programmed, burnt, or otherwise 'played with' merchandise will not be accepted. All returns must include all the factory accessories which come with the item. This includes any In-Circuit-Serial-Programming cables, anti-static packing, boxes, etc. With your return, enclose your PO#. Also include a brief letter of explanation of why the merchandise is being returned and state your request for either a refund or an exchange. Include the authorization number on this letter, and on the outside of the shipping box. Please note: It is your responsibility to ensure that returned goods reach us. Please use a reliable form of shipping. If we do not receive your package we will not be held liable. Shipping and handling charges are not refundable. We are not responsible for any shipping charges of merchandise being returned to us or returning working items to you. The full text might be found at https://www.olimex.com/wiki/GTC#Warranty for future reference. Page 17 of 17
MOD-EKG 价格&库存
很抱歉,暂时无法提供与“MOD-EKG”相匹配的价格&库存,您可以联系我们找货
