RFD77306
RFD77306
    RFDIGITAL
    IOT3DTOFSENSORSHIELD
RFD77306 数据手册
Based on RFD77402 Simblee ™ Simblee IoT 3D ToF Sensor Module DATASHEET RFD77306 Simblee IoT 3D ToF Sensor Shield RFD77804 Simblee Wireless IoT 3D ToF Sensor Kit A Simblee Sensor Shield that plugs directly into the Simblee Ecosystem. RFD77306 Simblee IoT 3D ToF Sensor Shield Stacks easily onto Simblee Ecosystem Fully Integrated micro module Time of Flight Sensor Technology Accurate distance measurements up to 2 meters Simple to use SimbleeToF Library High accuracy and repeatability I2C interface Low power Typical Applications • • • • • Smart Industrial Solutions Predictive Maintenance Public Spaces Next Gen Kiosks Touchless User Interfaces • • • • • Event Triggers Traffic Flow Monitoring Work Flows and Processes Smart Maintenance Smart Appliances 1 Simblee IoT 3D ToF Sensor Shield DATASHEET v1.0 © 2017 RF Digital Corporation 3.6.2017 www.simblee.com • • • • • Inventory Management Proximity Detection Smart Storage Smart Building Material Detection Based on RFD77402 Simblee ™ Simblee IoT 3D ToF Sensor Module RFD77306 Simblee IoT 3D ToF Sensor Shield TOP VIEW BOTTOM VIEW Dimensions: X: 1.2in (30.48mm) Y: 1.2in (30.48mm) Z: 0.45in (11.50mm) Parameters MIN Measurement Range 100 Maximum Refresh Rate NOM MAX Units 2000 mm 10 NOTES Hz Standby current 9.3 9.7 15 µA Current consumption - 7 15 mA Operating Voltage 2.7 3.0 3.3 Vdd Pull-up Voltage 1.8 - Vdd Vpull-up Operating Temperature -10 - 60 °C Temperature not to exceed - - 245 °C @ full range I2C: SDA and SCL VIL 0 - 0.9 V VIH 1.2 - - V VOL (@ 3mA) - 0.02 - V IOL (@ VOL = 0.4V) - 8 - mA I2C address 0x4C 2 Simblee IoT 3D ToF Sensor Shield DATASHEET v1.0 © 2017 RF Digital Corporation 3.6.2017 www.simblee.com Based on RFD77402 Simblee ™ Simblee IoT 3D ToF Sensor Module Rapid Development & Prototyping Kit RFD77306 Simblee IoT 3D ToF Sensor Shield RFD77804 Simblee IoT 3D ToF Sensor Kit 3 Simblee IoT 3D ToF Sensor Shield DATASHEET v1.0 © 2017 RF Digital Corporation 3.6.2017 www.simblee.com Based on RFD77402 Simblee ™ Simblee IoT 3D ToF Sensor Module RFD77306 IoT 3D ToF Shield is based on RFD77402 Sensor Module RFD77306 IoT 3D ToF Sensor Shield RFD77402 IoT 3D ToF Sensor Module See RFD77402 datasheet at: https://www.Simblee.com/RFD77402 RoHS & REACH Compliance The RFD77402 module is compliant with the European RoHS Directive 2002/95/EC (Restriction of the Use of Certain Hazardous Substances in Electrical and Electronic Equipment) and REACH (Registration, Authorization and Restriction of Chemicals, European Union Regulation (EC) 1907/2006). Eye Safety The RFD77402 module contains a laser emitter and corresponding drive circuitry. The laser output is Class 1 laser safety under all reasonably foreseeable conditions including single faults in compliance with IEC 60825-1:2014. The laser output will remain within Class 1 limits as long as the Simblee recommended device settings are used and the operating conditions specified in this datasheet are respected. The laser output power must not be increased by any means and no optics should be used with the intention of focusing the laser beam. 4 Simblee IoT 3D ToF Sensor Shield DATASHEET v1.0 © 2017 RF Digital Corporation 3.6.2017 www.simblee.com
RFD77306 价格&库存
很抱歉,暂时无法提供与“RFD77306”相匹配的价格&库存,您可以联系我们找货
