URM04 V2.0 (SKU:SEN0002)
URM04 V2.0
Figure 1: URM04 Beam Width 60 degree
Contents
1 Introduction
2 Specification
3 Dimension and Pin definition
4 Communication Protocols
4.1 Set Device Address
4.2 Trigger measurement
4.3 Read Distance
4.4 Read tempeature
5 Sensor Connection Diagram
6 Sensor Networking
7 Arduino sketch for driving one URM04 sensor
Introduction
A. Please read this mannual carefully before power on the device.
B. Do not use this device for military or medical purpose as they are not designed to.
URM04 is developed based upon our popular URM37 ultrasonic sensor. The RS485 interface allows
a number of sensors working together. Up to 32 URM04 may be connected together in a network.
Specification
Power: +5V
Current: =0xF0)
Temperature= ((HightByte-0xF0)*256-LowByte)/10
Else
Temperature= ((HightByte)*256-LowByte)/10
As the sensor uses RS485 interface which can not be connected directly to the MCU, a MAX485
chip will bridge the TTL interface to RS485, as shown in Figure 4.
For PC users, either a USB-RS485 or RS232-RS485 converter will bridge the gap. A diagram is
depicted in Figure 5 and 6.
Figure 4 Connect Sensor to MCU via MAX485
Figure 5 Connect Sensor to PC via USB-RS485 converter
Figure 6 Connect Sensor to PC via RS232-RS485 Converter
Figure 7 Connect Sensor to Arduino Via MAX485 IC
Sensor Networking
Upto 32 URM04 sensors are able to join a network. Simply serially connect the sensors uses twisted
pair cables. A diagram is illustrated in Figure 7.
Figure 7 URM04 Networking
The sketch code:
# The Sample code for driving single URM04 measuring distance function
# Editor : Lauren
# Date
: 2012.2.8
# Ver
: 0.3
# Product: URM04 Ultrasonic sensor
# Specification
* Detecting range: 4cm-500cm
* Resolution
: 1cm
* Interface
: RS485
* Units: Range reported in cm
* Temperature sensor: 12 bits reading from serial port
# Description:
# finish driving single URM function
# if use the IO expansion shield to drive the urm sensors, the measuring rate
may be 20Hz or slower[if you want].
# The sample code is compatible with the Arduino IDE 1.0 and also the earlier
version.
#include "Urm4parser.h"
void setup(){
urmInit();
// Init the URM04 sensor
void loop(){
static unsigned long timePoint = 0;
runUrm4();
// Drive URM04 Sensor and transmit the protocol to the sens
or via RS485 interface
// (IO Expansion shield V5 for arduino)
decodeURM4();
// Read and get the distance value from the sensor
if(millis() - timePoint > 100){
PrintData();
// print the data
timePoint = millis();
PrintData();
delay(100);
void PrintData(){
Serial.print("Distance value:
for(int i = 0; i < urmAccount; i++){
Serial.print(urmData[i]);
Serial.print(" ");
for(int i = 0; i < urmAccount;i ++){
Serial.print(urmID[i],HEX);
Serial.print(" ");
Serial.println();
The library code: please place the library file Urm4parser.h in to the sketch folder.
# The library for the URM04 sketch
# Editor : Lauren
# Date
: 2012.2.8
# Ver
: 0.3
# Specification
* Resolution
: 1cm
* Interface
: RS485
# Description:
version.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#define printByte(args) Serial.write(args)
#else
#include "WProgram.h"
#define printByte(args) Serial.print(args,BYTE)
#endif
#define SerialPort Serial
#define urmAccount 1
// Init the account of the URM04 sensor
#define CommMAXRetry 40
#define TriggerPin 2
/******************** Variables ****************/
byte startAddr = 0x11; // Init the URM04 485 Address -- URM04 default address
= 0x11
byte readingStep;
byte cmdst[10];
int urmID[urmAccount];
unsigned int urmData[urmAccount];
unsigned long managerTimer = 20;
/******************** Functions ****************/
void urmInit();
void runUrm4();
void urmTrigger(int id);
void urmReader(int id);
void transmitCommands();
void decodeURM4();
void analyzeUrmData(byte cmd[]);
/****************** Init sensor ****************/
void urmInit(){
pinMode(TriggerPin,OUTPUT);
// TTL -> RS485 chip driver pin
digitalWrite(TriggerPin,LOW);// Turn the driver pin to LOW
ing mode for the RS485 interface
-> Turn on read
// Turn the drvier pin to HIGH -> Turn on code
transmitting mode for the RS485 interface
readingStep = 0;
startAddr = 0x11;
managerTimer = millis();
for(int i = 0 ;i < urmAccount; i ++){
ddress
//Init the URM04 command receiving a
urmID[i] = startAddr + i;
urmData[i] = 0;
SerialPort.begin(19200);
// Init the RS485 interface
// Also when you are driving the URM
04, you could open serial monitor to
// tracing the steps and data feedba
ck from URM04
SerialPort.println();
SerialPort.print("The URM ID: 0x");
ddress
SerialPort.print(urmID[i],HEX);
SerialPort.print(" ");
SerialPort.println(" ");
SerialPort.println("The default baudrate: 19200");
SerialPort.println("Start drive the sensors!");
for(int i = 0 ;i < 10; i++)
cmdst[i] = 0;
//init the URM04 protocol
cmdst[0]=0x55;
cmdst[1]=0xaa;
/********************* Drive URM04 and get the data code ********************
void runUrm4(){
// You could adjust the sensor measuring rate
by changing the managerTimer value
static unsigned long timer = 0;
static int num = 0;
//Set the URM04 id to be drived
if(millis() - timer > managerTimer){
digitalWrite(TriggerPin, HIGH);
5 interface
//Turn on transmitting mode for the RS48
switch(readingStep){
case 0:
urmTrigger(urmID[num]);
managerTimer = 40;
//set a interval after trigger the measur
ing
break;
case 1:
urmReader(urmID[num]);
managerTimer = 0;
eading distance command
break;
case 2:
//set a interval after transmitting the r
digitalWrite(TriggerPin, LOW); //Turn on reading mode for the RS485 int
erface
managerTimer = 10;
break;
default:
readingStep = 0;
a new measuring for the sensor
// Finish reading the distance and start
break;
if(readingStep < 2)
readingStep++;
//step manager
else readingStep = 0;
timer = millis();
/********************* Transmit Command via the RS485 interface *************
void urmTrigger(int id){
// The function is used to trigger the measuring
cmdst[2] = id;
cmdst[3] = 0x00;
cmdst[4] = 0x01;
transmitCommands();
SerialPort.println("Trigger!");
void urmReader(int id){
// The function is used to read the distance
cmdst[2] = id;
cmdst[3]=0x00;
cmdst[4]=0x02;
transmitCommands();
SerialPort.println("Ask for distance!");
void transmitCommands(){
// Send protocol via RS485 interface
cmdst[5]=cmdst[0]+cmdst[1]+cmdst[2]+cmdst[3]+cmdst[4];
delay(1);
for(int j = 0; j < 6; j++){
printByte(cmdst[j]);
delayMicroseconds(10);
delay(2);
/********************* Receive the data and get the distance value from the R
S485 interface ***************/
void decodeURM4(){
if(SerialPort.available()){
unsigned long timerPoint = millis();
int RetryCounter = 0;
byte cmdrd[10];
cmdrd[i] = 0;
int i=0;
SerialPort.println("OK");
boolean flag = true;
boolean valid = false;
byte headerNo = 0;
while(RetryCounter < CommMAXRetry && flag)
cmdrd[i]= SerialPort.read();
printByte(cmdrd[i]);
if(i > 7){
flag=false;
printByte(0xEE);
printByte(0xFF);
SerialPort.flush();
break;
if(cmdrd[i] == 0xAA){
headerNo = i;
valid = true;
if(valid && i == headerNo + 6){
printByte(0xDD);
printByte(0xFF);
flag = false;
break;
i ++;
RetryCounter = 0;
else{
RetryCounter++;
delayMicroseconds(15);
printByte(millis() - timerPoint);
if(valid)
analyzeUrmData(cmdrd);
else SerialPort.println("Invalid feedback");
mmand
//Get an invalid error co
void analyzeUrmData(byte cmd[]){
byte sumCheck = 0;
for(int h = 0;h < 7; h ++)
sumCheck += cmd[h];
if(sumCheck == cmd[7] && cmd[3] == 2 && cmd[4] == 2){
byte id = cmd[2] - startAddr;
urmData[id] = cmd[5] * 256 + cmd[6];
SerialPort.print(id);
SerialPort.print(":");
SerialPort.println(urmData[id]);
else if(cmd[3] == 2 && cmd[4] == 2){
SerialPort.print("Sum error");
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+247.565911+32.06845
