3387
3387
    ADAFRUIT
    RIVET SEMI-TUBE 0.250" BRASS
3387 数据手册
Adafruit LSM9DS1 Accelerometer + Gyro + Magnetometer 9-DOF Breakout Created by lady ada https://learn.adafruit.com/adafruit-lsm9ds1-accelerometer-plus-gyro-plus-magnetometer-9dof-breakout Last updated on 2021-11-15 06:52:12 PM EST ©Adafruit Industries Page 1 of 27 Table of Contents Overview 3 • New New NEW for 2020! 5 Pinouts 6 • • • • 7 7 8 8 Power Pins I2C Pins SPI Pins Interrupt & Misc Pins Assembly 9 • Prepare the header strip: • Add the breakout board: • And Solder! 9 10 10 Arduino Code 11 • • • • • • • Wiring for Arduino Download Arduino libraries Load Demo Sketch Library Reference Begin! Set Ranges Read data 11 13 14 16 16 17 17 Python & CircuitPython 18 • • • • • • • • • 18 18 19 20 21 21 22 23 24 CircuitPython Microcontroller Wiring I2C SPI Python Computer Wiring I2C SPI CircuitPython Installation of LSM9DS1 Library CircuitPython & Python Usage Full Example Code Python Docs 25 Downloads 25 • • • • • • • Files Schematic Classic/Blue Stemma QT/Black Fabrication Print Classic/Blue Stemma QT/Black ©Adafruit Industries 25 26 26 26 27 27 27 Page 2 of 27 Overview Add motion, direction and orientation sensing to your Arduino project with this all-inone 9-DOF sensor. Inside the chip are three sensors, one is a classic 3-axis accelerometer, which can tell you which direction is down towards the Earth (by measuring gravity) or how fast the board is accelerating in 3D space. The other is a 3axis magnetometer that can sense where the strongest magnetic force is coming from, generally used to detect magnetic north. The third is a 3-axis gyroscope that can measure spin and twist. By combining this data you can REALLY orient yourself. ©Adafruit Industries Page 3 of 27 We've carried the LSM9DS0 from ST for a while, and the LSM9DS1 is their latest offering. We thought this could really make for a great breakout, at a very nice price! Design your own activity or motion tracker with all the data... We spun up a breakout board that has all the extra circuitry you'll want, for use with an Arduino (or other microcontroller) The LSM9DS1 is not the same set of sensors as the LSM9DS0. Here are some of the differences • LSM9DS0 accelerometer has ±2/±4/±6/±8/±16 g ranges. The LSM9DS1 has ±2/±4/±8/±16 g (no ±6 g range) • LSM9DS0 magnetometer has ±2/±4/±8/±12 gauss ranges. The LSM9DS1 has ±4/±8/±12/±16 gauss ranges. So the LSM9DS0 has ±2 gauss low range where-as the LSM9DS1 has ±16 gauss high range • LSM9DS0 and LSM9DS1 gyros both have the same ±245/±500/±2000 dps ranges. There are other differences, for example we noticed the LSM9DS1 has slightly worse accuracy. The gyro angular zero-rate (±25 for the LSM9DS0 and ±30 for the LSM9DS1 at the highest sensing range). The accelerometer offset accuracy is ±90 mg for the LSM9DS1 and ±60 mg for the LSM9DS0. However, these offsets may not matter for most projects and the pricing of the LSM9DS1 is lower than the LSM9DS0 ©Adafruit Industries Page 4 of 27 The breakout board version of this sensor has both I2C and SPI interfaces. Attaching it to the Arduino is simple, power Vin and GND with 3-5VDC, and wire up I2C data on SCL and SDA, and you're ready to go! More advanced users can use SPI, our library has support for both. The breakout comes fully assembled and tested, with some extra header so you can use it on a breadboard. Four mounting holes make for a secure connection, and we put the popular power+data pins on one side, and the interrupt pins on the other side for a nice & compact breakout. New New NEW for 2020! The Classic Blue revision of the popular LSM9DS1 breakout has a new baby sister in Adafruit Black! Fabbed at 1 x 0.7 inches and weighing just a few grams, she's everything you like about the Classic Blue LSM9DS1 in a smaller package, and somehow we managed to add the new SparkFun qwiic (https://adafru.it/Fpw) compatible STEMMA QT (https://adafru.it/Ft4) connectors for the I2C bus so you don't even need to solder! Just wire one up to your favorite micro with a plug-and-play cable (https://adafru.it/JnB) and use our example code and libraries to measure those DoF's! ©Adafruit Industries Page 5 of 27 Pinouts ©Adafruit Industries Page 6 of 27 Power Pins The sensor on the breakout requires 3V power. Since many customers have 5V microcontrollers like Arduino, we tossed a 3.3V regulator on the board. Its ultra-low dropout so you can power it from 3.3V-5V just fine. • Vin - this is the power pin. Since the chip uses 3 VDC, we have included a voltage regulator on board that will take 3-5VDC and safely convert it down. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V • 3V3 - this is the 3.3V output from the voltage regulator, you can grab up to 100mA from this if you like • GND - common ground for power and logic I2C Pins • SCL - I2C clock pin, connect to your microcontrollers I2C clock line. This pin is level shifted so you can use 3-5V logic, and there's a 10K pullup on this pin. • SDA - I2C data pin, connect to your microcontrollers I2C data line. This pin is level shifted so you can use 3-5V logic, and there's a 10K pullup on this pin. See the back of the Adafruit Black version for the full pin labels. ©Adafruit Industries Page 7 of 27 SPI Pins If you're interested in using SPI to interface with the LSM9DS1, you can! • SCL - this is also the SPI clock pin, it's level shifted so you can use 3-5V logic input • SDA - this is also the SPI MOSI pin, it's level shifted so you can use 3-5V logic input • CSAG - this is the Accelerometer+Gyro subchip Chip Select, it's level shifted so you can use 3-5V logic input • CSM - this is the Magnetometer subchip Select, it's level shifted so you can use 3-5V logic input • SDOAG - this is the Accelerometer+Gyro subchip MISO pin - it's 3V logic out, but can be read properly by 5V logic chips. • SDOM/DOM- this is the Magnetometer subchip MISO pin - it's 3V logic out, but can be read properly by 5V logic chips. Interrupt & Misc Pins Since there's so many sensors in the LSM9DS1, there's quite a number of interrupt outputs. • DEN - this is a pin that supposedly could be used to dynamically enable/disable the Gyro. There's actually no documentation on it but we break it out for you anyways. • INT1 & INT2 - These are interrupts from the accelerometer/gyro subchip. We don't have specific library support for these so check the datasheet for what you can make these indicate. They are 3V-logic outputs • DRDY - this is the accelerometer/gyro subchip data ready output. We don't have specific library support for these so check the datasheet for how you can set the registers to enable this pin. It is a 3V-logic output. • INTM - This is the interrupt from the magnetometer subchip. We don't have specific library support for it so check the datasheet for what you can make it indicate. It is a 3V-logic output. Note that the pinouts for the new Adafruit Black Stemma QT version are slightly different, with the positions of the DRDY and INTM pins swapped when compared to the Classic Blue revision ©Adafruit Industries Page 8 of 27 Black/Stemma QT Version only • STEMMA QT Connectors (https://adafru.it/Ft4) - These connectors allow you to make solderless connections to dev boards and various other QT accessories (h ttps://adafru.it/Ft6) using Stemma QT cables (https://adafru.it/JnB) Assembly If you have the breadboard version of this sensor, you'll want to solder some header onto the sensor so it can be used in a breadboard. The Flora version does not require any extra assembly Prepare the header strip: Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down ©Adafruit Industries Page 9 of 27 Add the breakout board: Place the breakout board over the pins so that the short pins poke through the breakout pads And Solder! Be sure to solder all pins for reliable electrical contact. Solder the longer power/data strip first (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https://adafru.it/aTk)). ©Adafruit Industries Page 10 of 27 If you plan to use the interrupts and/or you want the board to sit flatter in a breadboard, solder up the other strip! You're done! Check your solder joints visually and continue onto the next steps Arduino Code Wiring for Arduino   Note that the new Adafruit black revision with Stemma QT connectors has some of the pin labels on the back of the board. See the Pinouts page for more information You can easily wire this breakout to any microcontroller, we'll be using a Metro, Adafruit's Arduino compatible board. For another kind of microcontroller, just make sure it has I2C or SPI, then port the code - its pretty simple stuff! Let's start with just I2C interfacing since it requires the fewest number of wires. Here is how you would wire up one of the newer revision boards with the black PCB by using the new Stemma QT connectors: ©Adafruit Industries Page 11 of 27 •  Connect board VIN (red wire) to Arduino 5V if you are running a 5V board Arduino (Uno, etc.). If your board is 3V, connect to that instead. • Connect board GND (black wire) to Arduino GND • Connect board SCL (yellow wire) to Arduino SCL • Connect board SDA (blue wire) to Arduino SDA If you prefer to use a breadboard wire up the sensor like this: •  Connect board VIN (red wire) to Arduino 5V if you are running a 5V board Arduino (Uno, etc.). If your board is 3V, connect to that instead. • Connect board GND (black wire) to Arduino GND • Connect board SCL (yellow wire) to Arduino SCL • Connect board SDA (blue wire) to Arduino SDA If you have one of the classic blue versions of  the LSM9DS1, you'll wire it up like so: ©Adafruit Industries Page 12 of 27 • Connect Vin to the power supply, 3-5V is fine. Use the same voltage that the microcontroller logic is based off of. For most Arduinos, that is 5V • Connect GND to common power/data ground • Connect the SCL pin to the I2C clock SCL pin on your Arduino. On an UNO & '328 based Arduino, this is also known as A5, on a Mega it is also known as digi tal 21 and on a Leonardo/Micro, digital 3 • Connect the SDA pin to the I2C data SDA pin on your Arduino. On an UNO & '328 based Arduino, this is also known as A4, on a Mega it is also known as digi tal 20 and on a Leonardo/Micro, digital 2 Download Arduino libraries To begin reading sensor data, you will need to download the Adafruit_LSM9DS1 librar y and the Adafruit_Sensor library from the Arduino library manager. Open up the Arduino library manager: ©Adafruit Industries Page 13 of 27 Search for the Adafruit LSM9DS1 library and install it Search for the Adafruit Unified Sensor library and install it (You may have to scroll down pretty far to find it) We also have a great tutorial on Arduino library installation at: http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https:// adafru.it/aYM) Load Demo Sketch Now you can open up File->Examples->Adafruit_LSM9DS1->lsm9ds1 and upload to your Arduino wired up to the sensor ©Adafruit Industries Page 14 of 27 Then open up the Serial console at 115200 baud to read the sensor output! You'll get 9 distinct data points, accelerometer x/y/z in meters/s 2, magetometer x/y/z in gauss and gyroscope in x/y/x degrees/second We suggest using this Adafruit_Sensor interface as shown in this demo, since it will let you swap sensors without having to worry about units compatibility. Try twisting and moving the board around to see the sensors change value. ©Adafruit Industries Page 15 of 27 Library Reference The library we have is simple and easy to use You can create the Adafruit_LSM9DS1 object with: Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1(); // i2c sensor I2C does not have pins, as they are fixed in hardware. If you're using "hardware" SPI, you will have to wire up the pins as follows: • SCL -> SPI CLK • SDA -> SPI MOSI • SDO_AG & SDO_M -> SPI MISO (both together) You can determine the hardware SPI pins for your Arduino here (https://adafru.it/d5h) Then pick two pins for the CS lines Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1(LSM9DS1_XGCS, LSM9DS1_MCS); If you don't want to use the hardware SPI, you can also try the soft SPI capability, which is bitbanged. You can basically use any pins you like! Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1(LSM9DS1_SCK, LSM9DS1_MISO, LSM9DS1_MOSI, LSM9DS1_XGCS, LSM9DS1_MCS); Begin! To initialize the sensor, call lsm.begin() which will check the sensor can be found. It returns true/false depending on these checks. We suggest you wrap begin() in a statement that will check if the sensor was located: if(!lsm.begin()) { /* There was a problem detecting the LSM9DS1 ... check your connections */ Serial.print(F("Ooops, no LSM9DS1 detected ... Check your wiring!")); while(1); } ©Adafruit Industries Page 16 of 27 Set Ranges These chips have tons of registers, we basically provide interface code for the most useful stuff, such as setting the range. Each subsensor has it's own range. Higher ranges have less precision but can measure larger movements! Set up the ranges with the setup functions: // 1.) Set the accelerometer range lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_2G); //lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_4G); //lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_8G); //lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_16G); // 2.) Set the magnetometer sensitivity lsm.setupMag(lsm.LSM9DS1_MAGGAIN_4GAUSS); //lsm.setupMag(lsm.LSM9DS1_MAGGAIN_8GAUSS); //lsm.setupMag(lsm.LSM9DS1_MAGGAIN_12GAUSS); //lsm.setupMag(lsm.LSM9DS1_MAGGAIN_16GAUSS); // 3.) Setup the gyroscope lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_245DPS); //lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_500DPS); //lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_2000DPS); Choose whichever range you like, after you begin() the sensor! Read data Read data using the Adafruit_Sensor API by first creating four events, one for each sub-sensor: sensors_event_t accel, mag, gyro, temp; Then pass these into the getEvent function lsm.getEvent(&accel, &mag, &gyro, &temp); The data is snapshotted at once, so you can read and manage the data later. For the Accelerometer event you can read accel.acceleration.x, accel.acceleration.y or accel.acceleration.z which are in meters/second*second. For the Magnetometer event you can read mag.magnetic.x, mag.magnetic.y or mag.m agnetic.z which are in gauss. For the Gyro event you can read gyro.gyro.x, gyro.gyro.y or gyro.gyro.z, which are in degrees-per-second (dps) ©Adafruit Industries Page 17 of 27 The temperature event data is in temp.temperature, but we don't guarantee that the temperature data is in degrees C Python & CircuitPython Note that the new Adafruit black revision with Stemma QT connectors has some of the pin labels on the back of the board. See the Pinouts page for more information CircuitPython Microcontroller Wiring First wire up a LSM9DS1 to your board exactly as shown on the previous pages for Arduino. You can use either I2C or SPI wiring, although it's recommended to use I2C for simplicity. I2C Here's an example of wiring a Feather M0 to the sensor with an I2C connection, either the new classic blue form factor, or the newer revisions either on a breadboard or using the Stemma QT connectors: It's easy to use the LSM9DS1 sensor with Python or CircuitPython, and the Adafruit CircuitPython LSM9DS1 (https://adafru.it/C5b) module.  This module allows you to easily write Python code that reads the accelerometer, magnetometer, and gyroscope from the sensor. ©Adafruit Industries Page 18 of 27 You can use this sensor with any CircuitPython microcontroller board or with a computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN). • Board 3V to sensor VIN • Board GND to sensor GND • Board SCL to sensor SCL • Board SDA to sensor SDA SPI Wiring up the LSM9DS1 to a Feather M0 using SPI is a bit more complicated due to the addition of two sets of Sensor Out and CS pins. Wiring for the newer or older versions of the board are pretty similar ©Adafruit Industries Page 19 of 27 • Board 3V to sensor VIN (Red) • Board GND to sensor GND (Black) • Board SCK to sensor SCL (Purple) • Board MOSI to sensor SDA (Green) • Board MISO to sensor SDOAG AND sensor DOM (Orange) • Board D5 to sensor CSAG (Yellow) • Board D6 to sensor CSM (Blue) To use the classic blue board with SPI • Board 3V to sensor VIN (Red) • Board GND to sensor GND (Black) • Board SCK to sensor SCL (Purple) • Board MOSI to sensor SDA (Green) • Board MISO to sensor SDOAG AND sensor SDOM (Orange) • Board D5 to sensor CSAG (Yellow) • Board D6 to sensor CSM (Blue) Python Computer Wiring Since there's dozens of Linux computers/boards you can use we will show wiring for Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to see whether your platform is supported (https://adafru.it/BSN).  ©Adafruit Industries Page 20 of 27 I2C • Pi 3V3 to sensor VIN • Pi GND to sensor GND • Pi SCL to sensor SCL • Pi SDA to sensor SDA SPI Here's the Raspberry Pi wired with SPI: ©Adafruit Industries Page 21 of 27 • Pi 3V3 to sensor VIN • Pi GND to sensor GND • Pi SCLK to sensor SCL • Pi MOSI to sensor SDA • Pi MISO to sensor SDOAG AND sensor SDOM • Pi GPIO5 to sensor CSAG • Pi GPIO6 to sensor CSM CircuitPython Installation of LSM9DS1 Library You'll need to install the Adafruit CircuitPython LSM9DS1 (https://adafru.it/C5b) library on your CircuitPython board.   First make sure you are running the latest version of Adafruit CircuitPython (https:// adafru.it/Amd) for your board. Next you'll need to install the necessary libraries to use the hardware--carefully follow the steps to find and install these libraries from Adafruit's CircuitPython library bundle  (https://adafru.it/zdx).  Our introduction guide has a great page on how to install the library bundle (https://adafru.it/ABU) for both express and non-express boards. Remember for non-express boards like the, you'll need to manually install the necessary libraries from the bundle: • adafruit_lsm9ds1.mpy ©Adafruit Industries Page 22 of 27 • adafruit_bus_device Before continuing make sure your board's lib folder or root filesystem has the adafrui t_lsm9ds1.mpy, and adafruit_bus_device files and folders copied over. Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the CircuitPython >>> prompt. CircuitPython & Python Usage To demonstrate the usage of the sensor we'll initialize it and read the accelerometer, magnetometer, and more from the board's Python REPL. Run the following code to import the necessary modules and initialize the I2C connection with the sensor: import board import adafruit_lsm9ds1 i2c = board.I2C() sensor = adafruit_lsm9ds1.LSM9DS1_I2C(i2c) If you're connected using SPI, run the following code to initialise the SPI connection with the sensor: import board from digitalio import DigitalInOut, Direction spi = board.SPI() csag = DigitalInOut(board.D5) csag.direction = Direction.OUTPUT csag.value = True csm = DigitalInOut(board.D6) csm.direction = Direction.OUTPUT csm.value = True sensor = adafruit_lsm9ds1.LSM9DS1_SPI(spi, csag, csm) Now you're ready to read values from the sensor using any of these properties: • acceleromter - A 3-tuple of X, Y, Z axis accelerometer values in meters/second squared. • magnetometer - A 3-tuple of X, Y, Z axis magnetometer values in gauss. • gyroscope - A 3-tuple of X, Y, Z axis gyroscope values in degrees/second. • temperature - The sensor temperature in degrees Celsius. print('Acceleration (m/s^2): ({0:0.3f},{1:0.3f}, {2:0.3f})'.format(*sensor.accelerometer)) ©Adafruit Industries Page 23 of 27 print('Magnetometer (gauss): ({0:0.3f},{1:0.3f}, {2:0.3f})'.format(*sensor.magnetometer)) print('Gyroscope (degrees/sec): ({0:0.3f},{1:0.3f}, {2:0.3f})'.format(*sensor.gyroscope)) print('Temperature: {0:0.3f}C'.format(sensor.temperature)) In addition you can adjust some properties by getting and setting their values: • accel_range - The range of the accelerometer, should be a value of ACCELRANGE_2G, ACCELRANGE_4G, ACCELRANGE_8G, or ACCELRANGE_16G from the adafruit_lsm9ds1 module.  The default is 2G. • mag_gain - The gain of the magnetometer, should be a value of MAGGAIN_4GAUSS, MAGGAIN_8GAUSS, MAGGAIN_12GAUSS, or MAGGAIN_16GAUSS from the adafruit_lsm9ds1 module.  The default is 4 gauss. • gyro_scale - The scale of the gyroscope, should be a value of GYROSCALE_245DPS, GYROSCALE_500DPS, or GYROSCALE_2000DPS from the adafruit_lsm9ds1 module.  The default is 245 DPS. sensor.accel_range = adafruit_lsm9ds1.ACCELRANGE_4G sensor.mag_gain = adafruit_lsm9ds1.MAGGAIN_8GAUSS sensor.gyro_scale = adafruit_lsm9ds1.GYROSCALE_500DPS See the simpletest.py example (https://adafru.it/C5d) for a complete demo of printing the accelerometer, magnetometer, gyroscope every second.  Save this as code.py on the board and examine the REPL output to see the range printed every second. That's all there is to using the LSM9DS1 with CircuitPython! Full Example Code # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT # Simple demo of the LSM9DS1 accelerometer, magnetometer, gyroscope. # Will print the acceleration, magnetometer, and gyroscope values every second. ©Adafruit Industries Page 24 of 27 import time import board import adafruit_lsm9ds1 # Create sensor object, communicating over the board's default I2C bus i2c = board.I2C() # uses board.SCL and board.SDA sensor = adafruit_lsm9ds1.LSM9DS1_I2C(i2c) # # # # # # # # # # SPI connection: from digitalio import DigitalInOut, Direction spi = board.SPI() csag = DigitalInOut(board.D5) csag.direction = Direction.OUTPUT csag.value = True csm = DigitalInOut(board.D6) csm.direction = Direction.OUTPUT csm.value = True sensor = adafruit_lsm9ds1.LSM9DS1_SPI(spi, csag, csm) # Main loop will read the acceleration, magnetometer, gyroscope, Temperature # values every second and print them out. while True: # Read acceleration, magnetometer, gyroscope, temperature. accel_x, accel_y, accel_z = sensor.acceleration mag_x, mag_y, mag_z = sensor.magnetic gyro_x, gyro_y, gyro_z = sensor.gyro temp = sensor.temperature # Print values. print( "Acceleration (m/s^2): ({0:0.3f},{1:0.3f},{2:0.3f})".format( accel_x, accel_y, accel_z ) ) print( "Magnetometer (gauss): ({0:0.3f},{1:0.3f},{2:0.3f})".format(mag_x, mag_y, mag_z) ) print( "Gyroscope (rad/sec): ({0:0.3f},{1:0.3f},{2:0.3f})".format( gyro_x, gyro_y, gyro_z ) ) print("Temperature: {0:0.3f}C".format(temp)) # Delay for a second. time.sleep(1.0) Python Docs Python Docs (https://adafru.it/C5e) Downloads Files • EagleCAD PCB files on GitHub (https://adafru.it/ub2) • Classic/Blue Fritzing object available in Adafruit Fritzing library (https://adafru.it/ LKA) ©Adafruit Industries Page 25 of 27 • Stemma QT/Black Fritzing object available in Adafruit Fritzing library (https:// adafru.it/LKB) LSM9DS1.pdf Datasheet https://adafru.it/ub3 Schematic Classic/Blue Stemma QT/Black ©Adafruit Industries Page 26 of 27 Fabrication Print Classic/Blue Stemma QT/Black ©Adafruit Industries Page 27 of 27
很抱歉,暂时无法提供与“3387”相匹配的价格&库存,您可以联系我们找货
库存:341
