109990039
109990039
    SEEED(矽递科技)
    MPR121 Touch, Capacitive Sensor Evaluation Board
109990039 数据手册
Page 1 of 2 Bare Conductive Touch Board SKU: 109990039 Description Introduction: The touch board is a tool to make your projects interactive, responsive, smart or just fun. Use the Touch Board to change the world around you by turning almost any material or surface into a sensor. Paint a lightswitch on you wall, make a paper piano or create something nobody’s thought of yet. Connect anything conductive to one of its 12 electrodes and trigger a sound via its onboard MP3 player, play a MIDI note or do anything else that you might do with an Arduino or Arduino-compatible device. The Touch Board uses Atmel’s ATMega32U4 Microprocessor to make the board easy to use, flexible and widely accessible. Built in USB hardware lets the Touch Board perform a variety of functions. Features: • • • • • • • • •   Touch and Distance sensing   No programming required   Arduino-compatible   Works great with Electric Paint   MP3 Player / MIDI device   Micro SD card socket   Standard 3.5mm audio jack   LiPo battery charger   HID capable Specification: • • • • • • • •   Atmel ATMega32U4 Microprocessor   Freescale MPR121 dedicated touch interface   VLSI VS 1053B audio processor   Arduino compatible   5V operating voltage (automatic voltage selector for USB or battery operation)   LiPo battery charging with boost circuit for 5V operation   16 MHz clock speed   Can be powered and programmed over USB Page 2 of 2 • • • • • •   20 digital I/O pins   7 PWM channels   12 analog input channels   12 Touch electrodes (8 can be configured as digital inputs or outputs with PW/M capability)   84mm x 62mm foot print with maximum height of 10mm   On/Off switch when powered from battery http://www.seeedstudio.com/depot/Bare-Conductive-Touch-Board-p-2156.html 2/2/2016
109990039 价格&库存
很抱歉,暂时无法提供与“109990039”相匹配的价格&库存,您可以联系我们找货
