AG931-07E
AG931-07E
    NVECORP
    AAT003-10E - Magnetic, Rotary Position Sensor Evaluation Board
AG931-07E 数据手册
AG931-07E AAT003 40 KΩ Angle Sensor Evaluation Kit SN12447 NVE Corporation (800) 467-7141 sensor-apps@nve.com www.nve.com Kit Overview Evaluation Kit Features • AAT003-10E Angle Sensor • Part # 12426 Split-Pole Alnico 5 Round Horseshoe Magnet • Unity-Gain Buffer Amplifier • 1.5 V to 5.5 V Power Supply • Magnet Locating Fixture AAT003-10E Features • Tunneling Magnetoresistance (TMR) Technology • Very High Output Signal Without Amplification • Wide Airgap Tolerance • 40 KΩ Nominal Bridge Resistance for Low Power • Sine and Cosine Outputs for Direction Detection • Ultraminiature TDFN6 Package AAT-Series Sensor Applications • Rotary Encoders • Motor Shaft Position Sensors • Battery-Powered Angle Sensors (AAT001-10E low-power version) AAT003-10E Angle Sensor Description The AAT003-10E angle sensor is a low power, high output magnetic sensor element for position measurements when a rotating magnetic field is applied. Sine and cosine signals are available for a quadrature output. The sensor element has a resistance of approximately 40 KΩ, allowing a lownoise interface to signal-processing circuitry while still maintaining low power. Outputs are proportional to the supply voltage and peak-to-peak output voltages are much larger than conventional sensor technologies. The part is packaged in NVE’s 2.5 mm x 2.5 mm x 0.8 mm TDFN6 surfacemount package Visit www.nve.com for complete AAT003 product specifications. Quick Start ⇒ Connect VCC1 and VCC2 to a 5 V power supply. ⇒ Connect the “SIN” and “COS” screw terminals to an oscilloscope or to meters. ⇒ Place the split-pole magnet in the Plexiglas pocket SLOT DOWN. ⇒ Rotate the magnet. VOLTAGE ⇒ The outputs should be similar to the following graph: 3 Sin 2.75 2.5 Cos 2.25 2 0 90 180 270 ROTATION 360 The output is insensitive to magnet spacing over a wide range. Signal is lost if the magnet is too far away; if the magnet is too close the outputs will be nonsinusoidal. A relatively large magnet-sensor airgap is possible with the magnet provided with the kit, although smaller magnets will require a smaller gap. Evaluation Board Layout AAT003-10E TMR angle sensor 100 nF decoupling capacitor Dual unity-gain buffer amplifier Large output signal Wide airgap tolerance Low power 5.5V max. sensor supply input VCC1 = 5.5V Max VCC2 = 1.5V to 5.5V Angular reticle (10° per division) 1.5V to 5.5V buffer amp power supply input GND RAW SIN 10° per division FCVe Pocket for split-pole magnet RAW COS VCC1 VCC2 SIN COS GND GND www.nve.com (800) GMR-7141 Raw sensor outputs (unbuffered) AG931-06 ©NVE Corporation © Cosine and sine buffered outputs Principles of Operation Each of the four sensor elements contains two magnetic layers: a “pinned,” or fixed direction layer; and a movable-direction, or “free” layer. Internal sensor pairs are 90° out of phase to provide quadrature outputs. The diagram below illustrates the configuration, using arrows to represent the magnetic orientation of the layers: Pinned Layer Fr ee La ye r Free layer aligns with applied magnetic field Ap pli ed (30 Ma to gne 20 tic 0 O Fi e) eld Angle between pinned and free layers determines sensor resistance The sensor element free layers will align with the external field. As the applied field changes direction, the angle between the free layer and the pinned layer changes, changing the resistance of spintronic Tunneling Magnetoresistance (TMR) elements, which changes the device output voltages. In the typical configuration, an external magnet provides a saturating magnetic field (30 to 200 Oe) in the plane of the sensor, as demonstrated in this kit. Depending on the application, a bar magnet can also be used instead of a splitpole magnet. PCB Assembly Raw output signals from the AAT003 are available as test points on the board. The PCB assembly also includes a unity-gain buffer that provides lowimpedance outputs and buffers the sensor bridge from loading by downstream electronics. Ouput buffering may not be necessary in the end application depending on the impedance of the connections to the outputs of the board. AAT003-10E 1 Vcc 100 nF R3 (Cosine) 6 Vcc - R2 (Sine) 5 Sin 2 Cos 1.5 V to 5.5 V R1 (Sine) 0V to 5.5 V + VCC1 VCC2 SIN COS GND Raw Sin Raw Cos GND 3 R4 (Cosine) GND 4 + TSV622 100 nF AG931-07E Evaluation Kit schematic. Separate power supply connections for the sensor and op amp (VCC1 and VCC2) allow monitoring the current requirements of the sensor only. The minimum op amp supply voltage is 1.5 V, while the AAT003 sensor has no minimum. Sensitivity increases proportionately to the sensor supply voltage, as does current consumption. VCC1 and VCC2 can be connected together if desired. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this document are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. Manual No.: SN12447
AG931-07E 价格&库存
很抱歉,暂时无法提供与“AG931-07E”相匹配的价格&库存,您可以联系我们找货
AG931-07E
  • 1+715.542581+92.99896
