AG932-07E
Rotation Sensor
Evaluation Kit
SB-00-047A
NVE Corporation
(800) 467-7141
sensor-apps@nve.com
www.nve.com
Kit Overview
Included in the Evaluation Kit
• ADT002-10E rotation sensor
• Part # 12426 split-pole Alnico 5 round horseshoe magnet
• Circuitry and indicators for direction and quadrant
• Plastic magnet locating fixture
• Battery powered
ADT001/ADT002 Sensor Features
• Extremely low power (3 A typ. at 3.3 V)
• Wide airgap tolerance
• Integrated fault detection
• 2.4 V tο 5.5 V supply range
• −40°C tο +125°C operating range
• Ultraminiature TDFN6 package
ADT001/ADT002 Applications
• Water meters
• Rotational speed sensors
• Rotational position sensors
ADT001/ADT002 Sensor Description
The ADT001 and ADT002 rotation sensors are ultralow power, digital-output
magnetic rotational sensors. Two outputs are 90 degrees out of phase to provide
directional information. The ADT001 is high hysteresis for high noise
immunity in applications such as speed sensing; the ADT002 is low hysteresis
to provide accurate, absolute rotational quadrant information.
An additional output indicates a fault if the magnetic field is too high for
accurate measurements. This can occur if the magnet is too close to the sensor,
or with interference from an adjacent magnet.
The heart of the unique sensor is an array of four Tunneling Magnetoresistance
(TMR) elements in each quadrant. TMR technology enables low power and
miniaturization, making the sensors ideal for battery operation.
Visit www.nve.com for complete product specifications and reference designs.
Quick Start
⇒ Place the horseshoe magnet in the Plexiglas pocket.
⇒ Ensure both power jumpers are in place.
⇒ Turn the power switch ON.
⇒ Rotate the magnet and observe the indicator LEDs.
⇒ Turn the power OFF when not in use so the LEDs do not drain the battery.
Magnets
The sensor is accurate over a wide range of magnet spacing, especially with the
relatively strong magnet provided with the kit. Smaller or weaker magnets may
require closer spacing.
Low-cost radially-magnetized ferrite disk magnets can be used with these
sensors in production. Bar magnets can also be used in some configurations.
Evaluation Board Layout
Indicator LEDs
ADT002:
* Precise
* Digital outputs
* Wide airgap
* 2.4-5.5V supply
* Idd=3µA typ.@3V
ADT002-10E
rotation sensor
Demonstration
circuitry ICs
FAULT
SIN
Sensor output
test points
NVE
Sensor Ckt
pwr
pwr
Pocket for
horseshoe
magnet
COS
GND
CR1225 (3V)
OFF ON
www.nve.com
(800) GMR-7141
AG932-06
©NVE
Corporation
Jumpers for sensor
and circuitry power
3V battery
ON/OFF switch
Overview of Operation
ADT00X sensors contain four sensor elements—one in each quadrant. In a
typical sensor configuration, an external magnet provides a saturating magnetic
field (30 to 200 Oe) in the plane of the sensor, as demonstrated in this kit.
Mathematically, the outputs correspond to the sign of the sine and cosine of the
rotation, i.e., sgn(sinθ) and sgn(cosθ), as shown below:
Cos
Sin
90˚
180˚ 270˚
Rotation (CCW)
360˚
The sensor truth table is as follows:
Angle
0 -90
90 -180
180 -270
270 -360
Output
Sin
Cos
H
H
H
L
L
L
L
H
Thus the sensor outputs define the quadrant of rotation:
Evaluation Board Circuitry
The PCB assembly includes simple circuitry to drive LEDs from the sensor
outputs.
A 3-volt lithium button cell powers the evaluation board. Jumpers allow the
circuitry to be disabled or powered separately, or jumper connections can be
used to monitor the remarkably low sensor supply current.
The indicator LEDs are driven by 74LVC-Series CMOS logic. A 74LVC2G34
buffer drives red and orange indicator LEDs for the Sin and Cos sensor outputs.
A 74LVC1G139 decodes the sensor truth table, providing four outputs that drive
the quadrant-indicating yellow LEDs.
Sensor Circuitry
74LVC
2G34
ON/OFF
CR1225
(3V nom.)
ta
Angular
Sensor
Sin
2
FAULT
3
t io n
Vdd
1
ADT002-10E
Rotation Sensor
Ro
4.02K
3
4
1
6
3.32K
GND
6
Sin
Cos
2
1.69K
Cos
5
Fault
Sensor
5
8
1
A Y3
Y2
Y1
2
B Y0
4
3
0˚- 90˚
5
90˚- 180˚
270˚- 360˚
6
7
180˚- 270˚
74LVC
1G139
Limited Warranty and Liability
Information in this document is believed to be accurate and reliable. However, NVE does not give
any representations or warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such information. In no event
shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including,
without limitation, lost profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such damages are based on tort
(including negligence), warranty, breach of contract or any other legal theory.
Right to Make Changes
NVE reserves the right to make changes to information published in this document including, without
limitation, specifications and product descriptions at any time and without notice.
Use in Life-Critical or Safety-Critical Applications
Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or
equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and
such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such
application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless
against all claims and damages.
Applications
Applications described in this document are illustrative only. NVE makes no representation or warranty
that such applications will be suitable for the specified use without further testing or modification.
Customers are responsible for the design and operation of their applications and products using NVE
products, and NVE accepts no liability for any assistance with applications or customer product design.
It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the
customer’s applications and products planned, as well as for the planned application and use of
customer’s third party customers. Customers should provide appropriate design and operating
safeguards to minimize the risks associated with their applications and products. NVE does not accept
any liability related to any default, damage, costs or problem which is based on any weakness or
default in the customer’s applications or products, or the application or use by customer’s third party
customers. The customer is responsible for all necessary testing for the customer’s applications and
products using NVE products in order to avoid a default of the applications and the products or of the
application or use by customer’s third party customers. NVE accepts no liability in this respect.
An ISO 9001 Certified Company
NVE Corporation
11409 Valley View Road
Eden Prairie, MN 55344-3617
©NVE Corporation
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written
consent of the copyright owner.
Manual No.: SB-00-047A
很抱歉,暂时无法提供与“AG932-07E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+813.236041+105.41088
