SparkFun UV Sensor Breakout - ML8511
S EN -12 705 RO HS
images are CC BY-NC-SA 3.0
3D Download: Sketchup, STL, Blender
Description: The ML8511 breakout is an easy to use ultraviolet light sensor. The
MP8511 UV (ultraviolet) Sensor works by outputing an analog signal in relation to the
amount of UV light that’s detected. This breakout can be very handy in creating
devices that warn the user of sunburn or detect the UV index as it relates to weather
conditions.
This sensor detects 280-390nm light most effectively. This is categorized as part of
the UVB (burning rays) spectrum and most of the UVA (tanning rays) spectrum. It
outputs a analog voltage that is linearly related to the measured UV intensity
(mW/cm2). If your microcontroller can do an analog to digital signal conversion then
you can detect the level of UV!
https://www.sparkfun.com/products/12705
11/17/2015
很抱歉,暂时无法提供与“SEN-12705”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+244.28520
- 200+97.47000
- 500+94.21920
- 1000+92.61000
