EVAL-KXR94-2050
EVAL-KXR94-2050
    KIONIX(Kionix传感器)
    KXR94-2050 - Accelerometer, 3 Axis Sensor Evaluation Board
EVAL-KXR94-2050 数据手册
KXR94 Series Accelerometers and Inclinometers FEATURES MARKETS APPLICATIONS Small Package - 5x5x1.2mm DFN Multiplexed Analog or Digital SPI Interface Internal 1KHz Low Pass Filter Automotive \\ Stability Control Telematics/GPS Theft and Accident Alarms Low Noise Lead-free Solderability Excellent Temperature Performance High Shock Survivability Personal Navigation Devices Inertial Navigation and Dead Reckoning Low Power Consumption Cell Phones and Handheld PDAs User Definable Bandwidth Factory Programmable Offset and Sensitivity Self-test Function Gesture Recognition Cameras and Video Equipment Image Stabilization Industrial Platform Stabilization Drill Orientation PROPRIETARY TECHNOLOGY These high-performance silicon micromachined linear accelerometers and inclinometers consist of a sensor element and an ASIC packaged in a 5x5x1.2mm Dual Flat No-lead (DFN). The sensor element is fabricated from single-crystal silicon with proprietary Deep Reactive Ion Etching (DRIE) processes, and is protected from the environment by a hermetically-sealed silicon cap at the wafer level. The KXR94 series is designed to provide a high signal-to-noise ratio with integrated temperature compensation that provides excellent performance over temperature. These sensors can accept supply voltages between 2.5V and 5.25V. Sensitivity is factory programmable allowing customization for applications requiring from ±1.0g to ±4.0g ranges. Sensor bandwidth is user-definable. The sensor element functions on the principle of differential capacitance. Acceleration causes displacement of a silicon structure resulting in a change in capacitance. An ASIC, using a standard CMOS manufacturing process, detects and transforms changes in capacitance into an analog output voltage, which is proportional to acceleration. The sense element design utilizes common mode cancellation to decrease errors from process variation and environmental stress. Available in analog and multiplexed analog outputs and serial peripheral interface (SPI). 36 Thornwood Dr. - Ithaca, NY 14850 USA tel: 607-257-1080 - fax: 607-257-1146 - www.kionix.com - info@kionix.com “Kionix” is a registered trademark of Kionix, Inc. Products described herein are protected by patents issued or pending. Information provided in this document is believed to be accurate and reliable but is not guaranteed. Kionix does not assume responsibility for its use or distribution. No license is granted by implication or otherwise under any patent or other rights of Kionix. Kionix reserves the right to change product specifications or discontinue this product at any time without prior notice. © Kionix 2012 All Rights Reserved January 26, 2012 Rev. 2.3 Page 1 of 2 KXR94 Series Accelerometers and Inclinometers PERFORMANCE SPECIFICATIONS The performance parameters below are programmed and tested at 3.3 volts. However, the device can be factory programmed to accept supply voltages from 2.5 V to 5.25 V. Performance parameters will change with supply voltage variations. PERFORMANCE SPECIFICATIONS PARAMETERS Range UNITS KXR94-2050 g 1 Sensitivity KXR94-2353 ±2.0 CONDITION Factory programmable mV/g 660 typical (673 max) Not applicable counts/g Not applicable 819 target (835 max) 12-bit operation 0g Offset vs. Temp. mg/°C ±0.2 typical Sensitivity vs. Temp %/°C ±0.01 (xy) ±0.02 (z) typical g / Hz 45 typical Hz 800 -3dB % of FS 0.1 typical % of full scale output % ±1.25 (xy) ±0.2 (z) typical 3.3V ± 5% Noise Density Bandwidth 2 Non-Linearity Ratiometric Error Cross-axis Sensitivity % A/D Conversion Time µS Not applicable 40 typical MHz Not Applicable 5 typical SPI Communication Rate 3 Power Supply 2.0 typical V 3.3 mA Current Consumption Standard 1.03 typical 0.95 typical µA Operating 5 max Standby ENVIRONMENTAL SPECIFICATIONS PARAMETERS UNITS KXR94-2050 KXR94-2353 CONDITION -40 to 85 (Consumer/Industrial) Operating Temperature °C Storage Temperature °C -55 to 150 Mechanical Shock g 5000 ESD V 3000 Powered -40 to 125 (Automotive) Un-powered Powered or un-powered, 0.5 msec halversine Human body model NOTES 1 Custom ranges from 1.0g to 4.0g available. 2 Internal low pass filter. Lower frequencies are user definable with external capacitors. 3 SPI communication rate can be optimized for faster communication. ORDERING GUIDE Axis(es) of Sensitivity Range (g) Sensitivity Offset Operating Voltage (V) Ouput Temperature (°C) Package KXR94-1050 XYZ 2 560 (mV/g) 1.4 V 2.8 Mux Analog -40 to +85 5x5x1.2 DFN KXR94-2050 XYZ 2 660 (mV/g) 1.65V 3.3 Mux Analog -40 to +85 5x5x1.2 DFN KXR94-2283 XYZ 2 1000 (mV/g) 2.5V 5.0 Mux Analog -40 to +85 5x5x1.2 DFN KXR94-2353 XYZ 2 819 (counts/g) 2048 counts 3.3 Digital SPI -40 to +85 5x5x1.2 DFN KXR94-7050 XYZ 2 660 (mV/g) 1.65V 3.3 Mux Analog -40 to 125 5x5x1.2 DFN Product © Kionix 2012 All Rights Reserved January 26, 2012 Rev. 2.3 Page 2 of 2
EVAL-KXR94-2050 价格&库存
很抱歉,暂时无法提供与“EVAL-KXR94-2050”相匹配的价格&库存,您可以联系我们找货
EVAL-KXR94-2050
  • 5+368.560085+47.66484
