Triple Axis Accelerometer BMA220(Tiny) SKU:SEN0168
Analog Gas Sensor(MQ2) SKU:SEN0127
Contents
1 Introduction
2 Specification
3 Connecting Diagram
4 Sample Code
Introduction
This Triple Axis Accelerometer with Bosch BMA220 is an ultra small triaxial, low-g acceleration
sensor breakboard with I2C interface, aiming for lowpower consumer market applications. It allows
measurement of accelerations in 3 perpendicular axes and thus senses tilt, motion, shock and
vibration in cell phones, handhelds, computer peripherals, man-machine interfaces, virtual reality
features and game controllers.
With a size of only 2 mm x 2 mm, the Bosch BMA220 represents a new generation of acceleration
sensors. The Tri-Axis Accelerometer integrates a multitude of features that acilitates its use
especially in the area of motion detection applications, such as device orientation detection, gaming,
HMI and menu browser control. It is highly configurable in order to give the designer full flexibility
when integrating the sensor into his system.
It can be used in sensing tilt, motion and shock vibrati
By the way, we have collected some useful 3-axis data processing methods: How to Use a ThreeAxis Accelerometer for Tilt Sensing.
Specification
Power supply: 2.0-3.6V
Interface: I2C
Acceleration range:±2g/±4g/±8g/±16g
Ultra Low Power
LED power indication
Tiny size design and easy-to-use
Compatible with Arduino controllers
Connecting Diagram
Sample Code
#include
byte Version[3];
int8_t x_data;
int8_t y_data;
int8_t z_data;
byte range=0x00;
float divi=16;
float x,y,z;
void setup()
Serial.begin(9600);
Wire.begin();
Wire.beginTransmission(0x0A); // address of the accelerometer
// range settings
Wire.write(0x22); //register address
Wire.write(range); //can be set at"0x00""0x01""0x02""0x03", refer to Datash
het on wiki
// low pass filter
Wire.write(0x20); //register address
Wire.write(0x05); //can be set at"0x05""0x04"......"0x01""0x00", refer to D
atashhet on wiki
Wire.endTransmission();
void AccelerometerInit()
// reset the accelerometer
Wire.write(0x04); // Y data
Wire.requestFrom(0x0A,1);
while(Wire.available())
// request 6 bytes from slave device #2
// slave may send less than requested
Version[0] = Wire.read(); // receive a byte as characte
x_data=(int8_t)Version[0]>>2;
Wire.write(0x06); // Y data
Version[1] = Wire.read(); // receive a byte as characte
y_data=(int8_t)Version[1]>>2;
Wire.write(0x08); // Y data
Version[2] = Wire.read(); // receive a byte as characte
z_data=(int8_t)Version[2]>>2;
x=(float)x_data/divi;
y=(float)y_data/divi;
z=(float)z_data/divi;
Serial.print("X=");
Serial.print(x);
Serial.print("
Serial.print("Y=");
// print the character
Serial.print(y);
Serial.print("
Serial.print("Z=");
Serial.println(z);
void loop()
switch(range)
//change the data dealing method based on the range u've set
case 0x00:divi=16;
break;
case 0x01:divi=8;
break;
case 0x02:divi=4;
break;
case 0x03:divi=2;
break;
default: Serial.println("range setting is Wrong,range:from 0to 3.Please che
ck!");while(1);
AccelerometerInit();
delay(100);
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0168”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+43.355861+5.61610
- 国内价格 香港价格
- 1+43.214281+5.59776
