SEN0147
SEN0147
    DFROBOT
    SMARTGRAYSCALESENSOR
SEN0147 数据手册
    Smart Grayscale sensor SKU:SEN0147 WiFi Bee V1.0 (SKU:SEN0147) Contents     1 Introduction 2 Specifications 3 Tools need 4 Change the sensor between Analog and Digital 4.1 Analog mode 4.2 Digital mode Introduction This time we reinvented the line-tracking sensor. Beyond recognizing two specific colors or output through digital or analog only, the Smart Gray Sensor has integrated both digital and analog output features. In digital mode, user can have two color data recorded through simple button operation, to achieve two-color detections with high and low outputs, and requires no more configuration after being set. In analog mode, the output value reacts precisely to the color grayscale detected. Apart from being a stable and adaptative sensor in various environments, the Smart Grayscale Sensor also demonstrates a great potential in low-cost projects of color, grayscale and adjacence lights. Specifications       Supply voltage: 5v Interface Mode: Digital / Analog Output: Analog mode :0-5v output Digital mode: TTL level output (0v or 5v) according to application needs Digital switching signal feedback and dual analog gradation feedback You can set the digital mode supports color detection Dimensions: 37x10x15mm Tools need   Smart Grayscale sensor V1.0 Arduino controller Change the sensor between Analog and Digital Just short click the button and the mode will be changed between analog and digital. Analog mode Grayscale Sensor Connection Diagram in analog mode In analog mode, the brighter the Sensor detects, the brighter LED will be. You can connect the sensor to analog pin to read the Grayscale from the sensor, just as the normal grayscale sensor. Code Example: int grayscalePin=0; void setup() { Serial.begin(9600); Serial.println("Smart Grayscale sensor:"); } void loop() { Serial.print("Grayscale:"); Serial.println(analogRead(grayscalePin)); delay(500); } Digital mode In digital mode, you can set the logic of two different color by your own. 1. Long click the button until the LED slow blinking (which means first color detecting ready). 2. Let the grayscale sensor face to the first color (such as white paper) 3. Meanwhile short click the button and the LED gets dark (which means first color detected). 4. Short click the button and make the LED fast blink (which means second color detecting ready). 5. Let the grayscale sensor face to the second color (such as black paper) 6. Meanwhile short click the button and the LED gets dark (which means second color detected). 7. The first color (such as white paper) will be Logical '1', and the LED becomes bright. 8. The second color (such as black paper) will be Logical '0', and the LED becomes dark. 9. This setting maintains even if the power is off, so for one purpose, one setting is enough. LED gets dark when facing the black paper LED gets bright when facing the white paper Grayscale Sensor Connection Diagram in digital mode Code Example: int grayscalePin=8; void setup() { Serial.begin(9600); pinMode(grayscalePin,INPUT); Serial.println("Smart Grayscale sensor:"); } void loop() { Serial.print("Grayscale:"); if(digitalRead(grayscalePin)) { Serial.println("White detected"); } else { Serial.println("Black detected"); } delay(500); }                             Powered By DFRobot © 2008-2017
SEN0147 价格&库存
很抱歉,暂时无法提供与“SEN0147”相匹配的价格&库存,您可以联系我们找货
