Triple Axis Accelerometer Breakout ‐ ADXL345 (SKU:SEN0032)
Contents
1 Introduction
2 Specification
3 Application
4 Connection Diagram
5 Sample Code
6 Result
Introduction
Breakout board for the Analog Device ADXL345. The ADXL345 is a small, thin, low power, 3-axis
accelerometer with high resolution (13-bit) measurement at up to ±16 g. Digital output data is
formatted as 16-bit twos complement and is accessible through either a SPI (3- or 4-wire) or I2C
digital interface. The ADXL345 is well suited to measures the static acceleration of gravity in tiltsensing applications, as well as dynamic acceleration resulting from motion or shock. Its high
resolution (4 mg/LSB) enables measurement of inclination changes less than 1.0°.
Several special sensing functions are provided. Activity and inactivity sensing detect the presence or
lack of motion and if the acceleration on any axis exceeds a user-set level. Tap sensing detects
single and double taps. Free-fall sensing detects if the device is falling. These functions can be
mapped to one of two interrupt output pins. An integrated, patent pending 32-level first in, first out
(FIFO) buffer can be used to store data to minimize host processor intervention. Low power modes
enable intelligent motion-based power management with threshold sensing and active acceleration
measurement at extremely low power dissipation.
Specification
Working voltage: 3.3~6V
Current consumption @2.5v: 40uA / working mode, 0.1uA / standby mode
Communication interface: I2C / SPI (3 or4 lines)
Application
Tap/Double Tap Detection
Free-Fall Detection
Selecting Portrait and Landscape Modes
Tilt sensing
Connection Diagram
This diagram is an IIC connection method suitable with Arduino UNO. It would be differen if you use
other Arduino Controllers which the SCL & SDA pin might be different. And if you want to use SPI
interface, please refer to ADXL345 datasheet for more info.
Connection Diagram
By the way, we have collected some useful 3-axis data processing methods: How to Use a ThreeAxis Accelerometer for Tilt Sensing.
https://www.dfrobot.com/wiki/index.php/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
Result
Open the Serial monitor to see the 3-axis acceleration data and Roll-Pitch angle. See changs as you
sway the Accelerometer.
https://www.dfrobot.com/wiki/index.php/How_to_Use_a_ThreeAxis_Accelerometer_for_Tilt_Sensing
Result in Arduino IDE serial monitor
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0032”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+69.783851+9.02615
