CUSTOMER’S APPROVAL
COMPANY _________________
SIGNATURE _________________
DATE _________________
This product specification is subject to change without noice.
Please return one copy with your signature on this page for approval.
1.
SPECIFICATION
Model
Image device
TV Type
Effective Pixels
Cell Size
Horizontal Resolution
Sync. Type
Scanning System
Scanning System
32KM NTSC
1/3″ PIXEL CMOS
SENSOR PC1089K
NTSC
728(H) x 488(V) 380K
32KM PAL
PAL
6.35㎛(H) x 7.40㎛(V)
More than 520 TV Lines
Internal
2:1 Interlace 2:1 Interlace
15.735KHz
Scanning Frequency (H)
Scanning Frequency (V)
Video Output
Gamma Correction
Sensitivity
S/N Ratio
Gain Control Gain
Control
Electronic Shutter
Power Supply
Consumption Current
Reverse Polarity
Lens Mount
Operation Temp
Operation Temp
15.625KHz
60Hz
1.0 vpp Composite (75Ω)
0.45 typ.
0.2 Lux @ F2.0
More than 42Db (AGC
OFF)
Automatic Automatic
50Hz
1/60 ~ 1/100,000sec Auto
Regulated DC12.0V (6V ~
20V)
Max 50mA
Yes
Fixed Lens Mount
10 50℃ (H idit 10%RH
60%RH) 10 ~ 50℃
(Humidity: 10%RH ~ 60%
RH)
1/50 ~ 1/100,000sec Auto
20 ~ 70℃ (Humidity: 10%
RH ~ 60%RH)
Preservation Temp
32mm(H) x 32mm(W)
Dimensions
Weight
Lens Options
Approx. 26g
Board
Pinhole
Varifocal
f=3.6(Standard) / 2.2 / 2.9 /
RoHS
Varifocal
Compliant
Varifocal
Compliant
Varifocal
Compliant
2. DIMENSION (mm)
3. INTERFACE SPECIFICATION
4.3 / 6 / 8 / 12mm
Flat/Cone Pinhole:
f=3.7(Standard) / 2.8 / 4.3mm
Manual Varifocal: 4~8mm,
28~12mm
28~12mm
3.1) Picture Status
3.2) I/O CONNECTOR FUNCTION
DC12.0V (RED)
GND(BLACK)
VIDEO OUT(YELLOW)
3.3) I/O Harness
DC POWER INPUT(DC12V)
GROUND
VIDEO SIGNAL OUTPU
很抱歉,暂时无法提供与“SEN-11745”相匹配的价格&库存,您可以联系我们找货
