Page 1 of 2
SparkFun Wake on Shake
S EN -11 447 RO HS
images are CC BY-NC-SA 3.0
Description: Have you ever wanted your project to just “hibernate” until someone
picks it up or moves it? It’s a great strategy for dramatically extending the battery life
of a widget that doesn’t need to be active all the time. The SparkFun Wake-on-Shake
board is designed to make it really simple to do just that!
The Wake-on-Shake, based on a concept by Nitzan Gadish of Analog Devices,
combines the ATTiny2313A with the ADXL362 low-power MEMS accelerometer to cut
power to your project for long periods of time, all the while waiting for a shake or a
bump and sipping < 2uA @ 3.7V! With power consumption that low, the limiting factor
for lifespan in most devices will be aging-related self-discharge of the batteries.
The board is easy to use, you basically connect it as a power switch between your
device and a power source (2.0-5.5V). By default, the board will activate the load
when it experiences a mild bump or tilt; the load will be powered for 5 seconds after
that. Using a serial data connection, the sensitivity can be increased or decreased, as
can the delay time. Additionally, the “WAKE” pin allows the load to control when it
goes back to sleep. By pulling the wake signal high (to at least 2.7V), the load will
remain energized until it releases the pin.
Note: While it is possible to connect the load to the on-board serial port, allowing the
load to access the ADXL362 and EEPROM storage of the ATTiny2313A, caution
must be exercised when doing this to avoid sourcing current to the load through the
serial port data lines on the ATTiny2313A, which could damage the ATTiny2313A as
well as causing excessive off-state power dissipation.
Page 2 of 2
Features:
Supply Voltage: 2.0 - 5.5VDC
Power Consumption in Hibernation: < 2uA @ 3.7V
Wake Signal: 2.7 - 15V
Serial Header for Configuration is FTDI Basic Breakout Compatible
ISP Header for ATTiny2313A is Broken Out, No Bootloader is Available
2mm JST Connector for LiPo Battery Input
https://www.sparkfun.com/products/11447
10/14/2015
很抱歉,暂时无法提供与“SEN-11447”相匹配的价格&库存,您可以联系我们找货
