BMA180
Digital, triaxial acceleration sensor
Bosch Sensortec
General description
The BMA180 is an ultra high performance digital
The BMA180 is highly configurable in order to give the
triaxial acceleration sensor, aiming for low power
designer full flexibility when integrating the sensor
consumer market applications.
into his system. All features can be set by software
via the digital interface. Here the user can choose
The BMA180 allows high accurate measurement of
between an I²C and an SPI (4-wire) interface mode.
accelerations in 3 perpendicular axes and thus senses tilt, motion, shock and vibration in cell phones,
handhelds, computer peripherals, man-machine interfaces, virtual reality features and game controllers.
BMA180 target applications
ff Navigation (INS / Dead Reckoning)
Technical data
ff High accurate tilt detection
Sensitivity axes
(e.g. tilt compensated compass)
Measurement range
ff Pointing and menu scrolling
(switchable via SPI / I²C)
ff Display profile switching (portrait / landscape)
Sensitivity (calibrated)
ff Gaming
BMA180
x / y / z
±1g, ±1.5g, ±2g, ±3g, ±4g,
±8g, ±16g
1g: 8192LSB/g
1.5g: 5460LSB/g
ff Drop detection for warranty logging
2g: 4096LSB/g
ff Shock detection
3g: 2730LSB/g
ff Step-counting
4g: 2048LSB/g
8g: 1024LSB/g
Sensor operation
The BMA180 represents a new generation of digital
16g:
Resolution
acceleration sensors with a unique performance and
(±2g range)
feature set within 3 mm x 3 mm x 0.9 mm standard
LGA package.
(switchable 12 bit option)
Nonlinearity
±0.15% FS (±2g range)
Zero-g offset (ex-factory)
Zero-g offset
Key features BMA180
±15mg
±5mg
(after offset fine tuning)
Zero-g offset
±0.5mg/K
ff All parameters and features user programmable
temperature drift
ff 7 user programmable g-ranges and 10 selectable
Noise density
bandwidth settings
512LSB/g
14bit 0.244mg
150µg / √Hz
Bandwidth
low pass
ff Low-power consumption
(switchable
high pass
ff Ultra-low-power self-wake-up mode
via SPI/I²C)
band pass
ff User programmable interrupt engine
Digital input / output
ff 0g offset regulation and in-field offset re-calibration
Supply
V DD
1.62 ... 3.6V
voltages
V DDIO
1.20 ... 3.6V
with ultra-high accuracy
ff SPI (4-wire) / I²C interface
Current consumption
ff RoHS compliant, halogen-free
Temperature range
10Hz ... 1200Hz
1Hz
0.2 ... 300Hz
SPI & I²C, interrupt pin
650µA
-40°C … +85°C
2
Bosch Sensortec
BMA180
BMA180 Pin configuration (top view)
One of the key elements of the BMA180 is the intelligent interrupt engine that gives the hard- and software
DNC
designer full control. Various motion detection scenarios can be identified by the BMA180 and signaled
to the system via a simple interrupt pin. By using the
digital serial interface, the exact details of the motion
event that triggered the interrupt can be read-out.
Following motion detection use case scenarios are
supported by the interrupt engine:
DNC
1
VDD
2
VSS
3
INT
4
CSB
5
ff Any-motion (slope) detection
ff Tap sensing
12
11
DNC
10
VDDIO
BMA180
(top view)
6
9
SDI
8
SDO
7
SCK
DNC
ff Low-g / high-g detection
ff Data-ready with sample skipping option
ff Self-wake-up
Pin
Name
Function
The interrupts can be conveniently configured by the
No.
user and thus perfectly support the integration of the
1
DNC
Do not connect
BMA180 into the user’s system environment.
2
VDD
Analog supply voltage
3
VSS
Ground
Another important feature of the BMA180 acceleration
4
INT
Interrupt output
sensor is the power management module. This module
5
CSB
SPI chip select
6
DNC
Do not connect
7
SCK
Serial clock
8
SDO
Serial data output
9
SDI
Serial data in /out
10
VDDIO
Digital interface power supply
11
DNC
Do not connect
12
DNC
Do not connect
allows for optimizing the sensor’s power consumption
in-line with the specific user requirements. Thus, it is
not necessary to operate the sensor at full power for
all application scenarios all the time. For some use
cases the power consumption drastically shrinks to
just a fraction of what would be required in full performance mode. Moreover this feature of the BMA180
allows for an intelligent system power management
and thus significant reduction of the whole system’s
power consumption. In particular, this helps increasing battery life-time of any kind of mobile device.
Headquarters
Bosch Sensortec GmbH
Gerhard-Kindler-Strasse 8
72770 Reutlingen · Germany
Telephone +49 7121 3535 9 00
Fax +49 7121 3535 9 09
contact@bosch-sensortec.com
www.bosch-sensortec.com
Specification subject to change without notice
Doc.-Number: BST-BMA180-FL000-03 / Version_1.3_072010
© Bosch Sensortec GmbH reserves all rights in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on
to third parties. BOSCH and the symbols are registered trademarks of Robert Bosch GmbH, Germany.
很抱歉,暂时无法提供与“BMA180-SHUTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+341.158815+44.13410
