AMT303LD-DMK
AMT303LD-DMK
    CUIDEVICES
    DEMO KIT AMT303LD-V ENCODERS
AMT303LD-DMK 数据手册
Additional Resources: Product Page date 03/25/2014 page 1 of 6 SERIES: AMT30 │ DESCRIPTION: MODULAR ENCODER U U, V, W commutation lines small size 37 mm line count up to 1024 PPR optional line driver output (303LD) single pulse index capacitive ASIC technology modular locking hub design for ease of installation 2, 4, 6, 8, 10, 12, or 20 pole motors 6 programmable functions ’One Touch’ commutation signal alignment N • • • • • • • • • • ED FEATURES ELECTRICAL conditions/description power supply min TI parameter 4.5 current consumption with unloaded outputs U, V, W phase commutation pole 2, 4, 6, 8, 10, 12, 20 (software programmable) incremental output signals A, B, Z (AMT303) A, A, B, B, Z, Z (AMT303LD) quadrature output square wave quadrature output resolutions 96, 192, 200, 250, 384, 400, 500, 512, 800, 1000, 1024 index one pulse per 360 deg. position accuracy parameter 5 5.5 V 8 10 mA AMT303 (single ended) sink/source AMT303LD (differential) sink/source 2 20 0.2 IS C MECHANICAL conditions/description min typ max. rotational speed mounting options mA deg max units 8,000 RPM ±0.4 mm max units 125 °C 85 % A) 2 x M1.6 on 16 mm (0.63”) bolt circle B) 2 x #4 on 19.05 mm (0.75”) bolt circle C) 2 x M1.6 or M2 on 20 mm (0.787”) bolt circle D) 3 x M1.6 or M2 on 20.9 mm (0.823”) bolt circle with washers in option B holes E) 3 x M1.6 or M2 on 22 mm (0.866”) bolt circle F) 4 x M1.6 or M2 on 25.4 mm (1”) bolt circle axial play D units PPR O incremental output waveform quadrature output current max N commutation output signals typ ENVIRONMENTAL parameter conditions/description min operating temperature humidity -40 non-condensing vibration 10 ~ 500 Hz, 5 min. sweep, 2 hours each XYZ shock 3 pulses, 6 ms, 3 each XYZ cui.com typ 5 G 200 G Additional Resources: Product Page CUI Inc │ SERIES: AMT30 │ DESCRIPTION: MODULAR ENCODER date 03/25/2014 │ page 2 of 6 PART NUMBER KEY ED For customers that prefer a specific AMT303 configuration, please reference the custom configuration key below. AMT303XX - XXXX - XXXX - XX - XX - X Options: “blank” = standard connector C = locking connector D = conformal coating with standard connector E = conformal coating with locking connector AMT303 KITS N Resolution (ppr): 0096 0500 0192 0512 0200 0800 0250 1000 0400 1024 Sleeve Bore Diameter: 2000 = 2 mm 3000 = 3 mm 3175 = 3.175 mm (1/8”) 4000 = 4 mm 4760 = 4.76 mm (3/16”) 5000 = 5 mm 6000 = 6 mm 6350 = 6.35 mm (1/4”) 8000 = 8 mm SKIT = 8 sleve kit Motor Poles: 02 10 04 12 06 20 08 Direction: “blank” = CCW CW = clockwise TI Output Signals: “blank” = A, B, Z, U, V, W LD = Line Driver A, A, B, B, Z, Z, U, V, W U Base Number IS C O N In order to provide maximum flexibility for our customers, the AMT303 series is provided in kit form standard. This allows the user to implement the encoder into a range of applications using one sku#, reducing engineering and inventory costs. SLEEVES 8mm 1/4 inch (6.35mm) 6mm 5mm 3/16 inch (4.76mm) 4mm 1/8 inch (3.175mm) 3mm 2mm Blue Snow Red1 Green1 Yellow1 Gray60 Purple1 Orange Light Sky Blue ORDERING GUIDE AMT303XX-V TOOL A BASE TOP COVER D Output Signals: “blank” = A, B, Z, U, V, W signals LD = Line Driver A, A, B, B, Z, Z, U, V, W signals cui.com TOOL C SHAFT ADAPTER Additional Resources: Product Page CUI Inc │ SERIES: AMT30 │ DESCRIPTION: MODULAR ENCODER date 03/25/2014 │ page 3 of 6 ENCODER INTERFACE PINOUT CONNECTOR 1 AMT303LD GND_C1 GND_C1 13 N/A -Z 12 Z Z 11 N/A -A 10 A A 9 N/A -B 8 B B 7 V V 6 5 V+ 5 V+ 5 W W 4 GND GND 3 U U 2 zero set zero set 1 N/A N/A N AMT303 TI # U Function 14 Locking Connector Option ED Standard Connector Option B N Notes: 1. GND_C is mode selection line used at startup to determine encoder mode: VCC/Floating: SPI Communication Mode Ground: Normal Operation Mode Standard use requires attaching GND_C Pin# 14 to GND in order to get Commutation output. SPI Communication mode allows the user to write parameters to the encoder via SPI link, contact CUI Inc. for more details. 7 5 3 1 14 12 10 8 6 4 2 O 13 11 9 IS C Mating Connector: Samtec ISDF-07-D DETAIL B SCALE 4 : 1 13 11 9 Mating Connector: Samtec ISDF-07-D-L D 7 5 3 1 14 12 10 8 6 4 2 DETAIL B SCALE 4 : 1 Demo Board Side Encoder Side Samtec ISDF-07-D B 1' 0.25" (304.8) Demo Board Cable (Cable available without Demo Board Connector) cui.com 28 AWG 10 conductor 1.27 mm pitch Additional Resources: Product Page CUI Inc │ SERIES: AMT30 │ DESCRIPTION: MODULAR ENCODER date 03/25/2014 │ page 4 of 6 MECHANICAL DRAWING R15.49 0.610 15.30 0.602 15.33 0.604 N U 37.39 1.472 ED 10.34 0.407 28.58 1.125 TI 10.93 0.430 A (3 PLCS) 22.00 0.866 0.55 19.05 0.750 2.95 0.116 (2 PLCS) TOLERANCE: ±0.05mm UNLESS OTHERWISE SPECIFIED 1.70 0.067 (2 PLCS) O R2.10 0.083 12.60 0.496 N 21.45 0.844 2.00 0.079 (4 PLCS) 20.90 0.823 IS C DETAIL A SCALE 4 : 1 25.48 1.003 16.00 0.630 18.60mm 5.30mm 5.30mm D 18.60mm AMT303 COMM WWYY US Patent No. 6892590 AMT303LD COMM WWYY US Patent No. 6892590 R1.20mm R1.20mm SCALE 5:1 SCALE 5:1 cui.com Additional Resources: Product Page CUI Inc │ SERIES: AMT30 │ DESCRIPTION: MODULAR ENCODER date 03/25/2014 │ page 5 of 6 ENCODER OPERATIONAL MODE Initialization mode: ED – At power up the encoder goes through an initiation and stabilization procedure. This includes microprocessor stabilization and the program for combining Coarse and Fine channel of the encoder for getting the absolute start position. This takes less than 0.1 seconds. Tracking mode: U – MCU 12 bit position register is updated from Fine Asic every 48 μs. – The commutation program in the MCU has a compensation for the average delay caused by the update rate, leaving a remaining jitter of less than 24 μs RMS. •The communication jitter expressed in electrical degrees will be proportional speed and does not reach 6 deg RMS until the speed reaches the following values: Commutaon Jier in Electrical Degrees N 12 10 TI 8 6 4 2 0 0 N Jier (Electrical Degrees) 14 2000 4000 6000 8000 4 pole 6 pole 8 pole 10 pole 12 pole 20 pole 10000 O RPM COMMUTATION ALIGNMENT AND SETTING THE ZERO POINT IS C We strongly recommend the use of the AMT303 series demo board to set commutation zero. It greatly simplifies and expedites the process. The demo board also allows setting of resolution, # of motor poles, direction of quadrature increment, and commutation angle offset (when required). If you do not have or cannot obtain a demo board, use the following procedure to align the AMT303XX commutation angle with your motor: Mount the AMT303 series encoder to the motor. 2. Put the motor in a ‘locked rotor’ condition. Consult your motor manufacturer if you are not certain how to lock the rotor for commutation alignment. 3. With the motor in a locked rotor position, pull pin# 2 (zero set) low, tie Pin 2 to Ground, to write the rotor position into non-volatile memory in the encoder. 4. Power cycle the encoder, i.e., remove power from it. The commutation position is now permanently aligned with the motor rotor zero position and will use this offset at initialization every time at startup. Note: The procedure is based on the standard “WYE” motor phase connection configuration. If your motor uses other than the “WYE” phase connection, you must acquire the AMT303 series demo board to program the required offset to align encoder commutation signal zero with motor zero position. D 1. cui.com Additional Resources: Product Page CUI Inc │ SERIES: AMT30 │ DESCRIPTION: MODULAR ENCODER date 03/25/2014 │ page 6 of 6 REVISION HISTORY rev. description date 05/04/2011 initial release updated electrical specifications 1.02 updated pin-out and speed specification 1.03 addition of commutation jitter, shock, speed, and position accuracy, updated part number key 09/30/2011 1.04 updated Part Number Key 03/09/2012 1.05 clarification notes 1.06 added locking connector drawing 1.07 updated spec 1.08 added axial play specification ED 1.0 1.01 06/10/2011 09/21/2011 08/17/2012 U 03/29/2013 01/30/2014 03/25/2014 D IS C O N TI N The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
AMT303LD-DMK 价格&库存
很抱歉,暂时无法提供与“AMT303LD-DMK”相匹配的价格&库存,您可以联系我们找货
