SEN-10736
SEN-10736
    SPARKFUNELECTRONICS
    RAZOR IMU
SEN-10736 数据手册
ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 ITG-3200 3-Axis Gyro Evaluation Board Application Note Rev 1.1 A printed copy of this document is NOT UNDER REVISION CONTROL unless it is dated and stamped in red ink as, “REVISION CONTROLLED COPY.” InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 1 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 1. Revision History 0B Date 12/07/2009 03/18/2010 Revision 1.0 1.1 InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com Description Initial release Added assembly drawing, revised schematic, revised BOM, other edits for readability. 2 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 CONTENTS 1.  0BREVISION HISTORY ....................................................................................................................................... 2  2.  1BPURPOSE ..................................................................................................................................................... 4  3.  2.1  7BUsage ................................................................................................................................................ 4  2.2  8BRelated Documents ........................................................................................................................... 4  2BITG-3200 3-AXIS EVB OVERVIEW ................................................................................................................ 4  9B3.1 ITG-3200 Key Function and Pin-outs ....................................................................................................... 5  4.  5.  6.  3BSIGNAL PATHS AND CONFIGURABLE CONNECTIONS ........................................................................................ 6  4.1  10BITG-3200 Functional Block Diagram ................................................................................................. 6  4.2  1BITG-3200 Evaluation Board Schematic ............................................................................................. 7  4.3  12BBill of Materials (Parts Stuffing List) for ITG-3200 EV Board ............................................................ 8  4.4  13BAssembly Drawing for ITG-3200 EV Board ....................................................................................... 9  4.5  14BPower Supply Connections ............................................................................................................. 10  4.6  15BITG-3200 EVB Connector Signals Description................................................................................ 10  4.7  16BSerial Bus Levels, Speeds and Terminations.................................................................................. 12  4.8  17BSolder-Across “M” Jumpers ............................................................................................................. 12  4.9  18BTable 5. Solder-Across “M” Jumpers – what they do and how to connect ...................................... 12  4BDATA GATHERING OPTIONS ........................................................................................................................ 13  5.1  19BConnection to ARM7 Interface EVB ................................................................................................ 13  5.2  20BUse of ITG-3200 without ARM EVB board ...................................................................................... 13  5BSPECIAL INSTRUCTIONS .............................................................................................................................. 13  6.1  7.  21BElectrostatic Discharge Sensitivity................................................................................................... 13  6BMECHANICAL DIMENSIONS .......................................................................................................................... 14  InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 3 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 2. Purpose 1B This document describes the hardware and circuitry on the ITG-3200 3-Axis Evaluation Board (EVB). It includes applying the EVB to a larger system, understanding the key signals and circuit functions, hardware jumper settings, and port connectors. 2.1 Usage 7B This evaluation board provides three axes of motion processing, comprised of:   X- , Y-, and Z-Axis gyros with ±2,000 °/sec full-scale range; 16-bit digital data measured using on-chip ADCs, transmitted over I2C interface. The Evaluation board may be used independently with the I2C serial communications interface. Alternatively, it may be connected to InvenSense’s ARM Evaluation Board (INV-ARMEVB) for connectivity to a host Windows PC using the USB interface. 2.2 Related Documents 8B The following documents are recommended for a more comprehensive understanding of the components and systems described in this Application Note.  ITG-3200 Product Specification  ITG-3200 EVB Schematic Diagram (included in this document) 3. ITG-3200 3-Axis EVB Overview 2B The ITG-3200 3-Axis EVB contains the ITG-3200 3-axis digital gyroscope and its interface circuitry. It contains removable and ‘solder-across’ jumper points that permits several circuit configurations. Referring to Figure 1, the EVB is populated on its top side only for ease of measurement access. The 20-pin (10 x 2-pin) Main header connector is designed to interface with the InvenSense INV-ARM EVB, which is a host microcontroller board useful for adapting the ITG-3200 3-Axis EVB to a personal computer via its USB port. Figure 1. Top side of the ITG-3200 3-Axis EVB InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 4 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 The 10-pin (5 x 2-pin) Factory extension header is intended for connecting additional devices to the EVB, such as a digital-output compass, etc. The 3-pin power selection header is used to select which voltage supply is interfaced to the ITG-3200. The Power select jumper allows the ITG-3200 VDD to be supplied either directly from a 3.3V DC input on the main header, or by a local 3.0V voltage regulator. 3.1 ITG-3200 Key Function and Pin-outs 9B The ITG-3200EVB is a fully-tested evaluation board, providing a quick evaluation of the ITG-3200 X-, Y-, and Z-axis angular rate gyroscope. The ITG-3200 uses InvenSense’s proprietary MEMS technology with vertically driven vibrating masses to produce a functionally complete, low-cost motion sensor. All required conditioning electronics are integrated into a single chip measuring 4 x 4 x 0.9mm. It incorporates X-, Y-, and Z-axis low-pass filters and an EEPROM for on-chip factory calibration of the sensor. Factory trimmed scale factors eliminate the need for external active components and end-user calibration. A built-in Proportional-To-Absolute-Temperature (PTAT) sensor provides temperature compensation information. The product is lead-free and Green Compliant. Refer to the ITG-3200 Product Specification for a complete description. RESV-G INT CPOUT REGOUT RESV RESV VLOGIC AD0 SCL RESV RESV SDA Figure 2. Top View Pin-Out and Sense Orientation of the ITG-3200 InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 5 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 4. Signal Paths and Configurable Connections 3B 4.1 ITG-3200 Functional Block Diagram 10B The ITG-3200 consists of a MEMS gyroscope, a data-acquisition and digital signal processing section, and a data interface which is compatible to I2C. The data interface is a slave. VDD and GND are the main supply voltage connections, and VLOGIC is an input which sets the data interface logic-high level. This allows VDD to be different than the IO voltage. Thus, for example, VDD could be 2.6VDC while the data interface could connect to a 1.8V I2C bus, by using a VLOGIC of 1.8V. REGOUT is for connecting the (nominally) 1.7V internal voltage regulator to a bypass capacitor. CPOUT is for connecting a charge pump capacitor to the internal charge pump. INT is the ITG-3200 interrupt and may be software configured to a variety of modes. AD0 is the LSB of the I2C device address, so that when it is tied logic-low, the ITG-3200 address is 68h, and when logic-high (VLOGIC) the ITG-3200 address is 69h. Refer to the ITG-3200 product specification for power-on-timing waveforms for VDD and VLOGIC. Optional 1 CLOCK ITG-3200 Clock X Gyro Signal Conditioning ADC Y Gyro Interrupt Status Register Config Register Signal Conditioning ADC Interrupt 9 2 I C Serial Interface Sensor Register Z Gyro Signal Conditioning ADC Temp Sensor Charge Pump 20 CPOUT 12 23 24 INT AD0 SCL SDA FIFO ADC Factory Cal Bias & LDO 13 VDD 8 VLOGIC 18 GND 10 REGOUT Figure 3: ITG-3200 Functional Block Diagram InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 6 ©2010 InvenSense, Inc. All rights reserved. 5 4 3 2 1 Document Number: EB-ITG-3200-00-01.1 ITG-3200EVB Application Note Revision: 1.1 Release Date: 03/18/2010 I2C V_logic Voltage Select LDO_V_OUT D 4.2 ITG-3200 Evaluation Board Schematic M1 D 1B 1 2 3 V_LOGIC BP1 0.1uF M3 R1 10K/0402 M6 R2 2K/0402 U1 ITG-3200, 24-Lead QFN (4mm x 4mm x 0.9mm) RESV1 RESV2 6 7 RESV3 22 RESV-G_U1 12 11 13 18 SELECTED_VDD Voltage Select BP2 M7 0.1uF 21 19 VLOGIC AD0 SDA SCL RESV INT RESV-G CLKIN CPOUT REGOUT VDD GND RESV RESV NC NC NC NC RESV4 RESV5 RESV RESV R9 0/0402 VCC M5 NC NC NC NC 8 9 24 23 VCC R3 2K/0402 V_LOGIC AD0 SDA SCL 1 1 20 10 TP1 TEST POINT CP_OUT REG_OUT 2 3 4 5 BP3 0.1uF C1 2200pF/50V/0402 C 17 16 15 14 C M4 JP2 HEADER 3, 80mil, 180D, Male 3 2 1 VCC LDO_V_OUT SCL SDA AD0 RESV-G RESV-G 2 4 6 8 10 JP8 HEADER 14X2, Male, 90D, 2.54mmx2.54mm JP7 HEADER 3, 80mil, 180D, Male 1 3 5 7 9 11 13 15 17 19 21 23 25 27 RESV1 RESV2 RESV5 INT RESV4 CLK_IN CP_OUT R11 0/0402 LDO_V_OUT RESV-G VCC B 2 4 6 8 10 12 14 16 18 20 22 24 26 28 1 3 5 7 9 JP6 HEADER 5X2, Male, 180D, 2.0mmx2.0mm R10 0/0402 V_LOGIC RESV3 LDO_EN REG_OUT SCL SDA AD0 B R4 10K/0402 TP2 TEST-POINT 1 User Header R5 1M R6 0/0402 R7 100K/0402 VCC R8 2R2/0603 VCC BP4 0.1uF C2 0.47uF/0603 U2 YB1210ST25R300 SOT235 1 5 2 Vin OUT 3 GND 4 BYPASS EN NC 3V0 LDO_V_OUT C3 0.47uF/0603 BP5 0.1uF C4 0.033uF/0402 A A Invensense 1197 BORREGAS AVE. Phone: 408-988-7339 Fax: 408-988-8104 www.invensense.com SUNNYVALE, CA 94089 Creating a new Generation of Embedded Motion Sensors Title ITG-3200 EVB 5 InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA 7 Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 ©2010 InvenSense, Inc. All rights reserved. 4 3 Website: http//www.invensense.com Size Document Number Custom Date: 2 Thursday, March 18, 2010 Rev Sheet 1 1 of 1 B Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 ITG-3200EVB Application Note 4.3 Bill of Materials (Parts Stuffing List) for ITG-3200 EV Board 12B Parts Stuffing BOM for ITG-3200 EV Board. Also refer to Assembly Drawing for ITG-3200 EV Board Table 1. Parts stuffing list the ITG-3200 EVB. Only the top side requires component assembly Item Quantity Reference Part PCB Footprint 1 5 BP1,BP2,BP3,BP4,BP5 0.1uF 402 smt 2 1 C1 2200pF/50V 402 smt 3 2 C2,C3 0.47uF/0603 603 smt 4 1 C4 0.033uF 402 smt 5 2 JP2,JP7 HEADER 3 pin, 80mil, 180D, Male 3-pin 2mm header 6 2 P2,P7 PLUG 80mil 2-pin Short circuit plug Plugs to JP2, JP7 7 1 JP6 HEADER 5X2 pin, Male, 180D, 2.0mmx2.0mm SIP2X5N2 8 1 JP8 HEADER 10X2 pin, Male, 90D, 2.54mmx2.54mm HDB2X10NRA 9 4 R1, R2,R3,R4 10K 402 smt 10 1 R5 1M 402 smt 11 1 R8 2R2/0603 603 smt 12 2 R6, R10 0 Ohm 402 smt 13 1 U1 ITG-3200 QFN-24 14 2 R9, R7 DO NOT STUFF 0402 smt 16 1 U2 YB1210-ST25R300, 3.0V Regulator1 SOT-235 17 1 M7 Solder across Jumper Split oval 18 5 M1, M3, M4, M5, M6 Do not solder across Jumper Split oval 19 1 Blank PCB ITG-3200 EVB REV B Note 1: www.yobon.com.tw InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 8 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 4.4 Assembly Drawing for ITG-3200 EV Board 13B Figure 4. ITG-3200 EV Board Assembly Drawing. Follow the Parts Stuffing List for assembly instructions. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 9 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 4.5 Power Supply Connections 14B JP2 and JP7 are 3 header-pin plug-in jumpers which allow users to select between the on-board LDO and an external DC supply to the ITG-3200. For details, please refer to Table 2. Power Selection Jumpers. X X The on-board 3.0V LDO (Low-dropout voltage regulator) is a low-noise part. Its output is called 3V0 on the schematic, and using it will assure that the gyroscope and accelerometer performance will meet the intended specifications. Selecting the raw VCC line to power the chip is generally done while designing and evaluating with an embedded platform, where the host processor and related electronics need full control over the motion processing chip’s power supply. When the user intends to use the on board LDO 3V0 power, the external VCC must be higher than 3.7V to ensure the LDO works properly. If the user provides VCC with 5V, JP2 and JP7 must be set as “1-2 short” to enable the on-board 3.0V LDO. The ITG-3200 VDD and VLOGIC operation range is 2.1V to 3.6V. Refer to the ITG-3200 product specification for power-on-timing waveforms for VDD and VLOGIC. Figure 5. JP2 and JP7 Pin-out 4.6 ITG-3200 EVB Connector Signals Description 15B Table 2. Power Selection Jumpers (use P2, P7 to short pins as required) JP2 Pin Number Signal Description 1-2 short ITG-3200 VLOGIC = 3V using on board LDO 2-3 short ITG-3200 VLOGIC = VCC (from external) JP7 Pin Number Signal Description 1-2 short ITG-3200 VDD = 3V using on-board LDO 2-3 short ITG-3200 VDD = VCC (from external) InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 10 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 Table 3. “Main Header” User Interface Signals JP8 Pin Number Signal Name Signal Description 1 RESV1 Reserved. Do not connect to this pin. 3 RESV2 Reserved. Do not connect to this pin. 5 RESV5 Reserved. Do not connect to this pin. 7 INT 9 RESV4 Reserved. Do not connect to this pin. 11 CLKIN ITG-3200 pin 1 external clock input 13 CPOUT ITG-3200 pin 20 (charge pump capacitor) 15 GND GND 17 GND GND 19 ITG-3200 pin 12 interrupt output to host controller 3V on-board LDO (regulated DC) output 21 RESV-G 23 VCC 25 NC Not Connected 27 NC Not Connected 2 NC Not Connected 4 NC Not Connected 6 Reserved. Do not connect to this pin. VCC from ARM-7 Controller Board or external 3.3V at >100mA Do not connect to this pin. 8 VLOGIC VLOGIC DC Input, ITG-3200 pin 8, sets I2C bus logic levels 10 RESV3 Reserved. Do not connect to this pin. 12 NC 14 LDO_EN Not Connected 16 NC 18 REGOUT 20 SCL ITG-3200 pin 23 I2C clock line 22 SDA ITG-3200 pin 24 I2C data line 24 AD0 ITG-3200 pin 9 I2C Address bit zero 26 NC Not Connected 28 NC Not Connected EVB on-board 3V LDO enable (when pulled to VCC) Not Connected ITG-3200 pin 10, on-chip regulator bypass capacitor InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 11 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 Table 4. Extended Factory Connector pin functions JP6 Pin Number Signal Name 1 VCC Power from ARM-7 controller board or external 3.3V at >100mA 3 GND GND 5 NC Not Connected 7 NC Not Connected 9 NC Not Connected 2 LDO_V_OUT 4 SCL ITG-3200 I2C clock line 6 SDA ITG-3200 I2C data line 8 AD0 ITG-3200 I2C Address bit zero 10 RESV-G Signal Description 3V Output from LDO Reserved. Do not connect to this pin. 4.7 Serial Bus Levels, Speeds and Terminations 16B The ITG-3200 supports fast mode I2C up to 400Hz. The I2C bus open-drain pull up resistors are R2 and R3 for SDA and SCL; both are 2.2kohm connected to either 3.0V or the externally provided VCC. The pull up level is selected by JP2. Please refer to Table 2. Power Selection Jumpers. X X 4.8 Solder-Across “M” Jumpers 17B For fast and permanent configuration connections, a set of solder-across jumpers are provided. 4.9 Table 5. Solder-Across “M” Jumpers – what they do and how to connect 18B M Number M Jumper function 1 Shorts JP2 pins 1-2 to set ITG-3200 VLOGIC = 3.0V using on board LDO 3 Shorts JP2 pins 2-3 to set ITG-3200 VLOGIC = VCC externally supplied voltage 4 Shorts JP7 pins 2-3 to set ITG-3200 VDD = VCC externally supplied voltage 5 Shorts JP7 pins 1-2 to setITG-3200 VDD = 3.0V using on board LDO 6 Pulls ITG-3200 VLOGIC pin 8 to V_LOGIC supply. It is in parallel with R1 7 Shorts ITG-3200 pin 11 as required by Product Specification. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 12 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 5. Data Gathering Options 4B The ITG-3200 Digital Sensor Data is available at the Main Header connector. Alternately, for connectivity with a host PC, an InvenSense ARM Interface Board may also be used. 5.1 Connection to ARM7 Interface EVB 19B For communications via USB to a host computer, the ITG-3200EVB may be connected to InvenSense’s ARM7 Microprocessor Interface board, the INV-ARMEVB. It serves as an interface between a Windows PC USB port, and the ITG-3200 EVB Main header. The following photo shows the connection of ITG-3200 to INV-ARMEVB. Connection between the two boards is made via the Main header connector. Figure 6: Connect ITG-3200 to ARM Board 5.2 Use of ITG-3200 without ARM EVB board 20B I2C signals are available on JP8. The user may develop tools to communicate with the ITG-3200. There is no bus mode selection setting required. 6. Special Instructions 5B 6.1 Electrostatic Discharge Sensitivity 21B The ITG-3200 gyro can be permanently damaged by an electrostatic discharge. Proper ESD precautions for handling and storage are recommended. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 13 ©2010 InvenSense, Inc. All rights reserved. ITG-3200EVB Application Note Document Number: EB-ITG-3200-00-01.1 Revision: 1.1 Release Date: 03/18/2010 7. Mechanical Dimensions 6B The ITG-3200EVB is a 4 layer PCB with 32mm x 38mm overall dimensions. The mounting holes are arranged to fit 19.56mm x 18.54 mm fixture screw centers, offset from the edge of the board by 9.22mm and 3.05mm as shown. Figure 7: ITG-3200 Dimensions, Top Side shown This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2010 InvenSense, Inc. All rights reserved. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, CA 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 14 ©2010 InvenSense, Inc. All rights reserved.
SEN-10736 价格&库存
很抱歉,暂时无法提供与“SEN-10736”相匹配的价格&库存,您可以联系我们找货
