SEN-10724
SEN-10724
    SPARKFUNELECTRONICS
    ADXL345, HMC5883L, ITG-3200 Accelerometer, Gyroscope, Magnetometer Sensor Evaluation Board
SEN-10724 数据手册
 Export Restrictions This product has some level of export control/restriction, so may be delayed by 2-3 business days when shipping outside the United States. Contact us with questions, or we will contact you after you place your order. SparkFun 9 Degrees of Freedom - Sensor Stick S EN -10 724 RO HS       1  images are CC BY-NC-SA 3.0 Description: The SparkFun 9DOF Sensor Stick is a very small sensor board with 9 degrees of freedom. It includes the ADXL345 accelerometer, the HMC5883L magnetometer, and the ITG-3200 MEMS gyro. The ‘stick’ has a simple I2C interface and a mounting hole for attaching it to your project. Also, the board is a mere 0.036" thick (0.093" overall), allowing it to be easily mounted in just about any application. Having a hard time picking an IMU? Our Accelerometer, Gyro, and IMU Buying Guide might help! Dimensions: 1.37x0.42" https://www.sparkfun.com/products/10724 6/24/2015
SEN-10724 价格&库存
很抱歉,暂时无法提供与“SEN-10724”相匹配的价格&库存,您可以联系我们找货
