PK51-T
PK51-T
    ARM(安谋控股)
    KIT PRO DEVELOPER 1 YR LICENSE
PK51-T 数据手册
Getting Started Creating Applications with µVision®4 For 8-bit, 16-bit, and 32-bit Microcontrollers www.keil.com 2 Preface Information in this document is subject to change without notice and does not represent a commitment on the part of the manufacturer. The software described in this document is furnished under license agreement or nondisclosure agreement and may be used or copied only in accordance with the terms of the agreement. It is against the law to copy the software on any medium except as specifically allowed in the license or nondisclosure agreement. The purchaser may make one copy of the software for backup purposes. No part of this manual may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying, recording, or information storage and retrieval systems, for any purpose other than for the purchaser’s personal use, without written permission. Copyright © 1997-2009 Keil, Tools by ARM, and ARM Ltd. All rights reserved. Keil Software and Design®, the Keil Software Logo, µVision®, RealView®, C51™, C166™, MDK™, RL-ARM™, ULINK®, Device Database®, and ARTX™ are trademarks or registered trademarks of Keil, Tools by ARM, and ARM Ltd. Microsoft® and Windows™ are trademarks or registered trademarks of Microsoft Corporation. PC® is a registered trademark of International Business Machines Corporation. NOTE This manual assumes that you are familiar with Microsoft Windows and the hardware and instruction set of the ARM7, ARM9, Cortex-Mx, C166, XE166, XC2000, or 8051 microcontroller. Every effort was made to ensure accuracy in this manual and to give appropriate credit to persons, companies, and trademarks referenced herein. Getting Started: Creating Applications with µVision Preface This manual is an introduction to the Keil development tools designed for Cortex-Mx, ARM7, ARM9, C166, XE166, XC2000, and 8051 microcontrollers. It introduces the µVision Integrated Development Environment, Simulator, and Debugger and presents a step-by-step guided tour of the numerous features and capabilities the Keil embedded development tools offer. Who should Read this Book This book is useful for students, beginners, advanced and experienced developers alike. Developers are considered experienced or advanced if they have used µVision extensively in the past and knowledge exists of how the µVision IDE works and interacts with the debugger, simulator, and target hardware. Preferably, these developers already have a deep understanding of microcontrollers. We encourage this group of engineers to get familiar with the enhancements introduced and to explore the latest features in µVision. Developers are considered students or beginners if they have no working experience with µVision. We encourage this group of developers to start by reading the chapters related to the µVision IDE and to work through the examples to get familiar with the interface and configuration options described. They should make use of the ample possibilities the simulator offers. Later on, they should continue with the chapters describing the RTOS and microcontroller architectures. However, it is assumed that you have a basic knowledge of how to use microcontrollers and that you are familiar with a few instructions or with the instruction set of your preferred microcontroller. The chapters of this book can be studied individually, since they do not strictly depend on each other. 3 4 Preface Chapter Overview “Chapter 1. Introduction”, provides an overview of product installation and licensing and shows how to get support for the Keil development tools. “Chapter 2. Microcontroller Architectures”, discusses various microcontroller architectures supported by the Keil development tools and assists you in choosing the microcontroller best suited for your application. “Chapter 3. Development Tools”, discusses the major features of the µVision IDE and Debugger, Assembler, Compiler, Linker, and other development tools. “Chapter 4. RTX RTOS Kernel”, discusses the benefits of using a Real-Time Operating System (RTOS) and introduces the features available in Keil RTX Kernels. “Chapter 5. Using µVision”, describes specific features of the µVision user interface and how to interact with them. “Chapter 6. Creating Embedded Programs”, describes how to create projects, edit source files, compile, fix syntax errors, and generate executable code. “Chapter 7. Debugging”, describes how to use the µVision Simulator and Target Debugger to test and validate your embedded programs. “Chapter 8. Using Target Hardware”, describes how to configure and use third-party Flash programming utilities and target drivers. “Chapter 9. Example Programs”, describes four example programs and shows the relevant features of µVision by means of these examples. Getting Started: Creating Applications with µVision 5 Document Conventions Examples Description README.TXT1 Bold capital text is used to highlight the names of executable programs, data files, source files, environment variables, and commands that you can enter at the command prompt. This text usually represents commands that you must type in literally. For example: ARMCC.EXE 1 DIR LX51.EXE Courier Text in this typeface is used to represent information that is displayed on the screen or is printed out on the printer This typeface is also used within the text when discussing or describing command line items. Variables Text in italics represents required information that you must provide. For example, projectfile in a syntax string means that you must supply the actual project file name Occasionally, italics are also used to emphasize words in the text. Elements that repeat… Ellipses (…) are used to indicate an item that may be repeated Omitted code . . . Vertical ellipses are used in source code listings to indicate that a fragment of the program has been omitted. For example: void main (void) { . . . while (1); «Optional Items» Double brackets indicate optional items in command lines and input fields. For example: C51 TEST.C PRINT «filename» { opt1 | opt2 } Text contained within braces, separated by a vertical bar represents a selection of items. The braces enclose all of the choices and the vertical bars separate the choices. Exactly one item in the list must be selected. Keys Text in this sans serif typeface represents actual keys on the keyboard. For example, “Press Enter to continue It is not required to enter commands using all capital letters. 6 Contents Contents Preface................................................................................................................... 3 Document Conventions........................................................................................ 5 Contents ................................................................................................................ 6 Chapter 1. Introduction...................................................................................... 9 Last-Minute Changes ....................................................................................... 11 Licensing.......................................................................................................... 11 Installation ....................................................................................................... 11 Requesting Assistance ..................................................................................... 13 Chapter 2. Microcontroller Architectures ...................................................... 14 Selecting an Architecture ................................................................................. 15 Classic and Extended 8051 Devices ................................................................ 17 Infineon C166, XE166, XC2000 ..................................................................... 20 ARM7 and ARM9 based Microcontrollers...................................................... 21 Cortex-Mx based Microcontrollers .................................................................. 23 Code Comparison ............................................................................................ 26 Generating Optimum Code .............................................................................. 28 Chapter 3. Development Tools......................................................................... 33 Software Development Cycle .......................................................................... 33 µVision IDE ..................................................................................................... 34 µVision Device Database ................................................................................ 35 µVision Debugger ............................................................................................ 35 Assembler ........................................................................................................ 37 C/C++ Compiler .............................................................................................. 38 Object-HEX Converter .................................................................................... 38 Linker/Locator ................................................................................................. 39 Library Manager .............................................................................................. 39 Chapter 4. RTX RTOS Kernel ........................................................................ 40 Software Concepts ........................................................................................... 40 RTX Introduction............................................................................................. 43 Chapter 5. Using µVision ................................................................................. 55 Menus .............................................................................................................. 59 Toolbars and Toolbar Icons ............................................................................. 63 Project Windows .............................................................................................. 69 Getting Started: Creating Applications with µVision Editor Windows ............................................................................................... 71 Output Windows .............................................................................................. 73 Other Windows and Dialogs ............................................................................ 74 On-line Help .................................................................................................... 74 Chapter 6. Creating Embedded Programs ..................................................... 75 Creating a Project File ..................................................................................... 75 Using the Project Windows ............................................................................. 77 Creating Source Files ....................................................................................... 78 Adding Source Files to the Project .................................................................. 79 Using Targets, Groups, and Files..................................................................... 79 Setting Target Options ..................................................................................... 81 Setting Group and File Options ....................................................................... 82 Configuring the Startup Code .......................................................................... 83 Building the Project ......................................................................................... 84 Creating a HEX File ........................................................................................ 85 Working with Multiple Projects ...................................................................... 86 Chapter 7. Debugging ....................................................................................... 89 Simulation ........................................................................................................ 91 Starting a Debug Session ................................................................................. 91 Debug Mode .................................................................................................... 93 Using the Command Window.......................................................................... 94 Using the Disassembly Window ...................................................................... 94 Executing Code ................................................................................................ 95 Examining and Modifying Memory ................................................................ 96 Breakpoints and Bookmarks ............................................................................ 98 Watchpoints and Watch Window .................................................................. 100 Serial I/O and UARTs.................................................................................... 102 Execution Profiler .......................................................................................... 103 Code Coverage............................................................................................... 104 Performance Analyzer ................................................................................... 105 Logic Analyzer .............................................................................................. 106 System Viewer ............................................................................................... 107 Symbols Window........................................................................................... 108 Browse Window ............................................................................................ 109 Toolbox .......................................................................................................... 110 Instruction Trace Window ............................................................................. 111 Defining Debug Restore Views ..................................................................... 111 7 8 Contents Chapter 8. Using Target Hardware............................................................... 112 Configuring the Debugger ............................................................................. 113 Programming Flash Devices .......................................................................... 114 Configuring External Tools ........................................................................... 115 Using ULINK Adapters ................................................................................. 116 Using an Init File ........................................................................................... 121 Chapter 9. Example Programs ...................................................................... 122 “Hello” Example Program ............................................................................. 123 “Measure” Example Program ........................................................................ 127 “Traffic” Example Program ........................................................................... 138 “Blinky” Example Program ........................................................................... 142 Glossary ............................................................................................................ 146 Index.................................................................................................................. 151 Getting Started: Creating Applications with µVision Chapter 1. Introduction Thank you for allowing Keil to provide you with software development tools for your embedded microcontroller applications. This book, Getting Started, describes the µVision IDE, µVision Debugger and Analysis Tools, the simulation, and debugging and tracing capabilities. In addition to describing the basic behavior and basic screens of µVision, this book provides a comprehensive overview of the supported microcontroller architecture types, their advantages and highlights, and supports you in selecting the appropriate target device. This book incorporates hints to help you to write better code. As with any Getting Started book, it does not cover every aspect and the many available configuration options in detail. We encourage you to work through the examples to get familiar with µVision and the components delivered. The Keil Development Tools are designed for the professional software developer, however programmers of all levels can use them to get the most out of the embedded microcontroller architectures that are supported. Tools developed by Keil endorse the most popular microcontrollers and are distributed in several packages and configurations, dependent on the architecture.  MDK-ARM: Microcontroller Development Kit, for several ARM7, ARM9, and Cortex-Mx based devices  PK166: Keil Professional Developer’s Kit, for C166, XE166, and XC2000 devices  DK251: Keil 251 Development Tools, for 251 devices  PK51: Keil 8051 Development Tools, for Classic & Extended 8051 devices In addition to the software packages, Keil offers a variety of evaluation boards, USB-JTAG adapters, emulators, and third-party tools, which completes the range of products. The following illustrations show the generic component blocks of µVision in conjunction with tools provided by Keil, or tools from other vendors, and the way the components relate. 9 10 Chapter 1. Introduction Software Development Tools Like all software based on Keil’s µVision IDE, the toolsets provide a powerful, easy to use and easy to learn environment for developing embedded applications. They include the components you need to create, debug, and assemble your C/C++ source files, and incorporate simulation for microcontrollers and related peripherals. The RTX RTOS Kernel helps you to implement complex and time-critical software. Software Development Tools C/C++ Compiler RTX RTOS Kernel Library µVision IDE & Device Database µVision Debugger & Analysis Tools Complete Device Simulation RTOS and Middleware Components These components are designed to solve communication and real-time challenges of embedded systems. While it is possible to implement embedded applications without using a real-time kernel, a proven kernel saves time and shortens the development cycle. This component also includes the source code files for the operating system. RTOS and Middleware Components RTX RTOS Source Code TCPnet Networking Suite Flash File System USB Device Interface CAN Interface Hardware Debug Adapters The µVision Debugger fully supports several emulators provided by Keil, and other vendors. The Keil ULINK USB-JTAG family of adapters con nect the USB port of a PC to the target hardware. They enable you to download, test, and debug your embedded application on real hardware. Getting Started: Creating Applications with µVision Last-Minute Changes As with any high-tech product, last minute changes might not be included into the printed manuals. These last-minute changes and enhancements to the software and manuals are listed in the Release Notes shipped with the product. Licensing Each Keil product requires activation through a license code. This code is obtained via e-mail during the registration process. There are two types of product licenses:  Single-User License is available for all Keil products. A Single-User License grants the right to use a product on a maximum of two computers to one user. Each installation requires a license code that is personalized for the computer on which the product is installed. A Single-User license may be uninstalled and moved to another computer.  Floating-User License is available for many Keil products. The FloatingUser license grants the right to use that product on several computers by several different developers at the same time. Each installation of the product requires an individual license code for each computer on which the product is installed. Installation Please check the minimum hardware and software requirements that must be satisfied to ensure that your Keil development tools are installed and will function properly. Before attempting installation, verify that you have:  A standard PC running Microsoft Windows XP, or Windows Vista  1GB RAM and 500 MB of available hard-disk space is recommended  1024x768 or higher screen resolution; a mouse or other pointing device  A CD-ROM drive Keil products are available on CD-ROM and via download from www.keil.com. Updates to the related products are regularly available at www.keil.com/update. 11 12 Chapter 1. Introduction Installation using the web download 1. Download the product from www.keil.com/demo 2. Run the downloaded executable 3. Follow the instructions displayed by the SETUP program Installation from CD-ROM 1. Insert the CD-ROM into your CD-ROM drive. The CD-ROM browser should start automatically. If it does not, you can run SETUP.EXE from the CD-ROM. 2. Select Install Products & Updates from the CD Browser menu 3. Follow the instructions displayed by the SETUP program Product Folder Structure The SETUP program copies the development tools into subfolders. The base folder defaults to C:\KEIL\. The following table lists the default folders for each microcontroller architecture installation. Adjust the examples used in this manual to your preferred installation directory accordingly. Microcontroller Architecture Folder MDK-ARM Toolset C:\KEIL\ARM\ C166/XE166/XC2000 Toolset C:\KEIL\C166\ 8051 Toolset C:\KEIL\C51\ C251 Toolset C:\KEIL\C251\ µVision Common Files C:\KEIL\UV4\ Each toolset contains several subfolders: Contents Subfolder Executable Program Files \BIN\ C Include/Header Files \INC\ On-line Help Files and Release Notes \HLP\ Common/Generic Example Programs \EXAMPLES\ Example Programs for Evaluation Boards \BOARDS\ Getting Started: Creating Applications with µVision Requesting Assistance At Keil, we are committed to providing you with the best embedded development tools, documentation, and support. If you have suggestions and comments regarding any of our products, or you have discovered a problem with the software, please report them to us, and where applicable make sure to: 1. Read the section in this manual that pertains to the task you are attempting 2. Check the update section of the Keil web site to make sure you have the latest software and utility version 3. Isolate software problems by reducing your code to as few lines as possible If you are still having difficulties, please report them to our technical support group. Make sure to include your license code and product version number. See the Help – About Menu. In addition, we offer the following support and information channels, all accessible at www.keil.com/support1. 1. The Support Knowledgebase is updated daily and includes the latest questions and answers from the support department 2. The Application Notes can help you in mastering complex issues, like interrupts and memory utilization 3. Check the on-line Discussion Forum 4. Request assistance through Contact Technical Support (web-based E-Mail) 5. Finally, you can reach the support department directly via support.intl@keil.com or support.us@keil.com 1 You can always get technical support, product updates, application notes, and sample programs at www.keil.com/support. 13 14 Chapter 2. Microcontroller Architectures Chapter 2. Microcontroller Architectures The Keil µVision Integrated Development Environment (µVision IDE) supports three major microcontroller architectures and sustains the development of a wide range of applications.  8-bit (classic and extended 8051) devices include an efficient interrupt system designed for real-time performance and are found in more than 65% of all 8-bit applications. Over 1000 variants are available, with peripherals that include analog I/O, timer/counters, PWM, serial interfaces like UART, I2C, LIN, SPI, USB, CAN, and on-chip RF transmitter supporting low-power wireless applications. Some architecture extensions provide up to 16MB memory with an enriched 16/32-bit instruction set. The µVision IDE supports the latest trends, like custom chip designs based on IP cores, which integrate application-specific peripherals on a single chip.  16-bit (Infineon C166, XE166, XC2000) devices are tuned for optimum real-time and interrupt performance and provide a rich set of on-chip peripherals closely coupled with the microcontroller core. They include a Peripheral Event Controller (similar to memory-to-memory DMA) for highspeed data collection with little or no microcontroller overhead. These devices are the best choice for applications requiring extremely fast responses to external events.  32-bit (ARM7 and ARM9 based) devices support complex applications, which require greater processing power. These cores provide high-speed 32bit arithmetic within a 4GB address space. The RISC instruction set has been extended with a Thumb mode for high code density. ARM7 and ARM9 devices provide separate stack spaces for high-speed context switching enabling efficient multi-tasking operating systems. Bitaddressing and dedicated peripheral address spaces are not supported. Only two interrupt priority levels, - Interrupt Request (IRQ) and Fast Interrupt Request (FIQ), are available. Getting Started: Creating Applications with µVision  32-bit (Cortex-Mx based) devices combine the cost benefits of 8-bit and 16-bit devices with the flexibility and performance of 32-bit devices at extremely low power consumption. The architecture delivers state of the art implementations for FPGAs and SoCs. With the improved Thumb2 instruction set, Cortex-Mx1 based microcontrollers support a 4GB address space, provide bit-addressing (bit-banding), and several interrupts with at least 8 interrupt priority levels. Selecting an Architecture Choosing the optimal device for an embedded application is a complex task. The Keil Device Database (www.keil.com/dd) supports you in selecting the appropriate architecture and provides three different methods for searching. You can find your device by architecture, by specifying certain characteristics of the microcontroller, or by vendor. The following sections explain the advantages of the different architectures and provide guidelines for finding the microcontroller that best fits your embedded application. 8051 Architecture Advantages  Fast I/O operations and fast access to on-chip RAM in data space  Efficient and flexible interrupt system  Low-power operation 8051-based devices are typically used in small and medium sized applications that require high I/O throughput. Many devices with flexible peripherals are available, even in the smallest chip packages. 1 Cortex-M0 devices implement the Thumb instruction set. 15 16 Chapter 2. Microcontroller Architectures C166, XE166 and XC2000 Architecture Advantages  Extremely fast I/O operations via the Peripheral Event Controller  High-speed interrupt system with very well-tuned peripherals  Efficient arithmetic and fast memory access These devices are used in medium to large sized applications that require high I/O throughput. This architecture is well suited to the needs of embedded systems that involve a mixture of traditional controller code and DSP algorithms. ARM7 and ARM9 Architecture Advantages  Huge linear address space  The 16-bit Thumb instruction set provides high code density  Efficient support for all C integer data types including pointer addressing ARM7 and ARM9-based microcontrollers are used for applications with large memory demands and for applications that use PC-based algorithms. Cortex-Mx Architecture Advantages  One instruction set, Thumb2, reduces the complexity of the program code and eliminates the overhead needed for switching between ARM and Thumb instruction mode  The Nested Vector Interrupt Controller (NVIC) removes interrupt prolog and epilog code, and provides several, configurable priority levels  Extremely low power consumption with a variety of sleep modes The Cortex-Mx microcontroller architecture is designed for hard real-time systems, but can be used for complex System-on-Chip applications as well. Getting Started: Creating Applications with µVision 17 Classic and Extended 8051 Devices 8051 devices combine cost-efficient hardware with a simple but efficient programming model that uses various memory regions to maximize code efficiency and speed-up memory access. The following figure shows the memory layout of a classic 8051 device. 0x100 0xFFFF F8 CODE 98 SFR 0x100 SPACE 90 8051 Bit addressable 0x0000 88 IDATA 256 Bytes 80 0x80 0x80 0xFFFF 2F DATA 128 Bytes DATA 128 Bytes 0x 0 8051 Bitspace 4 Register Banks 20 1F 0 XDATA 0x0000 The 8051 architecture provides three different physical memory regions:  DATA/IDATA memory includes a 256 Bytes on-chip RAM with register banks and bit-addressable space that is used for fast variable accessing. Some devices provide an extended data (EDATA) space with up to 64KB.  CODE memory consists of 64KB ROM space used for program code and constants. The Keil linker supports code banking that allows you to expand the physical memory space. In extended variants, up to 16MB ROM space is available.  XDATA memory has a 64KB RAM space for off-chip peripheral and memory addressing. Today, most devices provide some on-chip RAM that is mapped into XDATA. 18 Chapter 2. Microcontroller Architectures  SFR and IDATA memory are located in the same address space but are accessed through different assembler instructions  For extended devices, the memory layout provides a universal memory map that includes all 8051-memory types in a single 16MByte address region 8051 Highlights  Fast interrupt service routines with two or four priority levels and up to 32vectored interrupts  Four register banks for minimum interrupt prolog/epilog  Bit-addressable space for efficient logical operations  128 Bytes of Special Function Register (SFR) space for tight integration of on-chip peripherals. Some devices extend the SFR space using paging.  Low-power, high-speed devices up to 100 MIPS are available 8051 Development Tool Support The Keil C51 Compiler and the Keil Linker/Locator provide optimum 8051 architecture support with the following features and C language extensions.  Interrupt functions with register bank support are written directly in C  Bit and bit-addressable variables for optimal Boolean data type support  Compile-time stack with data overlaying uses direct memory access and gives high-speed code with little overhead compared to assembly programming  Reentrant functions for usage by multiple interrupt or task threats  Generic and memory-specific pointers provide flexible memory access  Linker Code Packing gives utmost code density by reusing identical program sequences  Code and Variable Banking expand the physical memory address space  Absolute Variable Locating enables peripheral access and memory sharing Getting Started: Creating Applications with µVision 8051 Memory Types A memory type prefix is used to assign a memory type to an expression with a constant. This is necessary, for example, when an expression is used as an address for the output command. Normally, symbolic names have an assigned memory type, so that the specification of the memory type can be omitted. The following memory types are defined: Prefix Memory Space C: Code Memory (CODE) D: Internal, direct-addressable RAM memory (DATA) I: Internal, indirect-addressable RAM memory (IDATA) X: External RAM memory (XDATA) B: Bit-addressable RAM memory P: Peripheral memory (VTREGD – 80x51 pins) The prefix P: is a special case, since it always must be followed by a name. The name in turn is searched for in a special symbol table that contains the register’s pin names. Example: C:0x100 Address 0x100 in CODE memory ACC Address 0xE0 in DATA memory, D: I:100 Address 0x64 in internal RAM X:0FFFFH Address 0xFFFF in external data memory B:0x7F Bit address 127 or 2FH.7 C Address 0xD7 (PSW.7), memory type B: 19 20 Chapter 2. Microcontroller Architectures Infineon C166, XE166, XC2000 The 16-bit architecture of these devices is designed for high-speed real-time applications. It provides up to 16MB memory space with fast memory areas mapped into parts of the address space. High-performance applications benefit from locating frequently used variables into the fast memory areas. The below listed memory types address the following memory regions: Memory Type Description bdata Bit-addressable part of the idata memory. huge Complete 16MB memory with fast 16-bit address calculation. Object size limited to 64KB. idata High speed RAM providing maximum access speed (part of sdata). near Efficient variable and constant addressing (max. 64KB) with 16-bit pointer and 16-bit address calculation. sdata System area includes Peripheral Registers and additional on-chip RAM space. xhuge Complete 16MB memory with full address calculation for unlimited object size. C166, XE166, XC2000 Highlights  Highest-speed interrupt handling with 16 priority levels and up to 128 vectored interrupts  Unlimited register banks for minimum interrupt prolog/epilog  Bit instructions and bit-addressable space for efficient logical operations  ATOMIC instruction sequences are protected from interrupts without interrupt enable/disable sequences  Peripheral Event Controller (PEC) for automatic memory transfers triggered by peripheral interrupts. Requires no processor interaction and further improves interrupt response time.  Multiply-Accumulate Unit (MAC) provided for high-speed DSP algorithms Getting Started: Creating Applications with µVision C166, XE166, XC2000 Development Tool Support The Keil C166 Compiler supports all C166, XE166, XC2000 specific features and provides additional extensions such as:  Memory type support and flexible digital pattern processing for extremely fast variable access  Function inlining eliminating call/return overhead  Inline assembly for accessing all microcontroller and MAC instructions ARM7 and ARM9 based Microcontrollers The ARM7 and ARM9 based microcontrollers run on a load-store RISC architecture with 32-bit registers and fixed op-code length. The architecture provides a linear 4GB memory address space. In contrast to the previously mentioned 8/16-bit devices, no specific memory types are provided, since memory addressing is performed via 32-bit pointers in microcontroller registers. Peripheral registers are mapped directly into the linear address space. The Thumb instruction set improves code density by providing a compressed 16-bit instruction subset. The ARM7 and ARM9 cores are easy to use, cost-effective, and support modern object-oriented programming techniques. They include a 2-level interrupt system with a normal interrupt (IRQ) and a fast interrupt (FIQ) vector. To minimize interrupt overhead, typical ARM7/ARM9 microcontrollers provide a vectored interrupt controller. The microcontroller operating modes, separate stack spaces, and Software Interrupt (SVC) features produce efficient use of Real-Time Operating Systems. The ARM7 and ARM9 core provides thirteen general-purpose registers (R0– R12), the stack pointer (SP) R13, the link register (LR) R14, which holds return addresses on function calls, the program counter (PC) R15, and a program status register (PSR). Shadow registers, available in various operating modes, are similar to register banks and reduce interrupt latency. 21 22 Chapter 2. Microcontroller Architectures R1 ARM7 and ARM9 Operation Modes R2 User FIQ IRQ SVC UND ABT R3 R4 R5 R6 Normal execution state Fast Interrupt mode Interrupt mode Supervisor mode (software interrupt) Undefined instruction execution Memory access failure R7 R8 R8 R9 R9 R10 R10 R11 R11 R12 R12 R13 = SP R13 = SP R13 = SP R13 = SP R13 = SP R13 = SP R14 = LR R14 = LR R14 = LR R14 = LR R14 = LR R14 = LR CPSR SPSR SPSR SPSR SPSR SPSR User FIQ IRQ SVC ABT UND R15 = PC ARM7 and ARM9 Highlights  Linear 4 GB memory space that includes peripherals and eliminates the need for specific memory types  Load-store architecture with efficient pointer addressing. Fast task context switch times are achieved with multiple register load/store.  Standard (IRQ) and Fast (FIQ) interrupt. Banked microcontroller registers on FIQ reduce register save/restore overhead.  Vectored Interrupt Controller (available in most microcontrollers) optimizes multiple interrupt handling  Processor modes with separate interrupt stacks for predictable stack requirements  Compact 16-bit Instruction Set (Thumb). Compared to ARM mode, Thumb mode code is about 65% of the code size and 160% faster when executing from a 16-bit memory system. Getting Started: Creating Applications with µVision ARM7 and ARM9 Development Tool Support The ARM compilation tools support all ARM-specific features and provide:  Function Inlining eliminates call/return overhead and optimizes parameter passing  Inline assembly supports special ARM/Thumb instructions in C/C++ programs  RAM functions enable high-speed interrupt code and In-System Flash programming  ARM/Thumb interworking provides outstanding code density and microcontroller performance  Task function and RTOS support are built into the C/C++ compiler Cortex-Mx based Microcontrollers Designed for the 32-bit microcontroller market, the Cortex-Mx microcontrollers combine excellent performance at low gate count with features only previously found in high-end processors. With 4GB of linear, unified memory space, the Cortex-Mx processors provide bit-banding features and supports big and little endian configuration. Predefined memory types are available, while some memory regions have additional attributes. Code can be located in the SRAM, external RAM, but preferably in the Code region. Peripheral registers are mapped into the memory space. Code density is improved by the Thumb or Thumb2 instruction set, depending on the processor version. General-purpose registers rank from R0 to R12. R13 (SP) is banked, with only one copy of the R13 (MSP, PSP) being visible at a time. Special registers are available, but are not used for normal data processing. Some of the 16-bit Thumb instructions can access R0-R7 (low) registers only. There is no FIQ; however, nested interrupts and interrupt priority handling is implemented via the Nested Vector Interrupt Controller (NVIC), greatly reducing interrupt latency. 23 24 Chapter 2. Microcontroller Architectures Cortex Core Register Set R0 R1 R2 R3 Low Registers R4 R5 R6 General-Purpose Registers R7 R8 R9 R10 High Registers R11 R12 R13 = PSP R13 = MSP Process Stack Pointer (PSP), Main Stack Pointer (MSP): (banked) R14 = LR Link Register R15 = PC Program Counter xPSR Program Status Register PRIMASK FAULTMASK Exception Mask Registers Special Registers BASEPRI CONTROL Control Registers Cortex-Mx Highlights  Nested Vectored Interrupt Controller optimizes multiple external interrupts (up to 240 + 1 NMI, with at least eight priority levels)  R0-R3, R12, LR, PSR, and PC are pushed automatically to the stack at interrupt entry and popped back at interrupt exit points  Only one instruction set (Thumb2), assuring software upward compatibility with the entire ARM roadmap  Several Extreme Low-Power Modes with an attached Wake-Up Interrupt Controller (WIC) Getting Started: Creating Applications with µVision Cortex-Mx Development Tool Support In addition to the ARM specific characteristics, the Keil MDK-ARM supports the Cortex-Mx Microcontroller Software Interface Standard (CMSIS) and provides the following features:  Core registers and core peripherals are accessible through C/C++ functions  Device independent debug channel for RTOS kernels  Supports object oriented programming, reuse of code, and implements an easy way of porting code to different devices  Extensive debug capabilities allowing direct access to memory without stopping the processor  CMSIS is supported, making the software compatible across the Cortex-Mx architectures Architecture Comparison Conclusions The various architectures have pros and cons and the optimal choice depends highly on the application requirements. The following code comparison section provides additional architectural information that can help you in selecting the optimal microcontroller for your target embedded system. 25 26 Chapter 2. Microcontroller Architectures Code Comparison The following short but representative code examples show the impressive individual strengths of the different microcontroller architectures. I/O Port Access Comparison Source Code if (IO_PIN == 1) i++; } Description Increment a value when an I/O pin is set. {  8051 devices provide bit-addressable I/O Ports and instructions to access fixed memory locations directly  C166, XE166, XC2000 devices provide bit-addressable I/O Ports and instructions to access fixed memory locations directly  ARM7 and ARM9 devices provide indirect memory access instructions only. However, there are no bit operations.  Cortex-Mx devices provide indirect memory access instructions only, but allow atomic bit operations 8051 Code C166/XE166 and XC2000 Code sfr P0=0x80; sbit P0_0=P0^0; sfr P0L=0xFF00; sbit P0_0=P0L^0; #define IOP *(int*)) unsigned char i; unsigned int i; unsigned int i; unsigned int i; void main (void) { if (P0_0) { ; JNB P0_0,?C0002 void main (void) { if (P0_0) { ; JNB P0_0,?C0001 void main (void) { if (IOP & 1) { ; LDR R0,=0xE0028000 ; LDR R0,[R0,#0x0] ; MOV R1,#0x1 ; TST R0,R1 ; BEQ L_1 void main (void) { if (GPIOA->ODR) { ; STR R0,[R1,#0xc] ; LDR R0,[R2,#0] ; CBZ R0,|L1.242| ; i++; INC i ; } ; } i++; SUB i,ONES } RET 6 Bytes ; } RET 10 Bytes ARM7 and ARM9 Thumb Code ; ; ; ; i++; LDR LDR ADD STR } ; BX } R0,=i ; i R1,[R0,#0x0];i R1,#0x1 R1,[R0,#0x0];i Cortex-Mx Thumb2 Code i++; ; MOVS R0,#2 ; STR R0,[R1,#0xc] ; |L1.242| } LR 24 Bytes ; BX } LR 12 Bytes Getting Started: Creating Applications with µVision 27 Pointer Access Comparison Source Code Description typedef struct { int x; int arr[10]; } sx; int f (sx xdata *sp, int i) { return sp->arr[i]; } Return a value that is part of a struct and indirectly accessed via pointer.  8051 devices provide byte arithmetic requiring several microcontroller instructions for address calculation  C166, XE166, XC2000 devices provide efficient address arithmetic with direct support of a large 16 MByte address space  ARM devices are extremely efficient with regard to pointer addressing and always use the 32-bit addressing mode  In Cortex-Mx devices, any register can be used as a pointer to data structures and arrays 8051 Code MOV MOV MOV ADD MOV MOV RLC MOV INC INC MOV ADD MOV MOV ADDC MOV MOVX MOV INC MOVX MOV C166, XE166, XC2000 Code DPL,R7 DPH,R6 A,R5 A,ACC R7,A A,R4 A R6,A DPTR DPTR A,DPL A,R7 DPL,A A,DPH A,R6 DPH,A A,@DPTR R6,A DPTR A,@DPTR R7,A 25 Bytes MOV SHL ADD EXTS MOV R4,R10 R4,#01H R4,R8 R9,#01H R4,[R4+#2] 14 Bytes ARM 7 and ARM9 Thumb Code LSL ADD LDR R0,R1,#0x2 R0,R2,R0 R0,[R0,#0x4] 6 Bytes Cortex-Mx Thumb2 Code ADD LDR R0,R0,R1,LSL #2 R0,[R0,#4] 6-Bytes 28 Chapter 2. Microcontroller Architectures Generating Optimum Code The C/C++ compilers provided by Keil are leaders in code generation and produce highly efficient code. However, code generation and translation is influenced by the way the application software is written. The following hints will help you optimize your application performance. Coding Hints for All Architectures Hint Description Keep interrupt functions short. Well-structured interrupt functions only perform data collection and/or time-keeping. Data processing is done in the main function or by RTOS task functions. This reduces overhead involved with context save/restore of interrupt functions. Check the requirement for atomic operations. Atomic code is required for accessing data while using multiple RTOS threads or interrupt routines that access the memory used by the main function. Carefully check the application to determine if atomic operations are needed and verify the generated code. The various architectures have different pitfalls. For example, incrementing a variable on the 8051 and C166/XE166/XC2000 device is a single, atomic instruction, since it cannot be interrupted, whereas multiple instructions are required for an increment on ARM devices. In contrast, the 8051 requires multiple instructions to access the memory of an int variable. Apply the volatile attribute on variables that are modified by an interrupt, hardware peripherals, or other RTOS tasks. The volatile attribute prevents the C/C++ compiler from optimizing variable access. By default, a C/C++ Compiler may assume that a variable value will remain unchanged between several memory-read operations. This may yield incorrect application behavior in real-time applications. When possible, use automatic variables for loops and other temporary calculations. As part of the optimization process, the Keil C/C++ compiler attempts to maintain local variables (defined at function level) in CPU registers. Register access is the fastest type of memory access and requires the least program code. Getting Started: Creating Applications with µVision Coding Hints for the 8051 Architecture Hint Description Use the smallest possible data type for variables. Favor unsigned char and bit. The 8051 uses an 8-bit CPU with extensive bit support. Most instructions operate on 8-bit values or bits. Consequently, small data types generate code that is more efficient. Use unsigned data types whenever possible. The 8051 has no direct support for signed data types. Signed operations require additional instructions whereas unsigned data types are directly supported by the architecture. Favor the SMALL memory model. Most applications may be written using the SMALL memory model. You can locate large objects, as arrays or structures, into xdata or pdata memory using explicit memory types. Note, the Keil C51 run-time library uses generic pointers and can work with any memory type. When using other memory models, apply the memory type data to frequently used variables. Variables in the data address space are directly accessed by an 8-bit address that is encoded into the 8051 instruction set. This memory type generates the most efficient code. Learn how to use pdata memory type on your device. The pdata memory provides efficient access to 256 bytes using MOVX @Ri instructions with 8-bit addressing. However, pdata behaves differently on the various 8051 devices, since it may require setting up a paging register. The xdata memory type is generic and accesses large memory spaces (up to 64KB). Use memory-typed pointers when possible. By default, the Keil C51 Compiler uses generic pointers that may access any memory type. Memory-typed pointers can access only a fixed memory space, but generate faster and smaller code. Reduce the usage of Reentrant Functions. The 8051 lacks support for stack variables. Reentrant functions are implemented by the Keil C51 Compiler using a compile-time stack with data overlaying for maximum memory utilization. Reentrant functions on the 8051 require simulation of the stack architecture. Since reentrant code is rarely needed in embedded applications, you should minimize the usage of the reentrant attributes. Use the LX51 Linker/Locater and Linker Code Packing to reduce program size. The extended LX51 Linker/Locator (available only in the PK51 Professional Developer’s Kit) analyzes and optimizes your entire program. Code is reordered in memory to maximize 2byte AJMP and ACALL instructions (instead of 3-byte LJMP and LCALL). Linker Code Packing (enabled in C51 OPTIMIZE level 8 and above) generates subroutines for common code blocks. 29 30 Chapter 2. Microcontroller Architectures Coding Hints for C166, XE166, XC2000 Architectures Hint Description When possible, use 16-bit data types for automatic and parameter variables. Parameter passing is performed in 16-bit CPU registers (many 16-bit registers are available for automatic variables). More 16bit variables (signed/unsigned int/short) can be assigned to CPU registers. This generates code that is more efficient. Replace long with int data types when possible. Operations that use 16-bit types (like int and unsigned int) are much more efficient than operations using long types. Use the bit data type for boolean variables. These CPUs have efficient bit instructions that are fully supported by the Keil C166 Compiler with the bit data type. Use the SMALL or MEDIUM memory model when possible. In these memory models, the default location of a variable is in near memory, accessible through16-bit direct addresses encoded in the CPU instructions. You can locate large objects (array or struct) into huge or xhuge using explicit memory types. When using other memory models, apply the near, idata, or sdata memory type to frequently used variables. Variables in the near, idata, or sdata address space are accessed through a 16-bit address that is encoded directly into a single C166/XE166/XC2000 instruction. These memory types generate the most efficient code. Use the memory model HCOMPACT/HLARGE instead of COMPACT/LARGE. The memory models COMPACT and LARGE use the obsolete far memory type and have an object size limit of 16KB. The memory models HCOMACT and HLARGE use the huge memory type that feature a 64KB object size limit. Even cast operations from near to huge pointers are more optimal. Use near pointers when possible. Check if a near pointer is sufficient for accessing the memory, since near pointers can access variables in the near, idata, or sdata address space. Near pointers generate faster and smaller code. Getting Started: Creating Applications with µVision Coding Hints for the ARM7 and ARM9 Architecture Hint Description When possible, use 32-bit data types for automatic and parameter variables. Parameter passing is performed in 32-bit CPU registers. All ARM instructions operate on 32-bit values. In Thumb mode, all stack instructions operate only on 32-bit values. By using 32-bit data types (signed/unsigned int/long), additional data type cast operations are eliminated. Use the Thumb instruction set. Thumb mode is about 65% of the code size and 160% faster than ARM mode when executing from a 16-bit memory system. The MDK-ARM Compiler automatically inserts required ARM / Thumb interworking instructions. Use __swi software interrupt functions for atomic sequences. Via the __swi function attribute, the MDK-ARM Compiler offers a method to generate software interrupt functions directly, which cannot be interrupted by IRQ (__swi functions can be interrupted by FIQ interrupts). In contrast to other embedded architectures, ARM prevents access to the interrupt disable bits I and F in User mode. Enhance struct pointer access by placing scalars at the beginning and arrays as subsequent struct members. Thumb and ARM instructions encode a limited displacement for memory access. When a struct is accessed via a pointer, scalar variables at the beginning of a struct can be accessed directly. Arrays always require address calculation. Consequently, it is more efficient to place scalar variables at the beginning of a struct. Assign high speed interrupt code to RAM. Code executed from Flash ROM typically requires wait states or CPU stalls. Code execution from RAM does not. Consequently, time critical functions (like high-speed interrupt code) can be located in RAM directly using the Memory Assignment feature in Options for File – Properties available via the Context Menu of that file. Optimize for Size To optimize an application for minimal program size select under Options for Target the following toolchain:  In the dialog page Target enable Code Generation - Use Cross-Module Optimization  In the dialog page C/C++ select Optimization: Level 2 (-O2) and disable the options Optimize for Time, Split Load and Store Multiple, and One ELF Section per Function MicroLIB The compiler offers a MicroLIB to be used for further reducing the code size of an application. MicroLIB is tailored for deeply embedded systems, but is not fully ANSI compliant. Do not use MicroLIB when execution speed is your primary goal. Optimize for Speed To optimize an application for maximum execution speed, under Options for Target select the following toolchain:  In the dialog pageTarget enable Code Generation - Use Cross-Module Optimization  In the dialog page C/C++ select Optimization: Level 3 (-O3), enable Optimize for Time, and disable Split Load and Store Multiple 31 32 Chapter 2. Microcontroller Architectures Coding Hints for the Cortex-Mx Architecture Hint Description When possible, use 32-bit data types for automatic and parameter variables. Parameter passing is performed in 32-bit CPU registers. All ARM instructions operate on 32-bit values. In Thumb mode, all stack instructions operate only on 32-bit values. By using 32-bit data types (signed/unsigned int/long), additional data type cast operations are eliminated. Optimize for Size To optimize an application for minimal program size select under Options for Target the following toolchain:  In the dialog page Target enable Code Generation - Use CrossModule Optimization  In the dialog page C/C++ select Optimization: Level 2 (-O2) and disable the options Optimize for Time, Split Load and Store Multiple, and One ELF Section per Function MicroLIB The compiler offers a MicroLIB to be used for further reducing the code size of an application. MicroLIB is tailored for deeply embedded systems, but is not fully ANSI compliant. Do not use MicroLIB when execution speed is your primary goal. Optimize for Speed To optimize an application for maximum execution speed, under Options for Target select the following toolchain:  In the dialog pageTarget enable Code Generation - Use CrossModule Optimization  In the dialog page C/C++ select Optimization: Level 3 (-O3), enable Optimize for Time, and disable Split Load and Store Multiple Sleep mode features To optimize power consumption of an application you may use the WFI instruction to send the processor into Sleep Mode until the next interrupt is received. In C programs, use the intrinsic function __wfi() to insert this instruction into your code. Enhance struct pointer access, by placing scalars at the beginning and arrays as sub-sequent struct members. Thumb2 instructions encode a limited displacement for memory access. When a struct is accessed via a pointer, scalar variables at the beginning of a struct can be directly accessed. Arrays always require address calculations. Therefore, it is more efficient to place scalar variables at the beginning of a struct. Getting Started: Creating Applications with µVision Chapter 3. Development Tools The Keil development tools offer numerous features and advantages that help you to develop embedded applications quickly and successfully. They are easy to use and are guaranteed to help you achieve your design goals in a timely manner. Software Development Cycle When using the Keil tools, the project development cycle is similar to any other software development project. 1. Create a project, select the target device from the Device Data base, and configure the tool settings 2. Create your source files in C/C++ or Assembly 3. Build your application with the Project Manager 4. Debug and correct errors in source files, verify and optimize your application 5. Download your code to Flash ROM or SRAM and test the linked application Each component shown in the block diagram is described in the following section. 33 34 Chapter 3. Development Tools µVision IDE The µVision IDE is a window-based software development platform combining a robust editor, Project Manager, and Make Utility tool. µVision supports all the Keil tools including C/C++ Compiler, Macro Assembler, Linker, Library Manager, and Object-HEX Converter. µVision helps expedite the development process by providing:  Device Database for selecting a device and configuring the development tools for that particular microcontroller  Project Manager to create and maintain projects  Make Utility for assembling, compiling, and linking your embedded applications  Full-featured source code editor  Template Editor that is used to insert common text sequences or header blocks  Source Browser for rapidly exploring code objects, locating and analyzing data in your application  Function Browser for quickly navigating between functions in your program  Function Outlining for controlling the visual scope within a source file  Built-in utilities, such as Find in Files and functions for commenting and uncommenting source code  µVision Simulator and Target Debugger are fully integrated  Configuration Wizard providing graphical editing for microcontroller startup code and configuration files  Interface to configure Software Version Control Systems and third-party utilities  Flash Programming Utilities, such as the family of Keil ULINK USBJTAG Adapters  Dialogs for all development tool settings  On-line Help and links to microcontroller data sheets and user guides Getting Started: Creating Applications with µVision µVision Device Database The µVision Device Database offers a convenient way to select and configure your device and project parameters. It includes preconfigured settings, so that you can fully concentrate on your application requirements. In addition, you can add your own devices, or change existing settings. Use the features of the Device Database to:  Initialize the start up code and device settings  Load the configuration options for the assembler, compiler, and linker  You can add and change microcontroller configuration settings µVision Debugger The µVision Debugger is completely integrated into the µVision IDE. It provides the following features:  Disassembly of the code on C/C++ source- or assembly-level with program execution in various stepping modes and various view modes, like assembler, text, or mixed mode  Multiple breakpoint options including access and complex breakpoints  Bookmarks to quickly find and define your critical spots  Review and modify memory, variable, and register values  List the program call tree including stack variables  Review the status of on-chip microcontroller peripherals  Debugging commands or C-like scripting functions  Execution Profiling to record and display the time consumed, as well as the cycles needed for each instruction  Code Coverage statistics for safety-critical application testing  Various analyzing tools to view statistics, record values of variables and peripheral I/O signals, and to display them on a time axis  Instruction Trace capabilities to view the history of executed instructions  Define personalized screen and window layouts 35 36 Chapter 3. Development Tools The µVision Debugger offers two operating modes—Simulator Mode and Target Mode. Simulator Mode configures the µVision Debugger as a software-only product that accurately simulates target systems including instructions and most on-chip peripherals. In this mode, you can test your application code before any hardware is available. It gives you serious benefits for rapid development of reliable embedded software. The Simulator Mode offers:  Software testing on your desktop with no hardware environment  Early software debugging on a functional basis improves software reliability  Breakpoints that are impossible with hardware debuggers  Optimal input signals. Hardware debuggers add extra noise  Single-stepping through signal processing algorithms is possible. External signals are stopped when the microcontroller halts.  Detection of failure scenarios that would destroy real hardware peripherals Target Mode1 connects the µVision Debugger to real hardware. Several target drivers are available that interface to a:  ULINK JTAG/OCDS Adapter that connects to on-chip debugging systems  Monitor that may be integrated with user hardware or that is available on many evaluation boards  Emulator that connects to the microcontroller pins of the target hardware  In-System Debugger that is part of the user application program and provides basic test functions  ULINKPro Adapter a high-speed debug and trace unit connecting to on-chip debugging systems via JTAG/SWD/SWV, and offering Cortex-M3 ETM Instruction Trace capabilities 1 Some target drivers have hardware restrictions that limit or eliminate features of the µVision Debugger while debugging the target hardware. Getting Started: Creating Applications with µVision Assembler An assembler allows you to write programs using microcontroller instructions. It is used where utmost speed, small code size, and exact hardware control is essential. The Keil Assemblers translate symbolic assembler language mnemonics into executable machine code while supporting source-level symbolic debugging. In addition, they offer powerful capabilities like macro processing. The assembler translates assembly source files into re-locatable object modules and can optionally create listing files with symbol table and cross-reference details. Complete line number, symbol, and type information is written to the generated object files. This information enables the debugger to display the program variables exactly. Line numbers are used for source-level debugging with the µVision Debugger or other third-party debugging tools. Keil assemblers support several different types of macro processors (depending on architecture):  The Standard Macro Processor is the easier macro processor to use. It allows you to define and use macros in your assembly programs using syntax that is compatible with that used in many other assemblers.  The Macro Processing Language or MPL is a string replacement facility that is compatible with the Intel ASM-51 macro processor. MPL has several predefined macro processor functions that perform useful operations like string manipulation and number processing. Macros save development and maintenance time, since commonly used sequences need to be developed once only. Another powerful feature of the assembler’s macro processor is the conditional assembly capability. You can invoke conditional assembly through command line directives or symbols in your assembly program. Conditional assembly of code sections can help achieve the most compact code possible. It also allows you to generate different applications from a single assembly source file. 37 38 Chapter 3. Development Tools C/C++ Compiler The ARM C/C++ compiler is designed to generate fast and compact code for the ARM7, ARM9 and Cortex-Mx processor architectures; while the Keil ANSI C compilers target the 8051, C166, XE166, and XC2000 architectures. They can generate object code that matches the efficiency and speed of assembly programming. Using a high-level language like C/C++ offers many advantages over assembly language programming:  Knowledge of the processor instruction set is not required. Rudimentary knowledge of the microcontroller architecture is desirable, but not necessary.  Details, like register allocation, addressing of the various memory types, and addressing data types, are managed by the compiler  Programs receive a formal structure (imposed by the C/C++ programming language) and can be split into distinct functions. This contributes to source code reusability as well as a better application structure.  Keywords and operational functions that resemble the human thought process may be used  Software development time and debugging time are significantly reduced  You can use the standard routines from the run-time library such as formatted output, numeric conversions, and floating-point arithmetic  Through modular programming techniques, existing program components can be integrated easily into new programs  The C/C++ language is portable (based on the ANSI standard), enjoys wide and popular support, and is easily obtained for most systems. Existing program code can be adapted quickly and as needed to other processors. Object-HEX Converter The object-hex converter creates Intel HEX files from absolute object modules that have been created by the linker. Intel HEX files are ASCII files containing a hexadecimal representation of your application program. They are loaded easily into a device program for writing to ROM, EPROM, FLASH, or other programmable memory. Intel HEX files can be manipulated easily to include checksum or CRC data. Getting Started: Creating Applications with µVision Linker/Locator The linker/locator combines object modules into a single, executable program. It resolves external and public references and assigns absolute addresses to relocatable program segments. The linker includes the appropriate run-time library modules automatically and processes the object modules created by the Compiler and Assembler. You can invoke the linker from the command line or from within the µVision IDE. To accommodate most applications, the default linker directives have been chosen carefully and need no additional options. However, it is easy to specify additional custom settings for any application. Library Manager The library manager creates and maintains libraries of object modules (created by the C/C++ Compiler and Assembler). Library files provide a convenient way to combine and reference a large number of modules that may be used by the linker. The linker includes libraries to resolve external variables and functions used in applications. Modules from libraries are extracted and added to programs only if required. Modules, containing routines that are not invoked by your program specifically, are not included in the final output. Object modules extracted by the linker from a library are processed exactly like other object modules. There are a number of advantages to using libraries: security, speed, and minimized disk space are only a few. Libraries provide a vehicle for distributing large numbers of functions and routines without distributing the original source code. For example, the ANSI C library is supplied as a set of library files. You can build library files (instead of executable programs) using the µVision Project Manager. To do so, check the Create Library check box in the Options for Target — Output dialog. Alternatively, you may invoke the library manager from the Command Window. 39 40 Chapter 4. RTX RTOS Kernel Chapter 4. RTX RTOS Kernel This chapter discusses the benefits of using a Real-Time Operating System (RTOS) and introduces the features available in Keil RTX Kernels. Note that the Keil development tools are compatible with many third-party RTOS solutions. You are not bound to use Keil RTX; however, the RTX Kernels are well integrated into the development tools and are feature-rich, and well tailored towards the requirements of deeply embedded systems. Software Concepts There are two basic design concepts for embedded applications:  Endless Loop Design: this design involves running the program as an endless loop. Program functions (tasks) are called from within the loop, while interrupt service routines (ISRs) perform time-critical jobs including some data processing.  RTOS Design: this design involves running several tasks with a Real-Time Operating System (RTOS). The RTOS provides inter-task communication and time management functions. A preemptive RTOS reduces the complexity of interrupt functions, since time-critical data processing is performed in high-priority tasks. Endless Loop Design Running an embedded program in an endless loop is an adequate solution for simple embedded applications. Time-critical functions, typically triggered by hardware interrupts, are executed in an ISR that also performs any required data processing. The main loop contains only basic operations that are not timecritical, but which are executed in the background. This software concept requires only one stack area and is very well suited for devices with limited memory. Architectures that provide several interrupt levels allow complex low-level ISR functions. Time-critical jobs may execute in higher interrupt levels. Getting Started: Creating Applications with µVision 8051, C166/XE166/XC2000, and ARM Cortex-Mx microcontrollers provide several interrupt levels. Higher-level interrupts may halt lower-level interrupts, or the main function. It is impossible to suspend the execution of an ISR except through higher priority interrupts. Therefore, the timing of a system with many complex ISR levels is unpredictable, since high priority interrupts may take up most of the CPU time. Another challenge is to determine the worst-case stack nesting. Applications with complex ISR designs can have unnoticed stack resource issues, which may cause sporadic execution faults. Note, that the ARM architecture provides an extra stack for ISR that avoids stack memory surprises during the main loop execution. RTOS Design The RTOS design, due to its very nature, allows several tasks to execute within sequential time slices. A preemptive RTOS provides task priority levels, in which high priority tasks interrupt the execution of low priority tasks. Most RTOS systems offer inter-task communication and time delay functions supporting the design of complex applications. The ARM based architectures are designed for RTOS usage. An RTOS is almost mandatory on ARM7, ARM9, and Cortex-Mx based systems that have several interrupt sources. ARM devices provide a separate ISR stack, and hence, each task needs no additional stack for ISR execution (as required on 8051 and C166/XE166/XC2000 devices). 41 42 Chapter 4. RTX RTOS Kernel A preemptive RTOS supports multiple task priorities. Tasks with the same priority are executed in sequence; tasks with a higher priority suspend tasks with a lower priority. An ISR always interrupts task execution and may exchange data with other tasks. The RTOS also solves many other challenges specific to embedded applications. It helps you to maintain memory resources and data communication facilities, and allows you to split a complex application into simpler jobs. Keil provides several different RTOS systems for the various microcontroller architectures:  RTX51 Tiny and RTX166 Tiny (for 8051 and C166/XE166/XC2000) is a non-preemptive RTOS and uses a special stack swapping technique designed for devices with limited RAM  RTX (for ARM7/ARM9 and Cortex-Mx) and ARTX166 (for C166/XE166/XC2000) are preemptive RTOS kernels offering task priority levels. These kernels support message passing with ISRs and implement functions with thread-safe memory block allocation and deterministic execution times. An ISR may collect data into message buffers and send messages to a high priority task, which subsequently performs complex data processing. The ISR remains short and simple. Getting Started: Creating Applications with µVision 43 RTX Introduction Many microcontroller applications require simultaneous execution of multiple jobs or tasks. For such applications, an RTOS allows flexible scheduling of system resources (CPU, memory, etc.) to several tasks. With RTX, you write and compile programs using standard C. Only a few deviations from standard C are required in order to specify the task ID and priority. RTX-166 programs require the inclusion of the RTX166.H or RTX166T.H header file also. RTX_CONFIG.C is required on ARM devices. By selecting the operating system through the dialog Options for Target – Target, the linker, L166, included in µVision, links the appropriate RTX-166 library file. Single Task Program A standard C program starts execution with the main function. In an embedded application, the main function is usually coded as an endless loop and can be thought of as a single task that is executed continuously. For example: int counter; main (void) { counter = 0; while (1) { counter++; } // repeat forever // increment counter } Round-Robin Task Switching Round-Robin task switching allows a quasi-parallel, simultaneous execution of several tasks. Each task is executed for a predefined period. A timeout suspends the execution of a task and causes another task to be started. The following example uses this round-robin task switching technique. Program execution starts with job0, as an RTOS task function. The RTX function os_tsk_create marks job1 as ready for execution. The task functions job0 and job1 are simple counting loops. After its time slot has been consumed, RTX suspends the execution of job0 and begins execution of job1. As soon as its time slot is consumed, the system continues with job0. 44 Chapter 4. RTX RTOS Kernel Simple RTX Program using Round-Robin Task Switching int counter0; int counter1; __task1 void job0 (void) { os_tsk_create (job1, 1); while (1) { counter0++; } // start job 1 // endless loop // Increment counter 0 } __task void job1 (void) while (1) { counter1++; } } { main (void) { os_sys_init (job0); } // Endless loop // Increment counter 1 // the main function // starts only job 0 The Wait Functions The RTX kernels provide wait2 functions that suspend the execution of the current task function and wait for the specified event. During that time, a task waits for an event, while the CPU can execute other task functions. Wait for Time Delay RTX uses a hardware timer of the microcontroller device to generate periodic interrupts (timer ticks). The simplest event is a time delay through which the currently executing task is interrupted for a specified number of timer ticks. This following program is similar to the previous example with the exception that job0 is suspended with os_dly_wait after counter0 has been incremented. RTX waits three timer ticks until job0 is ready for execution again. During this time, job1 is executed. This function also calls os_dly_wait with 5 ticks time delay. The result: counter0 is incremented every three ticks and counter1 is incremented every five timer ticks. 1 For non-ARM devices the syntax is: void job0 (void) __task {…}. 2 Within RTX Tiny time delays are created with the function os_wait (K_TMO, …). Getting Started: Creating Applications with µVision 45 Program with Wait for Time Delay int counter0; int counter1; __task void job0 (void) { os_tsk_create (job1, 1); while (1) { counter0++; os_dly_wait (3); } // start job 1 // Increment counter 0 // Wait 3 timer ticks } __task void job1 (void) while (1) { counter1++; os_dly_wait (5); } } { // Increment counter 1 // Wait 5 timer ticks Wait for Event Flags Event flags are used for task coordination, that is, a task waiting for another task to raise an event flag. If an event flag was set previously, the task continues its execution. Program with Wait for Event Flag (job1 waits for job0 and counts overflow of i0) long i0, save_i0, i1; OS_TID id1; __task void job0 (void) { id1 = os_tsk_create (job1, 1); while (1) { i0++; if (i0 > 1000000) { i0 = 0; os_evt_set (1, id1); } } // task ID for event transmits // start job 1 // when i1 reaches 1000000 // clear i1 // set event '1' on job1 } __task void job1 (void) { while (1) { os_evt_wait_or (1, 0xffff); save_i0 = i0; i1; } } // wait for event '1' // save value of i0 // count events in i1 46 Chapter 4. RTX RTOS Kernel Preemptive Task Switching Tasks with the same priority1 (example above) need a round-robin timeout or an explicit call to a RTX wait function to execute other tasks. Therefore, in the example above, the value of save_i0 is not zero, as you might have expected. If job1 has a higher task priority than job0, execution of job1 starts instantly and the value of save_i0 will be zero. job1 preempts execution of job0 (this is a very fast task switch requiring a few ms only). Start job1 with Higher Task Priority : __task void job0 (void) { id1 = os_tsk_create (job1, 2); : : } // start job 1 with priority 2 1 RTX Tiny does not offer task priorities. Instead, RTX Tiny has one event flag per task, called signal, and uses the function os_wait (K_SIG, …) to wait for this signal flag. Getting Started: Creating Applications with µVision 47 Mailbox Communication A mailbox is a FIFO (first in – first out) buffer for transferring messages between task functions. Mailbox functions accept pointer values, typically referencing memory buffers. However, by using appropriate type casts, you may pass any integer 32-bit data type. Program with Mailbox Communication1 os_mbx_declare(v_mail, 20); __task void job0 (void) int i, res; // mailbox with 20 entries { os_mbx_init (v_mail, sizeof (v_mail)); os_tsk_create (job1, 2); // create mailbox first // before waiting tasks for (i = 0; i < 30; ) { // send 30 mail res = os_mbx_send (v_mail, (void *) i, 1000); if (res == OS_R_OK) i++; // check that mail send OK } os_tsk_delete_self (); // when done delete own task } __task void job1 (void) int v, res; { while (1) { res = os_mbx_wait (v_mail, (void **) &v, 0xFFFF); if (res == OS_R_OK || s == OS_R_MBX) { printf ("\nReceived v=%d res=%d", v, res); } } // receive mail // check status // use when correct } The task job0 uses a mailbox to send information to job1. When job1 runs with a higher priority than job0, the mail is instantly delivered. The mailbox buffers up to 20 messages when job1 runs with the same or lower priority than job0. The os_mbx_send and os_mbx_wait functions provide a timeout value that allows function termination when no mail can be delivered within the timeout period. 1 When creating high-priority tasks using a mailbox, initialize the mailbox before it might be used by a high-priority task. 48 Chapter 4. RTX RTOS Kernel Semaphores Semaphores are utilized to synchronize tasks within an application. Although they have a simple set of calls to the operating system, they are the classic solution in preventing race conditions. However, they do not resolve resource deadlocks. RTX ensures that atomic operations used with semaphores are not interrupted. Binary Semaphores Synchronizing two tasks is the simplest use case of a semaphore: os_sem semA; __task void job0 (void) os_sem_init(semA, 0); // declare the semaphore { while(1) { do_func_A(); os_sem_send(semA); } // free the semaphore } __task void job1 (void) { while(1) { os_sem_wait(semA, 0xFFFF); do_func_B(); } // wait for the semaphore } In this case the semaphore is used to ensure the execution of do_func_A() prior to executing do_func_B(). Getting Started: Creating Applications with µVision 49 Counting Semaphores (Multiplex) Use a multiplex to limit the number of tasks that can access a critical section of code. For example, a routine to access memory resources and that supports a limited number of calls only. os_sem mplxSema; __task void job0 (void) { os_sem_init (mplxSema, 5); while(1) { os_sem_wait (mplxSema); processBuffer(); os_sem_send (mplxSema); } // declare the semaphore // init semaphore with 5 tokens // acquire a token // free the token } In this example, we initialize the multiplex semaphore with five tokens. Before a task can call processBuffer(), it must acquire a semaphore token. Once the function has completed, it returns the token to the semaphore. If more than five calls attempt to invoke processBuffer(), the sixth must wait until one of the five running tasks returns its token. Thus, the multiplex semaphore ensures that a maximum of five calls can use processBuffer() simultaneously. Interrupt Service Routines An interrupt is an asynchronous signal from the hardware or software that forces the microcontroller to save the execution state. Interrupts trigger a context switch to an interrupt handler. Software interrupts are implemented as instructions in the instruction set of the microcontroller and work similar to hardware interrupts. Interrupts can be classified as a:  Maskable interrupt (IRQ) – a hardware interrupt that can be ignored by setting a bit in a bit-mask  Non-maskable interrupt (NMI) – a hardware interrupt that cannot be configured and thus cannot be ignored  Software interrupt – generated within a processor by executing an instruction 50 Chapter 4. RTX RTOS Kernel RTX ensures that interrupts execute correctly and leaves the machine in a welldefined state. Interrupt service routines, also known as interrupt handlers, are used to service hardware devices and transitions between operation modes, such as system calls, system timers, disk I/O, power signals, keystrokes, watchdogs; other interrupts transfer data using UART or Ethernet. Hints for working with interrupt functions in RTX:  Functions that begin with os_ can be called from a task but not from an interrupt service routine  Functions that begin with isr_ can be called from an IRQ interrupt service routine but not from a task. Never use them from FIQ.  Never enable any IRQ interrupt that calls isr_ functions before the kernel has been started  Avoid nesting IRQ functions on ARM7/ARM9 targets  Use short IRQ functions to send signals and messages to RTOS tasks  Interrupt functions are added to applications the same way as in non-RTX projects  By default, interrupts are globally enabled at startup Another important concept is the interrupt latency, which is defined as the period between the generation and servicing of that interrupt. This is especially important in systems that need to control machinery in real time, and therefore require low interrupt latency. RTX ensures that a subroutine will finish its execution in an agreed maximum length of time and that the interrupt latency does not exceed a predefined maximum length of time. The general logic of an ISR looks like the following code example. The interrupt function ext0_int sends an event to process_task and exits. The task process_task processes the external interrupt event. In this example, process_task is simple and only counts the number of interrupt events. Getting Started: Creating Applications with µVision #define EVT_KEY 0x00001 OS_TID int pr_task; num_ints; __irg void ext0_int (void) { 51 // external interrupt routine isr_evt_set (EVT_KEY, pr_task); acknYourInterrupt (); // send event to ‘process_task’ // acknowledge interrupt; } __task void process_task (void) num_ints =0; { while(1) { os_evt_wait_or (EVT_KEY, 0xFFFF); num_ints++; } } __task void init_task (void) { enableYourInterrupt (); pr_task = os_tsk_create (process_task, 100); os_tsk_delete_self (); // create task with prio } Press F1 to browse through the numerous examples and additional information in the on-line help. Memory and Memory Pools The compilers delivered with the Keil development tools provide access to all memory areas, regardless of the microcontroller architecture. Variables can be explicitly assigned to a specific memory space by including a memory type in the declaration, or implicitly assigned based on the memory model. Function arguments and atomic variables that cannot be located in registers are also stored in the default memory area. Accessing the internal data memory is considerably faster than accessing the external data memory. If possible, place often-used variables into the internal memory space and less-used variables into the external memory space. RTX provides thread-safe and fully reentrant1 allocation functions for fixed sized memory pools. These functions have a deterministic execution time that is 1 Variable length memory allocation functions are not reentrant! Disable/enable system timer interrupts using tsk_lock() and tsk_unlock() during the execution of malloc() and free(). 52 Chapter 4. RTX RTOS Kernel independent of the pool usage. Built-in memory allocation routines enable you to dynamically use the system memory by creating memory pools and use fixed sized blocks from the memory pool. The memory pool needs to be properly initialized to the size of the object. #include os_mbx_declare (MsgBox, 16); // declare an RTX mailbox U32 mpool [16*( 2 * sizeof (U32) ) /4 + 3]; // memory for 16 messages __task void rec_task (void); __task void send_task (void) U32 *mptr; // task to receive a message { os_tsk_create (rec_task, 0); os_mbx_init (MsgBox, sizeof (MsgBox)); // Task to send a message // init mailbox mptr = _alloc_box (mpool); // alloc. memory for the message mptr[0] = 0x3215fedc; mptr[1] = 0x00000015; // set message content os_mbx_send (MsgBox, mptr, 0xffff); // Send the message to 'MsgBox' os_tsk_delete_self (); } __task void rec_task (void) U32 *rptr, rec_val[2]; { os_mbx_wait (MsgBox, &rptr, 0xffff); rec_val[0] = rptr[0]; rec_val[1] = rptr[1]; // Wait for message // Store content to 'rec_val' _free_box (mpool, rptr); // Release the memory block os_tsk_delete_self (); } void main (void) { _init_box (mpool, sizeof (mpool), sizeof (U32)); os_sys_init (send_task); } To send a message object of a variable size and use the variable size memory block, you must use the memory allocation functions, which can be found in stdlib.h. Getting Started: Creating Applications with µVision 53 RTX and ARTX166 Function Overview Function Group RTX ARTX166 Task Management create-task, delete-task, passtask, change-priority, runningtask-id, running-task-priority, lock-task, unlock-task, systeminit, system-priority create-task, delete-task, passtask, change-priority, runningtask-id, running-task-priority, lock-task, unlock-task, systeminit, define-task Event/Signal Functions clear-event, get-event, set-event, wait-event, isr-set-event clear-event, get-event, set-event, wait-event, isr-set-event Semaphore Functions initialize -semaphore, sendsemaphore, wait-semaphore, isr-send-semaphore initialize -semaphore, sendsemaphore, wait-semaphore, isr-send-semaphore Mailbox Functions check-mbx, declare-mbx, initialize -mbx, send-mbx, waitmbx, isr-receive-mbx, isr-send-mbx, isr-check-mbx create-pool, check-pool, getblock, free-block check-mbx, declare-mbx, initialize -mbx, send-mbx, waitmbx, isr-receive-mbx, isr-send-mbx, Mutex Management initialize-mutex, release-mutex, wait-mutex initialize-mutex, release-mutex, wait-mutex System Clock (TimerTicks) delay-task, wake-up-task, setslice, create-timer, kill-timer, calltimer interval-wait delay-task, wake-up-task, setslice, create-timer, kill-timer, calltimer interval-wait Memory Management Generic WAIT Function RTX and ARTX166 Technical Data Technical Data RTX ARTX166 max Tasks 250 250 Events/Signals 16 per task 16 per task Semaphores, Mailboxes, Mutexes unlimited unlimited min RAM 2 – 3 KBytes 500 Bytes ARM7/ARM9 Cortex-Mx max Code Space 4.2 KBytes 4.0 KBytes 4.0 KBytes Hardware Needs 1 on-chip timer SysTick timer 1 on-chip timer Task Priorities 1 – 254 1 – 254 1-127 Context Switch < 7 µsec @ 60 MHz < 4 µsec @ 72 MHz < 15 µsec @ 20 MHz Interrupt Lockout 3.1 µsec @ 60 MHz not disabled by RTX 0.2 µsec @ 20 MHz 54 Chapter 4. RTX RTOS Kernel RTX51 Tiny and RTX166 Tiny Function Overview Function Group RTX51 Tiny RTX166 Tiny Task Management create-task, delete-task, running-task-id, switch-task, set-ready, isr-set-ready create-task, delete-task, running-task-id, delay-task Signal Functions send-signal, clear-signal, isrsend-signal send-signal, clear-signal, isrsend-signal, wait-signal System Clock (Timer-Ticks) reset-interval delay-task Generic WAIT Function wait wait RTX51 Tiny and RTX166 Tiny Technical Data Technical Data RTX51 Tiny RTX166 Tiny max Tasks 16 32 Signals 16 32 max RAM 7 + 3 Bytes/Task 8 + 4 Bytes/Task max Code Space 900 Bytes 1.5 KBytes Hardware Needs No Timer 1 on-chip Timer Context Switch 100-700 Cycles 400 – 4000 Cycles Interrupt Lockout < 20 Cycles < 4 µsec, 0 ws. Getting Started: Creating Applications with µVision Chapter 5. Using µVision The µVision IDE is, for most developers, the easiest way to create embedded system programs. This chapter describes commonly used µVision features and explains how to use them. General Remarks and Concepts Before we start to describe how to use µVision, some general remarks, common to many screens1 and to the behavior of the development tool, are presented. In our continuous effort to deliver best-in-class development tools, supporting you in your daily work, µVision has been built to resemble the look-and-feel of widespread applications. This approach decreases your learning curve, such that you may start to work with µVision right away. Based on the concept of windows:  µVision windows can be re-arranged, tiled, and attached to other screen areas or windows respectively  It is possible to drag and drop windows, objects, and variables  A Context Menu, invoked through the right mouse button, is provided for most objects  You can use keyboard shortcuts and define your own shortcuts  You can use the abundant features of a modern editor  Menu items and Toolbar buttons are grayed out when not available in the current context  Graphical symbols are used to resemble options, to mark unsaved changes, or reveal objects not included into the project  Status Bars display context-driven information  You can associate µVision to third-party tools 1 The screenshots presented in the next chapters have been taken from different example programs and several microcontroller architectures to resemble the main feature, sometimes the special feature, of that topic. The same window, dialog, or tab category will look slightly different for other microcontroller architectures. 55 56 Chapter 5. Using µVision To launch µVision click the µVision icon on your desktop or select µVision from the Start Menu. Window Layout Concepts You can set up your working environment1 in µVision at your discretion. Nevertheless, let us define three major screen areas. The definition will help you to understand future comments, illustrations, and instructions. 1 Any window can be moved to any other part of the µVision screen, or even outside of µVision to any other physical screen, with the exception of the objects related to the Text Editor. Getting Started: Creating Applications with µVision The Project Windows area is that part of the screen in which, by default, the Project Window, Functions Window, Books Window, and Registers Window are displayed. Within the Editor Windows area, you are able to change the source code, view performance and analysis information, and check the disassembly code. The Output Windows area provides information related to debugging, memory, symbols, call stack, local variables, commands, browse information, and find in files results. If, for any reason, you do not see a particular window and have tried displaying/hiding it several times, please invoke the default layout of µVision through the Window – Reset Current Layout Menu. 57 58 Chapter 5. Using µVision Positioning Windows The µVision windows may be placed onto any area of the screen, even outside of the µVision frame, or to another physical screen.   Click and hold the Title Bar1 of a window with the left mouse button Drag the window to the preferred area, or onto the preferred control, and release the mouse button Please note, source code files cannot be moved outside of the Editor Windows2. Invoke the Context Menu of the window’s Title Bar to change the docking attribute of a window object. In some cases, you must perform this action before you can drag and drop the window. µVision displays docking helper controls3, emphasizing the area where the window will be attached. The new docking area is represented by the section highlighted in blue. Snap the window to the Multiple Document Interface (MDI) or to a Windows area by moving the mouse over the preferred control. 1 You may click the page/object name to drag and drop the object. 2 Source code files stay in the Text Editor’s window. 3 Controls indicate the area of the new window position. The new position is highlighted. Getting Started: Creating Applications with µVision µVision Modes µVision operates in two modes: Build Mode and Debug Mode. Screen settings, Toolbar settings, and project options are stored in the context of the mode. The File Toolbar is enabled in all modes, while the Debug Toolbar and Build Toolbar display in their respective mode only. Buttons, icons, and menus are enabled if relevant for a specific mode. The standard working mode is Build Mode. In this mode you write your application, configure the project, set preferences, select the target hardware and the device; you will compile, link, and assemble the programs, correct the errors, and set general settings valid for the entire application. In Debug Mode, you can also change some general options and edit source code files, but these changes will only be effective after you have switched back to Build Mode, and rebuild your application. Changes to debug settings are effective immediately. Menus The Menu bar provides access to most µVision commands including file operations, editor operations, project maintenance, development tool settings, program debugging, window selection and manipulation, and on-line help. File Menu The File Menu includes commands that open, save, print, and close source files. The Device Database and License Manager dialogs are accessed from this menu. Edit Menu The Edit Menu includes commands for editing the source code; undo, redo, cut, copy, paste, and indentation, bookmark functions, various find and replace commands, source outlining functions, and advanced editor functions. Editor configuration settings are also accessed from this menu. 59 60 Chapter 5. Using µVision View Menu The View Menu includes commands to display/hide a variety of windows. You can also enable/disable the Status Bar. The Periodic Window Update option is useful in Debug Mode to force the screens to periodically refresh. If this option has not been selected, you can manually update the screens via the Toolbox. Project Menu The Project Menu includes commands to open, save, and close project files. You can Export your project to a previous version of µVision, Manage project components, or Build the project. In addition, you can set Options for the project, group, and file. You can manage multiple projects through the Multi-Project Workspace… Menu. Flash Menu The Flash Menu includes commands you can use to configure, erase, and program Flash memory for your embedded target system. Getting Started: Creating Applications with µVision Debug Menu The Debug Menu includes commands that start and stop a debug session, reset the CPU, run and halt the program, and single-step in high-level and assembly code. In addition, commands are available to manage breakpoints, view RTOS Kernel information, and invoke execution profiling. You can modify the memory map and manage debugger functions and settings. Tools Menu Configure and run PC-Lint or set up your own tool shortcuts to third party utilities. SVCS Menu The SVCS Menu allows you to configure and integrate your project development with third-party version control systems. Help Menu The Help Menu includes commands to start the on-line help system, to list information about on-chip peripherals, to access the knowledgebase, to contact the Technical Support team, to check for product updates, and to display product version information. 61 62 Chapter 5. Using µVision Peripherals Menu The Peripherals Menu includes dialogs to display and change on-chip peripheral settings. The content of this menu is tailored to show the specific microcontroller options selected for your application. Dialogs are typically available for System Configuration, Interrupts, UARTs, I2C, Timer/Counters, General Purpose I/O, CAN, Pulse-Width Modulators, Real-Time Clocks, and Watchdog Timers. This menu is active in Debug Mode only. Window Menu The Window Menu includes commands to split, select, and close various windows in the Text Editor. In addition, you can define your own screen layouts through the Debug Restore Views… dialog, and switch back and forth between the screen layouts you defined. Restore the default layout through Reset View to Defaults at any time. Currently open source code windows are listed at the bottom of the Window Menu. Getting Started: Creating Applications with µVision Toolbars and Toolbar Icons The µVision IDE incorporates several Toolbars with buttons for the most commonly used commands.  The File Toolbar contains buttons for commands used to edit source files, to configure µVision, and to set the project specific options  The Build Toolbar contains buttons for commands used to build the project  The Debug Toolbar contains buttons for commands used in the debugger The File Toolbar is always available, while the Build Toolbar and Debug Toolbar will display in their context. In both modes, Build Mode and Debug Mode, you have the option to display or hide the applicable Toolbars. File Toolbar New File – opens an empty text window Open File – dialog to open an existing file Save File – saves the contents of the current file Save All – saves changes in all open files Cut – deletes the selected text and copies it to the clipboard Copy – copies the currently selected text to the clipboard Paste – inserts text from the clipboard to the current cursor position Undo changes – removes prior changes in an edit window Redo changes – restores the last change that was undone Navigate Backwards – moves cursor to its former backward position 63 64 Chapter 5. Using µVision Navigate Forwards – moves cursor to its former forward position Bookmark – sets or removes a bookmark at cursor position Previous Bookmark – moves the cursor to the bookmark previous to the current cursor position Next Bookmark – moves cursor to the bookmark ahead of the current cursor position Clear All Bookmarks – removes bookmarks in the current document Indent – moves the lines of the highlighted text one tab stop to the right Unindent – moves all highlighted text lines one tab stop to the left Set Comment – converts the selected code/text to comment lines Remove Comment – converts the selected text lines back to code lines Find in Files – searches for text in files; results shown in an extra window Find – searches for specified text in current document Incremental Find – finds expression as you type Debug Session – starts/stops debugging Breakpoint – sets or removes a breakpoint at cursor position Disable Breakpoint – disables the breakpoint at cursor position Disable All Breakpoints – disables all breakpoints in all documents Kill All Breakpoints – removes all breakpoints from all documents Project Window – dropdown to enable/disable project related windows Configure – dialog to configure your editor, shortcuts, keywords, … Getting Started: Creating Applications with µVision Build Toolbar Translate/Compile – compiles or assembles the file in the current edit window Build – builds and links those files of the project that have changed or whose dependencies have changed Rebuild – re-compiles, re-assembles, and re-links all files of the project Batch Build – re-builds the application based on batch instructions. This feature is active in a Multi-Project environment only. Stop Build – halts the build process Download – downloads your application to the target system flash Target – drop-down box to select your target system (in the Toolbar example above: Simulator) Target Options – dialog to define tool and target settings. Set device, target, compiler, linker, assembler, and debug options here. You can also configure your flash device from here. File Extensions, Environments, and Books – dialog to configure targets, groups, default folders, file extensions, and additional books Manage Multi-Project Workspace – dialog to add or remove individual projects or programs to or from your multi-project container 65 66 Chapter 5. Using µVision Debug Toolbar Reset – Resets the microcontroller CPU or simulator while debugging Run – continues target program execution to next breakpoint Stop – halts target program execution Step One Line – steps to the next instruction or into procedure calls Step Over – steps over a single instruction and over procedure calls Step Out – steps out of the current procedure Run to Line – runs the program until the current cursor line Show Current Statement – Shows next statement to be executed Command Window – displays/hides the Command Window Disassembly Window – displays/hides the Disassembly Window Symbol Window – displays/hides Symbols, Variables, Ports, … Register Window – displays/hides Registers Call Stack Window – displays/hides the Call Stack tree Watch Window – drop-down to display/hide Locals and Watch Windows Memory Window – drop-down to display/hide Memory Windows Serial Window – drop-down to display/hide UART-peripheral windows and the Debug printf() View Logic Analyzer – displays variable values graphically; Also used as a drop-down to display/hide the Performance Analyzer and Code Coverage Window. Getting Started: Creating Applications with µVision Performance Analyzer – displays, in graphical form, the time consumed by modules and functions as well as the number of function calls Code Coverage – dialog to view code execution statistics in a different way than with the Performance Analyzer System Viewer – view the values of your Peripheral Registers Instruction Trace – displays/hides the Instruction Trace Window Toolbox – shows/hides the Toolbox dialog. Depending on your target system, various options are available. Debug Restore Views – drop-down to select the preferred window layout while debugging Additional Icons Print – opens the printer dialog Books – opens the Books Window in the Project Workspace Functions – opens the Functions Window in the Project Workspace Templates – opens the Templates Window in the Project Workspace Source Browser – opens the Source Browser Window in the Output Workspace. Use this feature to find definitions or occurrences of variables, functions, modules, and macros in your code. µVision Help – opens the µVision Help Browser File – Source file; you can modify these files; default options are used File – Source file; you can modify these files; file options have been changed and are different from the default options File or Module – header files; normally, included automatically into the project; options cannot be set for these file types 67 68 Chapter 5. Using µVision Folder or Group – expanded – icon identifying an expanded folder or group; options correspond to the default settings Folder or group – expanded – icon identifying an expanded folder or group; with changed options that are different from the default settings Folder or group – collapsed – with options corresponding to default settings Folder or group – collapsed – with options changed and different form default settings Lock – freezes the content of a window; prevents that window from refreshing periodically; You cannot manually change the content of that window. Unlock – unfreezes the content of a window; allows that window to refresh periodically. You can manually change the content of that window. Insert – creates or adds an item or object to a list Delete - removes an item or object from a list Move Up - moves an item or object higher up in the list Move Down - moves an item or object down in the list Peripheral SFR (Peripheral Registers, Special Function Register) Simulator VTREG (Virtual Register) Application, Container Variable Parameter Function Getting Started: Creating Applications with µVision Project Windows Project Windows display information about the current project. The tabs at the bottom of this area provide access to:  Project structure and management. Group your files to enhance the project overview.  Functions of the project. Quickly find and navigate between functions of the source code.  Microcontroller Registers. Only available while debugging.  Templates for often-used text blocks. Double click the definitions to insert the predefined text at cursor position.  Books specific to the µVision IDE, the project, and sometimes to the microcontroller used. Configure and add your own books to any section. 69 70 Chapter 5. Using µVision The Functions Window displays all functions of your project or of open editor files. Double-click a function to jump to its definition. Invoke its Context Menu to toggle the displaying mode of this window or scan the files. The Templates Window provides user-defined text blocks, which can be defined through the Configuration – Templates dialog. Double-click a definition or invoke the Context Menu to insert often-needed constructs into your code files. Alternatively, you can type the first few letters of the template name followed by Ctrl+Space to insert the text. Getting Started: Creating Applications with µVision Editor Windows The Editor Windows are used to:  Write, edit, and debug source files. Press F1 on language elements for help.  Set breakpoints and bookmarks  Set project options and initialize target systems by using powerful configuration wizards  View disassembly code and trace instructions while debugging Typically, this area contains the Text Editor with source code files, the Disassembly Window, Performance Analyzer, and Logical Analyzer. Editor Configuration Configure Editor settings, colors and fonts, user defined keywords, shortcut keys, and templates through the Configuration dialog. You can invoke this dialog via the Context Menu of the Template Window, the Edit – Configuration Menu, or through the File Toolbar command. 71 72 Chapter 5. Using µVision Using the Editor You can view text files in the Editor side by side. Invoke the Context Menu of the file tab and choose a horizontal or vertical arrangement. Files can be dragged and dropped from one Tab Group into the other, or can be moved to the Next Tab Group through the Context Menu. In addition, you can tile a file vertically and horizontally. Complete your code in any part of these fragments. Double-click the tiling line to remove the fragmentation. Double-click a file’s tab to close the file. Getting Started: Creating Applications with µVision Output Windows By default, the Output Windows1 are displayed at the bottom of the µVision screen and include:  The Build Output Window includes errors and warnings from the compiler, assembler, and linker. Double-click a message to jump to the location of the source code that triggered the message. Press F1 for on-line help.  The Command Window allows you to enter commands and review debugger responses. Hints are provided on the Status Bar of that window. Press F1 for on-line help.  The Find in Files Window allows you to double-click a result to locate the source code that triggered the message  The Serial and UART windows display I/O information of your peripherals  The Call Stack Window enables you to follow the program call tree  The Locals Window displays information about local variables of the current function  The Watch windows provide a convenient way to personalize a set of variables you would like to trace. Objects, structures, unions, and arrays may be monitored in detail.  The Symbols Window is a handy option to locate object definitions. You can drag and drop these items into other areas of µVision.  The Memory windows enable you to examine values in memory areas. Define your preferred address to view data.  The Source Browser Window offers a fast way to find occurrences and definitions of objects. Enter your search criteria to narrow the output. 1 Since almost all objects can be moved to their own window frame, the terminology ‘page’ and ‘window’ is interchangeably used in this book. 73 74 Chapter 5. Using µVision Other Windows and Dialogs Peripheral Dialogs and Windows Peripheral Dialogs and Windows allow you to review and modify the status of on-chip peripherals. These dialogs are dependent on the target system you selected at the beginning of your project and thus the options provided will vary. On-line Help µVision includes many pages of on-line manuals and context-sensitive help. The main help system is available from the Help Menu. Context sensitive on-line help is available in most dialogs in µVision. Additionally, you can press F1 in the Editor Windows for help on language elements like compiler directives and library routines. Use F1 in the Output Window for help on debug commands, error messages, and warnings. Getting Started: Creating Applications with µVision 75 Chapter 6. Creating Embedded Programs µVision is a Windows application that encapsulates the Keil microcontroller development tools as well as several third-party utilities. µVision provides everything you need to start creating embedded programs quickly. µVision includes an advanced editor, project manager, and make utility, which work together to ease your development efforts, decreases the learning curve, and helps you to get started with creating embedded applications quickly. There are several tasks involved in creating a new embedded project:  Creating a Project File  Using the Project Windows  Creating Source Files  Adding Source Files to the Project  Using Targets, Groups, and Files  Setting Target Options, Groups Options, and File Options  Configuring the Startup Code  Building the Project  Creating a HEX File  Working with Multi-Projects The section provides a step-by-step tutorial that shows you how to create an embedded project using the µVision IDE. Creating a Project File Creating a new µVision project requires just three steps: 1. Select the Project Folder and Project Filename 2. Select the Target Microcontroller 3. Copy the Startup Code to the Project Folder 76 Chapter 6. Creating Embedded Programs Selecting the Folder and Project Name To create a new project file, select the Project – New Project… Menu. This opens a standard dialog that prompts you for the new project file name. It is good practice to use a separate folder for each project. You may use the Create New Folder button in this dialog to create a new empty folder. Select the preferred folder and enter the file name for the new project. µVision creates a new, empty project file with the specified name. The project contains a default target and file group name, which you can view on the Project Window. Selecting the Target Microcontroller After you have selected the folder and decided upon a file name for the project, µVision asks you to choose a target microcontroller. This step is very important, since µVision customizes the tool settings, peripherals, and dialogs for that particular device. The Select Device1,2 dialog box lists all the devices from the µVision Device Database. You may invoke this screen through the Project – Select Device for Target… Menu in order to change target later. 1 For some devices, µVision requires additional parameters you must enter manually. Please read the device description in the Select Device dialog carefully, as it may contain extra instructions for the device configuration. 2 If you do not know the actual device you will finally use, µVision allows you to change the device settings for a target after project creation. Getting Started: Creating Applications with µVision Copying the Startup Code All embedded programs require some kind of microcontroller initialization or startup code1,2 that is dependent of the tool chain and hardware you will use. It is required to specify the starting configuration of your hardware. All Keil tools include chip-specific startup code for most of the devices listed in the Device Database. Copy the startup code to your project folder and modify it there only. µVision automatically displays a dialog to copy the startup code into your project folder. Answer this question with YES. µVision will copy the startup code to your project folder and adds the startup file to the project. The startup code files are delivered with embedded comments used by the configuration wizard to provide you with a GUI interface for startup configuration. Using the Project Windows Once you have created a project file successfully, the Project Window shows the targets, groups, and files of your project. By default, the target name is set to Target 1, while the group’s name is Source Group 1. The file containing the startup code is added to the source group. Any file, the startup file included, may be moved to any other group you may define in future. The Books Window, also part of the Project Windows, provides the Keil product manuals, data sheets, and programmer’s guides for the selected microcontroller. Double-click a book to open it. 1 The startup code’s default settings provide a good starting point for most single-chip applications. However, changes to the startup code may be required. 2 Library and add-on projects need no startup code. 77 78 Chapter 6. Creating Embedded Programs Right-click the Books Window to open its Context Menu. Choose Manage Books…, to invoke the Components, Environments and Books1 dialog to modify the settings of the exiting manuals or add your own manuals to the list of books. Later, while developing the program, you may use the Functions Window and Templates Window as well. Creating Source Files Use the button on the File Toolbar or the select the File – New… Menu to create a new source file This action opens an empty Editor Window to enter your source code. µVision enables color syntax highlighting based on the file extension (after you have saved the file). To use this feature immediately, save the empty file with the desired extension prior to starting coding. Save the new source file using the button on the File Toolbar or use the File – Save Menu 1 Most microcontroller manuals are part of the toolset, or are available on the Keil Development Tools CD-ROM. Getting Started: Creating Applications with µVision Adding Source Files to the Project After you have created and saved your source file, add it to the project. Files existing in the project folder, but not included in the current project structure, will not be compiled. Right-click a file group in the Project Window and select Add Files to Group from the Context Menu. Then, select the source file or source files to be added. A self-explanatory window will guide you through the steps of adding a file. Using Targets, Groups, and Files The µVision’s very flexible project management structure allows you to create more than one Target for the same project. A Target is a defined set of build options that assemble, compile, and link the included files in a specific way for a specific platform. Multiple file groups may be added to a target and multiple files may be attached to the same file group. You can define multiple targets for the same project as well. You should customize the name of targets and groups to match your application structure and internal naming conventions. It is a good practice to create a separate file group for microcontroller configuration files. Use the Components, Environment, and Books… dialog to manage your Targets, Groups, and Files configuration 79 80 Chapter 6. Creating Embedded Programs To change the name of a Target, Group, or File you may either:  Double-click the desired item, or  Highlight the item and press F2 Change the name and click the OK button. Changes will be visible in the other windows as soon as this dialog has been closed. Insert - create a new target or group Delete - remove a target, group, or source file from the project Move Up - move a target, group, or source file up the list Move Down - move a target, group, or source file down the list Instead of using the Move Up or Move Down buttons, you may drag and drop the source files within the Project Window to re-arrange the order of the files. Getting Started: Creating Applications with µVision Setting Target Options Open the Options for Target dialog from the Build Toolbar or from the Project Menu Through this dialog, you can  change the target device  set target options  and configure the development tools and utilities Normally, you do not have to make changes to the default settings in the Target and Output dialog. The options available in the Options for Target dialogs depend on the microcontroller device selected. Of course, the available tabs and pages will change in accordance with the device selected and with the target. When switching between devices, the menu options are available as soon as the OK button in the Device Selection dialog has been clicked. 81 82 Chapter 6. Creating Embedded Programs The following table lists the project options that are configurable on each page of the Target Options dialog. Dialog Page Description Device Selects the target device from the Device Database Target Specifies the hardware settings of your target system Output Specifies the output folders and output files generated Listing Specifies the listing folders and listing files generated User Allows you to start user programs before and after the build process C/C++ Sets project-wide C/C++ Compiler options Asm Sets project-wide Assembler options Linker Sets project-wide Linker options. Linker options are typically required to configure the physical memory of the target system and locate memory classes and sections. Debug Sets Debugger options, including whether to use hardware or simulation Utilities Configures utilities for Flash programming Setting Group and File Options In µVision, properties of objects and options can be set at the group level and on individual files. Use this powerful feature to set options for files and groups that need a configuration different from the default settings. To do so, open the Project Window:  Invoke the Context Menu of a file group and select Options for Group to specify the properties, compiler options, and assembler options for that file group  Invoke the Context Menu of a source file and select Options for File to specify the properties, compiler, or assembler options for that file Treat Target options similar to general options. They are valid for the entire project and for that target. Some options can be defined at the group level and on individual files. File-level options will supersede group-level options, which in turn, supersede the options set at the target level. Red dots on the icon’s left side are an indication that the options of that item differ from the general target options Getting Started: Creating Applications with µVision Configuring the Startup Code Keil tools include files with chip-specific startup code for most of the supported devices. Keil startup files contain assembler code with options you can adjust to your particular target system. Most startup files have embedded commands for the µVision Configuration Wizard, which provides an intuitive, graphical, and convenient interface to edit the startup code. Simply click the desired value to change data. Alternatively, you can use the Text Editor to directly edit the assembly source file. Keil startup files provide a good starting point for most single-chip applications. However, you must adapt their configuration for your target hardware. Targetspecific settings, like the microcontroller PLL clock and BUS system, have to be configured manually. 83 84 Chapter 6. Creating Embedded Programs Building the Project Several commands are available from the Build Toolbar or Project Menu to assemble, compile, and link the files of your project. Before any of these actions are executed, files are saved. Translate File – compiles or assembles the currently active source file Build Target – compiles and assembles those files that have changed, then links the project Rebuild – compiles and assembles all files, regardless whether they have changed or not, then links the project While assembling, compiling, and linking, µVision displays errors and warnings in the Build Output Window. Highlight an error or warning and press F1 to get help regarding that particular message. Double-click the message to jump to the source line that caused the error or warning. µVision displays the message 0 Error(s), 0 Warning(s) on successful completion of the build process. Though existing warnings do not prevent the program from running correctly, you should consider solving them to eliminate unwanted effects, such as time consumption, undesirable side effects, or any other actions not necessary for your program. Getting Started: Creating Applications with µVision Creating a HEX File Check the Create HEX File box under Options for Target — Output, and µVision will automatically create a HEX file during the build process. Select the desired HEX format through the drop-down control to generate formatted HEX files, which are required on some Flash programming utilities. 85 86 Chapter 6. Creating Embedded Programs Working with Multiple Projects Sometimes, application development requires working with more than one project at the same time. With single projects, that requires closing the current project and opening the new project. The µVision Multi-Project feature allows you to define a group of projects as a Multi-Project file and to work with those projects in one Project Window. By combining µVision projects, which logically depend on each other, into one Multi-Project, you increase the overview, consistency, and transparency of your embedded system application design. µVision supports you in grouping various stand-alone projects into one project overview. While all features described for single-projects also apply to Multi-Projects, additional functionalities are required and are available in the µVision IDE. Creating a Multiple Project Choose Project – New Multi-Project Workspace… to create a new Multi-Project file. This opens a standard Windows dialog that prompts you for the new project file name. To open an existing Multi-Project, choose Project – Open Project. You can differentiate a Multi-Project file from a standalone project file by its file extension. A file containing a Multi-Project has the extension filename.uvmpv rather than filename.uvproj – the naming convention for stand-alone projects. Managing Multiple Projects Invoke the Manage Multi-Project Workspace Components dialog through the Project – Manage – Multi Project Workspace… Menu, or use the Manage Multi-Project Workspace… button of the Build Toolbar. Manage Multi-Project Workspace… – dialog to add individual projects or programs to your Multi-Project Getting Started: Creating Applications with µVision Add existing stand-alone projects1,2 to your MultiProject. Use the controls to change the file order, to add or remove project files, or to define the active project. Removing or deleting a project from this list will not physically delete the project files, or the respective project from the storage location. Activating a Multi-Project To switch to another project, right click the project name you wish to activate, and click Set as Active Project. In this example, Measure is the currently active project, whereas Blinky is just about to become the active project. To uniquely identify the currently active project, µVision highlights its name in black. All actions executed within the µVision IDE apply only to this project; therefore, you can treat this project the same way you treat a stand-alone project. 1 Only existing projects can be maintained and added to a Multi-Project. You have to create the stand-alone project prior to managing it in the Multi-Project environment. 2 Projects can have identical names as long as they reside in different folders. 87 88 Chapter 6. Creating Embedded Programs Batch-Building Multiple Projects While you can compile the individual projects one-by-one, the Multi-Project environment provides a more convenient way to compile all the projects in one working step. Use the Batch Build1 command from the Build Toolbar or from the Project – Batch Build Menu to build, re-build, or clean the Project Targets. Batch Build – opens the window which lets you select the targets and actions Select the checkbox of the projects and related targets you wish to build, re-build, or clean. Object files will be created based on the settings outlined in the respective project. No ‘in common’ object file will be created in addition. The Build button compiles and assembles those files that have changed and links the selected targets. The Rebuild button compiles or assembles all files and links the selected targets. The Clean button removes the object files for the selected targets. 1 Batch Build can be used in a Multi-Project setup only. Getting Started: Creating Applications with µVision Chapter 7. Debugging The µVision Debugger can be configured as a Simulator1 or as a Target Debugger2. Go to the Debug tab of the Options for Target dialog to switch between the two debug modes and to configure each mode. The Simulator is a software-only product that simulates most features of a microcontroller without the need for target hardware. By using the Simulator, you can test and debug your embedded application before any target hardware or evaluation board is available. µVision also simulates a wide variety of peripherals including the serial port, external I/O, timers, and interrupts. Peripheral simulation capabilities vary depending on the device you have selected. The Target Debugger is a hybrid product that combines µVision with a hardware debugger interfacing to your target system. The following debug devices are supported:  JTAG/OCDS Adapters that connect to on-chip debugging systems like the ARM Embedded ICE  Target Monitors that are integrated with user hardware and that are available on many evaluation boards  Emulators that connect to the MCU pins of the target hardware  In-System Debuggers that are part of the user application program and provide basic test functions Third-party tool developers may use the Keil Advanced GDI to interface µVision to their own hardware debuggers. No matter whether you choose to debug with the Simulator or with a target debugger, the µVision IDE implements a single user interface that is easy to learn and master. 1 The Simulator offers more capabilities and features than those available when debugging on target hardware. The Simulator runs entirely on the PC and is not limited by hardware restrictions. 2 Programs run on your target hardware. You can debug your application with restrictions. 89 90 Chapter 7. Debugging To debug programs using the Simulator, check Use Simulator on the left side of the Debug dialog. To debug programs running on target hardware, check Use on the right side of the Debug dialog. In addition to selecting whether you debug with the Simulator or Target Debugger, the Debug dialog provides a great variety of debugger configuration options. Control Description Settings Opens the configuration dialog for the simulation driver or the Advanced GDI target driver Load Application at Startup Loads the application program when you start the debugger Limit Speed to Real-Time Limits simulation speed to real-time such that the simulation does not run faster than the target hardware Run to main() Halts program execution at the main C function. When not set, the program will stop at an implicit breakpoint ahead of the main function Initialization File Specifies a command script file which is read and executed when you start the debugger, before program execution is started Breakpoints Restores breakpoint settings from the prior debug session Watchpoints & PA Restores watchpoints and Performance Analyzer settings from the prior debug session Memory Display Restores memory display settings from the prior debug session Toolbox Restores toolbox buttons from the prior debug session CPU DLL Specifies the instruction set DLL for the simulator. Do not modify this setting. Driver DLL Specifies the instruction set DLL for the target debugger. Do not modify this setting. Dialog DLL Specifies the peripheral dialog DLL for the simulator or target debugger. Do not modify this setting. Getting Started: Creating Applications with µVision Simulation µVision simulates up to 4 GB of memory from which specific areas can be mapped for reading, writing, executing, or a combination of these. In most cases, µVision can deduce the correct memory map from the program object module. Any illegal memory access is automatically trapped and reported. A number of device-specific simulation capabilities are possible with µVision. When you select a microcontroller from the Device Database, µVision configures the Simulator accordingly and selects the appropriate instruction set, timing, and peripherals. The µVision Simulator:  Runs programs using the ARM7, ARM9, Thumb, Thumb2, 8051, C166/XE166/XC2000 instruction sets  Is cycle-accurate and correctly simulates instructions and on-chip peripheral timing, where possible  Simulates on-chip peripherals of many 8051, C166/XE166/XC2000, ARM7, ARM9, and Cortex-Mx devices  Can provide external stimulus using the debugger C script language Starting a Debug Session When you start a debug session, µVision loads the application, executes the startup code, and, if configured, stops at the main C function. When program execution stops, µVision opens a Text Editor window, with the current source code line highlighted, and a Disassembly Window, showing the disassembled code. Use the Start/Stop Debug Session command of the Debug Toolbar to start or stop a debugging session. Screen layouts are restored when entering and saved automatically when closing the Debugger. The current instruction or high-level statement (the one executed on the next instruction cycle) is marked with a yellow arrow. Each time you step, the arrow moves to reflect the new current line or instruction. 91 92 Chapter 7. Debugging This screenshot below shows some of the key windows available in Debug Mode. Getting Started: Creating Applications with µVision Debug Mode Most editor features are also available while debugging. The Find command can be used to locate source text and source code can be modified. Much of the Debugger interface is identical to the Text Editor interface. However, in Debug Mode the following additional features, menus, and windows are available: Debug Menu and Debug Toolbar – for accessing debug commands  Peripherals Menu – is populated with peripheral dialogs used to monitor the environment  Command Window – for executing debug commands and for showing debugger messages  Disassembly Window – provides access to source code disassembly  Registers Window – to view and change values in registers directly  Call Stack Window – to examine the programs call tree  Memory, Serial, and Watch Windows – to monitor the application  Performance Analyzer Window – to fine tune the application for performance  Code Coverage Window – to inspect the code for safety-critical systems  Logic Analyzer Window – to study signals and variables in a graphical form  Execution Profiler – to examine the execution time and number of calls  Instruction Trace Window – to follow execution of the program sequence  Symbol Window – to locate program objects comfortably  System Viewer – to supervise peripheral registers  Multiple Debug Restore Layouts – can be defined to switch between preferred window arrangements Besides the disabled build commands, you may not:  Modify the project structure  Change tool parameters 93 94 Chapter 7. Debugging Using the Command Window Generic compile and debug information are displayed here while stepping through the code. Additional notifications are provided if, for example, memory areas cannot be accessed. Enter debugger commands on the Command Line of the Command Window. Valid instructions will rise on its status bar with hints to parameters and parameter options. Insert expressions to view or modify the content of registers, variables, and memory areas. You can invoke debugger script functions as well. We strongly advise you to make use of the detailed online help information, by pressing F1. Describing the many options available is beyond the scope of this book. Using the Disassembly Window Configure this window by invoking its Context Menu. You can use this window to view the time an instruction needs to execute or to display the number of calls. You can also set or remove breakpoints and bookmarks. View a trace history of previously executed instructions through the View – Trace – View Trace Records Menu. To view a history trace, enable the option View – Trace – Enable Trace Recording. If the Disassembly Window is the active window, single-stepping works at the assembler instruction level rather than at the program source level. Getting Started: Creating Applications with µVision Executing Code µVision provides several ways to run your programs. You can  Instruct the program to run directly to the main C function. Set this option in the Debug tab of the Options for Target dialog.  Select debugger commands from the Debug Menu or the Debug Toolbar  Enter debugger commands in the Command Window  Execute debugger commands from an initialization file Starting the Program Select the Run command from the Debug Toolbar or Debug Menu or type GO in the Command Window to run the program Stopping the Program Select Stop from the Debug Toolbar or from the Debug Menu or press the Esc key while in the Command Window Resetting the CPU Select Reset from the Debug Toolbar or from the Debug – Reset CPU Menu or type RESET in the Command Window to reset the simulated CPU 95 96 Chapter 7. Debugging Single-Stepping To step through the program and into function calls use the Step command from the Debug Toolbar or Debug Menu. Alternatively, you enter TSTEP in the Command Window, or press F11. To step through the program and over function calls use the Step Over command from the Debug Toolbar or Debug Menu. Enter PSTEP in the Command Window, or press F10. To step out of the current function use the Step Out command from the Debug Toolbar or Debug Menu. Enter OSTEP in the Command Window, or press Ctrl+F11. Examining and Modifying Memory µVision provides various ways to observer and change program and data memory. Several windows display memory contents in useful formats. Viewing Register Contents The Registers Window shows the content of microcontroller registers. To change the content of a register double-click on the value of the register. You may also press F2 to edit the selected value. Getting Started: Creating Applications with µVision Memory Window Monitor memory areas through four distinct Memory Windows. Open the Memory Window from the Debug Toolbar or the View – Memory – Memory[x] Menu The Context Menu allows you to select the output format. Enter an expression in the Address field to monitor the desired area or object. To change the content of an address, double-click on the value and modify it. To update the Memory Window periodically, enable View – Periodic Window Update. Use Update Windows in the Toolbox to refresh the windows manually. To stop the Memory Window from refreshing, uncheck View – Periodic Window Update, or use the Lock button to get a snapshot of the window. You may compare values of the same address space by taking snapshots of the same section in a second Memory Window. Memory Commands The following memory commands can be entered in the Command Window. Command Description ASM Displays or sets the current assembly address and allows you to enter assembly instructions. When instructions are entered, the resulting opcode is stored in code memory. You may use the in-line assembler to correct mistakes or to make temporary changes to the target program. DISPLAY Displays a range of memory in the Memory Window (if it is open) or in the Command Window. Memory areas are displayed in HEX and in ASCII. ENTER Allows you to change the contents of memory starting at a specified address EVALUATE Calculates the specified expression and outputs the result in decimal, octal, HEX, and ASCII format UNASSEMBLE Disassembles code memory and displays it in the Disassembly Window 97 98 Chapter 7. Debugging Breakpoints and Bookmarks In µVision, you can set breakpoints and bookmarks while:  Creating or editing your program source code  Debugging, using the Breakpoints dialog, invoked from the Debug Menu  Debugging, using commands you enter in the Command Window Setting Breakpoints and Bookmarks To set execution breakpoints in the source code or in the Disassembly Window, open the Context Menu and select the Insert/Remove Breakpoint command. You can double-click the gray sidebar of the Editor Window or Disassembly Window to set a breakpoint, or use the breakpoint buttons of the File Toolbar. Breakpoints and bookmarks visualize in the Editor and the Disassembly Window alike and differ in their coloring. Breakpoints will display in red, where as bookmarks can be recognized by their blue color. Analog actions are required to define bookmarks. In contrast to breakpoints, bookmarks will not stop the program executing. Use Bookmarks to set reminders and markers in your source code. Define the critical spots easily and navigate quickly between bookmarks using the bookmark navigation commands. You can also define a bookmark and a breakpoint on the same line of code concurrently. Whereas bookmarks do not require additional explanations, breakpoints are discussed in detail in the following section. Getting Started: Creating Applications with µVision Breakpoints Window Invoke the Breakpoints Window from the Debug Menu. You have to stop the program running, to get access to this dialog. Modify existing breakpoints and add new breakpoints via this dialog. Enable/disable breakpoints using the checkbox in the Current Breakpoints list. Double-click on an existing breakpoint to modify its definition. Define a breakpoint by entering an Expression. Depending on the expression entered, one of the following breakpoint types is defined:  An Execution Breakpoint (E) is defined when the expression specifies a code address. This breakpoint is triggered when the specified code address is reached. The code address must refer to the first byte of a microcontroller instruction.  An Access Breakpoint (A) is defined when the expression specifies a memory access (read, write, or both) instruction. This breakpoint is triggered when the specified memory access occurs. You may specify the number of bytes or objects (based on the expression) which trigger the breakpoint. Expressions must reduce to a memory address and type. Operators (&, &&, =, = =, !=) may be used to compare values before the Access Breakpoint triggers and halts program execution or executes the Command.  A Conditional Breakpoint (C) is defined when the expression specifies a true/false condition and cannot be reduced to an address. This breakpoint is triggered when the specified conditional expression is true. The conditional expression is recalculated after each instruction. Therefore, program execution may slow down considerably. 99 100 Chapter 7. Debugging When a Command has been specified for a breakpoint, µVision executes the command and continues to execute your target program. The command specified can be a µVision debug function or signal function. To halt program execution in a µVision function, set the _break_ system variable. For more information, refer to System Variables in the on-line help. The Count value specifies the number of times the breakpoint expression is true before the breakpoint is triggered. Breakpoint Commands The following breakpoint commands can be entered in the Command Windows. Command Description BREAKSET Sets a breakpoint for the specified expression. Breakpoints are program addresses or expressions that, when true, halt execution of your target program or execute a specified command. BREAKDISABLE Disables a previously defined breakpoint BREAKENABLE Enables a previously defined breakpoint that is disabled BREAKKILL Removes a previously defined breakpoint BREAKLIST Lists all breakpoints You may also set execution breakpoints while editing or debugging using buttons on the File Toolbar. Watchpoints and Watch Window By default, Watch Windows consist of four page tabs: the Locals to view variables of the current function, two Watch pages for personalized watchpoints, and the Call Stack showing the program tree. Through the Watch Window, you can view and modify program variables. Nested function calls are listed in this window as well. The content is updated automatically whenever you step through the code in Debug Mode and the option View – Periodic Window Update is set. In contrast to the Locals Window, which displays all local function variables, the Watch Window displays user-specific program variables. Getting Started: Creating Applications with µVision Watchpoints Define watchpoints to observe variables, objects, and memory areas affected by your target program. Watchpoints can be defined in two Watch pages. The Locals Window contains items of the currently executed function. Items are added automatically to the Locals Window. There are several ways to add a watchpoint:  In any Watch Window, use the field  Double-click an existing watchpoint to change the name  In Debug Mode, open the Context Menu of a variable and use Add to… – Watch Window. µVision automatically selects the variable name beneath the mouse pointer. You can also mark an expression and add it to the Watch Window.  In the Command Window, use the WATCHSET command to create a new watchpoint  Finally, drag-and-drop any object from the Symbols Window or from source code files into the Watch Window Modify local variables and watchpoint values by double-clicking the value you want to change, or click on the value and press F2. Remove a watchpoint by selecting it and press the Del key. Watchpoint Commands The following watchpoint commands can be entered in the Command Window. Command Description WATCHSET Defines a watchpoint expression to display in a Watch Window WATCHKILL Deletes all defined watchpoint expressions in any Watch Window 101 102 Chapter 7. Debugging Serial I/O and UARTs µVision provides three Serial Windows, named «UART #{1|2|3}», for each simulated on-chip UART. Serial data output from the simulated microcontroller are shown in these windows. Characters you type into the Serial Window are considered input to the simulated microcontroller. The serial output can be assigned to a PC COM port using the ASSIGN Debugger command. Several modes for viewing the data are provided:  Basic VT100 Terminal Mode  Mixed Mode  ASCII Mode  HEX Mode You can copy the content of the window to the clipboard or save it to a file. Where applicable, you can use the Toolbox1 features to interact with the program. 1 You can add, remove, and change Toolbox buttons at any time. Use the Command Line in the Command Window for this purpose. Getting Started: Creating Applications with µVision Execution Profiler The Execution Profiler in µVision records the amount of time and the number of times each assembler instruction and high-level statement in your program executes. The amount of time and the number of calls, which are displayed in the Disassembly Window and in the Editor Window alike, are cumulative values. Enable the Execution Profiler through the Debug – Execution Profiling Menu. Invoke the Context Menu of the Disassembly Window to switch between the time and calls. When you locate program hotspots (with the Performance Analyzer), the Execution Profiler makes it easy to find real performance bottlenecks. 103 104 Chapter 7. Debugging Code Coverage The Code Coverage Window marks the code that has been executed, and groups the information based on modules and functions. Use this feature to test safety-critical applications where certification and validation is required. You can detect instructions that have been skipped, or have been executed fully, partially, or not at all. Code Coverage data can be saved to a file. You can even include a complete CPU instruction listing in this report. To make use of all these features, examine the COVERAGE command in the Command Window. In addition to the Code Coverage Window, µVision provides color-coded hints on the side bar of the Disassembly and Editor Window. The colors have the following meaning:  Lines not executed – are marked with a grey block  Fully executed lines – are marked with a green block  Skipped braches – are marked with an orange block  Executed branches – are marked with a blue block  Lines with no code – are marked with a light grey checked block Getting Started: Creating Applications with µVision Performance Analyzer The µVision Performance Analyzer displays the execution time recorded for functions in your application program. Results show up as bar graphs along with the number of calls, the time spent in the function, and the percentage of the total time spent in the function. Use this information to determine where your program spends most of its time and what parts need further investigation. Objects are sorted automatically dependent on the time spent. Invoke the Context Menu of the Performance Analyzer to switch to another presentation of your investigation. You can drive the output to display statistics of modules or functions. Eventually, you might need to clean up the collected data to get a fresh summary. Double-click an object exposed in the Module/Function column to jump to the source code line. 105 106 Chapter 7. Debugging Logic Analyzer The Logic Analyzer displays values of variables or virtual registers and shows the changes on a time axis. Add values through the Setup … button or drag and drop objects from other windows into the Logic Analyzer. Press Del, or use the Setup… button, or invoke the Context Menu to remove items from the list. The Logic Analyzer window contains several buttons and displays several fields to analyze data in detail. Move the mouse pointer to the desired location and wait one second to get additional information, which pops-up automatically. Control Description Setup… Define your variables and their settings through the Logic Analyzer Setup dialog Export… Saves the currently recorded signals to a tab-delimited file Min Time Displays the start time of the signal recording buffer Max Time Displays the end time of the signal recording buffer Range Displays the time range of the current display Grid Displays the time range of a grid line Zoom Changes the time range displayed. Zoom All shows the content of the buffer recording the signals. Zoom Sel zooms the display to the current selection (hold Shift and drag the mouse to mark a section). Show Opens the Editor or Disassembly Window at the code that caused the signal transition. It will also stop the program from executing. Setup Min/Max Configures the range of a signal. The Auto button configures the minimum and maximum values based on the values from the current recording. The Undo button restores the settings prior to using Auto. Getting Started: Creating Applications with µVision System Viewer Peripheral Registers are memory mapped registers that a processor can write to and read from to control a peripheral device. µVision provides an advanced method for viewing and debugging these peripheral registers. Invoke the System Viewer from the Debug Toolbar or from the View – System Viewer Windows Menu. You can define up to 100 different peripheral objects to monitor their behavior. The System Viewer offers the following features:  Parse a microcontroller device C header file into a binary format  Additional properties can be added to the header file to provide extra information such as Peripheral Register descriptions and the data breakdown of an Peripheral Register  The value of a Peripheral Register is updated either from the Simulator or from the target hardware. This can happen when the target is stopped, or periodically by enabling the View — Periodic Window Update Menu.  At any time, the content of a Peripheral Register can be changed simply by overwriting its value in the System Viewer 107 108 Chapter 7. Debugging Symbols Window The Symbols Window displays information from the Debugger in an ordered and grouped manner and can be called via the Debug Toolbar or from the View—Symbol Window Menu. This functionality includes objects:  Of simulated resources as the virtual registers, Simulator VTREG, with access to I/O pins, UART communication, or CAN traffic  From Peripheral Registers, Peripheral SFR, to access peripherals  Of the embedded application, recognizable by the name of the program, with access to functions, modules, variables, structures, and other source code elements Use this functionality to find items quickly. Drag and drop the objects to any other window of µVision. Mask works similar to a find function. Enter your search criteria and browse the results. For nested objects, the entire tree is displayed if a leaf item is found. The following search criteria may be used: # matches a digit (0 - 9) $ matches any single character * matches zero or more characters. Configure the window by invoking the Context Menu. Getting Started: Creating Applications with µVision Browse Window The Browse Window enables you to search for objects in the code. This feature can be used in Debug and Build Mode. Nevertheless, the browse information is only available after compilation. You have to set the option Options for Target – Output – Browser Information to signal to the compiler to include browse information into the object file. Launch this window via the File Toolbar or View – Source Browser Window. Enable or disable the Filter on buttons, enter your search criteria in the Symbol field and narrow the result through the File Outline drop-down. You can sort the results by clicking the header controls. Click an item to browse the occurrences and locate its usages. Double-click a line in the Definition and References page to jump to the code line. Invoke the Context Menu while pointing at an item. Dependent on the object class you will get different options. For functions, you can invoke the callers graph and the call graph. 109 110 Chapter 7. Debugging Toolbox The Toolbox contains user-configurable buttons that execute debugger commands or user-defined functions. Click on a Toolbox button to execute the associated command. Toolbox buttons may be clicked at any time, even while the program executes. Define a Toolbox button using the Command Window and the DEFINE BUTTON1,2 command. Use the same command to redefine the button. The general syntax for this command is: DEFINE BUTTON "button_label", "command" Where: button_label is the name that displays in the Toolbox command is the command that executes when the button is pressed The following examples show the commands used to create the buttons in the Toolbox shown above: DEFINE BUTTON "Decimal Output", "radix=0x0A" DEFINE BUTTON "My Status Info", "MyStatus ()" DEFINE BUTTON "Analog1 0..3V", "analog0 ()" /* call debug function */ /* call signal function */ DEFINE BUTTON "Show R15", "printf (\"R15=%04XH\\n\")" Remove a Toolbox button with the KILL BUTTON3 command. The button number required in this statement is shown on the left side of the button. For example: KILL BUTTON 5 /* resembles to: “Remove the ‘Stop Analog1’ button” */ 1 The printf() command defined in the last example introduces nested strings. The double quote (") and backslash (\) characters of the format string must be escaped with \ to avoid syntax errors. 2 3 Use this command to redefine the meaning of a button or change the description. The Update Windows button in the Toolbox is created automatically and cannot be removed. When pressed, this button updates the contents of several Debugger windows. Getting Started: Creating Applications with µVision Instruction Trace Window To follow the instruction sequence history, invoke the Instruction Trace Window from the Debug Toolbar or via the View – Trace Menu. Use this window in conjunction with the Disassembly Window. Trace recording has to be enabled to gather the information needed. To do so, use the View – Trace – Enable Trace Recording Menu. Double-click any line in the Instruction Trace Window to jump to or open the Disassembly Window. Use the predefined Filter options to view the instruction tree in the preferred mode. This functionality is available for the Simulator and while debugging the target hardware. The window’s look and feel might vary, since it depends on the driver settings of the debugging environment. Defining Debug Restore Views Multiple window layouts are possible in Debug Mode to switch quickly between preferred screen settings and window arrangements. Invoke the layouts from the Window – Debug Restore Views… dialog, or from the Debug Toolbar. Restore defaults through Window – Reset View to Defaults. Define and save your preferred look and feel through the Window Restore Views… dialog. Global Views propagate to all your projects, where Project Views are bound to that particular project. 111 112 Chapter 8. Using Target Hardware Chapter 8. Using Target Hardware This section describes the debugging possibilities of µVision in conjunction with your target hardware. The Keil ULINK USB-JTAG Adapter family is discussed in detail, and third-party adapters are mentioned. The following device families are supported by the Keil ULINK adapters:  8051 ULINK for Infineon XC8xx, ST µPSD3xxx, and NXP LPC95x  166  ARM ULINK, ULINKPro for ARM7, ARM9, and Cortex-Mx devices ULINK for Infineon C166, XE166, and XC2000 The µVision Debugger interfaces to the target hardware through the following drivers, which are provided by Keil:  8051 Monitor, FlashMon, MonADI, ISD51, EPM900, Infineon DAS  251 Monitor  166 Monitor for C166  166 Monitor, Infineon DAS for XE166, XC2000  ARM SEGGER J-Link/J-Trace for ARM7, ARM9, and Cortex-Mx In addition, many third-party vendors offer µVision drivers for their hardware, for example:  8051 Cypress USB development kits for EZ-USB devices  8051 Quickcore FPGA based Pro8051 device  8051 SST SoftICE for FlashFlex51 devices  8051 Silabs Debug Adapter for C8051Fxxx devices  ARM Signum Systems JTAGjet for ARM7, ARM9, and Cortex-Mx devices Getting Started: Creating Applications with µVision Configuring the Debugger Choose Target Options – from the Build Toolbar and select the Debug tab Alternatively, you can use the Project – Options for Target Menu, to open this dialog. Check the Use radio button and select the appropriate debug interface. Control Description Settings Opens the configuration dialog for the simulation driver or the Advanced GDI target driver Load Application at Startup Loads the application program when you start the debugger Limit Speed to Real-Time Limit simulation speed to real-time such that the simulation does not run faster than the target hardware Run to main() Program execution halts at the main C function. When not set, the program will stop at an implicit breakpoint ahead of the main function Initialization File Specifies a command script file which is read and executed when you start the debugger, before program execution is started Breakpoints Restores breakpoint settings from the prior debug session Watchpoints & PA Restores watchpoints and Performance Analyzer settings from the prior debug session Memory Display Restores memory display settings from the prior debug session Toolbox Restores toolbox buttons from the prior debug session CPU DLL Specifies the instruction set DLL for the simulator. Do not modify this setting. Driver DLL Specifies the instruction set DLL for the target debugger. Do not modify this setting. Dialog DLL Specifies the peripheral dialog DLL for the simulator or target debugger. Do not modify this setting. 113 114 Chapter 8. Using Target Hardware Programming Flash Devices The µVision IDE can be configured to program the Flash memory of your target system. You can use third-party Flash programming tools that you may attach to and invoke from the development environment. Flash programming is configured from the Utilities tab of the Options for Target dialog. You have to select the target driver, or a third-party command-line tool, which is usually provided by the chip vendor. Select Use Target Driver for Flash Programming to use a target adapter, like the Keil ULINK USB-JTAG Adapter, SEGGER J-Link, EPM900 Emulator, or Silabs adapter to program your system’s Flash memory. Select Use External Tool for Flash Programming to use a third-party command-line utility, like FlashMagic, to program your system’s Flash memory. Once configured, the Download to Flash button of the Build Toolbar or Flash Menu downloads the program to your target system’s Flash memory You can configure the µVision Debugger to automatically download to flash memory. To do so, check Update Target before Debugging. Getting Started: Creating Applications with µVision Configuring External Tools To configure µVision for Flash1 programming with a command-line utility, select Use External Tool for Flash Programming and specify the Command and the Arguments to be used. Choose Target Options – from the Build Toolbar and select the Utilities tab Alternatively, you can use the Project – Options for Target Menu to open the Utilities dialog. Project-specific items, like the path for the generated HEX file, output file name, device name, or clock frequency can be used in the Arguments field. Please use the on-line Help for additional information. 1 The µVision Device Database provides the correct configuration for memory Flash of many microcontroller devices. 115 116 Chapter 8. Using Target Hardware Using ULINK Adapters The Keil ULINK USB-JTAG family of adapters, further referred to as ULINK, connects your PC’s USB port to your target system. The connection between the microcontroller and the ULINK unit can be established via the JTAG1 port pins of the embedded system. The ULINK adapters enables you to:  Download target programs  Examine memory and registers  Single-step through programs  Insert multiple breakpoints  Run programs in real-time  Program Memory Flash Before using the Debugger on target hardware, you have to configure the µVision IDE to use the ULINK adapter, or any other external tool suited for Flash programming. The µVision Debugger can display memory contents and variables in several familiar formats. Memory and variables are updated periodically, providing an instant view of the current program status, even during program execution. It is possible to set breakpoints that trigger on accessing a specific variable. The Keil ULINK adapter family supports Flash device programming with configurable programming algorithms. You can choose from preconfigured programming algorithms, or customize the algorithms according to your needs. External Flash memory programming is supported for many target systems as well. 1 The ULINK adapters support a wide variety of devices and protocols, and support your target hardware port pin characteristics. Getting Started: Creating Applications with µVision 117 ULINK Feature Comparison Feature ULINK2 ULINKPro Run control debug (ARM & Cortex-Mx) Yes Yes Run control debug (8051 & C166) Yes - Data Trace(Coretex-M3) Yes Yes Instruction Trace(Cortex-M3) - Yes JTAG Clock Speed 10MHz 50MHz Flash Download 28 KBytes/s 600 KBytes/s Configuring µVision for ULINK Adapters When using ULINK adapters, you must change a few settings, so that the µVision IDE knows how to use the ULINK adapters for debugging. In detail, you must configure:  Debug Settings  Trace Settings (for Cortex-Mx devices only)  Flash Download Connect the ULINK adapter to your PC. Only then, the ULINK configuration is possible in µVision. Click Target Options from the Build Toolbar and select the Debug tab, or open the dialog from the Project – Options for Target – Debug Menu Click the Settings button to open the Target Driver Setup dialog. 118 Chapter 8. Using Target Hardware Configuring Debug Settings The Target Driver Setup dialog depends on the target device selected in your project. Please use the on-line Help for additional information. Configuring Trace Settings The Trace dialog tab controls the real-time trace operations. Please use the on-line Help for additional information. The Trace features are available for Cortex-Mx devices only. Getting Started: Creating Applications with µVision Configuring Flash Download The Keil ULINK drivers support a wide variety of Flash-based microcontrollers. Click Target Options from the Build Toolbar and select the Utilities tab, or open the dialog from the Project – Options for Target Menu To configure µVision for a specific driver, select Use Target Driver for Flash Programming and choose the appropriate driver from the drop-down control. Use the Settings button to open the driver-specific Flash Download Setup dialog. Here, you can configure how Flash Download works and specify the programming algorithms that are required by your target system. Please use the on-line Help for additional information. 119 120 Chapter 8. Using Target Hardware Programming Algorithms The ULINK driver allows you to specify the programming algorithm used to program Flash memory. Use the Add button of the Flash Download Setup dialog to open this dialog Add Flash Programming Algorithm. From here you can select one or more programming algorithms, one for each different Flash device. Highlight your preferred programming algorithm to Add it for your target hardware. If the Flash device you use is not listed, you may define new algorithms. Do this for a new Flash device, which is currently not directly supported by Keil. You may use the algorithms found in any \FLASH\ folder as a template for new algorithms. The programming algorithms included in your kit are stored in these folders:  ARM Toolset: \KEIL\ARM\FLASH\  C16x Toolset: \KEIL\C166\FLASH\ Getting Started: Creating Applications with µVision Using an Init File Some applications or target systems require the execution of specific debug commands or functions ahead of Flash programming. This feature is typically used to define BUS configuration for your device or to program Flash with auxiliary files, containing code or data, which are not included in your target program. The debug commands and functions are stored in an initialization file defined by the Init File text box. This file is executed before the Flash download is performed. BUS Configuration Typically, the BUS system has to be configured before a device with external Flash memory can be programmed. If you use the ULINK USB-JTAG adapter, you may create an initialization file that uses predefined debug functions, like _WBYTE and _WDWORD, to write to memory and configure the BUS. For example: _WDWORD(0xFFE00000, 0x20003CE3); _WDWORD(0xE002C014, 0x0E6001E4); // BCFG0: Flash Bus Configuration // PINSEL2: CS0, OE, WE, BLS0..3 Auxiliary Memory Content In addition to BUS configuration, the initialization file may contain instructions to load auxiliary programs or data into memory. For example: LOAD MyFile.HEX By default, the executable specified Project – Options for Target – Output is downloaded to Flash. 121 122 Chapter 9. Example Programs Chapter 9. Example Programs Each Keil toolset includes example programs, which are ready to run and which help you to get started. Browse the examples to learn how the development tools work and get familiar with the look and feel, as well as with the behavior of µVision. You may copy the code of the examples for your own purpose. Example programs1 are stored in the \EXAMPLES\ folder, where each program resides in a separate subfolder along with its project files. Thus, you can re-build the examples and evaluate the features of µVision quickly. While there are numerous example programs for you to examine, this manual describes and demonstrates only four:  Hello: Your First Embedded Program  Measure: A Remote Measurement System  Traffic: A Traffic Light and Pedestrian Cross Walk System  Blinky: An example of how to use target hardware As described in the previous chapters, many actions or functions of µVision can be called from a toolbar, a menu, or by entering a command in the Command Window. Some actions may be triggered through key combinations. We advise you to try out the various functions of µVision while in Debug Mode. Please test the features described in preceding chapters. In particular, get familiar with the navigation, invoke the Context Menu of various objects, drag and drop windows to other screen areas or other physical screens, and create and save personalized layouts. Invoke the Performance Analyzer, Logic Analyzer, Code Coverage, Symbols Window, and drag and drop items from one window to another window. Single-step through the code, get familiar with the Disassembly Window, and inspect how it works in conjunction with the Register Window, Output Window, and Serial Window. 1 Example programs are license free. Getting Started: Creating Applications with µVision “Hello” Example Program The first program in any programming language simply prints “Hello World” to the screen. In an embedded system, there is no screen, so the “Hello” program sends its output to the on-chip serial port. This entire program has one single source file, HELLO.C. This small application helps you to confirm that you can compile, link, and debug an application. You may perform these operations from the command line, using batch files, or from µVision using the provided project file. The target hardware1 for the “Hello” project is based on a standard microcontroller. Examples are provided for all supported architectures and are located in the folders as specified in the table below. Architecture Example Folder ARM \KEIL\ARM\EXAMPLES\HELLO\ C166/XE166/XC2000 \KEIL\C166\EXAMPLES\HELLO\ 8051 \KEIL\C51\EXAMPLES\HELLO\ Opening the “Hello” Project To begin working with the “Hello” project, open the HELLO.UVPROJ project file from the appropriate example folder. Select the Project – Open Project Menu and open HELLO.UVPROJ from the ...\EXAMPLES\HELLO\ folder. Alternatively, you may drag and drop the HELLO.UVPROJ file into the µVision application, or simply double-click the file. 1 Since µVision simulates the target hardware required for this program, you actually do not need target hardware or an evaluation board. 123 124 Chapter 9. Example Programs Once the project has been opened, µVision shows the source files that comprise the project. The files are shown in the Project Window. Double-click on HELLO.C to view or edit the source file. µVision loads and displays the file contents in the Editor Window. Building the “Hello” Project Compile and link the project using the Build button of the Build Toolbar, or select the Project – Build Target Menu. µVision runs the assembler and compiler, to assemble and compile the source files of the project. The linker adds the necessary object modules and combines them into a single executable program, which may be loaded by the µVision Debugger for testing. You can follow the build process in the Build Output Window. Errors, warnings, and additional trace messages are displayed here. Double-click an error or warning message to jump to the source line that triggered the notification. Getting Started: Creating Applications with µVision Testing the “Hello” Project Once the “Hello” program has been compiled and linked successfully, test it with the µVision Debugger. Select Debug – Start/Stop Debug Session from the menu or from the File Toolbar. µVision initializes the debugger, starts program execution, and halts before entering the main() C function. Use the following debugger commands to control program execution. Open the Serial Window UART #1 to display the application’s output Click the Run button of the Debug Toolbar or choose Debug – Run to start the “Hello” program. “Hello World” is printed to the Serial Window and the program enters into an endless loop. Click the Stop button to halt the program. Alternatively, press the Esc key while in the Command Line of the Command Window Use the Insert/Remove Breakpoint command to set or clear a breakpoint Test the Reset command to reset the simulated microcontroller. If the program is still running, it halts at the first breakpoint. Single-step through the program using the Step buttons. The current instruction, which will execute next, is marked with a yellow arrow. The yellow arrow moves each time you step. 125 126 Chapter 9. Example Programs While debugging, µVision displays the following default screen layout. If you re-arrange the layout, µVision saves the layout automatically and provides this layout next time you invoke the debugger. However, you cannot explicitly recall the changed layout, unless you saved it through the Window – Debug Restore Views… Menu. Take the opportunity to get familiar with the new look and feel, and the navigation features. See how the content of registers and memory areas can be changed. Display the values in the different representations. We recommend taking some time and using this simple example to explore the µVision capabilities. Getting Started: Creating Applications with µVision “Measure” Example Program The “Measure” program is a simple example that collects analog and digital data using methods similar to those that can be found in weather stations and process control applications. Three source files: GETLINE.C, MCOMMAND.C, and MEASURE.C are used. The “Measure” program1 records data received from digital ports and A/D inputs. A timer, which can be configured between 1 millisecond and 60 minutes, controls the sample rate and interval. The current time and all data from the input channels are measured and saved to a RAM buffer. Please find your preferred “Measure” program in one of the following locations: Architecture Example Folder ARM \KEIL\ARM\EXAMPLES\MEASURE\ C166/XE166/XC2000 \KEIL\C166\EXAMPLES\MEASURE\ 8051 \KEIL\C51\EXAMPLES\MEASURE\ Opening the “Measure” Project To start the “Measure” project, open the project file MEASURE.UVPROJ from the example folder of your choice. Compile the program; enable or disable the include files in the project structure, invoke the Context Menu of the Project Window, and toggle Show Include File Dependencies. Three application-related source code files are located in the Source Code group. The serial I/O and system modules are placed in the System Calls, whereas the startup file resides under the Startup Code group. 1 Since µVision simulates the hardware required for this program, you do not actually need target hardware or an evaluation board. 127 128 Chapter 9. Example Programs A project may contain one or more targets, a feature that allows you to build different versions of your program. The “Measure” project contains several targets for different test environments including the simulator and evaluation boards. Select the model with the Simulator target. The following files comprise the source code: MEASURE.C This file contains the main C function and the interrupt service routine for the timer. The main function initializes all peripherals and performs command processing. The interrupt routine manages the real-time clock and sampling. MCOMMAND.C This file processes the display, time, and interval commands. These functions are called from the main C function. The display command lists the analog values in floating-point format to give a voltage between 0.00V and 3.00V. GETLINE.C This file contains the command-line editor for characters received from the serial port. Building the “Measure” Project There are several commands you can access from the Project Menu and the Build Toolbar to compile and link the files in a project. Use the Translate File command to compile the selected file in the Project Workspace Use the Build Target command to compile files that have changed since the last build and link them Use Rebuild All Target Files command to compile and link all files in the project Use the Stop Build command to halt a build that is in progress Select the Build Target command to compile and link the source files of the “Measure” project. µVision displays a message in the Command Window when the build process has finished. Getting Started: Creating Applications with µVision Source Browser The “Measure” project is configured to generate complete browser and debug information. Use the Source Browse command from the File Toolbar or View Menu to view information about program variables and other objects Testing the “Measure” Project The “Measure” program is designed to accept commands from the on-chip serial port. If you have actual target hardware, you may use Hyperterm or another terminal program to communicate with the board. If you do not have target hardware, you can use µVision to simulate all aspects of the hardware, for example, the Serial Window in µVision simulates serial input. Use the Start/Stop Debug Session command from the Debug Toolbar or Debug Menu to start the µVision debugger Using the Serial Commands Test the following commands in the Serial Window. Action Command Description Clear C Clears the measurement record buffer Display D Displays the current time and input values continuously Interval I mm:ss.ttt Sets the time interval for measurement recording. The interval time must be between 0:00.001 (for 1ms) and 60:00.000 (for 60 minutes). Quit Q Quits the measurement recording Read R [count] Displays the saved records. Specify the number of records to be shown. All records are transmitted if count is not specified. You can read records on the fly if the interval is greater than one second, otherwise recording must be stopped. Start S Start recording. Data inputs are stored at the specified time interval. Time T hh:mm:ss Sets the current time in 24-hour format 129 130 Chapter 9. Example Programs Using the Serial Interface Open the serial UART Window from the View Menu or the Debug Toolbar to view the output Before you start running the “Measure” program, open the Serial Window so that you can enter commands and view the program output. Running the Program Use the step-buttons to execute code commands individually. If the Disassembly Window is the active window, the debugger steps through assembler instructions rather than through the source code. The current instruction or high-level statement (the one about to execute) is marked with a yellow arrow. Each time you step, the arrow moves to reflect the new current instruction line. Use the Run command from the Debug Toolbar or Debug Menu to start debugging the program Use the Stop command to halt program execution or press the Esc key while in the Command Window Use the Step Into command from the Debug Toolbar or Debug Menu to step through the program and into function calls Use the Step Over command from the Debug Toolbar or Debug Menu to step through the program and over a function call Use the Step Out command from the Debug Toolbar or Debug Menu to step out of the current function Use the Run To Cursor Line command from the Debug Toolbar or Debug Menu to run the program to the line you just highlighted Getting Started: Creating Applications with µVision Viewing Program Code Use the Disassembly Window command from the Debug Toolbar or View Menu to view mixed source and assembly code Test the various stepping commands, first while in the Disassembly Window, and then while in the Editor Window. Notice the different behavior of the Debugger. Call the Context Menu of the windows while moving the mouse over various code lines. Notice the different options. They depend on whether the statement can be executed or not. Notice the lines marked green, gray, or without any color. Invoke the Context Menu while pointing on the memory address. Using the Call Stack Use the Call Stack Window command of the Debug Toolbar or View Menu µVision tracks function nesting and displays data in the Call Stack Window. Double-click on the line of a function to jump to the source code. 131 132 Chapter 9. Example Programs Using the Trace Buffer In any programming process, it is often required to investigate circumstances that led to a certain state. You can guide the µVision Debugger to record instructions into a trace memory buffer. In Debug Mode, you can review the trace buffer using the View – Trace – Show Records in Disassembly command. Use the Trace Windows command from the Debug Toolbar or from the View – Trace – Instruction Trace Window Menu to view executed instructions stored in the trace buffer Whereas the trace information is always available in the Disassembly Window, the Instruction Trace Window is enabled for ARM devices only. In addition, inspect the Registers Windows showing register contents of the selected instruction. Invoke the Context Menu of the Disassembly Window to review the options offered. When you double-click in the Instruction Trace Window, the Disassembly Window shows the corresponding instruction. Getting Started: Creating Applications with µVision Using Breakpoints µVision supports execution, access, and complex breakpoints. The following example shows how to create a breakpoint that is triggered when the value 3 is written to current.time.sec. Open the Breakpoints dialog from the Debug – Breakpoints Menu. Enter the Expression current.time.sec==3 and select the Write check box. This specifies the breakpoint to trigger when the program writes the value 3 to current.time.sec. Click the Define Button to set the breakpoint. Double-click any breakpoint definition to redefine it. Reset the CPU to test the breakpoint, which will trigger and halt program execution when the number 3 is written to current.time.sec. The program counter line of the Debug Window marks the position where the breakpoint triggered. Viewing Memory Contents Use the Memory Window command from the Debug Toolbar or View Menu to display the memory content Use the Lock/Freeze icon to prevent values from refreshing µVision displays memory in various formats and reserves four distinct Memory Windows. Define the starting Address to view the content, or drag and drop objects from the Symbols Window into the Memory Window. Open the Context Menu to change formats, modify memory, or set breakpoints. 133 134 Chapter 9. Example Programs Watching Variables The µVision Debugger provides two Watch Windows to which you can add variables, structures, and arrays for easy reference. The Watch Window updates at the end of each execution command. Enable the View – Periodic Window Update Menu to refresh the content of this window during program execution. Use the Watch Window command on the Debug Toolbar or View Menu to launch the functionality or invoke the Locals The Locals page shows local symbols of the currently executed function. The Watch pages display program objects, which you desire to monitor. Structures and arrays open on demand when you click on the [+] symbol. Indented lines reflect nesting. There are several ways to add variables to Watch pages.  In the Watch Window, select the last line () on the Watch page. Press F2 or click with the mouse on this line. Enter the name of the variable you wish to watch.  Select a variable in the Editor Window, open the Context Menu (rightclick), and select Add to Watch Window  In the Command page of the Output Window enter WS (for WatchSet) followed by the Watch Window number (1 or 2) followed by the variable name  Simply drag and drop an object into this window Remove a variable from the Watch Window by selecting the line and press the Del key or use the Context Menu. Individual elements of structures and arrays cannot be removed singly. Getting Started: Creating Applications with µVision Viewing and Changing On-Chip Peripherals The “Measure” program accepts input from several I/O and A/D ports. Use the µVision Debugger to view data and interact with peripherals. Changes made to the inputs are reflected in the dialog window of each peripheral. Enter D in the Serial Window to monitor the output and the changes applied to input values. Reset the simulated CPU Start the program if it is not running already Open the Serial Window if it is closed The D command causes the “Measure” program to refresh the time, I/O Ports, and the A/D Inputs continuously. The input from the I/O Port and the A/D converter channels can be controlled from peripheral dialogs, which are available from the Peripherals Menu. Using Peripheral Windows The µVision Debugger provides windows for I/O and serial ports, A/D converters, interrupts, timers, and for most other chip-specific peripherals. Open the windows from the Peripherals Menu. The windows display the status of the registers as well as the pins of the simulated device. Open the A/D Converter dialog to view the status of the A/D controls and A/D data. You can enter input voltages for the Analog Input, which are reflected in the Serial Window. 135 136 Chapter 9. Example Programs Using VTREG Symbols In addition to the peripheral dialogs, you may use Virtual Target Registers (VTREG) to change input signals. On the Command Window, you can assign values to VTREG symbols. For example: PORT0=0xAA55 AIN1=3.3 /* Set digital input PORT to 0xAA55 */ /* Set analog input AIN1 to 3.3 volts */ Using User and Signal Functions The µVision Debugger supports a C-like script language that enables you to use VTREG symbols in a more programmatic way. A debug signal function is included in the “Measure” program. It can be invoked using the buttons in the Toolbox. Inspect the Command Window and press F1 to invoke the on-line help for further information. Using the Toolbox Use the Toolbox command from the Debug Toolbar or View Menu to display the Toolbox dialog The Toolbox contains user-defined buttons that are linked to debugger commands or to user-defined functions. Several buttons are predefined for the “Measure” program. The Analog0..3V button starts a user-defined signal function that provides input to Analog Input 1 on the simulated microcontroller. Getting Started: Creating Applications with µVision Using the Logic Analyzer The µVision Debugger includes a configurable Logic Analyzer you can use to trace simulated signals and variables during program execution. Open the Logic Analyzer Window from the Debug Toolbar or View Menu Add a number of signals to the Logic Analyzer, including the simulated A/D input signal. Click the Setup button in the Logic Analyzer Window to open the Setup dialog. Press the Ins key, enter 1 ADC1_IN1 , which is the name of the input signal for A/D Channel 1, and close the Setup dialog. You may prefer to just drag and drop the object from the Symbols Window into the Logic Analyzer Window. For complex analysis, multiple signals can be selected and recorded. Save and load the signal definitions using the Export Signal Definitions… and Import Signal Definitions… button. Run the program, and use the Analog1 0..3 button of the Toolbox to start changing the signal on Analog Input 1. Changes applied to the analog inputs are reflected in the Logic Analyzer. 1 The additional signals used in this screenshot are not integrated into the Measure example. 137 138 Chapter 9. Example Programs “Traffic” Example Program The “Traffic” program1 is an example that shows how a real-time operating system can be used in an embedded application. This example simulates the control of a traffic light and walk signal. During rush hours, the stop signal controls the traffic flow at an intersection and allows pedestrians to cross the street periodically or by pressing the “Push for Walk” button. After rush hours, the traffic light flashes yellow. You interface the “Traffic” program via the:  Serial UART Window, where you can change the current time and the hours of operation  Toolbox, where you can click the “Push for Walk” button to cross the street  Watch Window and I/O Port dialog, where you can watch the state of the traffic light and the start/stop pedestrian lights The following table specifies the location of the “Traffic” project files for the various architectures. Architecture Example Folder ARM \KEIL\ARM\RL\RTX\EXAMPLES\TRAFFIC\ C16x/XC16x \KEIL\C166\EXAMPLES\TRAFFIC\ 8051 \KEIL\C51\RTXTiny2\EXAMPLES\TRAFFIC\ Opening the “Traffic” Project To start working with the “Traffic” project, open the TRAFFIC.UVPROJ project file from the appropriate example folder. Most Keil example projects include a text file named ABSTRACT.TXT that explains the aspects and the intention of the program and is included in the Project Window. 1 Since µVision simulates the hardware required for this program, you do not need any target hardware, an evaluation board, or a traffic light. Getting Started: Creating Applications with µVision Using the Configuration Wizard µVision incorporates a Configuration Wizard that assists you in choosing the settings for the startup file and other configuration files. Traditionally, these files are assembler or other source files, which include macros or definitions you may change depending on your hardware configuration or preferences. The Configuration Wizard simplifies the process of making these selections. Of course, you may always edit these files in their original source form by clicking on the Text Editor tab. Building and Testing the “Traffic” Project Use the Rebuild command to compile and link all files of the project The “Traffic” program is designed to accept commands from the on-chip serial port, which is completely simulated within µVision, and to display output on a traffic light, which is connected to I/O port pins. Using the Toolbox Use the Toolbox command from the Debug Toolbar or View Menu to display the toolbox dialog The Push for Walk button is available on the Toolbox. Click this button to simulate a pedestrian who wants to cross the road and watch as the “stop” and “walk” lights change in the Watch Window. 139 140 Chapter 9. Example Programs Using the Watch Window Use the Watch Window command on the Debug Toolbar or View Menu. Open the Call Stack Window as well. The status of the traffic pedestrian lights displays in the Watch 1 page of the Output Windows using predefined watch expressions. Using I/O Ports You may also view the traffic light signal lines on the I/O Port dialog available from the Peripherals Menu. Using the Serial Window The Serial Window displays information and allows you to change the time and operating hours of the traffic light. Set the current time outside of the rush hours to view the flashing yellow light. Check the Watch Window to monitor the changed behavior. Use the serial commands listed in the following table. These commands are plain ASCII text. Each command must be terminated with a carriage return. Action Command Description Display D Displays the current time and the Start Time and End Time of operating hours. Press Esc to exit display mode. Set Current Time T hh:mm:ss Sets the current time for the traffic light. If the current time is within the operating hours specified by the Start and End times, the traffic light operates as normal. If the current time is outside the operating hours, the traffic light flashes the yellow light. Set Start Time S hh:mm:ss Sets the Start Time for normal operation Set End Time E hh:mm:ss Sets the End Time for normal operation Getting Started: Creating Applications with µVision Displaying Kernel-Aware Debug Information The µVision Simulator allows you to run and test applications created with a real-time operating system. Real-time applications load exactly like other programs. No special commands or options are required for debugging. Kernel-aware debugging is available in the form of a dialog that displays the aspects of the real-time kernel and the tasks in your program. This dialog can be used with target hardware. To open the kernel-aware debug window, use the Debug – OS Support Menu. 141 142 Chapter 9. Example Programs “Blinky” Example Program The “Blinky” program is an example application that blinks LEDs on an evaluation board. The blinking LEDs make it easy to verify that the program loads and executes properly on target hardware. The “Blinky” program is a board-specific application, and thus, since the boards are different, the program may show other board-specific features. Refer to the board manual for detailed information. Opening the “Blinky” Project Select the Project – Open Project Menu and choose the respective BLINKY.UVPROJ project from the following subfolders: Architecture Example Folder ARM \KEIL\ARM\BOARDS\vendor\board name\BLINKY\ C166/XE166/XC2000 \KEIL\C166\BOARDS\board name\BLINKY\ 8051 \KEIL\C51\EXAMPLES\BLINKY\ Each project contains an ABSTRACT.TXT file that explains how to use the “Blinky” program for that specific board. You will also find a detailed description of the “Blinky” program in the User’s Guide manual of the board. Getting Started: Creating Applications with µVision Building the “Blinky” Project The project may contain several targets, for example:  Simulator: is a configuration to debug code without real target hardware  Board specific target: is a configuration to download and test the program on real target hardware For testing on hardware ensure that Board specific target is selected. Use the Rebuild command of the Build Toolbar to compile and link all project files, or use the Project – Rebuild all target files Menu The executable files are placed in an output folder and are ready for downloading. 143 144 Chapter 9. Example Programs Downloading the “Blinky” Program Before using the Download command for the first time, verify the Flash options in the Project – Options for Target – Utilities dialog. Alternatively, you can use the Flash – Configure Flash Tools… Menu to reach the identical dialog. Connect the board to your PC. After you have configured the µVision IDE, the Flash – Download Menu uses the specified adapter for Flash programming. Click the Download to Flash Toolbar button, or use the Flash – Download Menu to flash the application program to the target hardware The program has been downloaded, and it runs successfully on your target hardware as soon as the LEDs are blinking. Debugging the “Blinky” Program To verify the configuration settings for the Debugger, open the Options for Target – Debug dialog.  Click the Use radio button and select the appropriate debug driver from the drop down list  Check Load Application at Startup and Run to main()  Click the Settings button and verify the driver configuration Getting Started: Creating Applications with µVision Click Start/Stop Debug Session from the Debug Toolbar, or open the Debug – Start/Stop Debug Session Menu, to start debugging your application Step One Line – use the step commands to debug the application on target hardware Reset – Reset the microcontroller while debugging Run – the program to flash the LEDs on your evaluation board Stop – program execution Show Current Statement – Show next statement to be executed in the code 145 146 Glossary Glossary ASCII American Standard Code for Information Interchange This is a set of codes used by computers to represent digits, characters, punctuation, and other special symbols. The first 128 characters are standardized. The remaining 128 are defined by the implementation. Assembler A computer program to create object code by translating assembly instruction – mnemonics into opcodes, and by resolving symbolic names for memory locations and other entities. Programs written in assembly language and translated by an assembler can be loaded into memory and executed. CAN Controller Area Network Is a bus standard, designed specifically for automotive applications, meanwhile also used in other industries. It allows microcontrollers and devices to communicate with each other without a host computer. CMSIS Cortex Microcontroller Software Interface Standard A vendor-independent hardware abstraction layer for the Cortex-Mx processors. It enables consistent, scalable, and simple software interfaces to the processor for interfacing peripherals, real-time operating systems, and middleware, simplifying software re-use, and reducing the time to market for new devices. Compiler A program that translates source code from a high-level programming language, such as C/C++, to a lower level language, for example, assembly language or machine code. A compiler is likely to perform many or all of the following operations: lexical analysis, preprocessing, parsing, semantic analysis, code generation, and code optimization. µVision implements C/C++ compilers. Getting Started: Creating Applications with µVision CRC Cyclic Redundancy Check Is a type of function to detect accidental alteration of data during transmission or storage. Debugger A computer program to test software. Debuggers offer sophisticated functions such as running a program step-by-step (single-stepping), stopping, pausing the program to examine the current state at some kind of event through breakpoints, and tracking the values of variables. FPGA Field-Programmable Gate Array A semiconductor device that can be configured by the customer after manufacturing. GPIO General Purpose Input/Output An interface available on microcontroller devices to interact digitally with the outside world. GPIOs are often arranged into groups, typically of 8, 16, or 32 pins. The GPIO port pins can be configured individually as input or output. ICE In-Circuit-Emulator A hardware device used to debug software of an embedded system. It provides hardware-level run-control and breakpoint features. Some ICEs offer a trace buffer that stores the most recent microcontroller events. Include file A text file that is incorporated into a source file using the #include preprocessor directive. Instruction set An instruction set, or instruction set architecture (ISA), is the part of the microcontroller architecture related to programming, including the native data types, instructions, registers, addressing modes, memory architecture, interrupt and exception handling, and external I/O. An ISA includes a specification of the set of opcodes – the native commands implemented by a particular microcontroller. 147 148 Glossary JTAG Joint Test Action Group The common name used for the IEEE 1149.1 standard called Standard Test Access Port and Boundary-Scan Architecture. JTAG is often used as a microcontroller debug or probing port and allows data transfer out of and into device memory. Library Is a file, which stores a number of possibly related object modules. The linker can extract modules from libraries to use them in building an object file. LIN Local Interconnect Network Is a vehicle bus standard or computer networking bus-system used within current automotive network architectures. The LIN bus is a small and slow network system that is used as a cheap sub-network of a CAN bus. Linker Is a program that combines libraries and objects, generated by a compiler, into a single executable program. Lint A tool to check C/C++ code for bugs, glitches, inconsistency, portability, and whether the code is MISRA compliant. Macro Defines a rule or pattern that specifies how a certain input sequence should be mapped to an output sequence. MDI An application that allows the user to open more than one document from the same application without having to purposely launch another instance of the application. Memory model Is a definition that specifies which memory areas are used for function arguments and local variables. Getting Started: Creating Applications with µVision MISRA Motor Industry Software Reliability Association A forum that provides software development standards for the C/C++ programming language, focusing on code safety, portability , and reliability in the context of embedded systems. Monitor Is a program for 8051 and C166 devices. It can be loaded into your target microcontroller to aid in debugging and rapid product development through rapid software downloading. Object A memory area that can be examined. Usually used when referring to the memory area associated with a variable or function. Object file Created by the compiler, this file contains an organized collection of objects, which are sequences of instructions in a machine code format, but might also contain data for use at runtime: relocation information, stack unwinding information, comments, names of variables and functions for linking, and debugging information. OCDS On Chip Debug Support A debug port that provides hardware emulation features for the Infineon 166 devices. Opcode An operation code is that portion of a machine language instruction that specifies the operation to be performed. Their specification and format are laid out in the instruction set architecture of the processor. Simulation Is the imitation of a real thing or process. In µVision, simulation is used to create embedded applications without using ‘real’ hardware. You can represent key characteristics and behaviors of the selected system, perform optimization, safety engineering, testing, and debugging. Stack An area of memory, indirectly accessed by a stack pointer, that shrinks and expands dynamically, and holds local function data. Items in the stack are removed on a LIFO (last-in, first-out) basis. 149 150 Glossary Token Is a fundamental symbol that represents a name or entity in a programming language. Thumb, Thumb2 An instruction set for ARM and Cortex devices. See instruction set. UART Universal Asynchronous Receiver/Transmitter Is an individual IC, or part of an IC, used for serial communications. Getting Started: Creating Applications with µVision Index µ µVision Concepts................................... 55 Debugger .................................. 35 Debugger Modes ...................... 36 Device Database ...................... 35 features ..................................... 34 IDE ........................................... 34 Operating Modes...................... 59 Cortex-Mx ................................ 15 ARM7/ARM9 Advantages ............................... 16 Coding Hints ............................ 31 Highlights ................................. 22 Microcontrollers ....................... 21 Tool Support ............................ 23 Assembler..................................... 37 Assistance..................................... 13 B 8 8051 Advantages............................... 15 Classic ...................................... 17 Coding Hints ............................ 29 Extended .................................. 17 Highlights................................. 18 Memory Types ................... 17, 19 Tool Support ............................ 18 Batch-Build .................................. 88 Bookmarks ................................... 98 Breakpoints .................................. 98 Commands ............................. 100 Managing ................................. 99 Types ........................................ 99 Build Toolbar ............................... 65 Building a project ......................... 84 C A Adding books ............................... 78 Adding source files ...................... 79 Adding targets, groups, files ........ 78 Additional Icons ........................... 67 Advantages 8051 ......................................... 15 ARM7/ARM9 .......................... 16 C166, XE166, XC2000 ............ 16 Cortex-Mx................................ 16 Architectures ................................ 14 16-bit ........................................ 14 32-bit ........................................ 14 8-bit .......................................... 14 C/C++ Compiler........................... 38 C166, XE166, XC2000 Advantages ............................... 16 Coding Hints ............................ 30 Highlights ................................. 20 Memory Types ......................... 20 Tool Support ............................ 21 Code comparison I/O Access ................................ 26 Pointer Access .......................... 27 Code coverage ............................ 104 Code, generating optimal ............. 28 Coding Hints 8051.......................................... 29 151 152 all architectures ........................ 28 ARM7/ARM9 .......................... 31 C166, XE166, XC2000 ............ 30 Cortex-Mx ................................ 32 Compare memory areas ............... 97 Compiler ...................................... 38 Copying the startup code ............. 77 Cortex-Mx .................................... 23 Advantages............................... 16 Coding Hints ............................ 32 Highlights................................. 24 Tool Support ............................ 25 Creating a HEX file ..................... 85 Creating a project file................... 75 Creating source files .................... 78 D Debug features ............................. 93 Debug Mode ................................ 93 Debug Toolbar ............................. 66 Debugger Configuring .............................. 90 Controls............................ 90, 113 starting ..................................... 91 Windows .................................. 92 Debugger, Simulator .................... 89 Debugging .................................... 89 Development cycle....................... 33 Development tools ....................... 33 Directory structure ....................... 12 Document Conventions.................. 5 E Embedded applications ................ 75 Examining memory...................... 96 Example programs ..................... 122 Examples Blinky..................................... 142 Hello program ........................ 123 Measure program ................... 127 Traffic program ...................... 138 Executing code ............................. 95 Execution Profiler ...................... 103 F File options ................................... 82 File Toolbar .................................. 63 Files .............................................. 79 finding object dependencies ....... 109 Flash Auxiliary content.................... 121 BUS configuration ................. 121 Download ............................... 119 External Tools ........................ 115 Init file .................................... 121 Programming Algorithm ........ 120 Programming Devices ............ 114 Folder structure ............................ 12 G Getting Help ................................. 13 Group options ............................... 82 Groups .......................................... 79 H Hardware requirements ................ 11 Help, Support ............................... 13 HEX converter ............................. 38 HEX file ....................................... 85 Highlights 8051 .......................................... 18 ARM7/ARM9 .......................... 22 C166, XE166, XC2000 ............ 20 Cortex-Mx ................................ 24 Getting Started: Creating Applications with µVision Creating .................................... 86 Managing ................................. 86 I I/O access comparison ................. 26 Infineon C166, XE166, XC2000 . 20 Installation ................................... 11 K Keil Tools ...................................... 9 Kernel information ..................... 141 L Last Minute Changes ................... 11 Library manager ........................... 39 Licensing...................................... 11 Linker ........................................... 39 Locator ......................................... 39 Loogic Analyzer ........................ 106 M Memory commands ..................... 97 Menu ............................................ 59 Debug ....................................... 61 Edit ........................................... 59 File ........................................... 59 Flash ......................................... 60 Help.......................................... 61 Peripherals ............................... 62 Project ...................................... 60 SVCS ....................................... 61 Tools ........................................ 61 View ......................................... 60 Window.................................... 62 Microcontroller Architectures...... 14 Modifying memory ...................... 96 Multiple Projects Activating................................. 87 Batch-Building ......................... 88 153 O Object-HEX converter ................. 38 On-line Help ................................. 74 Options ......................................... 81 P Performance Analyzer ................ 105 Peripheral ..................................... 74 Peripheral Registers ........... 107, 108 Pointer access comparison ........... 27 Preface............................................ 3 Product folder structure ................ 12 Programming algorithm ..... 119, 120 Project filename ........................... 76 Project folder ................................ 76 Project Window............................ 77 Project, Multi-project ................... 86 R Registers ....................................... 96 Release Notes ............................... 11 Resetting the CPU ........................ 95 Restore Views, Screen layouts ... 111 RTOS Design ...................................... 41 Endless loop design .................. 40 RTX variants ............................ 42 Software concepts .................... 40 RTX Event Flags ............................... 45 Function Overview ................... 53 Function Overview, Tiny ......... 54 Interrupt Service Routine ......... 49 Introduction .............................. 43 154 Mailbox communication .......... 47 Memory & Memory Pools ....... 51 Preemptive Task Switching ..... 46 Round-Robin ............................ 43 Semaphores .............................. 48 Binary................................... 48 Counting............................... 49 Single Task .............................. 43 Technical Data ......................... 53 Technical Data, Tiny................ 54 Time Delay .............................. 44 Wait function ........................... 44 S Sample programs ....................... 122 Selecting a microcontroller .......... 76 Selecting an Architecture ............. 15 Serial I/O .................................... 102 Setting default folders .................. 78 Simulator...................................... 91 Simulator, Debugger .................... 89 Single-stepping ............................ 96 Software requirements ................. 11 Source files .................................. 78 Starting a program........................ 95 Starting the debugger ................... 91 Startup code Configuring .............................. 83 Copying .................................... 77 Stopping a program ...................... 95 Support ......................................... 13 T Target Hardware ........................ 112 Target options .............................. 81 Targets ......................................... 79 Testing ......................................... 89 Tool options ................................. 81 Tool Support 8051 .......................................... 18 ARM7/ARM9 .......................... 23 C166, XE166, XC2000 ............ 21 Cortex-Mx ................................ 25 Toolbar Build ......................................... 65 Debug ....................................... 66 File ........................................... 63 Icons ......................................... 67 Toolbox ...................................... 110 Tools............................................. 33 Debuggers, Adapters ................ 10 Middelware .............................. 10 Software Development ............. 10 U ULINK ....................................... 116 Configuration ......................... 117 Configure Flash Download .... 119 Features .................................. 117 Flash Algorithms .................... 120 using Simulator .................................. 91 V viewing instruction history ......... 111 Viewing Registers ........................ 96 VTREG ...................................... 108 W Watchpoints................................ 101 Commands ............................. 101 Who should Read this Book ........... 3 Window Breakpoints .............................. 99 Browse ................................... 109 Getting Started: Creating Applications with µVision Code Coverage ....................... 104 Command ................................. 94 Debug Layouts ....................... 111 Disassembly ............................. 94 Editor ....................................... 71 Help.......................................... 74 Instruction Trace .................... 111 Logic Analyzer ...................... 106 Memory.................................... 97 155 moving and positioning ............ 58 Performance Analyzer ............ 105 Peripheral ................................. 74 Project ...................................... 69 summary of .............................. 73 Symbols .................................. 108 System Viewer ....................... 107 UART, Serial ......................... 102 156
PK51-T 价格&库存
很抱歉,暂时无法提供与“PK51-T”相匹配的价格&库存,您可以联系我们找货
