1979
1979
    ADAFRUIT
    STACKINGHEADERRASPBERRYPI
1979 数据手册
Stacking Header for Pi A+/B+/Pi 2/Pi 3 - 2x20 Extra Tall Header PRODUCT ID: 1979 Description Stack multiple plates, breakouts etc onto your Raspberry Pi Model B+ with this custom-made extra-tall and extra-long 2x20 female header. The female header part has extra spaces to make it 23mm tall: when placed on your Pi, a PCB will clear the Ethernet and USB jacks. The stacky pin part is also extra-long, 10mm, so that when a standard 1.5mm thickness PCB is installed, there will be 8.5mm remaining, plenty to plug into.  You'll get one header per order. Technical Details Dimensions: 5mm x 51mm x 23mm / 0.2" x 2" x 0.9" Pin Length: 10mm Pin Spacing: 2.5mm / 0.1" Pin Thickness: 0.6mm / 0.02" Weight: 6.5g Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1979”相匹配的价格&库存,您可以联系我们找货
    • 1+27.846031+3.23453
    库存:554
