FIT0504
FIT0504
    DFROBOT
    ALUMINUMHEATSINKCOOLINGFANFO
FIT0504 数据手册
  Aluminum Heatsink Cooling Fan for LattePanda SKU:FIT0504 INTRODUCTION Is your LattePanda running hot and throttling? This heat sink and fan combo will cool the CPU for smooth performance. The fan keeps the unit running at a stable temperature. The 2-Pin jumper wire makes it easily to connect with the CN2 headers on the board. This fan is low noise and has a thermal pad on the back that can stick on the metal shield on the board. With its aluminum casing, heat from CPU will be absorbed fast, giving you better performance. This is a simple and effective way to make the LattePanda cool! SPECIFICATION        Operating Voltage: 5v Operating Current: 0.14A Rated Speed: 6500 RPM Cable Length: 20cm Interface Type: 2.54mm 2-Pin DuPont Female Connector Dimension: 34.5 * 34.5 * 10 mm Weight: 12g Powered By DFRobot © 2008-2017
FIT0504 价格&库存
很抱歉,暂时无法提供与“FIT0504”相匹配的价格&库存,您可以联系我们找货
FIT0504
    • 1+107.72073
    库存:180
