P0017
P0017
    TERASIC(友晶科技)
    Manufacturer Specific Products - Interface Board
P0017 数据手册
Terasic THDB- HSMCHSMC-DVI Terasic HSMC-DVI Daughter Board User Manual Document Version 1.0.1 June. 25, 2009 by Terasic Introduction Page Index INTRODUCTION................................................................................................................................................................................. 1 1.1 1.1 FEATURES..................................................................................................................................................................... 1 1.2 1.2 ABOUT THE KIT ............................................................................................................................................................ 2 1.3 1.3 ASSEMBLE THE HSMC-DVI BOARD ............................................................................................................................ 5 1.4 1.4 GETTING HELP ............................................................................................................................................................. 6 ARCHITECTURE ................................................................................................................................................................................ 7 2.1 2.1 LAYOUT AND COMPONETS............................................................................................................................................ 7 2.2 2.2 BLOCK DIAGRAM .......................................................................................................................................................... 9 BOARD COMPONENTS ................................................................................................................................................................. 10 3.1 3.1 THE HSMC-DVI CONNECTOR................................................................................................................................... 10 3.2 3.2 GENERATE PIN ASSIGNMENTS ................................................................................................................................... 16 DEMONSTRATION .......................................................................................................................................................................... 20 4.1 4.1 INTRODUCTION ........................................................................................................................................................... 20 4.2 4.2 SYSTEM REQUIREMENTS ........................................................................................................................................... 20 4.3 4.3 HARDWARE SETUP ..................................................................................................................................................... 21 4.4 4.4 CONFIGURE FPGA .................................................................................................................................................... 21 4.5 4.4 DEMO OPERATION ...................................................................................................................................................... 22 4.6 4.5 DESIGN CONCEPT ...................................................................................................................................................... 22 4.7 4.6 SOURCE CODE LOCATION .......................................................................................................................................... 24 APPENDIX ......................................................................................................................................................................................... 25 5.1 5.1 REVISION HISTORY..................................................................................................................................................... 25 5.2 5.2 ALWAYS VISIT HSMC-DVI W EBPAGE FOR NEW MAIN BOARD ................................................................................. 25 ii Introduction 1 Introduction The Terasic HSMC-DVI is a DVI transmitter/receiver board with a High Speed Mezzanine Connector (HSMC) interface. It is designed to allow developers to access high quality and high resolution video signals in their FPGA. It gives the flexibility required in high resolution image processing systems by combining both the DVI transmitter and receiver onto the same card. Lastly, the HSMC-DVI daughter board can be connected to any HSMC/HSTC interface host boards. 1.1 1.1 Features Figure 1.1 shows the photo of the HSMC-DVI board. The important features are listed below: Digital Transmitter • One DVI transmitter with single transmitting port • Digital Visual Interface (DVI) Compliant • Supports resolutions from VGA to UXGA (25 MHz – 165 MHz Pixel Rates) • Universal Graphics Controller Interface •  12-Bit, Dual-Edge and 24-Bit, Single-Edge Input Modes  Adjustable 1.1 V to 1.8 V and Standard 3.3 V CMOS Input Signal Levels  Fully Differential and Single-Ended Input Clocking Modes  Standard Intel 12-Bit Digital Video Port Compatible as on Intel™ 81x Chipsets Enhanced PLL Noise Immunity  • On-Chip Regulators and Bypass Capacitors for Reducing System Costs Enhanced Jitter Performance  No HSYNC Jitter Anomaly  Negligible Data-Dependent Jitter • Programmable Using I²C Serial Interface • Single 3.3-V Supply Operation Digital Receiver • One DVI receiver with single receiving port • Supports UXGA Resolution (Output Pixel Rates Up to 165 MHz) • Digital Visual Interface (DVI) Specification Compliant • True-Color, 24 Bit/Pixel, 16.7M Colors at 1 or 2-Pixels Per Clock • Laser Trimmed Internal termination Resistors for Optimum Fixed Impedance Matching • 4x Over-Sampling • Reduced Ground Bounce Using Time Staggered Pixel Outputs • Lowest Noise and Best Power Dissipation Using TI PowerPAD™ Packaging 1 Introduction Figure 1.1. The HSMC-DVI board 1.2 1.2 About the KIT This section describes the package content • HSMC-DVI board x 1 • System CD-ROM x 1 The CD contains technical documents of the HSMC-DVI, and one reference design along with the source code. Figure 1.2 HSMC-DVI Package 2 Introduction The source code of reference design are available for the following FPGA main board: • DE3 Figure 1.2.1 The HSMC-DVI board connects with DE3 • Cyclone III Starter Board Figure 1.2.2. The HSMC-DVI board connects with Cyclone III Starter Board 3 Introduction • Cyclone III FPGA Development Kit Figure 1.2.3 The HSMC-DVI board connects with Cyclone III Development Board • Stratix III FPGA Development Kit Figure 1.2.4. The HSMC-DVI board connects with Stratix III Development Board 4 Introduction 1.3 1.3 Assemble the HSMC-DVI Board This section describes how to connect the HSMC-DVI daughter board to a main board, and using DE3 as an example. The HSMC-DVI daughter board connects to the main boards through the HSTC interface. For the DE3, the HSMC-DVI can be connected to any DE3’s four HSTC connectors using a THCB-HFF adapter card (Figure 1.3.1) which can be found in the DE3 package. Figure 1.3.1 THCB-HFF adapter card Figure 1.3.2 The HSMC-DVI board connects with DE3 Note. Do not attempt to connect/remove the HSMC-DVI daughter board to/from the main the main board when the power is on, or else the hardware could be damaged. 5 Introduction 1.4 1.4 Getting Help Here are some places to get help if you encounter any problem:  Email to support@terasic.com  Taiwan & China: +886-3-550-8800  Korea : +82-2-512-7661  Japan: +81-428-77-7000 6 Architecture 2 Architecture This Chapter covers the architecture of the HSMC-DVI board including its PCB and block diagram. 2.1 2.1 Layout and Componets The picture of the HSMC-DVI board is shown in Figure 2.1.1 and Figure 2.1.2 It depicts the layout of the board and indicates the location of the connectors and key components. Figure 2.1.1 The HSMC-DVI PCB and component diagram 7 Architecture Figure 2.1.2 The HSMC-DVI Back side – HSMC connector view The following components are provided on the HSMC-DVI board : • DVI Transmitter (U2) • DVI Receiver (U3) • I2C EEPROM (U4) • DVI Transmitter Connector (J2) • DVI Receiver Connector (J3) • HSMC Connector (J1) 8 Architecture 2.2 2.2 Block Diagram Figure 2.2.1 shows the block diagram of the HSMC-DVI board Figure 2.2.1 The block diagram of the HSMC-DVI board 9 Board Components 3 Board Components This section illustrates the detailed information of the components, connector interfaces, and the pin mapping tables of the HSMC-DVI board 3.1 3.1 The HSMC-DVI Connector This section describes pin definition of the HSMC-DVI interface onboard All the control and data signals of the DVI transmitter and receiver are connected to the HSMC connector, so users can fully control the HSMC-DVI daughter board through the HSMC interface. and 12V of the HSMC connector. 10 Power is derived from 3.3V Board Components Figure 3.1. The pin-outs on the HSMC connector 11 Board Components The table 3.1 below lists the HSMC signal direction and description. Note. The power pins are not shown in the table Table 3.1 Pin Numbers Name Direction Description 1 N.C. N/A Not Connect 2 N.C. N/A Not Connect 3 N.C. N/A Not Connect 4 N.C. N/A Not Connect 5 N.C. N/A Not Connect 6 N.C. N/A Not Connect 7 N.C. N/A Not Connect 8 N.C. N/A Not Connect 9 N.C. N/A Not Connect 10 N.C. N/A Not Connect 11 N.C. N/A Not Connect 12 N.C. N/A Not Connect 13 N.C. N/A Not Connect 14 N.C. N/A Not Connect 15 N.C. N/A Not Connect 16 N.C. N/A Not Connect 17 N.C. N/A Not Connect 18 N.C. N/A Not Connect 19 N.C. N/A Not Connect 20 N.C. N/A Not Connect 21 N.C. N/A Not Connect 22 N.C. N/A Not Connect 23 N.C. N/A Not Connect 24 N.C. N/A Not Connect 25 N.C. N/A Not Connect 26 N.C. N/A Not Connect 27 N.C. N/A Not Connect 28 N.C. N/A Not Connect 29 N.C. N/A Not Connect 30 N.C. N/A Not Connect 31 N.C. N/A Not Connect 32 N.C. N/A Not Connect 33 HSMC_SDA Inout I²C data 12 Board Components 34 HSMC_SCL Output I²C clock 35 N.C. N/A Not Connect 36 N.C. N/A Not Connect 39 N.C. N/A Not Connect 40 N.C. N/A Not Connect 41 DVI_RX_D0 Input DVI receiver pixel data 42 DVI_RX_D14 Input DVI receiver pixel data 43 DVI_RX_D1 Input DVI receiver pixel data 44 DVI_RX_D15 Input DVI receiver pixel data 45 3V3 Power Power 3.3V 46 12V Power Power 12V 47 DVI_RX_D2 Input DVI receiver pixel data 48 DVI_RX_D13 Input DVI receiver pixel data 49 DVI_RX_D3 Input DVI receiver pixel data 50 DVI_RX_D12 Input DVI receiver pixel data 51 3V3 Power Power 3.3V 52 12V Power Power 12V 53 DVI_RX_D4 Input DVI receiver pixel data 54 DVI_RX_D11 Input DVI receiver pixel data 55 DVI_RX_D5 Input DVI receiver pixel data 56 DVI_RX_D10 Input DVI receiver pixel data 57 3V3 Power Power 3.3V 58 12V Power Power 12V 59 DVI_RX_D6 Input DVI receiver pixel data 60 DVI_RX_D9 Input DVI receiver pixel data 61 DVI_RX_D7 Input DVI receiver pixel data 62 DVI_RX_D8 Input DVI receiver pixel data 63 3V3 Power Power 3.3V 64 12V Power Power 12V 65 DVI_RX_CTL1 Input Control signal 66 DVI_RX_D23 Input DVI receiver pixel data 67 DVI_RX_HS Input DVI receiver horizontal sync 68 DVI_RX_D6 Input DVI receiver pixel data 69 3V3 Power Power 3.3V 70 12V Power Power 12V 71 DVI_RX_VS Input DVI receiver vertical sync 72 DVI_RX_D5 Input DVI receiver pixel data 73 DVI_RX_DE Input DVI receiver pixel data 13 Board Components 74 DVI_RX_D4 Input DVI receiver pixel data 75 3V3 Power Power 3.3V 76 12V Power Power 12V 77 DVI_RX_CTL3 Input Control signal 78 DVI_RX_D3 Input DVI receiver pixel data 79 DVI_RX_CTL2 Input Control signal 80 DVI_RX_D2 Input DVI receiver pixel data 81 3V3 Power Power 3.3V 82 12V Power Power 12V 83 DVI_RX_DDCSDA Inout DDC I²C data 84 DVI_RX_D1 Input DVI receiver pixel data 85 DVI_RX_DDSCL Inout DDC I²C clock 86 DVI_RX_D16 Input DVI receiver pixel data 87 3V3 Power Power 3.3V 88 12V Power Power 12V 89 EDID_WP_n Output I²C write protect enable 90 DVI_RX_SCDT Input Receiver sync detect 91 N.C. N/A Not Connect 92 DVI_TX_D17 Output DVI transmitter data bus 93 3V3 Power Power 3.3V 94 12V Power Power 12V 95 DVI_TX_D16 Output DVI transmitter data bus 96 DVI_RX_CLK Input DVI receiver clock 97 N.C. N/A Not Connect 98 N.C. N/A Not Connect 99 3V3 Power Power 3.3V 100 12V Power Power 12V 101 DVI_TX_D12 Output DVI transmitter data bus 102 DVI_TX_D18 Output DVI transmitter data bus 103 DVI_TX_D13 Output DVI transmitter data bus 104 DVI_TX_D19 Output DVI transmitter data bus 105 3V3 Power Power 3.3V 106 12V Power Power 12V 107 DVI_TX_D14 Output DVI transmitter data bus 108 DVI_TX_D20 Output DVI transmitter data bus 109 DVI_TX_D15 Output DVI transmitter data bus 110 DVI_TX_D21 Output DVI transmitter data bus 111 3V3 Power Power 3.3V 14 Board Components 112 12V Power Power 12V 113 DVI_TX_D11 Output DVI transmitter data bus 114 DVI_TX_D22 Output DVI transmitter data bus 115 DVI_TX_D10 Output DVI transmitter data bus 116 DVI_TX_D23 Output DVI transmitter data bus 117 3V3 Power Power 3.3V 118 12V Power Power 12V 119 DVI_TX_D9 Output DVI transmitter data bus 120 DVI_TX_DKEN Output Data de-skew enable 121 DVI_TX_D8 Output DVI transmitter data bus 122 DVI_TX_HS Output DVI transmitter Horizontal sync 123 3V3 Power Power 3.3V 124 12V Power Power 12V 125 DVI_TX_D7 Output DVI transmitter data bus 126 DVI_TX_VS Output DVI transmitter vertical sync 127 DVI_TX_D6 Output DVI transmitter data bus 128 DVI_TX_CTL3 Output Multifunction 129 3V3 Power Power 3.3V 130 12V Power Power 12V 131 DVI_TX_D5 Output DVI transmitter data bus 132 DVI_TX_CTL2 Output Multifunction 133 DVI_TX_D4 Output DVI transmitter data bus 134 DVI_TX_CTL1 Output Multifunction 135 3V3 Power Power 3.3V 136 12V Power Power 12V 137 DVI_TX_D3 Output DVI transmitter data bus 138 DVI_TX_HTPLG Output Edge select/hot plug input 139 DVI_TX_D2 Output DVI transmitter data bus 140 TX_PD_n Output Power down (active low) 141 3V3 Power Power 3.3V 142 12V Power Power 12V 143 DVI_TX_D1 Output DVI transmitter data bus 144 DVI_TX_MSEN Input Monitor sense/programmable output 145 DVI_TX_D0 Output DVI transmitter data bus 146 DVI_TX_ISEL Output I²C interface select/I²C reset 147 3V3 Power Power 3.3V 148 12V Power Power 12V 149 DVI_TX_DE Output DVI data enable 15 Board Components 150 DVI_TX_SDA I/O DSEL/I²C data 151 DVI_TX_DDCSDA I/O DDC I²C data 152 DVI_TX_SCL Output Input bus select/I²C clock 153 3V3 Power Power 3.3V 154 12V Power Power 12V 155 DVI_TX_CLK Output DVI transmitter clock 156 N.C. N/A Not Connect 157 DVI_TX_DDCSCL Output DDC I²C clock 158 N.C. N/A Not Connect 159 3V3 Power Power 3.3V 160 GND Power Power Ground 161 GND Power Power Ground 162 GND Power Power Ground 163 GND Power Power Ground 164 GND Power Power Ground 165 GND Power Power Ground 166 GND Power Power Ground 167 GND Power Power Ground 168 GND Power Power Ground 169 GND Power Power Ground 170 GND Power Power Ground 171 GND Power Power Ground 172 GND Power Power Ground 3.2 3.2 Generate Pin Assignments This section describes how to automatically generate a top-level project, including DVI pin assignments For the DE3 main board: Users can easily create the HSMC-DVI board pin assignments by utilizing the DE3_System Builder V 1.4.3 or later (DE3_System Builder is available on the DE3 System CD or can be downloaded from the website http://de3.terasic.com). Here are the procedures to generate a top-level project for HSMC-DVI. 1) Launch DE3-System Builder 2) Add a DE3 board. Enable the HSTC-C connector and type desired pin pre-fix name in the dialog of DE3 Configuration. 16 Board Components 3) Add HSMC-DVI Board. 4) Connect DE3 and HSMC-DVI Board by drag-and-drop the mouse 17 Board Components 5) Click “Generate” to generate the desired top-level and pin assignments for the HSMC-DVI project. For the Cyclone III starter board, Cyclone III development board, and Stratix III development board: Users can easily generate HSMC-DVI pin assignments onto their main board by utilizing the Daughter Board Wizard V1.2.0 or later (Daughter Board Wizard is available on the DVI CD-ROM located in the “Tool” folder). Here are the procedures to generate a top-level project for HSMC-DVI. 1) Launch Daughter Board Wizard. 2) Select the Main Board Connector 3) Select the HSMC-Compliant Daughter Board 18 Board Components 4) Enter the signal Pre-fix name of Daughter Board and Click ‘Generate’ to generate the desired top-level and pin assignments for the HSMC-DVI project. 19 Demonstration 4 Demonstration This Chapter illustrates the reference design for the HSMC-DVI board 4.1 4.1 Introduction This section describes the functionality of the demonstration briefly. The demonstration shows how to use DE3 to controls the HSMC-DVI board. The demonstration includes two parts: Transmission Demo: The reference design can generate various video format signal for transmit. The supported format includes: Pattern ID Video Format PCLK (MHZ) 0 640x480@60P 25 1 720x480@60P 27 2 1024x768@60P 65 3 1280x1024@60P 108 4 1920x1080@60P 148.5 5 1600x1200@60P 162 Loopback Demo: Loopback (Internal bypass) the DVI video signals within the FPGA board. The video output pins of the receiver are directly connected to the input video pins of the transmitter. 4.2 4.2 System Requirements The following items are required for the HSMC-DVI Server demonstration. • HSMC-DVI x 1 • DE3 Board x 1 • LCD monitor with at least one DVI input x 1 • DVI Video source x 1 • DVI Cable x 2 20 Demonstration 4.3 4.3 Hardware Setup Figure 4.3.1 shows how to setup hardware for the HSMC-DVI demonstration. DVI Cable DVI Source Device Figure 4.3.1 Note: It is important to connect the DVI daughter board to Port C of the DE3 board. A THCB-HFF adapter card is used to establish connection with DE3 and HSMC-DVI daughter board. 4.4 4.4 Configure FPGA This section describes the procedures of configure the FPGA. Please follow the procedure below to configure FPGA: • Connect DE3 to your PC by an usb cable. • Power on DE3 • Project directory: DVI_Demo_DE3_150_PortC (Note: Project folder may vary depending on the DE3 device you are using and the corresponding port. As for this demonstration, we are using Port C on the DE3 FPGA) • Configure FPGA by the Bit Stream File: DVI_Demo.sof 21 Demonstration 4.5 4.4 Demo Operation This section describes the procedures of operation the demonstration. DVI Transmission Demo: For transmission demo, please attach a LCD to DVI-TX port with a DVI cable. By pressing Button[2] you can toggle between the transmission Demo and Loopback Demo. When transmission demo is active, LED[3] is Off. Click Button[3] can change active transmission pattern. The associated pattern ID is indicated by LED[2:0]. LED[2]Off -- LED[1]Off -- LED[0]Off means pattern ID zero. DVI Loopback Demo: For loopback demo, please attach a LCD to DVI-TX port and attach a DVI-Video source to DVI-RX port with DVI cables, in respectively. By pressing Button[2] you can toggle the transmission Demo and Loopback Demo. When loopback demo is active, LED[3:0] are on. The loopback demonstration uses the EDID information which is stored in EEPROM on the DVI-RX. The EDID is already initiated with the DVI board. However, if the EDID is erased or modified by users, please remember to initialize EDID. By pressing Button[1], the EDID initialization process is started. The LED[3:0] starts to blink when EDID initialization is in process. When EDID is initialized successfully, the LED[3:0] stops blinking. If EDID initialization fails, please try to remove the cable attached to DVI_RX port and press Button[1] to try again. 4.6 4.5 Design Concept This section describes the design concepts for the HSMC-DVI demonstration. System Block Diagram: Figure 4.5.1 show the block diagram of the demonstration. 22 Demonstration Figure 4.5.1 Block diagram The “Video Pattern Generator” module corresponds to the generated test patterns for transmission demo. The test patterns includes: Pattern ID Video Format PCLK (MHZ) 0 640x480@60P 25 1 720x480@60P 27 2 1024x768@60P 65 3 1280x1024@60P 108 4 1920x1080@60P 148.5 5 1600x1200@60P 162 23 Demonstration The display resolution and pixel rate will change when the mode changes. In this module, the ALTERA PLL-RECONFIG controller is used to generate various pixel rates. The RECONFIG data for various clocks are stored on the ROM. The module source code is located in “vpg” sub-folder. For more information about Stratix III re-configuration PLL, please refer to www.altera.com/literature/an/an454.pdf The “Video Latch” module is used to latch DVI-RX video for high-speed video streaming. The “Video Source Selector” module corresponds to the selected desired video source for final video display. Altera LPM_MUX controller is used to achieve high-speed video streaming selection. The “I2C EEPROM Write” module corresponds to writing aspects of the EDID content to EDID. For writing custom EDID data, users can change this module. 4.7 4.6 Source Code Location Table 4.6 shows the source code location for the DVI reference design for various FPGA main boards. Table 4.6 FPGA Main Boards Reference design location DE3-340 Device (Port C) \Examples\DVI_Demo_DE3_340_PortC DE3-150 Device (Port C) \Examples\DVI_Demo_DE3_150_PortC Cyclone III Starter Board \Examples\DVI_Demo_QB3 Cyclone III Development Board (Port B) \Examples\DVI_Demo_C3H_PortB Stratix III Development Board (Port B) \Examples\DVI_Demo_S3H_PortB 24 Appendix 5 Appendix 5.1 5.1 Revision History Date Change Log June 25, 2009 Initial Version March 15, 2010 Table 3.1 Pin assignments corrected 5.2 5.2 Always Visit HSMC-DVI Webpage for New Main board We will be continuing providing interesting examples and labs on our HSMC-DVI webpage. Please visit www.altera.com or hsmcdvi.terasic.com for more information. 25
P0017 价格&库存
很抱歉,暂时无法提供与“P0017”相匹配的价格&库存,您可以联系我们找货
