CABLE-40-40-10CM
CABLE-40-40-10CM
    OLIMEX
    DATA/TOUCHSCREEN CABLE FOR OLINU
CABLE-40-40-10CM 数据手册
Page 1 of 1 CABLE-40-40-10CM CABLE WITH 0.05'' STEP 40 PIN CONNECTORS Ribbon cable with two 40-pin 0.05″ step connectors and length 10 cm. Suitable for the LIME boards (A10OLinuXino-LIME, A20-OLinuXino-LIME, etc). IMPORTANT: the cable and the connectors are very fragile - if you attempt to disconnect the setup by pulling the cable it might break! Furthermore - you might bend the pins! Use pliers or other suitable object to disconnect the connectors carefully! https://www.olimex.com/Products/Components/Cables/CABLE-40-40-10CM/ 4/30/2015
CABLE-40-40-10CM 价格&库存
很抱歉,暂时无法提供与“CABLE-40-40-10CM”相匹配的价格&库存,您可以联系我们找货
