800-00040
800-00040
    PARALLAXINC.
    3-WIRE EXT.,22AWG,F/F,4""
800-00040 数据手册
Page 1 of 1 Home Store Product Info Education Support Resources Company 3-pin Power-Signal-Ground Cable Extensions (4") These female/female terminated cables are of high quality - they have specified and built to order specifically by Parallax and quality checked by Parallax Hong Kong engineering staff. The 22-gauge three-conductor wire is covered with a pliable silicone insulation and the tactile feeling conveys a much higher confidence than common extension cables. Parallax priced these cables very reasonably thanks to high-volume manufacturing. Parallax boards support these cables with their 3-pin male headers. Many Parallax sensors also use a 3-pin interface compatible with these cables. Whether you are flying an ELEV-8 quadcopter or extending your Ping))) sensor far from your microcontroller, these cables are the best choice. Features:        Item code 800-00040 Stock  Price $ Starting from: 10 pieces $ Starting from: 25 pieces $ Starting from: 100 pieces $ 22 AWG 3-conductor insulated cable 0.1" spacing single row connector for power, ground and signal Female/female terminations Uses Molex series 70058 #16-02-0087 terminal or equivalent Uses Molex #50-57-9003 housing or equivalent ROHS Pliable tactile feeling Also available in the following sizes:        3-pin Power-Signal-Ground Cable Extensions (6") 3-pin Power-Signal-Ground Cable Extensions (8") 3-pin Power-Signal-Ground Cable Extensions (12") 3-pin Power-Signal-Ground Cable Extensions (16") 3-pin Power-Signal-Ground Cable Extensions (20") 3-pin Power-Signal-Ground Cable Extensions (24") 3-pin Power-Signal-Ground Cable Extensions (36") 8/7/2012
800-00040 价格&库存
很抱歉,暂时无法提供与“800-00040”相匹配的价格&库存,您可以联系我们找货
