P0087
P0087
    TERASIC(友晶科技)
    HDMI-HSTC CARD (VER.1.4)
P0087 数据手册
THDB-HDMI Terasic HDMI Video Daughter Board User Manual 1 CONTENTS Chapter 1 Introduction ...................................................................................... 2 1.1 About the KIT .......................................................................................................................................... 2 1.2 Assemble the HDMI Board ...................................................................................................................... 3 1.3 Getting Help ............................................................................................................................................. 3 Chapter 2 HDMI Board ....................................................................................... 4 2.1 Features .................................................................................................................................................... 4 2.2 Layout and Componets ............................................................................................................................ 7 2.3 Block Diagram of HDMI Signal Transmission........................................................................................ 8 2.4 Block Diagram of HDMI Signal Receiving ........................................................................................... 10 2.5 Generate Pin Assignments ..................................................................................................................... 11 2.6 Pin Definition of HSTC Connector ........................................................................................................ 13 Chapter 3 Demonstration ................................................................................ 21 3.1 Introduction ............................................................................................................................................ 21 3.2 System Requirements............................................................................................................................. 21 3.3 Setup the Demonstration ........................................................................................................................ 22 3.4 Operation................................................................................................................................................ 23 Chapter 4 Case Study ....................................................................................... 27 4.1 Overview ................................................................................................................................................ 27 4.2 System Function Block .......................................................................................................................... 27 4.3 NIOS Program ....................................................................................................................................... 31 Chapter 5 Appendix ......................................................................................... 35 5.1 Revision History .................................................................................................................................... 35 5.2 Always Visit THDB-HDMI Webpage for Update.................................................................................. 35 1 Chapter 1 Introduction THDB-HDMI is a HDMI transmitter/receiver daughter board with HSTC (High Speed Terasic Connector) interface. Host boards, supporting HSTC-compliant connectors, can control the HDMI daughter board through the HSTC interface. This THDB-HDMI kit contains complete reference designs with source code written in Verilog and C, for HDMI signal transmitting and receiving. Based on reference designs, users can easily and quickly develop their applications. 1.1 About the KIT This section describes the package content. The THDB-HDMI package, as shown in Figure 1-1, contains:   THDB-HDMI board x 1 System CD-ROM x 1 The CD contains technical documents of the HDMI receiver and transmitter, and one reference design for HDMI transmitting and receiving with source code. Figure 1-1 THDB-HDMI Package 2 1.2 Assemble the HDMI Board This section describes how to connect the HDMI daughter board to a main board, and use DE3 as an example. The HDMI board connects to main boards through the HSTC interface. For DE3, the HDMI daughter board can be connected to any one of four HSTC connectors on DE3. Figure 1-2 shows a HDMI daughter board connected to the HSTC connector of DE3. Due to high speed data rate in between, users are strongly recommended to screw the two boards together. Note. Do not attempt to connect/remove the HDMI daughter board to/from the main board when the power is on, or the hardware could be damaged. Figure 1-2 Connect HDMI daughter board to DE3 board 1.3 Getting Help Here are some places to get help if you encounter any problem:    Email to support@terasic.com Taiwan: +886-3-570-0880 China : +86-27-8774-5390 3  Chapter 2 HDMI Board This chapter will illustrate technical details of HDMI board. Users may modify the reference designs for various purposes accordingly. 2.1 Features This section describes the major features of the HDMI board.  Board Features:      One HSTC interface for connection purpose One HDMI transmitter with single transmitting port One HDMI receiver with dual receiving ports Two 2K EEPROM for storing EDID of two receiver ports separately Powered from 3.3V pins of HSTC connector  HDMI Transmitter Features: 1. HDMI 1.4 transmitter 2. Compliant with HDMI 1.3, HDMI1.4a 3D,HDCP 1.4 and DVI 1.1 specifications 3. Supporting link speeds of up to 2.25 Gbps (link clock rate of 225MHZ) 4. Supporting diverse 3D formats which are compliant with HDMI 1.4a 3D specification. o Supporting 3D video up to 1080P@23.98/24/30Hz,1080i@50/59.94/60/Hz o Supporting formats: framing packing, side-by-side(half),top-and-bottom 5. Various video input interface supporting digital video standards such as: o 24/30/36-bit RGB/YCbCr 4:4:4 o 16/20/24-bit YCbCr 4:2:2 o 8/10/12-bit YCbCr 4:2:2 (CCIR-656) 6. Bi-direction Color Space Conversion (CSC) between RGB and YCbCr color space with programmable coefficients 4 7. Up/down sampling between YCbCr 4:4:4 and YCbCr 4:2:2 8. Either for conversion from 12-bit/10-bit to component to 8-bit 9. Support Gammat Metadata packet 10. Digital audio input interface supporting: o Up to four I2S interface supporting 8-channel audio, with sample rates of 32~192 kHz and sample sizes of 16~24 bits o S/PDIF interface supporting PCM, Dolby Digital, DTS digital audio at up to 192kHz frame rate o Support for high-bit-rate (HBR) audio such as DTS-HD and Dolby TrueHD through the four I2S interface or the S/PDIF interface, with frame rates as high as 768kHz o Support for 8-channel DSD audio through dedicated inputs o Compatible with IEC 60958 and IEC 61937 o Audio down-sampling of 2X and 4X 11. Software programmable, auto-calibrated TMDS source terminations provide for optimal source signal quality 12. Software programmable HDMI output current level 13. MCLK input is optional for audio operation. Users could opt to implement audio input interface with or without MCLK 14. Integrated pre-programmed HDCP keys 15. Purely hardware HDCP engine increasing the robustness and security of HDCP operation 16. Monitor detection through Hot Plug Detection and Receiver Termination Detection 17. Embedded full-function pattern generator 18. Intelligent, programmable power management Table 2-1 lists supported input video format: Table 2-1 Input video formats supported by the HDMI board Input Pixel Clock Frequency(MHz) Color Video Bus Hsync/ space Format Width Vsync 24 RGB 4:4:4 30/36 12/15/18 24 4:4:4 YCbCr 30/36 12/15/18 4:2:2 16/20/24 480i 480p XGA 720p 1080i SXGA 1080p UXGA 13.5 27 65 74.25 74.25 108 148.5 162 13.5 27 65 74.25 74.25 108 148.5 13.5 27 65 74.25 74.25 13.5 27 65 74.25 74.25 108 148.5 13.5 27 65 74.25 74.25 108 148.5 Separate 13.5 27 65 74.25 74.25 Separate 13.5 27 74.25 74.25 148.5 Embedded 13.5 27 74.25 74.25 148.5 Separate Separate Separate 5 162 12/15/18 Separate 27 54 148.5 148.5 Embedded 27 54 148.5 148.5  HDMI Receiver Features: 1. Dual-Port HDMI 1.4 receiver 2. Compliant with HDMI 1.3, HDMI1.4a 3D,HDCP 1.4 and DVI 1.1 specifications 3. Supporting link speeds of up to 2.25 Gbps (link clock rate of 225MHZ) 4. Supporting diverse 3D formats which are compliant with HDMI 1.4a 3D specification. o Supporting 3D video up to 1080P@23.98/24/30Hz,1080i@50/59.94/60/Hz o Supporting formats: framing packing, side-by-side(half),top-and-bottom 5. Various video input interface supporting digital video standards such as: o 24/30/36-bit RGB/YCbCr 4:4:4 o 16/20/24-bit YCbCr 4:2:2 o 8/10/12-bit YCbCr 4:2:2 (ITU BT-656) o 12/15/18-bit double data rate interface (data bus width halved, clocked with both rising and falling edges) for RGB/YCbCr 4:4:4 o 24/30/36-bit double data rate interface (full bus width, pixel clock rate halved, clocked with both rising and falling edges) o Input channel swap o MSB/LSB swap 6. Bi-direction Color Space Conversion (CSC) between RGB and YCbCr color space with programmable coefficients 7. Up/down sampling between YCbCr 4:4:4 and YCbCr 4:2:2 8. Dither for conversion from 12-bit/10-bit to component to 10-bit/8-bit 9. Support Gammat Metadata packet 10. Digital audio output interface supporting: o Up to four I2S interface supporting 8-channel audio, with sample rates of 32~192 kHz and sample sizes of 16~24 bits o S/PDIF interface supporting PCM, Dolby Digital, DTS digital audio at up to 192kHz frame rate o Optional support for 8-channel DSD audio up to 8 channels at 88.2kHz sample rate o Support for high-bit-rate (HBR) audio such as DTS-HD and Dolby TrueHD through the four I2S interface or the S/PDIF interface, with frame rates as high as 768kHz o Automatic audio error detection for programmable soft mute, preventing annoying harsh output sound due to audio error or hot-unplug 11. Auto-calibrated input termination impedance 6 provides process-, voltage- and temperature-invariant matching to the input transmission lines. 12. Integrated pre-programmed HDCP keys 13. Intelligent, programmable power management Table 2-2 lists the supported output video formats: Table 2-2 Output video formats supported by the HDMI board Output Pixel Clock Frequency(MHz) Color Video Bus Hsync/ space Format Width Vsync RGB 4:4:4 24 30/36 12/15/18 24 4:4:4 30/36 12/15/18 YCbCr 16/20/24 4:2:2 12/15/18 Separate Separate Separate 480i 480p XGA 720p 1080i SXGA 1080p UXGA 13.5 27 65 74.25 74.25 108 148.5 162 13.5 27 65 74.25 74.25 108 148.5 13.5 27 65 74.25 74.25 13.5 27 65 74.25 74.25 108 148.5 108 148.5 13.5 27 65 74.25 74.25 Separate 13.5 27 65 74.25 74.25 Separate 13.5 27 74.25 74.25 148.5 Embedded 13.5 27 74.25 74.25 148.5 Separate 27 54 148.5 148.5 Embedded 27 54 148.5 148.5 162 2.2 Layout and Components The photo of the HDMI board is shown in Figure 2-1 and Figure 2-2. It indicates the location of the connectors and key components. Figure 2-1 HDMI transmitter and receiver on the front of the HDMI board 7 Figure 2-2 On the back of the HDMI board with HSTC connector and HDMI ports  The THDB-HDMI board includes the following key components:           Receiver (U3) Receiver port 1/2 (J2/J3) Transmitter (U6) Transmitter port (J4) 27MHZ OSC (Y1) HSTC expansion connector (J1) Receiver I2C EEPORM (U4/U5) RX Regulator (REG1) TX Regulator (REG2) Level shifter (U2) 2.3 Block Diagram of HDMI Signal Transmission This section describes the block diagram of HDMI signal transmission. Figure 2-3 shows the block diagram of HDMI signal transmission. Please refer to the schematic included in the CD for more details. The HDMI transmitter is controlled through I2C interface, where the host works as master and the transmitter works as a slave. Because the pin PCADR is pulled low, the transmitter I2C device address is set to 0x98. Through the I2C interface, the host board can access the internal registers of transmitter to control its behavior. 8 Figure 2-3 The block diagram of the HDMI signal transmission The host can use reset pin TX_RST_N to reset the transmitter, and listen to the interrupt pin TX_INT_N to detect change of the transmitter status. When interrupt happens, the host needs to read the internal register to find out which event is triggered and perform proper actions for the interrupt. Here are the steps 1-2-3 to control the transmitter: 1. Reset the transmitter from the TX_RST_N pin 2. Initialize the transmitter through the I2C interface 3. Polling the interrupt pin INT_N continuously.  If a HDMI sink device is detected (HDP flag is on): o Read and parse EDID to determine the capacity of the attached HDMI sink device. o Configure desired output video/audio, including color space and color depth. o Perform HDCP authentication o Output video/audio signals to the Video/Audio bus.   Stop video output if a video sink device is removed (HPD flag is off). Perform proper actions according to various interrupt events. 9 2.4 Block Diagram of HDMI Signal Receiving This section describes the block diagram of HDMI signal receiving. Figure 2-4 shows the block diagram of HDMI signal receiving. Please refer to the schematic included in the CD for more details. The HDMI receiver is controlled through the I2C interface, where the host works as master and the transmitter works as a slave. Because the pin PCADR is pulled low, the transmitter I2C device address is set to 0x90. Through the I2C interface, the host board can access the internal registers of receiver to control its behavior. The receiver can support two receiving ports, but only one port can be activated at the same time. Figure 2-4 The block diagram of HDMI signal receiving The host can use the reset pin RX_RST_N to reset the receiver, and listen to the interrupt pin RX_INT_N to detect change of the receiver status. When interrupt happens, the host needs to read the internal register to find out which event is triggered and perform proper actions for the interrupt. 10 Here are the steps to control the receiver: 1. Reset the receiver from the RX_RST_N pin 2. Read the EEPROM (EDID) to check whether the EEPROM contents need to be updated. When writing data to EEPROM, remember to pull-low the EEPROM write protection pin EDID_WP. Finally, make sure EDID_WP is pulled high and configure the both I2C pins as input pins, so the attached HSTC source device can read the EDID successfully. 3. Initialize the receiver through the I2C interface 4. Pull-Low the RX1_HPD_N and RX2_PHD_N pins to enable HPD pins of receiving ports. 5. Set receiver port 1 as active port. 6. Polling the interrupt pin RX_INT_N. Switch to another receiver port every three seconds and activate it if no HDMI source device found on the current active port.  If a HDMI source device is detected: o Perform HDCP authentication. o Read the input video format, including color space and color depth. o Configure input and output color space.  Perform proper actions according to various interrupt events. 2.5 Generate Pin Assignments This section describes how to automatically generate a top-level project, including HDMI pin assignments. Users can easily create the HDMI board pin assignments by utilizing the DE3_System Builder V 1.3.1 or later. Here are the procedures to generate a top-level project for THDB-HDMI. 1. Launch DE3-System Builder 2. Add a DE3 board. Enable the HSTC-C connector and type desired pin pre-fix name in the dialog of DE3 Configuration. 11 3. Add HDMI Board. 4. Connect DE3 and HDMI Board by drag-and-drop the mouse. 12 5. Click “Generate” to generate the desired top-level and pin assignments for a HDMI project. 2.6 Pin Definition of HSTC Connector This section describes pin definition of the HSTC interface onboard. All the control and data signals of HDMI transmitter and receiver are connected to the HSTC connector, so users can fully control the HDMI daughter board through the HSTC interface. Power is derived from 3.3V and 5V pins of the HSTC connector. Figure 2-4 shows the physical pin location and signal name on the HSTC connector. 13 14 15 Figure 2-5 HSTC Connector of HDMI board 16 The table below lists the HSMC signal direction and description. Note. The power pins are not shown in the table. Table 2-3 The HSTC pin definition of the THDB-HDMI board Signal Name Pin Direction Description RX_I2S[3] Number 3 (FPGA View) input RX_SCK 4 input RX_WS 5 input RX_MCLK RX_RD[0] RX_GD[10] RX_GD[11] RX_GD[9] RX_RD[2] RX_GD[8] RX_RD[1] RX_GD[7] RX_RD[4] RX_HPD[1] 6 9 10 11 12 15 16 17 18 21 22 input input input input input input input input input input output RX_RD[3] RX_CEC[1] 23 24 input inout RX_I2S[1] 27 input RX_RST_N RX_I2S[2] 28 29 input input RX_SCDT 30 input RX_SPDIF 33 input RX_INT_N RX_I2S[0] 34 35 input input RX_RD[11] 36 input 17 I2S serial data output, doubles as DSD Serial Right CH2 data output I2S serial clock output, doubles as DSD clock I2S word select output, doubles as DSD Serial Right CH0 data output Audio master clock Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Enable Hardware Plug Detection for HDMP Port 1, Low Active Digital Video Output Pins. CEC (Consumer Electronics Control) for HDMI Port 1 I2S serial data output, doubles as DSD Serial Right CH1 data output Hardware reset pin. Active LOW I2S serial data output, doubles as DSD Serial Left CH2 data output Indication for active HDMI signal at input port S/PDIF audio output, doubles as DSD Serial Left CH2 data output Interrupt output. Default active-low I2S serial data output, doubles as DSD Serial Left CH0 data output Digital Video Output Pins. RX_MUTE 39 input RX_RD[10] RX_DSD RX_RD[9] RX_RD[8] RX_RD[7] RX_RD[6] RX_RD[5] EDID_WP RX_GD[3] RX_GD[1] RX_GD[5] RX_GD[2] RX_GD[6] RX_GD[0] RX_GD[4] RX_BD[10] RX_PCLK RX_BD[8] RX_BD[11] RX_BD[9] RX_BD[3] RX_BD[2] RX_BD[1] RX_DE RX_BD[0] RX_PCSDA 40 41 42 45 46 48 52 53 54 57 58 59 60 63 64 65 66 69 70 71 72 75 76 77 78 81 input input input input input input input output input input input input input input input input input input input input input input input input input inout RX_HS RX_BD[4] RX_PCSCL 82 83 84 output input inout RX_DDC_SDA[1] RX_EVENODD 87 88 inout input RX_DDC_SCL[1] RX_VS RX_DDC_SDA[0] RX_BD[5] RX_DDC_SCL[0] RX_BD[6] RX_HPD[0] 89 90 93 94 95 96 99 inout output Inout Input Inout input output RX_BD[7] TX_GD[8] RX_CEC[0] 100 101 102 Input output inout Mute output, doubles as DSD Serial Right CH3 data output Digital Video Output Pins. DSD Serial Left CH3 data output Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. EEPROM Write Protection Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Output data clock. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Digital Video Output Pins. Data enable Digital Video Output Pins. Serial Programming Data for chip programming Horizontal sync. signal Digital Video Output Pins. Serial Programming Clock for chip programming DDC I2C Data for HDMI Port 1 Indicates whether the current field is Even or Odd for interlaced format DDC I2C Clock for HDMI Port 1 Vertical sync. signal DDC I2C Data for HDMI Port 0 Digital Video Output Pins. DDC I2C Clock for HDMI Port 0 Digital Video Output Pins. Enable Hardware Plug Detection for HDMP Port 0, Low Active Digital Video Output Pins. Digital video input pins. CEC (Consumer Electronics Control) for 18 TX_GD[9] TX_GD[10] TX_RD[0] TX_GD[11] TX_RD[3] TX_RD[1] TX_RD[6] TX_RD[2] TX_RD[8] TX_RD[4] TX_RD[9] TX_RD[5] TX_RD[7] SDA SCL TX_RD[11] TX_GD[6] TX_RD[10] TX_GD[5] TX_GD[7] TX_GD[4] TX_PCSCL TX_PCSDA TX_RST_N TX_GD[3] TX_INT_N TX_GD[2] TX_DSD_L[3] TX_GD[1] TX_DSD_R[3] TX_GD[0] TX_DSD_L[2] TX_BD[11] TX_DSD_R[2] TX_BD[10] TX_DSD_L[1] TX_BD[9] TX_DSD_R[1] TX_PCLK TX_DSD_L[0] TX_BD[8] TX_DSD_R[0] TX_BD[7] TX_DCLK TX_BD[6] TX_SCK 105 106 107 108 111 112 113 114 117 118 119 120 123 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 HDMI Port 0 Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. I2S serial data for on-board EEPROM I2S serial clock for on-board EEPROM Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. Digital video input pins. I2C Clock for DDC I2C Data for DDC Hardware reset pin. Active LOW Digital video input pins. Interrupt output. Default active-low Digital video input pins. DSD Serial Left CH3 data input Digital video input pins. DSD Serial Right CH3 data input Digital video input pins. DSD Serial Left CH2 data input Digital video input pins. DSD Serial Right CH2 data input Digital video input pins. DSD Serial Left CH1 data input Digital video input pins. DSD Serial Right CH1 data input Input data clock DSD Serial Left CH0 data input Digital video input pins. Digital video input pins. Digital video input pins. DSD Serial audio clock input Digital video input pins. I2S serial clock input output output output output output output output output output output output output output inout output output output output output output output output inout output output input output output output output output output output output output output output output output output output output output output output output 19 TX_BD[5] TX_WS TX_BD[4] TX_MCLK TX_BD[3] TX_I2S[0] TX_BD[2] TX_I2S[1] TX_BD[1] TX_I2S[2] TX_BD[0] TX_I2S[3] TX_DE TX_VS TX_HS TX_SPDIF TX_CEC 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 output output output output output output output output output output output output output output output output inout Digital video input pins. I2S word select input Digital video input pins. Audio master clock input Digital video input pins. I2S serial data input Digital video input pins. I2S serial data input Digital video input pins. I2S serial data input Digital video input pins. I2S serial data input Data enable Vertical sync. signal Horizontal sync. signal S/PDIF audio input CEC (Consumer Electronics Control) 20 Chapter 3 Demonstration This chapter illustrates the video/audio demonstration for the HDMI board. 3.1 Introduction This section describes the functionality of the demonstration briefly. This demonstration shows how to use DE3 to control the HDMI board. The demonstration includes two parts:  Transmission-Only: Generate HDMI Video/Audio signal for transmission, including various video formats and color space. There are 11 video formats available. The color space includes RGB444, YUV422, and YUV444.  Loopback: Loopback (Internal bypass) the HDMI Video/Audio Signals. The audio and video output pins of the receiver are directly connected to the input audio and video pins of the transmitter. 3.2 System Requirements The following items are required for transmission-only and loopback demonstrations.  Transmission-Only    THDB-HDMI x 1 DE3 Board x 1 LCD monitor with at least one HDMI input x 1 21  HDMI Cable x 1  Loopback      THDB-HDMI x 1 DE3 Board x 1 LCD monitor with at least one HDMI input x 1 HDMI Source Device x 1 HDMI Cable x 2 3.3 Setup the Demonstration Figure 3-1 and Figure 3-2 show how to setup hardware for transmission and loop-back demonstrations, respectively.  Transmission Only HDMI Cable Figure 3-1 HDMI Transmission-Only Demonstration Setup  Loopback 22 Video in HDMI Cable Figure 3-2 HDMI Loopback Demonstration Setup 3.4 Operation This section describes the procedures of running the demonstration.  FPGA Configuration Please follow the steps below to configure the FPGA.  Make sure hardware setup is completed.  Connect PC and DE3 with a USB cable.  Power on DE3.  Make sure Quartus II is installed on your PC.  Execute the batch file hdmi_demo.bat under the folder “examples\DE3_xxx_TX_RX\demo batch”.  HDMI Transmission-Only After FPGA is configured, please follow the steps below to run the HDMI transmission-only demonstration.  Connect the HDMI LCD monitor and the HDMI transmitting port with a HDMI cable.  Power on the LCD monitor and make sure the LCD monitor is set to the mode where HDMI input is the source. Please refer to the user manual of your HDMI Display for more details. 23  When LCD monitor is detected, the LED2 of DE3 will be turned on.  After approximately 10 seconds, a test pattern will be displayed on the LCD monitor. The first displayed pattern is 480p (720x480p60) pattern.  Press “BUTTON0” to change test patterns. Please refer to Table 4-2 for built-in test patterns. There are eleven built-in test patterns available in this demonstration. You will not be able to see all the test patterns if your LCD monitor doesn’t support such resolution.  Press “BUTTON1” to change the color space of pattern source. The color space includes RGB444, YUV422, and YUV444. Figure 3-3 and Figure 3-4 show the test pattern of FULL HD (1920x1080p60) in RGB and YUV color space, respectively. It will take approximately 10 seconds to display a new pattern on the LCD when users change test pattern or color space. Figure 3-3 FULL HD in RGB444 Color Space Figure 3-4 FULL HD in YUV Color Space Figure 3-5 shows the NIOS program trace log when a HDMI LCD monitor is detected. It indicates the LCD monitor in use supports color space YUV444 and YUV422, but not RGB444. Various video formats supported are listed according to Video Identify Code (VIC). The format of input and 24 output color of the transmitter is RGB444 and RGB444, respectively. It implies there is no change of color format in between. Figure 3-5 NIOS program trace log of transmitting-only demonstration  HDMI Internal Loopback After FPGA is configured, please follow the steps below to run the HDMI loopback demonstration.  Connect the HDMI LCD and the HDMI TX port with a HDMI Cable.  Power on the LCD monitor and make sure the LCD monitor is set to the mode where HDMI input is the source.  Connect the HDMI source device and HDMI RX port with a HDMI Cable.  Power on the HDMI source device and make sure its HDMI port is selected as the output.  Users will be able to see the video displayed on the LCD monitor and hear the sound, if there is a speaker built-in.  Users can change the RX port connected to the HDMI source device. The demonstration can automatically detect the RX port and activate it. 25 Figure 3-6 shows the NIOS program trace log when a HDMI LCD source device is detected. It indicates the input video resolution is 1280 x 720 (VIC=4) with color space RGB444 and 36-bits color depth. Both input color and output color of the receiver and transmitter are configured as RGB444. In another words, the color format doesn’t change from the source to the LCD monitor during the loopback process. The output color depth of the transmitter is configured as 24-bits. Figure 3-6 NIOS program trace log of loopback demonstration 26 Chapter 4 Case Study This chapter describes the design concepts for the HDMI demonstration in the previous chapter. 4.1 Over view This section describes the overview of the reference design. This reference design shows how to use DE3 to control HDMI board. Please refer to the pervious chapter for the demonstration of this reference design. The source code of the reference design can be found in the THDB-HDMI CD under the directory of Examples folder. The demonstration includes the following two major functions:  Transmission only: Generate HDMI Video/Audio signals for transmission, including various video formats and color space. There are 11 video formats available. The color space includes RGB444, YUV422, and YUV444.  Loopback: Loopback (internal bypass) the HDMI Video/Audio Signals. The audio and video output pins of the receiver are directly connected to the input audio and video pins of the transmitter. 4.2 System Function Block This section will describe the system behavior in function blocks. Figure 4-1 shows the system function block diagram of this demonstration. In the design, SOPC is included because NIOS II processor is used to control both transmitter and receiver through I2C interface. 27 The NIOS program is designed to run on the on-chip memory. A customized I2S controller is designed to generate I2S 48K stereo audio for the HDMI transmitting-only mode. The audio data is stored in the on-chip memory and sent to the HDMI transmitter by NIOS II processor. The video pattern generator is designed to generate test patterns for HDMI transmitter-only mode. It provides eleven video formats in three color spaces. The source selector circuit is designed to select the desired video source between the video pattern generator and the video from the receiver. Four LEDs and two BUTTONs on DE3 are used for human interface. BUTTONs are designed to change the test pattern and associated color space for transmission. LEDs are designed to indicate the HDMI status, which is illustrated in Table 4-1. BUTTONs are designed to change the video format and color space of the build-in video pattern generator, which is illustrated in Table 4-2. Figure 4-1 System Function Block Diagram 28 Table 4-1 LED Indications LED Description System is running. HDMI sink device is detected and synchronized. HDMI source device is detected and synchronized. Table 4-2 Button Operation Definition BUTTON Description Press to change active video format of the built-in video pattern generator. Press to change active video color space of the built-in video pattern generator.  Transmitter Controlled by NIOS II Processor The transmitter is controlled by NIOS program through I2C interface. Based on I2C protocol, the NIOS program can read/write the internal registers of the transmitter, and control the behavior of the transmitter. The NIOS program controls the transmitter to perform the following procedures step by step: o Initialize the HDMI chip. o Detect if a HDMI sink device is attached or detached, e.g. LCD Display. o Read and parse the EDID content to find the capability of the HDMI sink device. The capability includes supported color space, video format (VIC code), and color depth etc. o Perform HDCP authentication. o Configure the color space of input and output. The transmitter offers color space transformation and outputs RGB444, YUV422, or YUV444 o Configure the color depth of output video. o Send VIC to the video sink device. o Configure the audio interface and format of output video. 29  Receiver Controlled by NIOS II Processor The receiver is controlled by NIOS program through I2C interface. Based on I2C protocol, the NIOS program can read/ write the internal registers of the receiver, and control the behavior of the receiver. The revision number of receiver is either A1 or A2, which can be determined by querying the register 4 of receiver. The major differences between both revisions are: 1. Receiver initialization process 2. Video synchronization process. Please search the global variable “Is_A2” in it6605.c for detail information. The NIOS program controls the receiver to perform the following procedures step by step: o o o o Initialize the HDMI receiver chip. Detect if a HDMI source device is attached or detached. Select one of the receiving ports and activate it. Read and parse the EDID content to find the capability of the HDMI source device. The capability includes supported color space, video format (VIC code), and color depth etc. o Perform HDCP authentication. o Report the input video (VIC) and audio format of the attached HDMI source device. o Configure the color space of input and output. The receiver can provide color space transformation.  Video Pattern Generator The video pattern generator is designed to generate test pattern for HDMI transmitting-only mode. The supported video formats are listed in Table 4-2. Video Format 720x480p60 1024x76pP60 1280x720p50 1280x720p60 1280x1024 1920x1080i60 1920x1080i50 1920x1080p60 1920x1080p50 VIC 3 19 4 5 20 16 31 30 PCLK (MHZ) 27 65 74.25 74.25 108 74.25 74.25 148.5 148.5 1600x1200p5 1920x1080i120 46 162 148.5 It also supports three color spaces, which are RGB444, YUV422, and YUV444. The required PCLK is generated from Megafunction ALTPLL and ALTPLL_RECONFIG IP. The required PLL-reconfigure data is stored in on-chip ROMs.  Video Source Selector The source selector is implemented using Megafunction LPM_MUX. 4.3 NIOS Program This section describes the design flow and how Nios II processor controls transmitter and receiver. Figure 4-2 shows the software stack of the NIOS program. The I2C block implements the I2C read/write functions based on GPIO system call. The HDMI transmitter block and receiver block are referred as the HDMI driver. The HDMI transmitter chip and receiver chip are managed and controlled through the I2C protocol. The I2S driver block is in charge of sending audio data to the transmitter. Figure 4-2 Software Stack Figure 4-3 shows the file list of the NIOS program. The control center is located in main.c. The 31 beep.c includes audio raw data for generating a tone sound. The folder named terasic_lib includes the I2C driver. The folder named HDMI_Lib includes transmitter and receiver drivers. The platform-dependent functions are located in mcu.c under HDMI_Lib. Figure 4-3 NIOS Program File List 32  System Configuration To use the HDMI library in NIOS II, the const _MCU_ should be defined in the configuration settings, as shown in Figure 4-4. Two on-chip memories are created to store the NIOS program and data separately. The size of each on-chip memory is 128 K bytes. One on-chip memory is used to store program and the other one is used to store data. The option “Small C Library” must be enabled to reduce the size of the program. The associated configuration is shown in Figure 4-5 Figure 4-4 Define _MCU_ constant 33 Figure 4-5 Configuration of System Library  Audio Test If users would like to test audio during HDMI transmitting-only mode, please remove the constant definition TX_VPG_COLOR_CTRL_DISABLED from main.c. Users will hear a tone sound from the built-in speaker of HDMI LCD monitor when pressing BUTTON1 of DE3 board. 34 Chapter 5 Appendix 5.1 Revision Histor y Revision Date Change Log 1.0 DEC 02 2008 Initial Version 1.1 APR 06 2009 Support Receiver Revision A2 1.2 JAN 04 2010 Figure 2-1 Corrected 1.3 MAR 09 2011 Support HDMI 1.4 1.4 AUG 01 2017 Contact Information 5.2 Always Visit THDB-HDMI Webpage for Update We will be continuing providing interesting examples and labs on our THDB-HDMI web page. Please visit www.altera.com or hdmi.terasic.com for more information. 35
P0087 价格&库存
很抱歉,暂时无法提供与“P0087”相匹配的价格&库存,您可以联系我们找货
P0087
  • 1+2639.079961+341.86827
库存:1
