P0083
P0083
    TERASIC(友晶科技)
    HDMI RECEIVER DAUGHTER CARD
P0083 数据手册
HDMI_RX_HSMC Terasic HDMI Video Receiver Daughter Board User Manual 1 CONTENTS Chapter 1 Introduction .......................................................................................................................... 2 1.1 About the KIT ....................................................................................................................................................... 2 1.2 Assemble the HDMI_RX_HSMC Board .............................................................................................................. 3 1.3 Getting Help .......................................................................................................................................................... 4 Chapter 2 Features .............................................................................................................................. 6 2.1 Features ......................................................................................................................................................... 6 2.2 Layout and Components ....................................................................................................................................... 8 2.3 Block Diagram of HDMI Signal Receiving .......................................................................................................... 9 2.4 Generate Pin Assignments .................................................................................................................................. 11 2.5 Pin Definition of HSMC Connector .................................................................................................................... 12 Chapter 3 Demonstration ................................................................................................................... 18 3.1 Introduction......................................................................................................................................................... 18 3.2 System Requirements.......................................................................................................................................... 18 3.3 Setup the Demonstration ..................................................................................................................................... 19 3.4 Operation Chapter 4 ........................................................................................................................................................ 19 Case Study ........................................................................................................................ 22 4.1 Overview ......................................................................................................................................................... 22 4.2 System Function Block ....................................................................................................................................... 22 4.3 Nios Program ...................................................................................................................................................... 25 Chapter 5 Appendix............................................................................................................................ 29 5.1 Revision History ................................................................................................................................................. 29 5.2 Always Visit HDMI_RX_HSMC board Webpage for Update ............................................................................ 29 1 Chapter 1 Introduction HDMI_RX_HSMC is a HDMI receiver daughter board with HSMC (High Speed Mezzanine Connector) interface. Host boards, supporting HSMC-compliant connectors, can control the HDMI daughter board through the HSMC interface. This HDMI_RX_HSMC kit contains complete reference design with source code written in Verilog and C, for HDMI signal receiving. Based on reference design, users can easily and quickly develop their applications. 1.1 About the KIT This section describes the package content. The HDMI_RX_HSMC package, as shown in Figure 1-1, contains:  HDMI_RX_HSMC board x 1  System CD-ROM x 1 The CD contains technical documents of the HDMI receiver, and one reference design for HDMI receiving with source code. 2 Figure 1-1 HDMI_RX_HSMC Package 1.2 Assemble the HDMI_RX_HSMC Board This section describes how to connect the HDMI_RX_HSMC daughter board to a main board, and uses DE4 as an example. The HDMI_RX_HSMC board connects to main boards through the HSMC interface. For DE4, the HDMI_RX_HSMC daughter board can be connected to any one of the two HSMC connectors on DE4. Figure 1-2 shows a HDMI_RX_HSMC daughter board connected to the HSMC connector of DE4. Due to high speed data rate in between, users are strongly recommended to screw the two boards together. 3 Figure 1-2 Connect HDMI_RX_HSMC daughter board to DE4 board Note. We need to use the THCB-HMF2 card in between to make the HDMI_RX_HSMC daughter board connected to the HSMC connector of DE4. The photo of the THCB-HMF2 card is shown in Figure 1-3. Figure 1-3 THCB-HMF2 card 1.3 Getting Help Here are some places to get help if you encounter any problem: 4  Email to support@terasic.com  Taiwan : +886-3-550-8800  China : +0086-13971483508  Korea : +82-2-512-7661  English Support Line: +1-408-512-12336 5 Chapter 2 Features This chapter will illustrate technical details of HDMI_RX_HSMC board. 2.1 Features This section describes the major features of the HDMI_RX_HSMC board. Board Features:  One HSMC interface for connection purpose  One HDMI receiver with dual receiving ports  Two 2K EEPROM for storing EDID of two receiver ports separately  Powered by 3.3V power pins of HSMC connector HDMI Receiver Features: 1. Dual-Port HDMI 1.4 receiver, Pin compliant with CAT6023 2. Compliant with HDMI 1.3, HDMI 1.4a 3D, HDCP 1.4 and DVI 1.0 specifications 3. Supporting link speeds up to 2.25 Gbps (link clock rate of 225MHZ) 4. Supporting diverse 3D formats which are compliant with HDMI 1.4a 3D specification.  Supporting 3D video up to 1080P@23.98/24/30Hz, 1080i@50/59.94/60/Hz, 720P@50/59.94/60Hz  5. Supporting formats: framing packing, side-by-side ( half ), top-and-bottom. Various video input interface supporting digital video standards such as:  24/30/36-bit RGB/YCbCr 4:4:4 6  16/20/24-bit YCbCr 4:2:2  8/10/12-bit YCbCr 4:2:2 (ITU BT-656)  12/15/18-bit double data rate interface (data bus width halved, clocked with both rising and falling edges) for RGB/YCbCr 4:4:4  24/30/36-bit double data rate interface (full bus width, pixel clock rate halved, clocked with both rising and falling edges)  Input channel swap  MSB/LSB swap 6. Bi-direction Color Space Conversion (CSC) between RGB and YCbCr color space with programmable coefficients 7. Up/down sampling between YCbCr 4:4:4 and YCbCr 4:2:2 8. Dither for conversion from 12-bit/10-bit to component to 10-bit/8-bit 9. Support Gammat Metadata packet 10. Digital audio output interface supporting:  Up to four I2S interface supporting 8-channel audio, with sample rates of 32~192 kHz and sample accuracy of 16~24 bits  S/PDIF interface supporting PCM, Dolby Digital, DTS digital audio at up to 192kHz frame rate  Optional support for 8-channel DSD audio up to 8 channels at 88.2kHz sample rate  Support for high-bit-rate (HBR) audio such as DTS-HD and Dolby TrueHD through the four I2S interface or the S/PDIF interface, with frame rates as high as 768kHz  Automatic audio error detection for programmable soft mute, preventing annoying harsh output sound due to audio error or hot-unplug 11. Auto-calibrated input termination impedance provides temperature-invariant matching to the input transmission lines 12. Integrated pre-programmed HDCP keys 13. Intelligent, programmable power management 7 process-, voltage- and 2.2 Layout and Components The photos of the HDMI_RX_HSMC board are shown in Figure 2-1 and Figure 2-2. They indicate the location of the connectors and key components. Figure 2-1 HDMI receiver on the front of the HDMI_RX_HSMC board 8 Figure 2-2 On the back of the HDMI_RX_HSMC board with HSMC connector The HDMI_RX_HSMC board includes the following key components:  Receiver (U3)  Receiver port 0/1 (J1/J2)  27MHZ OSC (Y1)  HSMC expansion connector (J3)  Receiver I2C EEPORM (U2/U4)  RX Regulator (REG1/U6)  Level shifter (U1) 2.3 Block Diagram of HDMI Signal Receiving This section describes the block diagram of HDMI signal receiving. Figure 2-3 shows the block diagram of HDMI signal receiving. Please refer to the schematic included in the CD for more details. The HDMI receiver is controlled through the I2C interface, where the host works as master and the transmitter works as a slave. Because the pin PCADR is pulled low, the transmitter I2C device address is set to 0x90. Through the I2C interface, the host board can access the internal registers of receiver to control its behavior. The receiver can support two receiving ports, but only one port can be activated at the same time. 9 Figure 2-3 Block diagram of HDMI signal receiving The host can use the reset pin RX_RST_N to reset the receiver, and listen to the interrupt pin RX_INT_N to detect change of the receiver status. When interrupt happens, the host needs to read the internal register to find out which event is triggered and perform proper actions for the interrupt. Here are the steps to control the receiver: 1. Reset the receiver from the RX_RST_N pin 2. Read the EEPROM (EDID) to check whether the EEPROM contents need to be updated. When writing data to EEPROM, remember to pull-low the EEPROM write protection pin EDID_WP(please refer to the part schematic of the EEPROM circuit). Finally, make sure EDID_WP is pulled high and configure the both I2C pins as input pins, so the attached HSMC source device can read the EDID successfully 3. Initialize the receiver through the I2C interface 4. Pull-Low the RX1_HPD_N and RX2_PHD_N pins to enable HPD pins of receiving ports 5. Set receiver port 1 as active port 6. Polling the interrupt pin RX_INT_N. Switch to another receiver port every three seconds and 10 activate it if no HDMI source device found on the current active port  If a HDMI source device is detected:  Perform HDCP authentication  Read the input video format, including color space and color depth  Configure input and output color space 2.4 Generate Pin Assignments This section describes how to automatically generate a top-level project, including HDMI pin assignments. Users can easily create the HDMI_RX_HSMC board pin assignments by utilizing the Terasic System Builder (Please visit http://www.terasic.com.tw/en/ to download the latest version of System Builder). Here are the procedures to generate a top-level project for HDMI_RX_HSMC.  Launch Terasic System Builder(from the following path on the HDMI_RX system CD:HDMI_RX_Tool\DE4_SystemBuilder.exe)  Select CLOCK,LED x 8,Button x 4  Select HDMI TX and HDMI RX on the HSMC Expansion options, which is shown in Figure 2-4  Input desired pin Prefix Name in the dialog of DE4 Configuration 11 Figure 2-4 Select the DE4 Board Click “Generate” to generate the desired top-level and pin assignments for a HDMI project. 2.5 Pin Definition of HSMC Connector This section describes pin definition of the HSMC interface onboard. All the control and data signals of HDMI receiver are connected to the HSMC connector, so users can fully control the HDMI_RX_HSMC daughter board through the HSMC interface. Power is derived from 3.3V and 12V pins of the HSMC connector. Figure 2-5 shows the physical pin location and signal name on the HSMC connector. 12 13 14 Figure 2-5 HSMC Connector of HDMI_RX_HSMC board Table 2-1 below lists the HSMC signal direction and description. Note. The power pins are not shown in the table. 15 Table 2-1 The HSMC pin definition of the HDMI_RX_HSMC board Signal Name Pin NO. Direction Description (FPGA HSMC_SDA HSMC_SCL RX_RST_n EDID_WP_n RX_SCDT RX1_CEC 33 34 55 56 59 60 View) inout output input output input inout RX_INT_n RX1_HPD_n 61 62 input output RX_RD11 RX_MUTE 65 66 Input input RX_RD10 RX_DSD RX_RD9 RX_SPDIF 67 68 71 72 Input input Input input RX_RD8 RX_I2S0 RX_RD7 RX_WS 73 74 77 78 Input input Input input RX_RD6 RX_I2S3 RX_RD5 RX_I2S2 RX_RD4 RX_I2S1 RX_RD3 RX0_HPD_n 79 80 83 84 85 86 89 90 Input input Input input Input input Input output RX_RD2 RX0_CEC 91 92 Input inout RX_MCLK RX_SCK RX_RD1 RX_PCSCL RX_RD0 RX_PCSDA RX_GD11 RX_EVENODD 96 98 101 102 103 104 107 108 input input Input inout Input inout Input input I2C serial data for on-board EEPROM I2C serial clock for onboard EEPROM Hardware reset pin. Active LOW EEPROM Write Protection(active high) Indication for active HDMI signal at input port CEC (Consumer Electronics Control) for HDMI Port 1 Interrupt output. Default active-low Enable Hardware Plug Detection for HDMP Port 1, Low Active Digital Video Input Pins Mute output, doubles as DSD Serial Right CH3 data output Digital Video Input Pins DSD Serial Left CH3 data output Digital Video Input Pins S/PDIF audio output, doubles as DSD Serial Left CH2 data output Digital Video Input Pins I2S serial data output, doubles as DSD Digital Video Input Pins I2S word select output, doubles as DSD Serial Right CH0 data output Digital Video Input Pins I2S serial data output, doubles as DSD Digital Video Input Pins I2S serial data output, doubles as DSD Digital Video Input Pins I2S serial data output, doubles as DSD Digital Video Input Pins Enable Hardware Plug Detection for HDMP Port 0, Low Active Digital Video Input Pins CEC (Consumer Electronics Control) for HDMI Port 0 Audio master clock I2S serial clock output, doubles as DSD clock Digital Video Input Pins Serial Programming Clock for chip programming Digital Video Input Pins Serial Programming Data for chip programming Digital Video Input Pins Indicates whether the current field is Even or Odd 16 RX_GD10 RX_VS RX_GD9 RX_HS RX_GD8 RX_DE RX_GD7 RX_BD0 RX_GD6 RX_BD1 RX_GD5 RX_BD2 RX_GD4 RX_BD3 RX_GD3 RX_BD4 RX_GD2 RX_BD5 RX_GD1 RX_BD6 RX_GD0 RX_BD7 RX0_DDC_SCL RX_BD11 RX0_DDC_SDA RX_BD10 RX1_DDC_SCL RX_BD9 RX1_DDC_SDA RX_BD8 RX_PCLK 109 110 113 114 115 116 119 120 121 122 125 126 127 128 131 132 133 134 137 138 139 140 143 144 145 146 149 150 151 152 156 Input output Input output Input input Input Input Input Input Input Input Input Input Input Input Input Input Input Input Input Input inout Input inout input input input inout input input for interlaced format Digital Video Input Pins Vertical sync. signal Digital Video Input Pins Horizontal sync. signal Digital Video Input Pins Data enable Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins Digital Video Input Pins DDC I2C Clock for HDMI Port 0 Digital Video Input Pins DDC I2C Data for HDMI Port 0 Digital Video Input Pins DDC I2C Clock for HDMI Port 1 Digital Video Input Pins DDC I2C Data for HDMI Port 1 Digital Video Input Pins Output data clock. 17 Chapter 3 Demonstration This chapter illustrates the video/audio demonstration for the HDMI_RX_HSMC board. Users may modify the reference design for various purposes accordingly. 3.1 Introduction This section describes the functionality of the demonstrations briefly. This demonstration shows how to use DE4 to control the HDMI_RX_HSMC board. The demonstration includes:  Loopback HDMI_RX to HDMI_TX: Loopback (internal bypass) the HDMI Video and Audio Signals. The audio and video output pins of the receiver are directly connected to the input audio and video pins of the transmitter. 3.2 System Requirements The following items are required for Loopback HDMI_RX to HDMI_TX demonstration.  Loopback HDMI_RX to HDMI_TX  HDMI_RX_HSMC board x 1  HDMI_TX_ HSMC board x 1  DE4 Board x 1  LCD monitor with at least one HDMI input x 1  HDMI Source Device x 1  HDMI Cable x 2  THCB-HMF2 board x2 18 3.3 Setup the Demonstration Figure 3-1 shows how to setup hardware for Loopback HDMI_RX to HDMI_TX demonstration. Figure 3-1 Loopback HDMI_RX to HDMI_TX Demonstration Setup 3.4 Operation This section describes the procedures of running the demonstrations.  FPGA Configuration Please follow the steps below to configure the FPGA.  Make sure hardware setup is completed  Connect PC with DE4 via a USB cable  Power on DE4  Make sure Quartus II has been installed on your PC  Execute the batch file hdmi_demo.bat under the folder “HDMI_RX_Demonstration\DE4_230_HDMI_TX_RX\demo batch”(for the Loopback demonstration) 19  Internal Loopback HDMI_RX to HDMI_TX Note. Do not attempt to connect/remove the HSMC_HDMI daughter board to/from the main board when the power is on, or the hardware could be damaged. After FPGA is configured, please follow the steps below to run the Loopback HDMI_RX to HDMI_TX demonstration.  Connect the HDMI LCD and the HDMI TX port with a HDMI Cable  Power on the LCD monitor and make sure the LCD monitor is set to the mode where HDMI input is the source  Connect the HDMI source device and HDMI RX port on the HDMI_RX_HSMC board with a HDMI Cable  Power on the HDMI source device and make sure its HDMI port is selected as the output  Users will be able to see the video displayed on the LCD monitor and hear the sound, if there is a speaker built-in  Users can change the RX port connected to the HDMI source device. The demonstration can automatically detect the RX port and activate it Figure 3-2 shows the Nios II program trace log when a HDMI LCD source device is detected. It indicates the input video resolution is 1280 x 720 (VIC=4) with color space RGB444 and 36-bits color depth. Both input color and output color of the receiver and transmitter are configured as RGB444. In another words, the color format doesn’t change from the source to the LCD monitor during the loopback process. The output color depth of the transmitter is configured as 24-bits. 20 Figure 3-2 Nios II program trace log of Loopback HDMI_RX to HDMI_TX demonstration 21 Chapter 4 Case Study This chapter describes the design concepts for the Loopback HDMI_RX to HDMI_TX demonstration in the previous chapter. 4.1 Over view This section describes the overview of the reference design. This reference design shows how to use DE4 to control HDMI_RX_HSMC board. Please refer to the previous chapter for the demonstration of this reference design. The source code of the reference design can be found under the directory of Examples folder in the CD of the HDMI_RX_HSMC board. The demonstration includes the following function:  Loopback HDMI_RX to HDMI_TX: Loopback (internal bypass) the HDMI Video and Audio Signals. The audio and video output pins of the receiver are directly connected to the input audio and video pins of the transmitter. 4.2 System Function Block This section will describe the system behavior in function blocks. Figure 4-1 shows the system function block diagram of this demonstration. In the design, SOPC is included because Nios II processor is used to control receiver through I2C interface. The Nios II program is designed to run on the on-chip memory. The source selector circuit is designed to select the desired video source between the video pattern generator and the video from the receiver. Four LEDs on DE4 are used for human interface. LEDs are designed to indicate the HDMI status, which is illustrated in Table 4-1. BUTTONs are designed to change the video format and color space of the build-in video pattern generator, which is illustrated in Table 4-2 22 Figure 4-1 System Function Block Diagram Table 4-1 LED Indications LED Description System is running. HDMI sink device is detected and synchronized. HDMI source device is detected and synchronized. 23 Table 4-2 Button Operation Definition BUTTON Description Press to change active video format of the built-in video pattern generator. Press to change active video color space of the built-in video pattern generator.  Receiver Controlled by Nios II Processor The receiver is controlled by Nios II program through I2C interface. Based on I2C protocol, the Nios II program can read/write the internal registers of the receiver, and control the behavior of the receiver. The revision number of receiver is either A1 or A2, which can be determined by querying the register 4 of receiver. The major differences between both revisions are: 1. Receiver initialization process 2. Video synchronization process Please search the global variable “Is_A2” in it6605.c for detail information. The Nios II program controls the receiver to perform the following procedures step by step:  Initialize the HDMI receiver chip  Detect if a HDMI source device is attached or detached  Select one of the receiving ports and activate it  Read and parse the EDID content to find the capability of the HDMI source device. The capability includes supported color space, video format (VIC code), and color depth etc  Perform HDCP authentication  Report the input video (VIC) and audio format of the attached HDMI source device  Configure the color space of input and output. The receiver can provide color space transformation  Video Source Selector The source selector is implemented using Megafunction LPM_MUX. 24 4.3 Nios Program This section describes the design flow and how Nios II processor controls receiver. Figure 4-2 shows the software stack of the Nios II program. The I2C block implements the I2C read/write functions based on GPIO system call. The HDMI receiver block is referred as the HDMI driver. The HDMI receiver chip is managed and controlled through the I2C protocol. Figure 4-2 Software Stack Figure 4-3 shows the file list of the Nios II program. The control center is located in main.c. The beep.c includes audio raw data for generating a tone sound. The folder named terasic_lib includes the I2C driver. The folder named HDMI_Lib includes transmitter and receiver drivers. The platform-dependent functions are located in mcu.c under HDMI_Lib. 25 Figure 4-3 Nios II Program File List 26  System Configuration To use the HDMI library in Nios II, the const _MCU_ should be defined in the configuration settings, as shown in Figure 4-4. Two on-chip memories are created to store the Nios II program and data separately. The size of each on-chip memory is 128 K bytes. One on-chip memory is used to store program and the other one is used to store data. The option “Small C Library” must be enabled to reduce the size of the program. The associated configuration is shown in Figure 4-5 Figure 4-4 Define _MCU_ constant 27 Figure 4-5 Configuration of System Library  Audio Test If users would like to test audio during HDMI transmitting-only mode, please remove the constant definition TX_VPG_COLOR_CTRL_DISABLED from main.c. Users will hear a tone sound from the built-in speaker of HDMI LCD monitor when pressing BUTTON1 of DE4 board. 28 Chapter 5 Appendix 5.1 Revision Histor y Revision Date Change Log 1.0 NOV 02 2010 Initial Version 1.1 FEB 11 2011 Change the EDID_WP descriptions 1.2 MAR 9 2011 Update to HDMI 1.4 5.2 Always Visit HDMI_RX_HSMC board Webpage for update We will be continuing providing interesting examples and labs on our HDMI_RX_HSMC board web page. Please visit www.altera.com or hdmi_1.4_rx.terasic.com for more information. 29
P0083 价格&库存
很抱歉,暂时无法提供与“P0083”相匹配的价格&库存,您可以联系我们找货
P0083
    库存:1
