LCD-4.3-WQVGA-20R
LCD-4.3-WQVGA-20R
    BEACONEMBEDDEDWORKS
    AM37x, DM37x Zoom™ WQVGA
LCD-4.3-WQVGA-20R 数据手册
PRODUCT BRIEF: Logic PD :: Texas Instruments www.logicpd.com/ti Zoom DM3730 SOM-LV Development Kit ™ The Zoom DM3730 SOM-LV Development Kit is a fullfeatured, high-performance application development kit for evaluating the functionality of Texas Instruments’ DaVinci™ DM37x and Sitara™ AM37x processors and Logic PD’s System on Module (SOM). ZOOM DM3730 SOM-LV DEVELOPMENT KIT :: HIGHLIGHTS: Wattson is instrumental in helping you minimize power in run, idle, standby, suspend, and system-off states, maximizing battery life product-ready DM3730 SOM-LV 4.3” WQVGA LCD + Ready to run Board Support Packages (BSPs): Android BSP Linux™ BSP Windows® Embedded CE BSP Application development is performed right on the productready DM3730 SOM-LV and software Board Support Packages (BSPs) included in the kit, enabling you to seamlessly transfer application code and hardware into production. The included DM3730 SOM-LV utilizes the superset processor, allowing for easy evaluation of either the DM3730 or AM3703 processor. To assist with software development, Logic PD includes Wattson™, a power measurement and performance monitoring application, standard on all Logic PD Zoom Development Kits. The application delivers real-time graphical feedback and data logging capabilities without the need for external oscilloscopes and meters. Wattson guides you to the lowest power and highest performance software combination for your product. + Includes + Includes + Wattson power measurement application + Compact size DM3730 SOM-LV :: BENEFITS: + Long product lifecycle + Low-power, high-performance + Network ZOOM DM3730 SOM-LV DEVELOPMENT KIT WITH DM3730 SOM-LV & 4.3” WQVGA LCD INCLUDED connectivity (802.11b/g/n and Bluetooth 2.1 + EDR radios) + Compact SOM-LV form factor (31.2 x 76.5 x 7.4 mm) the DM3730 SOM-LV Product Brief for more information + See in the end application. Wattson is independent of the system, allowing power measurement even when the SOM is in deep sleep states like suspend and off. Wattson runs on Windows and Linux PCs, enabling software development for Windows CE- and Linuxbased products. Zoom™ DM3730 SOM-LV Development Kit Ordering Information Product Features Model Number SOM-LV Configuration Suggested Resale SDK-DM3730-10-256512R SOMDM3730-10-2782IFCR $997 DM3730 SOM-LV Included + DaVinci™ DM3730 processor, 1 GHz, 256 MB mDDR, 512 MB NAND flash, 8 MB NOR flash, 10/100 Ethernet, 802.11b/g/n, Bluetooth Included LCD Panel + 4.3” WQVGA LCD panel + 4-wire touchscreen DM3730 / AM3703 SOM-LV Ordering Information Model Number Speed (MHz) mDDR/ NAND Flash (MB) NOR Flash (MB) Wired Ethernet 802.11b/g/n Ethernet Bluetooth Temp. (°C) SOMAM3703-10-2780HFCR 1000 256/512 0 Y N N 0°–70° SOMDM3730-10-2782IFCR 1000 256/512 8 Y Y Y 0°–70° SOMDM3730-10-1782IFXR 800 256/512 8 Y Y Y -20°–70° SOMDM3730-10-1782JFIR 800 256/512 8 Y N Y -40°–85° Display + Integrated LCD, touch, and backlight connector for 4.3” LCD panel + 24-bit HDMI port (video only) Audio + Stereo input and output jacks NOTE: Custom configurations are available by special order. Please contact Logic PD Sales for details. Network Support + One RJ45 Ethernet jack connector with magnetics (application/debug) + Antenna for 802.11b/g/n and Bluetooth 2.1 + EDR wireless radios Optional Zoom Display Kit Ordering Information PC Card Expansion + CompactFlash® Type I card + MMC/SD card Model Number Sharp LCD PN Display Size LCD-4.3-WQVGA-20R LQ043T1DG28 4.3” Display Format Key Features WQVGA 480 x 272 Widescreen, color, transmissive NOTE: The DM3730 SOM-LV Development Kit comes with a 4.3” WQVGA LCD. The optional Zoom Display Kit listed in the table above is available for purchase separately. Please see Logic PD’s website for more details: www.logicpd.com/dm3730-am3703-som-lv USB + Three USB 2.0 high-speed host + One USB 2.0 high-speed On-the-Go device Serial I/O + 115.2kbps RS-232 debug serial port Expansion Boards and Debug + High-density breakout board + Connectors for JTAG and ETM interfaces Software + LogicLoader™ (bootloader/monitor) + Android, Linux, Windows Embedded CE BSPs + Windows Embedded CE 180-day Evaluation Kit + Wattson™ power measurement application Cables + Serial cable (null-modem) 10-pin to DB9 UART adapter cables + Ethernet crossover cable + USB cables: two A to mini-B & one mini-A to A + 5 volt power supply with universal adapter + Two LOGIC PD WEBSITE :: DESIGN RESOURCES: + Logic PD Products : www.logicpd.com/products + Logic PD Technical Support : www.logicpd.com/support + Contact Logic PD Sales : www.logicpd.com/contact/inquiry 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com © 2013 Logic PD, Inc. All rights reserved. PN: 1018063 Rev C RoHS Compliant
LCD-4.3-WQVGA-20R 价格&库存
很抱歉,暂时无法提供与“LCD-4.3-WQVGA-20R”相匹配的价格&库存,您可以联系我们找货
