Zybo Accessory Kit - Recommended Addition for the Zybo
SKU: 240-067
Product Description
Note:
This kit contains an SDSoC voucher that is only for use with the Zybo. Information on
purchasing a general purpose SDSoC license is available from Xilinx
here: http://www.xilinx.com/products/design-tools/software-zone/sdsoc.html#buy
Includes Xilinx® SDSoC Zynq Development Voucher, USB cable, 5V power supply, 8GB
microSD card.
Designs using embedded linux may consume more power than sourced from USB.
Some items can also be purchased individually.
What's
Included:
USB Micro Cable (for programming and power)
5V Power Supply (for external power)
8GB micoSD Card With Adapter (for loading Bit files directly)
USB A to Micro-B Cable
Standard USB A to micro-B cable, measuring nearly 5ft in length.
5V 2.5A Switching Power Supply
Features:
5V, 2.5A Switching Power Supply
Suitable for use with the Zybo™ FPGA board
Can also be used as an external power supply for the Analog Discovery 2
MicroSD Card with Adapter
This SDH2 V2.0-compliant MicroSD card is perfect for use with our SD/MicroSD equipped
products. For example, our ZYBO board can boot Linux off of one, and our chipKIT WF32 can
store web pages on one. With the included MicroSD-to-SD adapter, you can even use it with our
PmodSD, giving you access to high speed storage from almost any system board with a Pmod
port. Plus, with a certified class 10 rating*, it's fast enough for 1080p video recordings or other
high-bandwidth applications.
When using the adapter, you'll be able to write-protect the card as well. Allow your professor,
fellow students, or your dog take a look at your data without making changes. Hey, an added
layer of defense against Murphy's Law is never a bad idea! To that end, the card & its adapter
come in a clear plastic protective case.
*Supports 10 MB/S non-fragmented sequential write speed and uses a high-speed bus mode.
Features:
8GB MicroSD
Class 10 (10MB/S performance)
SDHC V2.0 Compliant
Formatted w/ FAT32 file system
http://store.digilentinc.com/zybo‐accessory‐kit‐recommended‐addition‐for‐the‐zybo/ 1/25/2017
很抱歉,暂时无法提供与“240-067”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+237.097141+30.42225
