PRT-14059
PRT-14059
    SPARKFUNELECTRONICS
    SMARTIPITOUCH
PRT-14059 数据手册
SmartiPi Touch PRT-14059 Description: The SmartiPi Touch is a case and stand for the official Raspberry Pi 7" Touchscreen LCD. The  display securely fits into the case with four screws, while a Raspberry Pi 2, 3, B+ or A+ is enclosed in the  compartment on the back with a simple door. A ribbon cable that comes with the display connects into the  Raspberry Pi DSI port. The stand has a pivot that allows you to adjust the angle of the screen for better  viewing, as well as mounting points to affix it to a certain location. The SmartiPi Touch also includes a small case that houses your very own Raspberry Pi Camera Module,  which can be attached via LEGO‐compatible studs on the front or the back of the display case. Additionally,  if you are looking to attach any HATs to the Raspberry Pi, you are in luck! The door to the Raspberry Pi has  been cut to accommodate access to all of its GPIO pins. There is even a dual micro USB splitter cable  included, which allows you to use a micro USB power supply to power the display and the Raspberry Pi at  the same time! Note: The SmartiPi Touch does NOT include an LCD, camera, Raspberry Pi or any other electronics. This product only contains the case and additional assembly parts. Includes: 1x SmartiPi Touch Case 1x Adjustable Stand 1x Raspberry Pi Camera Module Case 1x Micro USB Splitter Cable – 10cm 1x DSI Ribbon Cable 2x Wall Mount Bracket 1x Assembly Screw Bag 1x Allen Wrench SparkFun Electronics ®
PRT-14059 价格&库存
很抱歉,暂时无法提供与“PRT-14059”相匹配的价格&库存,您可以联系我们找货
