751-00010
751-00010
    PARALLAXINC.
    3-WIREEXTENSIONCABLES30PACK
751-00010 数据手册
Assorted 3‐Wire Extension Cable 30‐Pack Product ID: 751‐00010 Overview Unsure just how long you need that 3‐wire extension cable to be? Worry no more with this 30‐pack of cables  of varying length. Also included are an assortment of male/male headers should you need to transform your  female/female wires into male/female or male/male wires. These 22‐gauge, three‐conductor wire cables are covered with a pliable silicone shielding of a much higher  quality than common extension cables. The female sockets are conveniently compatible with all 3‐pin Parallax  sensors, and many Parallax boards also support these cables with 3‐pin ground‐power‐signal ports.  Whether  you are flying an ELEV‐8 quadcopter or mounting your PING))) Ultrasonic Distance Sensor away from your  microcontroller, these cables are the best choice. Features 22 AWG 3‐conductor silicone shielded cable 0.1" spacing single‐row connector for power, ground, and signal Female/Female terminators Uses Molex series 70058 #16‐02‐0087 terminal or equivalent Kit Contents (3)  ‐ 4" wire (#800‐00040) (3)  ‐ 6" wire (#800‐00060) (10) ‐ 8" wire (#800‐00080) (5)  ‐ 12" wire (#800‐00120) (2)  ‐ 16" wire (#800‐00160) (2)  ‐ 20" wire (#800‐00200) (3)  ‐ 24" wire (#800‐00240) (2)  ‐ 36" wire (#800‐00360) (12) ‐ 3‐Pin header (451‐00303) (2)  ‐ 1x40 SIP header (#451‐04001) Copyright© Parallax Inc. 2016
751-00010 价格&库存
很抱歉,暂时无法提供与“751-00010”相匹配的价格&库存,您可以联系我们找货
