PIM011
PIM011
    PIMORONI
    OMNIVESAMOUNTFORRASPBERRYPI
PIM011 数据手册
    OmniVESA PIM011 The perfect mounting solution for your Raspberry Pi! Simply remove the protective backing from the OmniVESA and follow the instructions below to mount your Raspberry Pi either bare or in any of the most popular cases. The nylon screws provided are long enough to work with all of the relevant cases, though if you find they are protruding too far from the case of your choice you can easily trim them down using some cutting pliers. Just remember to use eye protection when cutting! The OmniVESA supports 75mm and 100mm spacing mounts The kit contains  1 x OmniVESA  2 x M4 16mm Nylon Knurled Thumbscrews  2 x 5mm Nylon Spacers  2 x M2.5 x 16 nylon screw  3 x M2.5 nuts Raspberry Pi uncased - use the nylon bolts provided to attach the Pi to the VESA mount using the mounting holes on the Pi itself https://shop.pimoroni.com/products/omnivesa 4/13/2017
PIM011 价格&库存
很抱歉,暂时无法提供与“PIM011”相匹配的价格&库存,您可以联系我们找货
PIM011
    库存:3
