410-163
410-163
    DIGILENT(迪芝伦)
    PMOD8LDLOGICLEVELLEDBOARD
410-163 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com Pmod8LD™ Reference Manual Revised April 15, 2016 This manual applies to the Pmod8LD rev. B Overview The Digilent Pmod8LD has eight high-bright LEDs that are driven by logic-level transistors so that each LED can be individually illuminated from a logic high signal. Features include:     Eight high brightness green LEDs BJTs for low-power logic level control Small PCB size for flexible designs 1.1 in × 0.8 in (2.8 cm × 2.0 cm) 2×6-pin Pmod port with GPIO interface The Pmod8LD. 1 Functional Description The Pmod8LD utilizes individual transistors so that each LED can be turned on or off independently. In order to active an LED, the associated pin on the pin header must receive about 1mA of current. 2 Interfacing with the Pmod The Pmod8LD communicates with the host board via GPIO pins. Correspondingly, to turn a particular LED on, the pin must be driven to a logic high state and driven to a logic low state to turn a LED off. With the parallel arrangement of these LEDs it is possible to turn on (or off) multiple LEDs simultaneously. A pin description and diagram are provided below. DOC#: 502-163 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 2 Pmod8LD™ Reference Manual Header J1 Pin Signal Description 1 LD0 LED 0 2 LD1 LED 1 3 LD2 LED 2 4 LD3 LED 3 5 GND Power Supply Ground 6 VCC Power Supply (3.3/5V) P4 7 LD4 LED 4 GND 8 LD5 LED 5 9 LD6 LED 6 10 LD7 LED 7 11 GND Power Supply Ground 12 VCC Power Supply (3.3/5V) P1 P2 J1 Connector P3 Vcc P7 P8 Table 1. Pinout description table. P9 P10 GND Vcc Figure 1. Pmod8LD module circuit diagram. 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1.1 inches long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 2
410-163
物料型号:Pmod8LD™
器件简介: - Pmod8LD模块包含八个高亮度绿色LED,由逻辑级晶体管驱动,使得每个LED可以通过逻辑高电平信号单独点亮。
引脚分配: - 引脚1:LDO - LED0 - 引脚2:LD1 - LED1 - 引脚3:LD2 - LED2 - 引脚4:LD3 - LED3 - 引脚5:GND - 电源地 - 引脚6:VCC - 电源(3.3/5V) - 引脚7:LD4 - LED4 - 引脚8:LD5 - LED5 - 引脚9:LD6 - LED6 - 引脚10:LD7 - LED7 - 引脚11:GND - 电源地 - 引脚12:VCC - 电源(3.3/5V)
参数特性: - 八个高亮度绿色LED - 使用低功耗逻辑级控制的BJT(双极型晶体管) - 小型PCB尺寸,便于灵活设计,尺寸为1.1英寸×0.8英寸(2.8厘米×2.0厘米) - 2×6引脚Pmod接口,带有GPIO(通用输入输出)接口
功能详解: - Pmod8LD利用单独的晶体管,使得每个LED可以独立开启或关闭。要激活一个LED,相应的引脚必须接收到大约1mA的电流。 - 通过GPIO引脚与主机板通信。要点亮特定的LED,必须将引脚驱动到逻辑高状态,要关闭LED则驱动到逻辑低状态。由于这些LED的并行排列,可以同时点亮(或关闭)多个LED。
应用信息: - 该模块适用于需要通过逻辑信号控制LED的应用。
封装信息: - 引脚间距为100 mil(密耳),PCB的长度在引脚平行的两侧为1.1英寸,在垂直于引脚的两侧为0.8英寸。
410-163 价格&库存
很抱歉,暂时无法提供与“410-163”相匹配的价格&库存,您可以联系我们找货
