2094
2094
    ADAFRUIT
    HEX STANDOFF 4-40 S STEEL 1-1/4"
2094 数据手册
JTAG (2x10 2.54mm) to SWD (2x5 1.27mm) Cable Adapter Board PRODUCT ID: 2094      Description This adapter board is designed for adapting a 'classic' 2x10 (0.1"/2.54mm pitch) JTAG cable to a slimmer 2x5 (0.05"/1.27mm pitch) SWD Cable. It's helpful for using products like the JTAGulator or SEGGER J-Link with tiny boards that use the 10-pin SWD programming connector. This board comes with no cables. It's really just the adapter - but is super helpful when you want to use JTAG debugging on boards that can't support 2x10 cables. We do stock the SWD cable if you need one here!  Technical Details o o o o Dimensions w/components: 34mm x 24mm x 12mm / 1.3" x 0.9" x 0.5"  Weight: 5.7g  EagleCAD PCB Files on GitHub  Fritzing object available in Adafruit Fritzing library        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2094”相匹配的价格&库存,您可以联系我们找货
