CAB-ISP10W200
CAB-ISP10W200
    EQUINOXTECHNOLOGIES
    CABLERIBBON10WAYIDCPRGRM
CAB-ISP10W200 数据手册
10-way In-System Programming (ISP) Cable (0.1" IDC connectors) Equinox Code: CAB-ISP10W200 Digikey Code: 483-1030-ND The CAB-ISP10W200 is a 10-way In-System Programming (ISP) ribbon cable designed to connect from any ISP programmer which features a 10-way IDC connector to a 10-way 0.1" pitch IDC connector on a suitable Target System. The cable features 200mm of flat ribbon cable with a 10-way IDC 0.1" pitch female connector on each end. The IDC connectors are fitted with 'cable grips' and are bump polarised to prevent the connector being plugged in the wrong way around. The CAB-ISP10W200 cable is suitable for use with any Equinox ISP programmer and also with any programmer or 'Starter Kit' which features the 10-way 0.1" pitch IDC connector. eg. Atmel STK500, STK501 etc. Specification: • • • • • Cable length (connector to connector): 200mm Cable type: 10-way flat ribbon cable (red stripe denotes pin 1) Each end of the cable is terminated with a 10-way 0.1" pitch IDC female connector Connectors are fitted with 'cable grips' for added resilience. Connectors are bump-polarised to stop the connector being plugged in the wrong way around This cable is compatible with the following equipment: • • • Any Equinox ISP programmer with a 10-way 0.1" pitch IDC connector eg. Equinox EPSILON5, EPSILON5-MK4, FS2000A, FS2003, FS2009, FS2009USB, PPM3-MK2, PPM4-MK4 Any ISP Starter Kit or Development Board which features a 10-way IDC connector eg. Atmel STK500, STK501, STK502, STK505 etc Any other programmer or Target PCB which features a 0.1" pitch 10-way IDC male connector. ISP Ribbon Cable - family overview 6-way 0.1" pitch ISP ribbon cable (200mm) 20-way 0.1" pitch ISP ribbon cable for ARM microcontrollers (200mm) Digi-key - 483-1029-ND Equinox - CAB-ISP6W200 Digi-key - 483-1032-ND Equinox - CAB-ARM-20W 10-way 0.1" pitch ISP ribbon cable (200mm) 10-way 0.05" pitch ISP ribbon cable for ARM microcontrollers - (150mm) Digi-key - 483-1030-ND Equinox - CAB-ISP10W200 Digi-key - 483-1033-ND Equinox - CAB-ARM-10W-150 16-way 0.1" pitch ISP ribbon cable (200mm) Typical layout of an ISP cable connector (10-way) Digi-key - 483-1031-ND Equinox - CAB-16W/16W-ISP-RIBBON
CAB-ISP10W200 价格&库存
很抱歉,暂时无法提供与“CAB-ISP10W200”相匹配的价格&库存,您可以联系我们找货
